Request for animation tips and resources
Free video editor/compositor? Blender? I've used that. DaVinci Resolve still has a free version I believe, I use that. On my old laptop I have Quicktime Pro (not free) which allows import of image sequences to create avi's
[Released] Substance Painter Assistant [Commercial]I bought the script and exporting is working well once I wrapped my head around the preparations made to the Object_low.obj. I am having issue with the Import into DS side.
It would be so helpful if a video tutorial for the Import into DAZ Studio were made.
- It needs to show how to set up a naming system for BOTH SP and in the script.
- It needs to show how to deal with using the same channel file in more than one spot in the Iray shader. (Example: Glossiness from SP going into Glossy Layered Weight, Glossy Reflectivity, and Top Coat Weight.)
If you made this video I would be greatly appreciative, because right now I'm still having to manually assign channel images to their spots in the Iray shader.
Retargeting motion to rigify after Diffeo import.Hi all
I did a quick video on a free addon to retarget Mixamo motions to your Genesis 8 characters after conversion to rigify in Blender.
Forced to Re-install Genesis 8 Starter Essentials over and overI just added something to my previous post - take a look at that, maybe.
Make sure the filter box (bottom of the Smart Content pane) is unchecked and type "Essentials" in the search box again. If the G8 Essentials shows in colour then there should be an uninstall option. If it's gray-shades then try right-clicking and picking "view in Content Library" (or something along those lines) - once there, try right-click and "Delete" - this should remove any rogue metadata still sitting in the database.
ETA: Follow Richard's instructions first - they are probably right!
[Released] Turbo Loader for Genesis 8 and 8.1 [Commercial]Rod Wise Driggo said:
Changing from my manual moving of files to turbo loader I do have two questions:
1) How is the ***unknown product*** defined?
I only install via DIM (3rd party stuff with Content Wizard). So all my stuff has metadata. Still what confuses me is that TL even declares some of my G8F base figures as *** unknown product ***. Sometimes I even get two entries like with Angharad 8:
Angharad 8 with 59 morphs
Angharad 8 *** Unknown Product *** with 7 Morphs
How is this possible?It all depends on what the Daz Studio database returns for a file. Turbo Loader asks the DS database what product a morph belongs to and then categorizes on that. If the DS database says it does not have any products for a file, TL categorizes the morph as from an unknown product. My recommendation... LOG IN. That makes a BIG difference as the DS database gets updated. If you never log in, the DS database gets woefully out of date and you will get lots of Unknown Products. (Note the name of the unknown products is going to change this week as the v1.1 update drops into the store and you will need to rescan (check out the v1.1 tutorial video:
2) I want to handle my extensive base figure collection only through TL. So install all the figures (and I own all gen 8 base figures I guess), have the ones disabled I do not use but have the textures available if I want to use them. Now it seems that TL does not alter the files in the projection morphs folder. Doesn't affect this load times? Or are the projection morphs only loaded if I load the particular base figure the projection morphs are made for?
You would have to check the DS log when you load a figure with projection morphs. I don't really have many that use projection morphs. On my system, there are so few that it doesn't seem to affect my load times.
Thx!
[Released] Turbo Loader for Genesis 8 and 8.1 [Commercial]Changing from my manual moving of files to turbo loader I do have two questions:
How is this possible?2) I want to handle my extensive base figure collection only through TL. So install all the figures (and I own all gen 8 base figures I guess), have the ones disabled I do not use but have the textures available if I want to use them. Now it seems that TL does not alter the files in the projection morphs folder. Doesn't affect this load times? Or are the projection morphs only loaded if I load the particular base figure the projection morphs are made for?
Thx!
Using Unity Products in Daz3DJust export such product as FBX or OBJ and import it to Daz Studio.
Probably you need to adjust materials / shaders and maybe scale in Daz Studio.
Does dforce suck?ragamuffin57 said:
marble said:
Cyberdene said:
Never liked Deforce. Its okay for working on getting characters to sit with certain clothing. But Marvelous Designer still makes it easier to drape clothes within seconds. Not 10 min. Deforce is even slower simulating clothes with memorized pose on. It only works slightly faster with it turned off. But the minute you turn on memorized pose, I swear it takes up to 16 minutes or longer just to simulate anything. And my GPU is a 3060
I have Marvelous Designer 8 (pre-subscription version) sitting idle on my Desktop PC and a bunch of paid-for tutorials which are also resting undistrubed. I do know that MD will simulate in a fraction of the time takes dForce but I wonder about the faff of getting the posed character out of DAZ Studio and into MD and then back again. So far I have not bothered with that faff but I have to say that I have a really powerful GPU (RTX 3090) which seems to have made minimal difference to the simulation time of dForce whereas MD8, using only CPU, is orders of magnitude quicker.
