• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Thanks AM for the Stoat/Ermine/Weasel...so cute
    Doc Acme said:
    I really really want him, but unfortunately I can't use dForce hair as I export.
    What do you export to? I know C4D can import dForce hair as splines, and I imagine other programs can as well.
    And yes, this is super cute, and makes it apparent that I didn't know the difference between a weasel and a badger.
    By
    Gordig Gordig May 2022 in The Commons
  • DAZ doesn't read the normals, or "smoothing groups" of an FBX file correctly.
    I have started to model jewelry in (an older version of) 3DS Max and export it as FBX so I could use it in DAZ 3D. I plan to do this more in the future. However, if I'm going to do it there's something I really need to solve first.
    The FBX file itself seems fine – when I re-import it to 3DS Max all the normals are rendered exactly as they're supposed to. I have been googling for the older threads of the same problem and I do understand now that "smoothing groups" that I use are rather a 3DS Max feature. Still, I haven't either found a solution to my problem or I'm really missing something that's more obvious to others.
    Here's what the groups are supposed to do: you can choose a group of polygons that are huddled together and if they share a number they will render as a single, smooth surface. Likewise if you group neighboring polygons they will render as a different smoothing surface and form a sharp line between the surfaces. If the surfaces share the same numbers somewhere in between then the line in that spot is also smoothened out.
    Here's what the shape is meant to look like, it's made of clear ridges:
    Here's how it imports as FBX into DAZ 3D. For some reason it works partially, while the other areas look like they melted in a forge:
    Any ideas? I'd rather save my future jewelry from the forge heat. cheeky
    By
    Elaini Elaini May 2022 in Daz Studio Discussion
  • issue on the option "Rig or Re-target Skeleton" - DazToMaya 1.8 with Maya 2020 or 2022 versions.
    Hi guys,
    Unfortunately setting to "None" the "source" only partially fixes the problem, the rig created with "Rig or retarget skeleton" breaks if I move it with "source" set as "control rig" (image 2) or with another animation (image 3).
    Steps to reproduce the issue:
    1) Open a Genesis 8.1 character in Daz, click on the plugin window (without morphs/without clothes)
    2) in Maya, click Auto import and import in a new scene
    3) in Human IK, click on "None" as source
    4) Click Rig or Re-target skeleton, select an empty folder when asked
    5) Character comes out with a rig in A-pose as in image 1 attached. It is movable if "None" is set as source, but breaks with "Control rig" set as "source"
    Has anyone solved this? The DaztoMaya plugin needs some love, I'd really like to use it in my workflow as it'd save me hours.
    By
    japporeactor japporeactor May 2022 in Maya Discussion
  • [Released] Turbo Loader for Genesis 8 and 8.1 [Commercial]
    DoctorJellybean said:
    Rod Wise Driggo said:
    Well a second question regarding the "unknown products" and the "logged in"-state. So I do need to login in studio do make sure that the database is current, right? Should I be logged in during scan? Do I need to trigger any DB update manually? Thanks!
    Yes, login in Studio so that the database can be updated. You don't need to be logged in during a scan, once a week should be fine.
     Now, why would I have to log in to update the database when I have everything installed and up to date with DIM? What is being updated exactly, and why should it make a difference? I have no intention of ever Connect-ing. Sounds like DIM-only users are being left out of the loop.
    Metadata gets updated via DAZ Connect.
    That has been know to cause problems from time to time, and I expect it will again. What part of the metadata is updated? Are you saying that the metadata from Connect is different than what is in the DIM-downloaded packages? If so, why is it different? How is it that every single product has different versions of metadata? Why can't the DIM downloads have the same metadata as Connect? Sounds like DIM is treated as second-class.
    By
    NorthOf45 NorthOf45 May 2022 in Daz PA Commercial Products
    By
    DoctorJellybean DoctorJellybean May 2022 in Daz PA Commercial Products
  • [Released] Substance Painter Assistant [Commercial]
    SnowSultan said:
    I am having nothing but problems with this product. Exports mess up the geometry of many objects and I cannot get any textures to automatically be applied back into Studio no matter how many times I adjust the parameters or rename the textures themselves. I will keep trying though, and if I can get it to work, I will try to post exactly what worked for me.
    I am sorry you are having difficulty!
    I am not sure what you mean about Export messes up the geometry?  How?
    For the import, what are the filenames you are trying to import from SP?  What is your file naming scheme?
