• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Daz Studio Pro BETA - version 4.20.0.17! (*UPDATED*)
    Is there a way to select a single toolbar and export/import just that one, or is the entire set of toolbars always exported/imported?
    By
    barbult barbult February 2022 in Daz Studio Discussion
    MadHammer said:
    @DoctorJellybean
    This may not be true for all beta users, I for one am on 4.20.0.3 and cannot save toolbars or even import toolbars.
    Also re: 4.20.0.3 functionality of the Hexagon Bridge has been removed. When I send back to DAZ from Hexagon I can only name a morph, overwright a morph and put it in a category, all other options are missing. It could be just me, but just because DAZ says it is fixed doesn't seem to mean that it is fixed for everyone.
    With all the complaints here, I am not going to go as far as 'DAZ Devs don't test', but will go so far as saying that it is apparent that their testing (at least their regression testing) needs a process overhaul.
    Please try saving\importing a toolbar again and post the full log.
    By
    DoctorJellybean DoctorJellybean February 2022 in Daz Studio Discussion
    MadHammer said:
    @DoctorJellybean
    Check in the options (press F2 on your keyboard) in the last tab called Bridges if you have the Advanced mode activated.
    By
    Imago Imago February 2022 in Daz Studio Discussion
    @DoctorJellybean
    By
    MadHammer MadHammer February 2022 in Daz Studio Discussion
  • Problems with smart content tab
    My take: learn how this stuff works because you can fully customize and set up everything. You're right: smart contents does make using DS a lot easier, and the best part is that you can easily add 3rd party contents yourself.
    Thing to realize / know: it's all about the metadata. In specific you need to provide a file with a category as well as an item type to make it 'work'. Next there's also the compatibility base which associates items (think about hair or props + their material, stuff like that).
    So, what to do...  find the Blum outfit in your content library (pane). Does it have a type indicator in the upper right corner indicating what it is?  Right click on it, use "categorize" to see where it should be located in the smart contents hierarchy.
    You can also right click on the folder it's in (when using the content library pane of course) and use the option "Edit metadata...", this gives you access to look into and/or change the meta data that's added to certain files.
    By
    ShelLuser ShelLuser February 2022 in New Users
  • [Released] Props & Poses Converter from Genesis 2 to Genesis 3 [Commercial]
    Easily use your Genesis 2 props, accessories, and poses with your Genesis 3 characters! Automatically convert almost your entire library of props, accessories, and poses using the Props & Poses Converter for Genesis 2 Female or the Props & Poses Converter for Genesis 2 Male scripts! The Props & Poses Converter scripts provide batch execution for automatically converting your Genesis 2 Female or Male props, accessories, and poses to Genesis 3 props, accessories, and poses in your library. Easily select the Genesis 2 props and poses in your library, select an output directory, and execute the script. Even better, icons and categories are copied from your Genesis 2 prop or pose to the new Genesis 3 prop or pose.
    Your new Genesis 3 props, accessories, and poses are completely Smart Content aware! They will show up when you select a Genesis 3 Female or Genesis 3 Male. Plus, all of the materials shown in Smart Content for your Genesis 2 prop or accessory will show for your converted Genesis 3 prop or accessory.
    Items without metadata can be converted but will not show up in Smart Content. They may also need to be converted using a Force Convert Item(s) button. Zero Poses are not converted.
    • Convert Genesis 2 props and accessories for use by Genesis 3 characters*
    • Convert Genesis 2 posed props (e.g., hand gripping a sword) to Genesis 3 posed props
    • Convert Genesis 2 poses to Genesis 3 poses
    • Convert Genesis 2 hierarchical poses to Genesis 3 hierarchical poses**
    • Convert swords, bows, glasses, jewelry, etc.
    • Convert accessories: hats, belts, glasses, jewelry, etc.