I had a chat with an artist on DevArt who is a Poser user who uses MD7 to drape his clothing for every scene (he, like me, creates stories in a series of scenes). He maintains that it is quicker and more accurate to do it in MD. I'm not so sure, given all the back-and-forth, whether it is worth the effort in DAZ Studio. Perhaps someone can suggest an expidited workflow because I'm probably not using the most efficient method in my trial runs.
By the way, a typical drape time for me is about 6 minutes, not 16, but that is still painfully slow.
Marble you have a faster machine with more memory than I. I have a 2070 super I also have a huge library of D force items all basically useless.
The time it takes to simulate and then the inevitable explosions. Has **#@! me off.
20 minutes it has taken with some simulations only to crash and burn in Daz .
Yet I can have a genesis 8 character in MD. Import a pose morph, drape, rearrange a garment and import it back into daz before daz has hardly got off the starting block !!
I really had high hopes for Dforce as poser did a half-decent job of draping what little dynamic cloth there was back in the day.
Marble go for it I have used poser for and age, late 90s and since iray was introduced Daz , I had MD before Deforce and let my MD licence laps thinking that Dforce word be a game-changer for me. But alas no and have bought a new MD subscription :( and slowly learning how to get the best out MD . Plus now you can use Adobe substance painter in MD. Painter was a present for my 65th birthday.
I have been so used to the daz universe and the ease of its use, Then there is the money I have spent I have been reluctant like a druggy to leave daz comfort zone .
So to reiterate Marble dust off your training vids and open up MD try a couple of simple garments and I think you just surprise yourself on the ease of simple garment making.
Thanks for your advice and yes, I do feel bad about having a marvelous tool sitting idle while I suffer the tedious wait for dForce simulations. I also have a large library of dForce clothes and I don't want to start over making my own (most likely inferior) versions. Ideally I could use MD8 to drape my dForce (or conforming) clothes on a posed G8 avatar in MD. I know this is possible because I have tried it but, as I said, there is probably a more effitcient workflow. Most of the tutorials deal with making clothes from scratch rather than importing ready made clothing from DAZ Studio. I still have the option of upgrading to MD 11 with a 60% discount but I don't want to spend another $200 just to have it languishing unused on my PC.
Ahh, yes, my 3090 GPU was also a birthday present (at least I was gifted the difference between the price of a 3070 and a 3090). Thank goodness for family. I'm 70 by the way. As for Substance Painter - nice that you have it but I am reluctant to spend any money with Adobe and I just hate subscriptions.
Rigid Follower Node renders rotated incorrectlyI think what's going on is internally, D|S is making copies of the bits of geometry you see in preview and rendering those (I know it has to do this for subdivision and smoothing anyway) - at some point there's a -90 or +180 or something incorrectly applied, probably because that bit of code was adapted from code from a plugin for an app with a different coordinate orientation. Sort of like the frustrating orientation quirks associated with OBJ import/export.
GOZ from Zbrush to DAZ not workingHey,
I can send character from Daz to Zbrush, then I do really a really simple sculpt and the problem is that I'm not able to send the sculpt back to Daz with GoZ. The only info from Zbrush that I got is "file saved to disk sucessfully".
Daz doesn't seem to receive any info back, no pop-up message about back import.
I tried to reinstall both Zbrush and Daz and filepath from Zbrush to Daz seems correct
I have Zbrush 2022.05 and DAZ Studio 4.2 PRO
I work on a Mac
Could you please help?
How to import a room with multiple propHello David!
I would like to thank you, all has been fixed, however there is a new error that the new update make.
let's say i want import my mesh like this ( with the eyes move location )
the plugin will not import them in the correct location. but will keep the original position of the eye.
this is just an exemple.
( didn't have this error before you update the plugin)
Evermotion Blender scene import into DSwurger said:
I'm kind of getting that impression. The scenes look great in Blender, and I'm guessing the work getting them looking the same in DS would be brutal. I may just go with the DS to Blender route with the figures. At least then there are less material issues to correct.
Be sure to check out diffeomorphic for that. Makes the process a hell of a lot easier than tryin to export as OBJ or FBX then import into blender and relink everything by hand.
Evermotion Blender scene import into DSRL_Media said:
First thing I would do is export from blender as obj, import obj into DS, apply uber shader. Chances are it is going to look bad, or lag the hell out of DS viewport because of heavy poly count. That's usually the two results I get importing scenes like that into DS. DS is really not as good as other 3d programs with displaying geometry that has triangles, n-gons, or heavy polygon counts without lag.
If the geometry looks OK and is not lagging, then you are gonna have to look into adding the material maps back to the right places, which can be tedious. If material zones and maps are named in a way you can understand, it is not difficult though.