    By
    RiverSoft Art RiverSoft Art May 2022 in Daz PA Commercial Products
  • Quick way to retrieve name of figure when all you see "Genesis 8 Female" in the scene panel?
    This may help http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/metadata/list_products_used/start - open/paste it into the ScriptIDE pane and its output will appear below the script, or you can download and then check the log (Help>Troubleshooting>View Log File).
    By
    Richard Haseltine Richard Haseltine May 2022 in New Users
  • Wacky Modelling ~ In Carrara ~
    I added the curves to the idle motion devil
    Stezza, Unreal is free, no Spaz Studio or other programs used, this is straight Carrara export and Unreal import
    so you could make games with your characters enlightened only pay once you earn a million USD a year
    By
    WendyLuvsCatz WendyLuvsCatz May 2022 in Carrara Discussion
  • The "Animators Assemble!" thread for Daz animation WIPs, clips, and tips
    Maybe a weird question, but how do you actually import FBX animation into DS? I built my Cascadeur animations on G8 characters, and I have no problem using them in C4D or Houdini, but the only way I've found to get them into DS is to import the FBX, then Copy Figure and paste to a G8, but the results always look wonky, like I'm trying to use G3 animation on a G8 or something.
    By
    Gordig Gordig May 2022 in Art Studio
  • Frame around yellow triangle with exclamation mark
    The same product was also installed with Connect inside DS.
    2022-05-05 11:54:37.448 [INFO] :: D:/My DAZ Connect Data/data/cloud/1_62385/environments/architecture/ansiko/california summer/cs beach bag set.duf (1,1): Syntax error - expected '{' or '['
    2022-05-05 11:54:37.448 [INFO] :: Error loading asset: D:/My DAZ Connect Data/data/cloud/1_62385/environments/architecture/ansiko/california summer/cs beach bag set.duf
    Connect also updated the metadata for the product to look for it in the Connect Library, which is in a totally different location, with a totally different folder setup.Which why you are seeing the "can't find it" icons for everything in that product that uses the database driven view(Smart).
    Connect doesn't play well with others.So you will need to decide which install method you want to use.
    I suggest DIM and never login inside DS again to protect the metadata/database from this type of install salad. :)
    edit:manual install/DIM/Central + never login inside DS again works for Daz Store content also.
    Content downloaded/bought at a different store most likely won't have any metadata included with it, nor would the Daz store have any metatdata for it, so there wouldn't be any to mess up.
    By
    IceCrMn IceCrMn May 2022 in Technical Help (nuts n bolts)
    I know this has been addressed before but I've tried all of the solutions I found and nothing is helping.
    I'm trying to use the California Summer Beach Props that I bought yesterday but everything - props, materials, shaders and script all have the frame with the yellow triangle and exclamation point.
    When I double-click on a prop I get the error message - An error occurred while reading the file, see the log for details.  The log is below.
    I've downloaded the zip file and unzipped it with 7zip without a problem so there's nothing wrong with the compressed file.  I've double-checked that all of the files are where they belong.  Frankly I'm stumped.  Any help would be greatly appreciated.
    Thanks!
    022-05-05 11:54:37.386 [INFO] :: Prepare asset load (open): /Environments/Architecture/ANSIKO/California Summer/CS Beach Bag Set.duf
    2022-05-05 11:54:37.386 [INFO] :: Locking viewport redraw...
    2022-05-05 11:54:37.386 [INFO] :: Viewport redraw locked.
    2022-05-05 11:54:37.448 [INFO] :: Native format content directories: 8
    2022-05-05 11:54:37.448 [INFO] :: Poser format content directories: 5
    2022-05-05 11:54:37.448 [INFO] :: Other import format content directories: 0
    2022-05-05 11:54:37.448 [INFO] :: Begin asset load (open): /Environments/Architecture/ANSIKO/California Summer/CS Beach Bag Set.duf
    2022-05-05 11:54:37.448 [INFO] :: Operation failed
    2022-05-05 11:54:37.480 [INFO] :: Unlocking viewport redraw...
    2022-05-05 11:54:37.480 [INFO] :: Viewport redraw unlocked.
    By
    TheresaGood TheresaGood May 2022 in Technical Help (nuts n bolts)
  • Importing Camera data INTO Daz Studio
    does it import VooDoo?
    https://sites.google.com/site/mcasualsdazscripts/mcjvoodoodaz-for-ds1-2-3-4
    By
    WendyLuvsCatz WendyLuvsCatz May 2022 in Technical Help (nuts n bolts)
    Hi, just read... I'd got the same problem although I have switched to Houdini. I'need to import a camera animation in Daz in create enviroments and render into it before coming back to Houdini and postprocess in Nuke. But at the moment I can't be able to manage this workflow...
