• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • A crop-top for Genesis 3, Base, Aiko7, Victoria 7 with PerfectFit morphs
    LINK: https://sites.google.com/site/mcasualsdazscripts9/mcjg3croptop
    there's now a version for G8 Base and Kin Seohyun
    https://sites.google.com/site/mcasualsdazscripts9/mcjg8croptop
    Introduction
    The crop top looks about OK when fitted on Genesis 3, but looks distorted when you resize the breasts
    or apply the Victoria 7 or Aiko4 body ... so ... for a perfect fit ... i supply 12 fix-morphs
    Use
    In your library go to \ People \ Genesis 3 Female \ Clothing \ mcasual
    drop the cropTop on Genesis 3 Female
    if the fit is acceptable, that's about it
    if you want a better fit
    open the sub-folder named mcjG3CropTopPresets
    select the cropTop figure << -- very important
    apply one of the 12 fix-Morphs
    Big means the breasts are scaled up 120%
    BigCleav means big + cleavage, means the  breasts are closer-together
    Def means the breasts are the default size and rogetherness
    DefCleav means default breast size but the  breasts are closer-together
    For Genesis 3 base/default
    \mcjCTG3Big
    \mcjCTG3BigCleav
    \mcjCTG3Def
    \mcjCTG3DefCleav
    For Victoria 7
    \mcjCTV7Big
    \mcjCTV7BigCleav
    \mcjCTV7Def
    \mcjCTV7DefCleav
    For Aiko 7
    \mcjCTA7Big
    mcjCTA7BigCleav
    \mcjCTA7Def
    \mcjCTA7DefCleav
    By
    mCasual mCasual November 2019 in Freebies
  • What if Blender could seamlessly render Iray materials?
    Just to point out that the diffeomorphic plugin DOES materials conversion for both cycles and eevee. It works fine for most iray materials. Actually it has some issues with sss and dual lobe specularity. These features are implemented but it's not a perfect match. Then things may improve if anyone is interested to contribute.
    So would you say material conversion is 80%+ accurate?
    I'm confused with some people saying the conversion is good and other people (like @marble) saying the conversion is not accurate at all.
    If someone could clarify why there's such disparity in opinion, that would be much appreciated.
    It depends on what texture set you are using.  One person could be using a G8F with the default G8F textures or maybe Victoria 8 textures which convert over with diffeomorphic fine.  But someone else could be using G8F with textures from lets say bluejaunte or sublimelyvexed will needs its materials tweaked in blender because diffeomorphic didnt convert it properly because as Padone mentioned diffeo has issues with SSS and DLS which if i had to guess G8 or V8 textures dont have or if they do they arent as detailed or high res or whatever as bluejaunte or sublimelyvexed textures.
    By
    unused account - glossedsfm unused account - glossedsfm November 2019 in The Commons
  • Daz Studio Pro BETA - version 4.12.2.60! (*UPDATED*)
    Ok... I spent the best part of my weekend testing with:
    DAZ Studio
     - 4.12.0.86
     - 4.12.1.16
    NVIDIA studio drivers
     - 430.86
     - 431.86
     - 441.12
     - 441.28
    There are two separate issues that cause CPU fallback.
    1. There seems to be a driver bug in R440 branch (441.12, 441.28) which causes immediate CPU fallback on switching viewport to Iray preview for RTX card users and it affects both DAZ Studio versions (General Release and Public Beta). This does not happen with older driver versions (430.86, 431.86).
    2. There seems to be an application or Iray bug in DAZ Studio 4.12.1.16 Public Beta which causes CPU fallback under certain conditions. I have finally found a combination of DAZ own products that reliably triggers this bug for me -- simply starting DAZ Studio and loading Babina 8 character (https://www.daz3d.com/babina-8) and panties and bra from the Lingerie Robe Set (https://www.daz3d.com/lingerie-robe-set-for-genesis-8-female-s) while Iray preview is enabled causes immediate CPU fallback. This does not happen in 4.12.0.86. Note that if you load for example Victoria 8 instead of Babina 8 it won't happen, but what might happen is that you get visual artefacts in Iray viewport -- textures of the clothing items are blended with the figure skin regardless of whether the clothing item is parented or not. Toggling Iray preview or loading another clothing item clears that up.
    I reported the driver bug to NVIDIA OptiX and Iray team, hopefully DAZ 3D can get around to fixing the second bug.
    TL;DR -- if you are using RTX card stay on NVIDIA 43x.xx drivers branch, and don't use public beta until this is fixed.
    By
    sylvie1998 sylvie1998 November 2019 in Daz Studio Discussion
  • Harwood House: Have you seen the props?
    Incoming argument between Victoria and Michael about the fact he's left the toilet seat up...
    By
    Matt_Castle Matt_Castle November 2019 in The Commons
  • ZDG random Daz Studio discoveries and questions.