One of the reasons I am really trying to get DS people into blender to render instead of the other way is the geometry issue. I can make some really nice hard surface detailed things, it looks amazing in bleder. But when imported into DS there is all kinds of shading artifacts, holes get covered over, all kinds of weirdness.I'm kind of getting that impression. The scenes look great in Blender, and I'm guessing the work getting them looking the same in DS would be brutal. I may just go with the DS to Blender route with the figures. At least then there are less material issues to correct.
Evermotion Blender scene import into DSFirst thing I would do is export from blender as obj, import obj into DS, apply uber shader. Chances are it is going to look bad, or lag the hell out of DS viewport because of heavy poly count. That's usually the two results I get importing scenes like that into DS. DS is really not as good as other 3d programs with displaying geometry that has triangles, n-gons, or heavy polygon counts without lag.
One of the reasons I am really trying to get DS people into blender to render instead of the other way is the geometry issue. I can make some really nice hard surface detailed things, it looks amazing in bleder. But when imported into DS there is all kinds of shading artifacts, holes get covered over, all kinds of weirdness.Evermotion Blender scene import into DSI'm looking for some tips or tutorials on importing a full Blender scene into DS, but all I can find is stuff on exporting from DS to Blender. Evermotion has some interior scenes that I would like to use, but don't want to bother if it will be too much trouble to import and update for Iray.
Thanks
Free Software that Makes Life EasierOK annoying FBX import quirk is you get parametric shaders in layers
otherwise it does load the maps and the lightbulbs have glow!
but the glass has no alpha or transparency
you have to drill through the paremetric shader to find it and drop a glass shader on each because consolidating textures it loses the names of the objects it applies to
likewise the decals need the alpha png map or the opacity map in alpha
applying the shader to any object replaces all the shaders!!!!! so you are stuck with the layered one
really need to add lights to those bulbs
Octane cheats work better but I likely can do some Carrara native cheats that are much faster
interestingly enough Carrara is the only program that correctly imports this so far (that I have tried)
DAZ studio and Poser make a right mess of it and iClone 3DXchange misses all the textures
Twnmotion gets most of it with some bits misrotated not tried Blender and Unreal yet
Video Carrara native render
Adding Dual Quaternion support to UnrealEngine4 (Images inside)AlienRenders said:
There was a recent update to the 5.0 branch. I've merged the changes to my own 5.0-mod branch and it now builds. So 5.0-mod is good to go. I'm now testing if the shaders will compile as that is done in the editor, not in visual studio.
edit: Just finished trying updating an old project to UE5. Everything looks good. All shaders compiled. The 5.0-mod branch looks good.
When I cloned main UE5 branch it required Visual Studio 2017 to compile. When I cloned yours, it's asking for 2015 :D Does it mean I have to bunch of Visual Studios when dealling with UE? :D Also, I'll keep asing. Are you available for a chat?
st3ph3nstrang3 said:
ssuukk2 said:
AlienRenders said:
Don't think it'll help. It's the main 5.0 branch that won't build for me. My stuff is fine. I've updated my code and pushed to my github repo. If anyone wants to try it, it's there under 5.0-mod.
Hi is there any way to contact you for a chat? I'm struggling with a lot ot things that, it seems, were never done before. Zero answers on official UE forums. And you seem like you're some kind of mesh/bone/skinning wizard. The problems I'm facing are i.e.: I was able to import 1000 morphs on demand at runtime, and they mostly run OK, but for some morph force values they... flicker with black shadow. But there's really much more problems and you're probably the only person that knows something about this...
Black flickering with morphs is a known issue and unrelated to DQ skinning. When you are importing your skeletal mesh, change the import normals to "Compute" (or try the other options). I don't remember specifically which option it was, but that solved it for me.
I know it isn't. I'm just looking for anyone who knows some higher level stuff about meshes/skingin etc in Unreal, because people either have no idea about all this or they're not willing to share...
Looking for help on finding a good tutorial to import from daz to blender and then back to dazKainjy said:
If you want to reuse the cat mesh you have 2 option: geograft or convert the face cat into a weareable mask. I suggest the second solution: take your cat head, close mesh holes, import in DAZ and parent to Head joint
Ah, that makes more sense. I'll prob do that, thanks!
Daz Studio Pro BETA - version 4.20.0.17! (*UPDATED*)DoctorJellybean said:
hkuyer said:
Hi Richard,
Force quiting Daz is something I do almost on a daily basis, usually when dForce blows up. Could that really be an issue?
It might be a security issue, but my previous version worked fine right up to that update. I have uninstalled and re-installed the Postgres database, but that didn't fix it.
Meantime a 4.12 version still works on the same machine, but from another folder. Unfortunately that version doesn't render in iRay... something todo with my RTX3060 card I think.
Start 4.12, click on the hamburger (menu) icon on the Content Library pane, and click Content DB Maintenance. Check Reset Database and click Accept. Once that is done, close 4.12 and after waiting a minute or so start 4.20.0.17. If it starts ok, then repeat the steps, but check Re-Import Metadata and then Accept.