    By
    Sun2x Sun2x May 2022 in Technical Help (nuts n bolts)
  • Daz Studio Pro BETA - version 4.20.0.17! (*UPDATED*)
    Anarkia333 said:
    WendyLuvsCatz said:
    OK this is new and exceedingly annoying.
    the animation range reverting to 217 on reopening scenes is always annoying and stopped for a few builds
    now it is back with sprinkles on top, it does it on the fly everytime I do something like pan a camera angry
    OMG guys use DAZ for animation is soo ridiculous cheeky
    yeah, just spent 17 hours rendering the New Sponza Atrium from Intel with iray 1800 frames
    https://www.facebook.com/wendy5/videos/3939049862886761
    back to Filament and sanity now wink
    BTW DAZ does not import the FBX nicely so unless you have something that does Like Carrara with textures and glow on bulbs! to export an obj, don't bother
    https://www.intel.com/content/www/us/en/developer/topic-technology/graphics-processing-research/samples.html
    By
    WendyLuvsCatz WendyLuvsCatz May 2022 in Daz Studio Discussion
  • [Updated] Database issues after moving library (and frustration venting)
    The best way to avoid surprises is to only install with DIM and NEVER log in to your account from inside Daz Studio.
    Never, ever, ever install a product with DIM and then install it again (or update it) from inside Daz Studio (i.e. with Daz Connect)! If you do, the result  will result be duplicated files, products that used to work suddenly not working or having screwed up metadata or missing thumbnails. By never logging in, you can avoid those issues. You need to disable autologin in preferences. Don't let those symbols on the thumbnails fool you into thinking you have to install again inside Daz Studio after installing with DIM. That is not what those symbols mean. They mean that the product is available to be installed with Daz Connect. If you've installed it with DIM, you don't care that it is also available to install with Daz Connect, because doing so only causes problems.
    By
    barbult barbult May 2022 in New Users
    Are you logging in to your account from Studio? There is no need unless you want to use Connect. That is also how Studio knows that the products are available to install. When you "update metadata", are you using the Content Database Maintenance tool, or right-click on the Products from the Smart Content pane?
    By
    NorthOf45 NorthOf45 May 2022 in New Users
    Blank_Canvas said:
    I bought the script and exporting is working well once I wrapped my head around the preparations made to the Object_low.obj. I am having issue with the Import into DS side.
    It would be so helpful if a video tutorial for the Import into DAZ Studio were made.
    • It needs to show how to set up a naming system for BOTH SP and in the script.
    The script is flexible enough it should be able to take any naming system from SP as you can define any acronym you want, which could even be something like "This is a long acronym"
    • It needs to show how to deal with using the same channel file in more than one spot in the Iray shader. (Example: Glossiness from SP going into Glossy Layered Weight, Glossy Reflectivity, and Top Coat Weight.)
    Unfortunately, the script can only assign automatically to one channel.  You can multi-select channels and then assign one of the files on the right easily though.
    If you made this video I would be greatly appreciative, because right now I'm still having to manually assign channel images to their spots in the Iray shader.
    I don't plan to make another video at this time, sorry.
    By
    By
    Possibly resolved. I am hesitatingly calling this resolved.
    What seems to have fixed it was scanning known drives for files, and then re-import metadata.
    Right-click Content Tab > Scan Known Directories for Files...
    By
    gepetersiii gepetersiii May 2022 in New Users
    Alright, I must say that one of the most frustrating 'features' of Daz Studio is the fact that every time I open DS, I never know what I am going to get. I can close the app, immediately reopen it and all of a sudden several preview images are missing from products. Close it and reopen it again, and this time get all missing metadata. And yet a third time can result in Iray not working. I apologize for the venting. It leads to this:
    I moved my library to its own drive. I have moved the library multiple times in the past without issue. I opened DS and checked that all associations worked. Everything seemed fine. However, I came back to it this afternoon and this time ALL my products are grayed out. None of them show metadata. They all have the option of installing (using Connect which I refuse to use).
    I get the feeling I am going to end up deleting the whole library and reinstalling. I hope not. <<Is there a way to repair this issue?>>
    Thank you!!!
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
