• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Install/Folder issues and questions
    I have been using DAZ for a while now and some things are still very confusing.
    1. Installation and the SmartContent Tab
    1a. When I install items using the DAZ Install Manager, those items do not show up in my SmartContent tab. The only workaround that I have found is that I have to right click on the SmartContent tab and select "Content Database Management." From there I have to check Process Metadata Queue & Re-Import Metadata. Once I do that, the items will show in SmartContent (usually). This doesn't seem to be a normal problem. I have asked this question before but I hoped maybe someone might have some new thoughts/advice for me.
    1b. Related to 1a, above, my SmartContent tab is a mess now. Several items are duplicated, several have missing images, and some just seem broken. I have previously done a full system wipe and re-loaded everything and this did not clear up this issue.
    2. Does anyone know if it's possible to get items to move items from "Lost and Found" into the established categories? I have so many items that are entirely only found in my Lost and Found at this point, that it's become unmanageable.
    The Content Library tab is so un-intuitive that I don't use it unless I have to (for 3rd party products I've installed). I know that some users create their own libraries/folder structures, but every tutorial I've watched on that process seems to say that it's not only complex but also very easy to break and make things even worse than they are now.
    Please, if you do have some advice for me, explain it like I'm a 5 year old.
    Thank you in advance for any help you can offer.
    By
    morrisonmp morrisonmp December 2025 in Technical Help (nuts n bolts)
  • Sagan: A DAZ Studio to Blender Alembic Exporter
    Hey thanks a lot for the update! I just got around to testing it. Yes now it I can see the eyebrows in blender. They are a mesh object only? They seem to import as mesh object in blender and checking convert to hair curves doesnt convert it.
    By
    starslinger starslinger December 2025 in Blender Discussion
  • Fixing Autofit Shirt
    outthinkers_77543974b9 said:
    I'm using the weight map tool fill a fill of 0.0% on the pelvis and 100% on the shoulder and forearm but, you can see that the pelvis is still at max influence. I'm not sure how to correct this and videos do not address it.
    I don't think you should remove weight on Pelvis as that'll bring you problems when bending figure's Pelvis bone. Instead, you should remove weight on the bottom of sleeves when selecting Pelvis bone with Node Weight Brush tool.
    Besides, which kimono product are you using ? If it's for G8F, it can well fit on G8.1F without Auto Fit. But some product has wrong Preferred Base set in its metadata, so it brings you Auto Fit dialogue... You can easily fix it via: Edit > Figure > Scene Identification...
    By
    crosswind crosswind December 2025 in Technical Help (nuts n bolts)
  • Can't install this third party character
    I have just tested it in a test library, and she works.
    But the file structure does not follow the general concept overall.
    To find her you must look in your content library, as the product doesn't have metadata. It is also a little weird, that there is only a scene subset with her including her hair.
    Tell more about what you are doing and where you are looking for her.
    By
    felis felis December 2025 in New Users
  • Any way to just load the morphs I need not everything?
    I am aware of the third-party tool that catalogs the morphs used in a scene and allows you to rename the morph extension of all other morphs to prevent DAZ from loading them when it loads a Genesis figure (Turbo Loader). What I am looking for is some native support In Daz for reducing the amount of morphs that are loaded when I select, for instance, G9. I have made a lot of purchases And I have thousands of morphs (from many different stores) I don't understand why there isn't a native way to just load the morphs I need without loading everything in the content directories without some wonky work around like changing file extensions to hide morphs. It makes animation pretty much impossible since even default morphs that are 0 seem to be calculated by DAZ whenever you make a pose adjustment. This is probably what is causing a lot of slow down for folks and it just doesn't seem to be talked about much on this forum. If I were just to completely clean out my contract directory and load the base Genesis 9 Animation is extremely smooth and the whole thing runs like a charm. Why is this seemly basic functionality not supported outside of third-party vendors? Perhaps I'm missing something And you folks can enlighten me. I also don't want to create a morph From the morph loader pro export/import process as that doesn't solve the core problem (of default/zero morphs being calculated anyway during animation) and that would not keep the associated jcms for the combined final product. Heck, even being able to save my character in a way that disassociates it with the genesis framework to by-pass this automatic load of everything in the catalog would be an improvement. Am I missing something here?
