DIM can't install daz studio and PostgreSQL CMS HEEEEELP :C (solved)
gokgokgok222 said:
memcneil70 said:
I am not an expert, but can you uninstall the DIM you have and download a new copy? Is it possible the copy you have got corrupted during the download?
I hope others see this and offer other advice that may be more helpful.
I have downloaded, uninstalled and re-downloaded another copy, and still I always get that same ""dzInstall.ini" error and this one "Error connecting to CMS. Cannot be started by client." I'm starting to lose hope :c, I have tried everything to solve this error, but something I somehow managed to do, was to download some of the content that was included in the download in daz central, but when downloading Daz studio and postgresql the download stays at 89% and the "install" button appears again, the same happens when I try to re-download daz studio and postgresql in DIM.
The dzinstall message is not an error, it is expected behaviour if you have not used the stand-alone installers.
DIM can't install daz studio and PostgreSQL CMS HEEEEELP :C (solved)memcneil70 said:
Ron's Photoshop Brushes do not appear in DIM or DAZ CentralI purchased Ron's Hydro Explosion photoshop brushes. The asset does not appear in DIM or DAZ Central for downloading. The option for manual install does not work in the DAZ page. How do I download it?
DIM not installing anythingThat OP's assumption might be correct. These workarounds are really worth trying: install a DS copy via Central or offline install the DS IM package in DIM.
I think the SSL certificate / activation should come from a VC++ library. Both of DIM and DS packages include VC++ redistribution pack but issues may be still incurred case by case...Updating CMSJenner2005_214fc98680 said:
I deleted all Files and reinstalled the Content. The Database Icon in all Files is Grayed out. If i press the Database Icon Left of the Settings i can first stop the CMS, and if i click again he tries to connect with teh CMS.
I tryed to start DAZStudio in Dimm but it takes forever. I am using Windows 11. Nothing happens if i use the Database Icon. All Files are grayed out at the Database Icon.
Jenner2005 - I've had nothing but issues with attempting to do a fresh install on my machines. The issue is the same for both the PC and Mac OS using W11 Pro and Monterey. I did not bother with using Daz Central, but attempted at least 8 times on each platform to go direct from DIM. DIM installs fine, but Daz Studio refuses to install after the download....and let's not get started on anything related to PostgreSQL/CMS nightmare. I thought at first it may be an Apple thing, but was proven wrong when I switched to W11.
I hope you're able to get this figured out to share some insight with some of the rest of us who have rolled out efforts to complete fresh installs.
HeadShop 2023 Photo-to-3D supports Genesis 9, in Store 4/24 (Commercial)HeadShop has been supporting photo-to-3D conversions for DAZ figures since 2007. We have continuously updated our product to keep up with the development of new DAZ features and figures. This is one of the times when DAZ made major changes in Genesis 9. adding great new capabilities for the new figure. HeadShopPRO stepped up to the challenge to support Genesis 9. The result is HeadShopPRO 2023.
HeadShopPRO 2023 is the latest version of the HeadShop family, replacing HeadShopPRO, with some important additions.
- HeadShopPRO 2023 fully supports the new Genesis 9 figure(s). Genesis 9 is a huge milestone for DAZ, as it dramatically increases the flexibility and realism of the figure. Unfortunately this also means that it is NOT compatible with earlier models (15% smaller, separate “Eyes” and “Mouth”, different head-shape that includes neck, etc.
- HeadShopPRO now also includes some new 3D mesh libraries that enables users to create 3D printable busts, either monochrome or full-color sandstone statues.
In addition
- We further improved our “AutoSculpt” libraries. Most 3D heads lack realism if they ignore the unique “topography” of each head, such as different shapes of noses, chins, creases and so on. We developed over 120 shapes with sliders to help users individually change the shapes one-by-one or mix-and-match, which is a different way than competing approaches by others, because it works like a police “sketch artist”, basing portrait on the description of individual elements (-how was the lip – narrow, fleshy, straight, zig-zag) and similar.
- We also feature retouch tools in the “Color” tab in case there are imperfections in the texture or leftovers from hair or other artifacts.
- HeadShop is NOT installing with DAZ Central or Install Manager but comes with its own installation. Please follow the easy steps in the README before installing all 4 folders.
Please watch our new HeadShopPRO 2023 video here: https://youtu.be/L-wZLeR2l7o
DIM not installing anythingDaz Central and DIM share settings, where applicable, so I am not at all sure why that would happen - assuming it wasn't missing the UAC prompt of similar.
DIM not installing anythingYou're right, I mistyped. I used DAZ Central to install Studio, then DIM started working.
DIM not installing anythingIt's not the downloads, once I got Studio installed through
ConnectCentral everything else downloaded fine. All I can recommend for those still unable to install Studio itself is to use the alternate method of DAZ Central to put Studio in, then use DIM to install your content.Is there a way to uninstall Genesis versions using Daz Studio instead of Daz Central?No, Daz Studio can uninstall only content it itself installed. Why not install Daz Central or Daz Install Manager, tel them where the manifests are if you don't have the paths set anymore, and let them uninstall?