    • Copy icons from Genesis 2 presets to Genesis 3 presets for a professional look
    • Converted items are Smart Content enabled! All of the materials shown in Smart Content for your Genesis 2 props and accessories will show for your converted Genesis 3 props and accessories
    • Automatically convert almost your entire library of props, accessories, and poses with one operation!
    Note that this product cannot do conversions between genders, i.e., it cannot convert Genesis 2 Female poses and props to Genesis 3 Male poses and props.
    * The Props & Poses Converter scripts do not work with multi-part props (i.e., 2 daggers are loaded from the same preset) or with props/accessories with Genesis 2 bone rigging.
    ** Hierarchical poses require extra steps due to the props needing to be loaded. Some hierarchical poses cannot be saved correctly using a script and require a manual step.
    By
    RiverSoft Art RiverSoft Art February 2022 in Daz PA Commercial Products
    maybe if that is their attitude people should start returning faulty  products because I believe that overrides any 30 day limit in most countries. I know the ACCC in Australia would consider faulty goods worthy of a full refund, I believe Paypal has recourse fot that too because if they refuse to provide a working build for products they sold you after removing functionality they have in effect sold you faulty products.
    I did save a backup and have multiple builds but honestly how many people do that for every software they use, imagine if Adobe removed the ability to import jpg for example because they claimed it was a bug they shouldn't have had  how people would react.
    By
    WendyLuvsCatz WendyLuvsCatz February 2022 in Daz Studio Discussion
  • DAZ to Blender Bridge: How To in Blender 3.0?
    Are you finding the bridge option in D/S? I don't know how much they have changed what, concerning the bridge {'cause I gave up on that}, but all that bridge thing used to do was make a file ready to be brought into Blender. Then one opened Blender and using the add-on one browsed to and loaded in their usual fashion, imported in the object.
    It used to only work for G8 but I think they made it to work on more items now. Anyhow, you know I trust that you can simply export out .obj files from D/S; and then of course, import those into Blender. On the export settings there is reference to Blender.
    For 3D printing, might want to uncheck "groups" so the obj will be one piece.
    By
    Catherine3678ab Catherine3678ab February 2022 in Technical Help (nuts n bolts)
  • issues with fitting clothing to very slender/petite female characters.
    You could export to blender, use shrinkwrap, adjust a bit, then import back to daz studio as a dress morph.
    By
    Padone Padone February 2022 in Daz Studio Discussion
  • Wrong Imported clothes
    Hi, Im new to using Daz3d characters inside of Blender.
    Ive tried using the bridge but its too much trouble and wont work so I decided to export OBJ from Daz3d and import into Blender manually.
    I started off with System 46 for Genesis Female 3 inside Daz3d, please see image 1. I wanted to change the clothes, which I did by adding new material to Geo Shell and changed to a metallic shell, see image 2.
    I then exported the obj with correct settings into blender.
    When I import into Blender the shell is not correct. See image 3. Its the orginal white shell, not the shell I desired, the metallic one.
    Can anyone please help, it would be very much appreciated, thanks. Maybe I;ve got incorrect export/import settings.
    By
    graeme_398f9f74 graeme_398f9f74 February 2022 in Blender Discussion
  • New! Novica & Forum Members Tips & Product Reviews Pt 14
    MelanieL said:
    memcneil70 said:
    I sent in a feedback report to Customer Service with a copy of a PDF I printed before the change and one printed after. And included how I have used the PDF in the past and why this new format negates that. But one thing I found yesterday, is when the images go extremely wide, and you try to print them off, critical details like the SKU don't print off. I think I had five items from the Mega Bundle from yesterday that I had to open back up to hunt down the SKU.
    But what really gets me, the PAs take all their time to produce a product and either they or someone else create images to show their products off and this new format destroys all that work.
    Ah, so I'm not the only one annoyed by the printing thing!
    I've always printed off product pages for everything I've bought as a record of what it was (in case it disappears from the store in the future) and to use on my (offline) rendering PC. Since the black pages were inflicted on me (just a few days ago, later than many forumites) I've been using an Incognito browser to get the old page format, which up to now is working for me, but presumably this won't last.