    By
    ZombieLove ZombieLove December 2025 in Daz Studio Discussion
  • Hair cap issues when rendering in Blender
    This problem occurs in the Cycles render engine - in Eevee it doesn't exist. There's a couple of hair caps/scalps that I have purchased that are "poking through" and creating dark artifacts in areas where they're supposed to be transparent. This is my current workflow:
    - Import the hair cap via Diffeomorphic on its own rig.
    - Convert to MHX under Rigging
    - Combine the hair cap rig with the base model rig using Merge Rigs under Corrections (uncheck all options).
    - Transfer Shapekeys from base model to hair cap under Morphs (PJCMs, Expressions, etc.)
    - In Modifiers, add Smooth Corrective and Subdivision Surface under the Armature.
    - Leave Materials as-is (Alpha Hashed on both options)
    When the model is static, all looks well. But if I import an Expression, random parts of the hair cap will show up in the render as dark splotches in areas where it's supposed to be transparent. So far I've noticed it on the Faux Hawk Hair cap and the Chuck Hair - Short Hair caps. Is this a Cycles setting issue, a material issue, or something else like unnecessary/duplicate shapekeys?
    By
    jwcjaygaines jwcjaygaines December 2025 in Blender Discussion
  • G9 MHX - weird toe twists with feet in high heels pose
    Oh, I didn't know that the DAZ rig isn't needed to import poses. Great - thanks!
    Yeah, I don't know how Diffeo 4.5 snuck in there again. However, I'm still getting that toe twist with Diffeo 5
    That's fine though. I'll just leave it off.
    Picture on the right is G8 with Tweak Bones checked and "Snap FK All".
    No FK toe twist is happening with G8.
    By
    DrGonzo62 DrGonzo62 December 2025 in Blender Discussion
  • Animated simulations
    Export as OBJ, at base resolution and making you you don't get any extras like Rigid Follow Nodes, then import as a morph.
    By
    Richard Haseltine Richard Haseltine December 2025 in Technical Help (nuts n bolts)
  • Fixing corrective morph issue on (merged) geograft on diffeomorphic [FIXED]
    Importing the daz favorites also tries to retrieve missing morphs for the favorites you have selected in daz studio, this may work fine or not depending on the favorites you have selected and where they are located in the daz content library. In general you select a few favorites for the shapes you need for animation, then import hidden morphs as custom morphs.
    By
    Padone Padone December 2025 in Blender Discussion
    Alright, thanks a lot to both of you :)
    So this seems to be fixed, there isn't any more weird deformation when I bend the figure's thigh. However, all I did was import with DAZ favorites, I didn't do the import custom morphs part... I also don't see the "BC_" morphs in the shape keys list, yet, again, the bends work fine. Is there something I'm missing here?
    Thanks again :)
    By
    Misarmor Misarmor December 2025 in Blender Discussion
    From your picture I can tell you're using a old version of the addon, again please update as there's many recent fixes for mhx and rigify, you need to update both the addon and the mhx runtime. Tried here with tweak bones and works fine.
    p.s. Also it is no more necessary to keep the daz rig as mhx alone works fine to export back to daz, while rigify is more limited to import daz poses but works fine for export. In both cases the figure needs to be unlocked in daz studio to be able to import the IK features.
    https://diffeomorphic.blogspot.com/2025/12/diffeomorphic-add-ons-version-500.html
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Setup/Rigging
    By
  • Geograft expolading morph?
