• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Any way to split a morph, like eyeballs
    Hmmm, I don't think it's my morph.  I actually revised it to have the lids set to a more slightly relaxed look but I need the blink morphs to cooenside with that so they look right.  Right now.... see the screen shot...
    Never mind.  NOW the eyes are open to the value they should be.  Not sure what changed.  Perhaps when I slaved the morphs together?  It's all very strange.  Not complaining but strange!
    Now he just needs fur.
    By
    RAMWolff RAMWolff November 2023 in Technical Help (nuts n bolts)
    RAMWolff said:
    OK, figured out why the ERC method wasn't working for the teeth.  I moved the teeth and eyes (as well as tear, eyelashes and eyebrow card) from the main figure so I guess ERC didn't "see" them but funnily the eyes were seen so that's kinda strange.  The morph works great now but I still need to figure out how to tamper down how much of Fuzzy's eyes from "over opening".  I looked all over to see how to limit the blink morph to open only to the 75% range.  At 100% range it's just too much.  I looked all over in the Property Hierarchy and just couldn't find a way to control that for the morph there but I was sure it's located there....
    That's great !
    As for limitation, you may try to set Min - Max value in Parameter Settings of the dial(s) or use Attributes Type - ERC [Keyed] to define the keyed values in Property Hierarchy. However, you shouldn't have to do that, as TBH I'm still afraid that there might've been something wrong in the corrective morphs when you made/fix them with Zbrush.
    As a tinker, I've ever fixed lots of pairs of eyeballs and eyelids (tiny, huge, real and toons...) for PHM, eJCM, cbs... whatever, I never had to set specific formulas to "control" them "open/close", just made them work in very standard ERC way(s), because all these corrective morphs should be only "delta" to the existing expression property dials. As long as "delta" is correctly made and set up, they'll work with no issue.
    Pls DO further check or remake some corrective morphs to test.
    By
    crosswind crosswind November 2023 in Technical Help (nuts n bolts)
    By
  • Transfer Utility - Repositions Shoes Incorrectly
    For a non Genesis Base figure (if it was in your case), set different options in Transfer Utility as attached screenshots. Then you have to further fix the character's body morph on the wearable....
    Reminder: Never use a Character to make wearables ! Use Base figure, then it'll be easier to rig and fix distortion with bodymorphs / corrective morphs, etc....
    By
  • Daz to blender
    Hello,
    Please I really need help coz I am totally desperate.
    I have 2 characters in daz studio, and i have animation.
    These two characters interact witch each other, and I would like to export this entire scene including animation into blender.
    Any idea how to do it?
    I am really desperate and i dont know anymore.
    If I try to use bridge, it doesnt let me, because I can select only once character, if I select both characters I get error.
    If I transfer one model then another, then animations work, but they are totally on wrong spots, and not together...
    By
    stealzor3 stealzor3 November 2023 in Blender Discussion
  • hair being pulled in at neck
    Try to: select the hair in Parameters pane, Show Hidden Property, Zero the hidden property of the character's head morph.. Or, just parent the hair to your character's head.
    By
    crosswind crosswind November 2023 in Daz Studio Discussion
  • Let's appreciate/discuss today's new releases - ongoing thread
    Concerning face transfer and ai.
    This kind of thing has literally been "ai" ever since, so that's not a distinction that would matter per se. "Generative ai" currently may have such an edge, that people have become faithful enough to jump over there, which might mean a change.
    For the quality - apparently "ai" as we know it,  including generative, seems to have an easier go on textures, than it has on geometry, at first glance. In fact it only really will be drawing pink elephants (+- , if you train it to reproduce images).
    However with given 3D Figures like Genesis 123, even if pretty abstract and flexible, there of course is a chance to train it in such a way, that it could work out pretty well. "It" does not necessarily mean, that you can do it with only one machine learning model and without some preprocessing, e.g. you might have to determine some normalization parameters or similar, or work with some kind of expert system, in order to have something workable. To do it from one photo, you might at present need a relatively terrible lot of training data, to let it distinguish actual geometry. Maybe it needs a multi step process to work, e.g. apply a suggested texture to a geometry to probe and determine overstretched areas, then adjust - to put this idea into an algorithm, you might think of alpha go, which had a model for selecting moves to check (order), and a model to judge the board. This likely isn't too trivial.