    I wish there was a store funtion to print a store page that produced a print-friendIy version. I can see one day I'll need to make do with a set of screenshots and glue them together into a PDF using Libreoffice!
    I actually have been thinking that might be what I would have to do also. And when you buy a large bundle or a lot from a great sale, that is a huge chore. I tried going Incognito but have not seen a difference. And just trying to look at today's offerings was such a chore, I gave up after I looked at a deep sale item. It said I owned it, The Stash Bundle! Curious I opened it up, but could not find any indication of what I owned or didn't. No greyed out image or anything. I just closed down the sales page and after skimming the forums, will turn away from Daz's website and watch the news and continue to add/fix metadata on owned products.
    By
    memcneil70 memcneil70 February 2022 in Art Studio
  • how do you add materials to things?
    Does the item come with materials? Is it a daz product, and did you install in a way thata dded it to the Content Management System (through Daz Studio, Install manager, or Daz Central or manually and then import metadata)?
    By
    Richard Haseltine Richard Haseltine February 2022 in Daz Studio Discussion
  • How Do I Find Missing Materials?
    Well, the first question would be, how did you install the products?
    Lot's of things can go wrong when packaging something for distribution.
    So here are a couple basic things.
    If they are there, and this is content you bought from Daz.Then most likely it was installed with both Connect and either Central or DIM.
    That usually makes install stir fry and you'll need to do a little work getting it sorted out.
    I suggest using only DIM and never logging in inside Studio so Connect won't fiddle with the metadata.You only need to login inside Studio if you are using Connect.
    If they aren't there you need to look inside the zip folder the product came in to find out where it was supposed to go.
    Posting a screen shot of the popup, or copy/pasting the error it shows to your forum post would make things easier to diagnose :)
    By
    IceCrMn IceCrMn February 2022 in New Users
    If you can find it in the library, then don't use smart content, I never do. You can load everything from the content library if you need. In my understanding the main reason content doesn't show in smart content is down to the metadata missing or being corrupted
    By
    FSMCDesigns FSMCDesigns February 2022 in New Users
    Seems they are not installed correctly since I never have that happen when I load normal content from the store. That only happens to me when I import OBJs from outside of DS
    By
  • DC / DIM - tweaks to help users to roll back to earlier versions
    IceCrMn said:
    In my non-programer point of view.
    I would think it simpler to add a button on the DIM UI that says "Roll back to Previous Version" (applicable to the general release version only beta class software is a different discussion) and next to that button(or under it) would be text that displayed what version that would be installed.
    Under the hood, that install package and all of it's dependencies(if any) could be moved to a folder in the download directory.
    Seems like it would be easy to do with few if any problems within DIM.
    Does DIM have a plugin framework to allow for a PA to make such things?
    PA's don't do anything in regards to DIM. All we do is package our products and Daz takes over creating the metadata, tags, categorization and building the DIM package.
    By
    frank0314 frank0314 February 2022 in Product Suggestions
  • Website Testing and Updates - Navigation
    Yesterday, it took me hours to figure out what was in the sale and what was not. I had bought the Teen Kola 8.1 Bundle the day before, but because of the design of the page, it took me a bit to see that line that said the items I already owned would be 'discounted'. I tested the items I wanted, then the Mega Bundle and yes, the Mega was cheaper. But I waited to see if a flash sale would pop up during the day with something I wanted. Nope, old hairs. So I finally bought it. And that spent my March budget.
    But as I printed the promo pages as .pdfs I found that the SKUs weren't being printed on all the pages, and what I dispise is the wasted space on what was produced. I use those pages to give me information on usage (remember that many PAs use their images to show how to use their products), what the required products are, if they are a material set or a prop or whatever. With older items it is easy to tell a material product is that because you see its code line, but on a .duf it could be almost anything. Some do have material in the naming structure, but others do not. But I love the pictures for themselves. The PAs put a lot of work into them. I appreciate that. That awful blured mess is dreadful.