    Yeah, it's been too long, and I'm trying to cobble together many pages into a shorter single post, so sorry if this is a bit, well, random, lol. I looked at the above dress, and I will say 'ok' for the moment. I discovered a minor glitch as you may notice in my renders and while I could make it go away with a previous T-post test, in the following renders it persisted even after dialing the offending dial back to zero. I also had considerable fun with a gen7 to gen 8 converter by RiverSoftArt. FWSA Sandi left, and FWSA Vanessa right (converted to gen8). I had a paragraph somewhere about various elf ears, in short, I do find the close to the head ear shaps tend to clash more with hair, than the more distant types that give room for hats and hair (why I have used Vanessa's ears on Sandi so much).
    as for the other project, I am going to be relying on some Clark tech to assume it is feasible at all, considering that nothing shy of a star is efficient at fusion. to paraphrase Britannica, atom sizes can only be described in ratios due to quantum behavior rather than a specific size, so distances between atoms can only be described in ratios as much as some despise not having an exact number, lol. I am dealing with something that has a similar issue that makes the hydrogen scoop engine impractical. The amount of compressing and energy needed to collect the mater to fuse is drastically larger than the energy you get out of the reaction. a 1.67x10^3 scale (1,600x) to go from gas to liquid for water is bad enough without considering the heat and pressure needed to convince air collected and compressed into a plasma willing to fuse. The scoop needed would be so large to collect hydrogen in space, that the thrust from the fusion would not be able to provide any reasonable amount of delta-V given the weight of the scoop, let alone provide enough energy from the fusion reactor to sustain the reaction. I will simply assume some Clark tech has made sustaining the reaction feasible for a slightly more dense atmosphere intake for the fusion candle thruster.
    (screeching halt) I am rewriting this as the above and former numbers are way off, way way way off. the concept will remain the same, it's just way bigger.   -     I couldn't find a quick answer online searching for a ratio of air to plasma, so I assumed a 2000 reduction from intake through to fusion cell diameter. (Then a chat happened over on SFIA, Hence the rewrite)  I may be off by an order of magnitude or a few on how much air needs to be compressed to start forming plasma, however, the gist is, it's not a small amount of compressing air. It is a gargantuan volume of air being compressed into an infinitesimally small size, to get it to the point of fusing. it's not easy, but when you start to get fusion, you're on your way. Yeah, that's a lot of Clark tech to make that happen, lol. Yeah, I was off, lol.
    Edit during typing this. "the optimum density value is around one-millionth of the atmosphere." - EUROfusion (thanks to Rhamphoryncus on SFIA for the link and info). Many thanks, I guess my example is way off, lol. and due to some other things chatted about, due to the rate of fusion, the bottom-most 5 coils, would need to be extended to about a kilometer or so long, depending on how much air we want to fuse before it exits the rocket nozzle. Also, from another angle, going beyond a million to 1 inlet to chamber cross aria (at earth sea level), would result in a loss in reaction energy due to the reaction changing to something else that I don't totally understand. I suspect throttling the amount of intake could allow control of that, however to much intake would be detrimental for more than just losing energy in the reaction chamber. So napkin maths, assuming a rocket nozzle throat of 1cm, the inlet of the compressor on the side of the fusion candle would need to be about a million cm (10000 meters) across. Hmmm. a 1km long fusion chamber doesn't sound so bad now, lol.  10km intake, plus a tad more as it would be in the upper atmosphere not further down. (back to fixing the 3D sketch, again, thanks)
    I settled on a dual reactor setup. one reactor powering the platform, intake fans, and compression coils. The other reactor providing purely thrust, all of its net gains being dumped into thrust. This thing is moving planets after all, so why not get all the bang for the buck out of the thrust reactor.
    It was when I was doing that napkin math, I noticed how long it had been, so I decided to toss together a makeshift replica of the original idea from SFIA (Jeremy Jozwik from Artstation).
    I still have a few things to clean up on the coils inside the thing that got mangled when copying them around the radius of the fusion candle platform.
    there is an easy workaround in daz for now, for just the single surface zone. Smoothing can remain on for the rest, it will be fine.
    despite having a few ideas on how it may look a tad different, that thing is just cool as all hell. I want to see more than just the one clip of it (I also want to see more of SFIA Unity as well).
    https://www.dropbox.com/s/nslqwd1ge3ybsgz/ZdgFusionCandleWIP01LimitedUseCredit_01001.zip?dl=0
    the obj is about 109MB in size, no UV mapping, just procedural shader zones, and mesh. 720288 faces (polys) is not a small model, I will also say I have seen larger (ignoring SGA even, lol). And then the web page crashes when adding links, ugh.
    Edit 25nov2019. as I watch the many AMD and intel CPU launch vids, I am working on smoothing over the inner coils some, and refining the edges of the outer ring of air-intake box things. I hope to have something conled togeather within the day or so, I will make it a new post, this one otherwise works well enough for many things.
    Things are moving along rather well.
    By
    ZarconDeeGrissom ZarconDeeGrissom November 2019 in Art Studio
  • aniMate Video examples
    How about this one https://www.daz3d.com/animate-martial-arts-boxing-for-victoria-8 ? If not it may be your browser or security settings blocking them.