    So i believe, there will be such technology, without doubt, and there probably pretty much has already been (movies?), but i can't tell where version 2 of the mentioned plugin is or will be.
    (E.g. for geometry, you might be interested in training a model, that just tries to adjust some morphs, like muscle morphs, in order to make an animation look more realistic, training on sports videos or a sequence of photos. It's a similar problem, concerning geometry. For getting more realistic movement interpolation between two poses, you could probably do away with a muscle model, which follows some heuristic of how acceleration happens, and perhaps the bigger muscle to move first/faster in place, with a little bit of second-guessing on the coordination part, i.e. not 100% greedy FCFS, but either just smoothly distributed, or distributing timing windows for partial moving. Simplistic tree search could also be used, e.g. if a body part is intended to create the maximum speed, like sometimes in martial arts, or maybe it's meant to be a relaxed move, and so on. Of course you could model it, and let an ai run with some dice throwing, similarly. A useful interface could however allow you to tweak a move towards some aim, without complicating the process of how to train something for all possible tweaking. So what did i just emphasize? A) somehow randomly adjust morphs to match an image from a sports movie, meaning a hell of a complexity to render from different angles and compare, vs. B) have a theoretical model of the body somehow with the route for movement being clear, and we just need to figure out, which part is moving where to at which stage, and what the stages are. So in essence, if the problem was of the A)-kind, machine learning might make sense, because no one will ever figure out all the angles in a simple way, while the B)-kind implies rather tweaking paramters of a given model, with whatever method, could be machine learning, monte carlo algorithm with some heuristic, simplistic two step heuristics and distribution/skipping of paramters. Also depends on the quality you need, and on the distances to cover. Of course B) as an approach, probably has little to do with Face Transfer anymore, so maybe it's a good example for distinction.)
    By
    generalgameplaying generalgameplaying November 2023 in The Commons
    you have to bake transformations before running transfer utiity.  Bake = Export the shoes after positioning them, and then reimport the shoes.  This way all transforms are at 0.
    If you are running transfer utility on non-default figure (in other words if you have any morphs applied), then you need to tick the box for 'reverse source shape from target' or whatever its called in the options dialogue of transfer utility.
    By
    lilweep lilweep November 2023 in Technical Help (nuts n bolts)
    Are they hairs made for the figure? Is there a morph aplied which scales the head?
    By
    Richard Haseltine Richard Haseltine November 2023 in Daz Studio Discussion
  • Diffeomorphic DAZ Importer version 1.6.0 released
    tcgmark said:
    I'm having an issue with the tranfer vertex groups feature in the advanced panel.  Using blender 4.0 and diffeomorphic 1.7.2.1930.  Used to be when i imported HD and base characters, i could transfer vertes groups to the HD from the base with this feature after applying a multires modifier to the HD mesh.  now i get a missing attribute error.
    AttributeError: 'DAZ_OT_TransferVertexGroups' object has no attribute 'transfermethod'
     I don't check this site very often, but I happened to notice this. The bug is fixed in the latest commit.
    By
    ThomasLarsson ThomasLarsson November 2023 in Blender Discussion
    joliva said:
    Hello,
    I'm a new user to Daz trying to attach these OBJ boots I made to my Genesis 8.1 Morph for posing and animation. When I try using the transfer utility, it positions the shoes below the feet like in the attached image. Does anyone know what I can do to get them in the right positon?
    Thanks!
    1. With the default load of G8.1 {no character morphs} - does this footwear "land" exactly where it should be upon import. It "has to."
    2. Then run the Transfer Utility and see what happens. Their placement should not be changing. IF it is correct, select the footwear and save it as a figure/prop.
    3. Then remove that footwear from the scene, with the target figure selected - load the newly saved footwear. As you gently move the foot about there may be a few corrective morphs to make. There may be a little weight-mapping to be adjusted too. [be very careful to have the footwear selected for this, not the target figure] When done, resave the file to the exact same folders as before [so the new will overwrite the old].
    4. Then remove that footwear from the scene, with the target figure selected - loaded the new footwear. Select the character and dial in the character morph. The footwear should still fit however some morphs, esp. those from extreme character morphs, may require a little fitting morph.
    5. Sometimes an alternative method works -- hide the foot or the toes.
    By
    Catherine3678ab Catherine3678ab November 2023 in Technical Help (nuts n bolts)
    Hello,
    Thanks!