Is there a way to uninstall Genesis versions using Daz Studio instead of Daz Central?I installed Daz Studio with the offline installer, but the library I have was previously downloaded with Daz Central. I only need Genesis 8, 8.1 and 9, the others (1-3) I want to remove them to save space because I don't use them. As I don't have Daz Central anymore, can I use Daz Studio for the uninstallation?Daz to blender bridge not showing up in DazI want to help because i had the same issue
NOT SHOWING in :script -> ok it is ot any more here but ...
NOT SHOWING EITHER in SEND TO
so for those in my case :
when i installed the bridge via the DAZ central or EVEN MANGER it doesn't show up
WHY ?
because it has installed the dll file (dzblenderbridge.dll) in another folder than the daz studio file which is in C:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4
SO here is what i have done : i copy paste the dll file INTO the path above C:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4>>>>> PLUGINS
FIRST STEP RESOLVED : the send to blender appear in daz studio > fILE > send to
i don't know if the entire process will worked but ... if my answer can help resolving at least this first step .... then i am happy .....
DIM not installing anythingIt makes an attempt to download for about a quarter of a second and then fails. I don't think this has anything to do with DAZ's servers, this is behaving as if there's no such user or no internet connection at all.
I installed it fresh in a new folder, no luck. This is...kinda getting to be a gigantic problem for me.
EDIT: I got Studio installed using DAZ
ConnectCentral and now DIM is installing other content normally. Didn't end up in the directory I wanted, but it's not a huge deal since it's all going to be on the same drive now anyway.Migrating DAZ Studio assets from an existing drive to a new external driveAre your manual installed items in the same library as that from Daz Central?
Essentially you can copy (move) your libraries to a new location, and then edit the library path in Daz Studio Edit > Preferences > Content > Content Directory Manager.
Then it should work in Daz Studio.
But to get new installation to get to your new location, you must change it in your installer. I don't know if you in Daz Central can set a custom path. In DIM you can.
And to get Daz Central / DIM to know where the current content is installed, it uses the manifest files. So it would be best to update the paths in all the manifest files to the new path. Notepad++ can help with that.
Daz to Unreal 5.0/5.1Hey so I have the same question, and I'm REALLY a novice.
So do I simply download this github file and put it where the bridge is supposed to go in the Unreal filepath?
Its insane how out of date this bridge stuff is and guide through the normal means within Daz, their website, their videos, their software, its all a mess that doesnt lead to answers.
So what happened with me was that I downloaded the Unreal bridge like it has me do with Daz Central. It opens up Daz 3D, then I try to send the plug in over, and it says the only version is for 5.0. I do it anyways.
My unreal Engine 5.1 sees the plug in, I turn it on, it has me restart Unreal 5.1. Then when I try to make any project file with the plug in file it wont even open the program! So im dead in the water with this useless bridge. Will the download from your link this simply?More Parks, Please...Living in California, we have a lot of beautiful parks like Memcneil70 mentions. Would be cool to see options "more park like" in terms of those, maybe even just parking lot areas or camp ground type or better yet some lakes with more modern fishing amenities.
Open parks, wide lawns, trees, and various walkways with benches. Kind of Central Park or just the classic movie park is what I have been looking for. Daz can only handle so much memory strain, and I get that these would be intensive to both make and use, but some options besides gardens and private pathways would still be great to have.Help for content managementAscania said:
Sure. You just have to remember to switch install directories in DIM and not use DAZ Central.
Awesome!!! Thanks for the quick response!!
Help for content managementSure. You just have to remember to switch install directories in DIM and not use DAZ Central.
Migrating DAZ Studio assets from an existing drive to a new external driveI usually use DAZ Central for items I buy on the DAZ website, but I do manual installs for all other content.
So, Easter Eggs?joanna said:
PerttiA said:
Astrafel said:
I remember a mystery livestream that resulted in the reveal of G9 had a "watch to get a free item" promo to attract interest. I cannot remember if it was hundreds or thousands of people who tuned in though.
That was different as the free item was not added to ones product library, but the (non-Daz) download link was shown in the chat messages.
But then, back in autumn, there was some greek mythology promo that if you bought themed products for a week, you'd get a free exclusive figure, and back then I wasn't participating, but I clearly remember delays in adding that free product and complaints, but in the end, I think, everyone got their product added.
As much as I agree that it doesn't look great on Daz to not keep their announced deadlines, at the same time I'm understanding that they're a small team, and it might take time, especially if there are glitches. I shared my screenshots to show that some progress is being made and how it should look like once the product is there.
By the way, I just checked, and it doesn't seem to show in my DIM (or I'm not looking properly—I haven't used it at all so far), so check your product library too. If it's there, it'll likely show up in DIM eventually (I remember instances where Daz+ freebie wouldn't show up in Daz Central for half a week while it was already in DIM, so I'm guessing the opposite is possible).
Yes, you are correct it was the Knight Series