    I have sent in a Customer Service report with my feedback days ago, before I knew about the SKUs not always printing.
    I don't want advertising to YouTube unless it is to a tutorial by the PA for usage of the product. I don't like having to open up hidden fields to print them.
    What I don't understand is how a professional company can repeatedly make this kind of mess, when a free website without advertising, for writers to post stories, can manage to set-up a test framework and have a variety of users, admins, writers, readers who all give feedback and help in the design and work to improve the old site that has had to reinvent itself three times due to servers, software, and other issues. By doing that we have a site that is stable, able to be read by people who have vision issues (legally blind without aids) and is accessible worldwide. And still free.
    And I am also avoiding the store as well. The changes that have happened to ruin the shopping experience, the emphasis on poorer quality, weird metadata assignment, items that never show up in Smart Content, are saving me a group of cash.
    My thanks to DAZ.
    But, I guess the latest shiny piece of trash in the Metaverse is worth it? Yes?
    By
    memcneil70 memcneil70 February 2022 in The Commons
  • I must be pretty slow, but...
    jeff_someone said:
    I have no problems using the Daz to Unreal bridge to get a character over to UE.  What I can't seem to figure out is how can I either 1) import a pose, or 2) pose the character myself in UE.  I can 'pose' it in the Skeleton Editor the character but that pose does not get shown in the Viewport in UE.  I assume it to be told to use a specific animation asset or pose asset.  Can anyone point me to how to do this?  I've youtubed and googled tons but they all talk about converting Daz character to UE Mannequin or doing animation, whereas I just want to be able to pose the character and place it posed in the viewport/level scene.
    Thanks - Jeff
    p.s. am I stupid for wanted to UE exclusively for its real-time rendering capability?  I have no desire to make games or such...   I've used Blender EEVEE and while its good, it's nowhere as good as UE rendering capabilities.
    Control Rigs can be used to create poses inside Unreal itself. The Daz plugin does come with a basic Control Rig, which can be used as a starting point.
    I still struggle with Control Rigs, the learning curve is steep.
    In the past, if i needed a quick pose in the viewport.
    1. Create a pose in the Skeleton Editor
    2. Click "Create Asset" at the top of the window. Then Create Asset > Create Animation > Current Pose
    This will create an animation asset that consists of just your pose.
    3. Drag that newly created animation asset into your scene in the editor viewport.
    I would create an animation asset rather than a pose asset, simply for quicker results.
    But long term, learn how to use pose assets and you can build your own pose library in UE5.
    By
    Jo_3875656 Jo_3875656 February 2022 in Unreal Discussion
  • Daz Bridges Update!!!
    butaixianran said:
    And if you export Character with high heel but with Zero Pose. Then, in blender, what gonna happen if you import a pose file with flat feet? Your character's pose will be like no high heel, right?
    It is handled the same as daz studio. Usually you have a "heel pose" for the feet, provided with the outfit, that you can apply or not. Then the heel pose will be overwritten or not depending on the other pose you load. Then you can apply the heel pose again if needed.
    Or in blender you can select all the bones apart the feet then load the pose, so it will not apply to the feet. Same for any other part of the rig. Same for animations.
    By
    Ellessarr said:
    Thanks - Jeff
    you must set on unreal side of the plugin to use the frame 0 as ref pose.
    to do that with the plugin instaled open your unreal project then go for the "edit"---> project settings
    in the left side where it's saying
    all settings
    project
    xxxxx
    xxxxx
    xxxxx
    game
    scrol down until you see plugins
    then click on daz to unreal settings
    then if not marked, mark the option frame zero is reference pose.
    now on daz pose your character in the way you want, then use the plugin, if everything goes well it will be exported on the pose you set.
    Thank you, I will give that a try!
    By
    jeff_someone jeff_someone February 2022 in Unreal Discussion
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