    By
    joliva joliva November 2023 in Technical Help (nuts n bolts)
  • Incline bench front leg rigging
    Richard Haseltine, @crosswind, thank-you for helping me out and giving me ideas.  I appreciate your help.
    I went the morph route, and it pretty much gave me what I wanted with the adjustable front leg, the linear motion in-and-out along the top shaft of the leg, and the dial.
    -b
    By
    Grafitaleblu Grafitaleblu November 2023 in Technical Help (nuts n bolts)
  • Face Transfer 2
    NotAnArtist said:
    Richard Haseltine said:
    It says that it will be available in the DS beta first, then later there will be an update for the general release. If you do not wish to pre-purchase then don't, it is up to you to weigh the cost and benefit of each offer before deciding whether tot ake it up or not (or even to decide you are not interested enough to do any weighing).
    It's wrong to tell people that they can sufficiently weigh cost or benefit based on such nebulous, weak information!
    If there isn't enough information to persuade you to buy then surely th weighing will simply come down against purchase.
    I was tempted to buy this thing but then my brain woke up with a few questions.
    If I buy the preliminary item, Face Transfer 2, for $34.97, I will not receive an actual product, but it will allow me to get access to the unlimited beta version later.
    Would there be an additional price for that beta? ["get access"]
    Acess means, as others have already found, that you get a serial number for the product - that is all that will be needed.
    And then when the General Release version is launched, would I get any extra discount for having spent money on the first two steps?
    Again, you would have a serial number - Daz has not yet chargd for a beta and then for the release version, and I would certainly not expect them to start now.
    BTW, when I get access to the unlimited beta version, I may discover I don't like it, so would I get my $34.97 back?
      *It could happen beyond the 30-day return policy, related to the first purchase.
    This would certainly be a reason to wait, but it is your call. Though I thought there was something about early next month - if that did stretch beyond 30 days from the tail-end of November I would certainly be inclined to argue for an extension (with what success I can't guess).
    So are they inviting people to spend $34.97 to TEST something, and if they don't like it, phhhht, $34.97 gone, and no product to show for it at all?
    By
    Richard Haseltine Richard Haseltine November 2023 in The Commons
  • Please - Face Transfer 2
    Havos said:
    SolitarySandpiper said:
    mwokee said:
    I watched the YouTubes promoting Face Transfer 2 and was not impressed with the real life examples. I'm interested in getting it but the results are not realistic enough for me. Are there any tricks for getting better results or were the videos pretty much as far as you can go? There are AI applications that are stunning in what they can do but I can't justify the cost. Maybe this is a you-get-what-you-pay-for thing. I want quality for cheap and I'm out of luck? If Daz can do better, maybe update their how-to videos?
    What Ai applications can do a stunning job at what face transfer 2 is trying to do on the cheap?... i really am hoping there is such a application.
    cheers.
    It is possible the author used AI to improve his algo, rather than it being bundled into the plug-in, which I suspect would not be easy. AI is after all a somewhat hyped subject at the moment, and it is hard to say exactly what is AI and what is not.
    I did pick up FT2, but mostly because of the deal that came with it. DAZ's deals involving free products up to X dollars, often only include a bunch of largely undiscounted DOs. With this deal you got $30 dollars of heavily discounted products, particularly if you had 3 punches. With $30 dollars of undiscounted products you might get a couple of cheap pose sets, but with FT2 I got about 10 free DOs, some of which had a high base price. I also got a gift card for 27% off, so I am happy regardless of how useful FT2 turns out to be.
    Frankly, I was amazed. I was going to buy FT2 anyway, but with the punches, the last "giving thanks" coupon discount and an extra 10% for the cart for buying one of the other new items, the FT2 itself was $16 and I got 10 freebie items, all G9 stuff.
    By
    paulawp (marahzen) paulawp (marahzen) November 2023 in The Commons
    A morph co8ld do up/down movement - morphs move the points in a straight line. You can also use the Joint Editor to adjust the orientation of a bone, dragging the centre/end points and then using the right-click menu to align the bone. Setting limits is one way to constrain movements, though I am not sure if this is what you want.
    By
    Richard Haseltine Richard Haseltine November 2023 in Technical Help (nuts n bolts)
    A morph co8ld do up/down movement - morphs move the points in a straight line. You can also use the Joint Editor to adjust the orientation of a bone, dragging the centre/end poitns and then using the right-click menu to align the bone. Setting limits is one way to constrain movements, though I am not sure if this is what you want.