    More messing around
    Test.... too many to count - Gen 9
        * restart daz to start fresh
        * load gen 9. Nothing but gen9. Remove eyes/brows/lashes/mouth/tear
        * Set resolution to base with subd to 0
        * Export
            1% scale
            x = x, y = y, z = z
            ignore invisible nodes (on)
            use bone welds /  remove unused verts / triangulate n-gons (off)
            write uv coordinates (on)
            collapse uv tiles (off)
            write normal/faces/polylines/separate objects (on)
            filter objects (on, selected roots)
            write groups (use nose names, on)
            write surfaces (original, on)
            write material libary (on)
            quote paths containing spaces (on)
        * Import into blender, reset operator presets so the settings are
            scale 1%
            clamb bound (0)
            forward axis (-z)
            up axis (y)
            split by object (on)
            split by group/vertex groups (off)
            validate meshes (on)
        * Blender export:
            selection only (on)
            scale (1%)
            forward axis (-z)
            up axis (y)
            uv coordinates/normals (on)
            colors/curves as nurbs/triangulated mesh (off)
            apply modifiers (on)
            object/material/vertex/smooth groups (all off)
      * Daz morph loader pro import:
            x = x, y = y, z = z
            primary figure (vertex only)
            Create control (no)
           Reverse deformations (yes)
           overwrite existing (make unique)
    Import Success. Zero issues.
    Dictator  no G9. A new scene was made and dictator was loaded directly into it. Instead of removing eyes/eyebrows/etc I removed the texture shells.
    **Exact** same settings as above = Geometry did not match.
    Changing primary (vertex only) to primary figure from graft (facet order) = Mesh explodes
    Turning off "Ignore invisible nodes" + Primary figure (vertex only) = Geometry did not match.
    Turning off "Ignore invisible nodes" + primary figure from graft (facet order) = Mesh explodes
    **Exact** same settings as the base g9 test. Geometry did not match. Changing primary (vertex only) to primary figure from graft (facet order) = Error (Facet count mismatch - base does not equal target (33568 != 8636)), error (matching facets), Warning (geometry did not match).
    Same test as above but both g9 and the graft were exported together. = same warnings.
    By
    Jessie Jessie December 2025 in Technical Help (nuts n bolts)
    That's correct. I got the same result as padone had. As I said above, only Auto Follow stardard pJCMs can be transferred via Diffeo but this AP is a unique product. The vendor made quite a few non-standard corrective morphs (MCMs) as well as Pose Control properties for joint rotation correctives.
    You have to separtely import custom morphs to make the correctives work as expected ~~
    By
    crosswind crosswind December 2025 in Blender Discussion
    Not to sound rude or ungreatful for the help (I'm not) but.... everything you asked me is answered in my post.
    "You worked on the geograft per se without fitting it on G9 ?"
    I've tried:
    • Gen 9 with *geograft* no shells
    • gen 9 with *geograft* and shells
    • *geograft* alone
    • *geograft* with shells
    As stated, I've tried with it fitted and with it *unfitted*, with the shells and without the shells, every combo you can think of I've tried. The numbered list 1-7 is, as evident by the above, one attemt of many. Using an unfitted graft is not the defult, nor all that I have tried.
    The screen shot you linked is identical to what I described save for the size - 1% vs 100% - which I've *always* used 1% instead of a 100 as it saves me the issue of scaling it in blender.
    "don't understand why you adjusted Y/Z and what you adjusted..."
    In your own image you have the "corrected" y/z axis. Anyone who has even looked at the output settings knows, this is not the defult. You have to manually FIX them; i.e swapping the two. This was self explianatory.
    Again, I don't mean to sound rude or bitchy, but my inital post answered all of these. And all that said I'm thinking is something with my blender import/export as texting with the base g9 (load g9. Set base resoultion, 0 subD, export, instantly import as mesh without touching blender causes) no issues. What could be wrong with blender IDK as the import settings I listed is the "operated presets" - same ones I've always used
    By
    Okay, I've been fighting this all day, so its time I got some help. I am trying to make a moraph for a gen 9 geograft, spefically an adult product. Here's what I've been doing/trying/ my settings/ etc.