    By
  • DazToHue vs DTL
    I'm the creator of DTL, so as with MrPDean's response, please take what I say with a pinch of salt. I've not used DTH but I do follow progress and am very impressed with the system's capabilities.
    DTL Conversion
    My background is character animation, so DTL is primarily focused on creating a character that can be dropped into Unreal and will work out of the box with existing animation systems, demos and control rigs etc. For example, a figure produced by the release version of DTL (not yet released) can be dropped into the standard 3rd person UE demo project with almost zero configuration (see here: https://youtu.be/BPQgRld3I7A?si=c3hRBkFHzLhLNyXX).
    During the conversion process, DTL completely rebuilds the character's skeleton, matching the joint orientations, rotation orders and names to exactly match that of Unreal's Metahuman / MannyQuinn figures. DTL also automatically merges the figure's meshes (including geografts) and produces a set of morphs that work on the merged mesh.
    Both the current beta version of DTL and the release version also produce a complete set of game engine compatible JCMs that cover the complete range of human motion. The DTL demo projects contain a pre-configured Animation Blueprint Post Process that uses UE's posedriver technology to drive the JCMs at runtime so that realistic body shape and muscle deformation are maintained even when the character is performing extreme motions like acrobatics.
    Associated Software
    DTL uses Maya to perform the conversion. There is an Indie version of Maya available for $300 a year and a trial version is also available. Please see here for links: https://virtuality.space/dtl/dtl-prerequistes.html#software
    After conversion, a DTL converted figure is ready for further editing in Maya / Blender / Houdini etc if, for example, extra morphs are to be made or UV atlasses are to be produced.
    The reason DTL uses the DazToUnreal plugin as part of the process is that the plugin contains an implementation of Pixar's subdivision algorithm for exporting fbx files with higher subdivision levels (i.e. higher polygon counts). As well as producing an fbx file, the DazToUnreal plugin also produces a .dtu file that contains useful information that DTL uses during the conversion process. DazToUnreal also automatically creates a set of materials in Unreal Engine that can be applied to the DTL converted figure. Kudos is owed to David Vodhanel for his amazing work on the DazToUnreal plugin.
    It important to note that the figures DTL produces can be used with any game engine that can import clean, well formed, game ready character fbx files - despite the use of the DazToUnreal plugin during their creation process, DTL converted figures are not limited to use in Unreal Engine.
    The Future of DTL
    The release version of DTL (now planned for early 2024) will include the following features in addtion to 100% Unreal Engine skeleton compatibility:
     ~ Morph driven joint transforms that enable the morphing of one character to another in realtime, give full functionality to morphs like 'mouth open' and ensure rigid follower meshes like buttons and zips stay in place when morphs are applied at runtime.
    ~ G9 (and possibly G3) support
    The 100% UE compatible skeleton functionality is already finished. The morph driven joint transforms and G9 support are in a working state and just need refining.
    The automatic creation of a custom assets for UE's Machine Learning system for muscle deformation is also planned for a subsequent release.
    The Future of Character Animation
    Further down the line, I plan to make DTL capable of creating assets for neural network based locomotion animation systems. Neural network based animation systems stand to replace state trees and blendspaces with a neural network and produce far, far more compelling results than traditional animation techniques. These systems are also incredibly performant at runtime.
    One of the world's leading researchers in the field (Daniel Holden) started working for Epic earlier this year. I've been following Daniel's work (and others in the field) since 2017 when he published his seminal paper on the subject.
    All of the work I have done so far on DTL so far has been with the intention of being ready for when a neural network based animation system become commercially available - without doubt, they are the future of character animation: See here for the current state of the art (as produced by Sebastian Starke, another leading researcher in the field): https://youtu.be/YhH4PYEkVnY?si=9kffOsUgvdGmDx36
    I feel there is a very high chance we will finally see these systems being rolled out in a user friendly, commercial form during 2024.
    By
    dave_0aa47f5a80 dave_0aa47f5a80 November 2023 in Daz Studio Discussion
    cheers.
    By
    Havos Havos November 2023 in The Commons
    Maybe it should be a morph...But I don't know how to do that either.
    -b
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
Create An Account