    1. Load up the graft and remove the shell's so the only thing I'm working with is the graph itself.
    2. Export with these settings - Adjust Y/Z so they match blenders. Scale is set to 1%. Ignore invisible nodes/ use bone weilds/ remove unused verts/ triangualte n-gons/ and collapse uv tiles are all UNCHECKED. The only thing with a checkmark are write uv coordinates/normals/faces/polylines/seperateobjects/groups/surfaces.
    3. Import into blender 4.3.2 with these settings - scale 1, clamp bounding box 0, forward axis -z, up axis y. Split by object/group are UNCHECKED, while vertex groups/validatemeshes are checked.
    4. make my morph using sculpt mode (only using smooth and grab)
    5. Export from blender with these settings - selection only, scale 1%, forward axis -z, up axis y. Colors/ curves as nurbs/ triangualte mesh/ apply modifiers/ object groups/ material gropus/ smooth groups/ pbr extensions are UNCHECKED, while UV coordianates/ normals/ vertex groups are checked.
    6. Go back to daz where the only thing in the scene is the geograft.
    7. Morph loader pro import settings: scale is 100%, and again the y/z axis's have been fixed. Load morphs for: Primary figure from graft (I tried "primary figure (vertex only)" and got geomerty did not match, failed to create morph.) Set Create control property to "yes" and overwrite existing is set to "deltas only". Nothing else is touched.
    Morph imports fine but when trying to use it, I get explosion hell, which means I am clearly doing something wrong.
    Am I exporting it wrong? I've tried:
    • Gen 9 with geograft no shells
    • gen 9 with geograft and shells
    • Geograft alone
    • Geograft with shells
    • shells alone
    • adding the morph to Gen9
    • adding it to the geograft
    • adding it to the shells
    • using Primary figure (vertex only)
    • using primary figure from graft
    • Changing the scale
    • using one, both or all of - create control property, reverse deformations, overwrite existing - in morph loader pro
    • Checking/unchecking different settings in Daz's exporter.
    • checking/unchecking different settings in Blenders import/export
    Some one help me out here, please, because this is driving me nuts. I've made morphs before for gen 8 but clearly with geograft/gen9 there's something I'm missing.
    Edit fixed spelling on "geograft"
    By
  • Create a new morph with different max value from existing one.
    In the simplest case, export at 125%, use a morph loader to import that as a new morph. But of course you will then need to do the same with any corrective morphs, and reconnect them, and with rigging adjustments.
    By
    Only standard morphs are transferred automatically, if the geograft is using custom morphs you have to import them apart. In general we don't want to import all the geograft morphs in blender, but only those we need for animation. One way to be aware what morphs we need is to select "show hidden properties" and "currently used" in the daz studio parameters pane. I gave it a try and seems to work reasonably well here, however, I'd not recommend using this product for blender as it is extremely complex, and the custom rig won't work anyway, the morphs work fine without the rig though.
    steps:
    1. in daz studio select some favorites for the AP morphs you want to import
    2. import with G8 preset + daz favorites
    3. import the custom morphs from the AP folder
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Setup/Morphs
    By
    Thanks to your feedback I was able to track the issue down to my current Blender 4.5 preferences.
    A clean 5.0 install without importing preferences does not have this issue anymore.
    Thanks to you I knew where to look and getting it fixed.
    Not sure how my preferences keep getting messed up. Not too long ago I had to start over because I couldn't get the hand-dialups to import properly.
    Could be another addon causing issues I suppose.
    By
    Tried your test pose on blender 4.5.5 and 5.0, with the latest diffeomorphic version I linked above, it works fine here, no idea what may be wrong on your side. Tried with and without jcms. Again unless there's specific steps to follow to trigger the issue.
    What are your global settings and import options ?
    By
    Thanks for checking, Padone!
    I just tried it on a different machine using only the Heeled shoe pose control and I'm getting the same result after I click "Snap FK All".
    I'm still on 4.5.1, so I'll update one of my systems to Blender 5 and see if that is indeed the issue.
    I've also added the DAZ scene I used for the import in case things go wrong for me in DAZ already.
    As always - thanks for your feedback!
    There are so many moving parts in all of this that an outside perspective is invaluable.
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