    By
    Richard Haseltine Richard Haseltine November 2019 in New Users
  • *closed* RRRR - "Build it and they will come" Render Contest
    tag: luci45 #5
    Pleistocene Park
    Featuring animals, plants and people of the Pleistocene epoch, Pleistocene Park was a favorite destination for the ladies of Harpywood, who felt it their duty to offer more attractive attire to the native Homo Erectus ladies.
    Used:
    Useful Fabric Iray Shaders
    Japanese Style Dining Sets - Lotus replaced with Harpywood's Dahlia Summer (and friends)
    Gabriella for V5
    UltraHD IRAY HDRI With DOF - Parks and Creation
    From Russia for Rune 7
    Homo Erectus V4
    Also used:
    Extinct Animals (Smith Micro)
    Cotylorhynchus
    Gamebirds 2 (Hivewire)
    Shoe Boxes and Store Props
    Spartan Warrior Spear
    Georgina Hair for Genesis
    Heath Hair for Genesis 3 Male(s) & Female(s)
    Char Hair for Genesis 2 Female(s)
    Bernedette Hair for Genesis 8 Female(s)
    Bardot Outfit
    Neanderthal clothing (Mec4D)
    Summer Dress for Genesis
    Possibilities 2PC Dress for Genesis 2 Female and Victoria 6
    Wave Sandals
    Surgical Beauty
    Various morphs
    Agnes
    Laundry Day Mega Set
    Colorful Jewelry for Genesis 8 Female(s)
    Dresses ad shoes
    Plastic Surgery
    By
    luci45 luci45 November 2019 in Art Studio
  • Why does one have to be rocket scientict to make this work? Morphs on Gen 1 and Gen 2
    Repeat - Not a Smart Content Issue
    The parameters tab remains empty, no matter where innthevhierarchy I click!
    This leads me to believe that your problem is not Smart Content.  This sounds like a problem installing or locating the morph dsf/DSON files.    The base morphs should be installed with the Genesis Starter Essentials installation package.  Genesis 2 figures also have starter essentials install files. I believe they get installed in the "data" file folder, which should be in the same file directory as your default Studio content.  Victoria 6. etc. full body morphs are installed in folders within this data file. Morph packages also get installed in the data file.
    My guess is either that the morph dsf/DSON files are not installed in the correct directory, or that for some reason the whole data file tree is not in the same content location as your people file tree.
    By
    Diomede Diomede November 2019 in Carrara Discussion
  • Fitting Reby Sky hair to Genesis 3
    I'm trying to get Reby Sky hair (for Victoria 4) to fit correctly to Genesis 3 female.
    For some reason though, the forehead is really big when i fit to the new TG3 character.
    You can see what I mean on the image below. I've added a G2F character to the middle as well so you can see the difference. The forehead gets bigger the newer the base model is.
    Can anyone suggest a way I could get it to fit properly (or at least have a smaller forehead/lower hairline)?
    Playing with the scale size of the hair doesn't seem to help. I've also tried using the transfer utliity with no luck, unless anyone can suggest some really specific setting I haven't tried yet.
    By
    Trex Trex November 2019 in Technical Help (nuts n bolts)
  • Who's Next to Join the G8 Family?
    Jenni 8 is the 36th female character and 57th core figure.
      2017 2018 2019 2020
    January   01/09/18 - #11 Owen 8
    01/23/18 - #12 Karyssa 8
    01/02/19 - #34 Christian 8
    01/15/19 - #35 Sydney 8
    01/22/20 - #62 CJ 8
    February   02/13/18 - #13 Alexandra 8
    02/22/18 - #14 Edward 8
    02/05/19 - #36 Tasha 8
    02/19/19 - #37 Landon 8
    March   03/13/18 - #15 Aiko 8
    03/27/18 - #16 Ollie 8
    03/05/19 - #38 Bridget 8
    03/19/19 - #39 Mrs. Chow 8
    April   04/11/18 - #17 Penny 8
    04/24/18 - #18 Edie 8
    04/04/19 - #40 Mr. Woo 8
    04/25/19 - #41 Tika 8
    May   05/09/18 - #19 Mika 8
    05/22/18 - #20 Floyd 8
    05/09/19 - #42 Sanjay 8
    05/23/19 - #43 Kala 8
    June
    06/15/17 - #01 Victoria 8
    06/05/18 - #21 The Girl 8
    06/19/18 - DAZ Dog 8
    06/06/19 - #44 Elios 8
    06/20/19 - #45 Ellithia 8
    July
    07/25/17 - #02 Olympia 8
    07/03/18 - #22 Teen Kaylee 8
    07/17/18 - #23 Mabel 8
    07/04/19 - #46 Teen Jane 8
    07/17/19 - #47 Kanade 8
    August
    08/22/17 - #03 Michael 8
    08/10/18 - #24 Zelara 8
    08/21/18 - #25 Toon Dwayne 8
    08/08/19 - #48 Gabriela 8
    08/22/19 - #49 Diego 8
    08/29/19 - Centaur 8
    (#50 Female and #51 Male)
    September
    09/19/17 - #04 Teen Josie 8
    09/04/18 - #26 Latonya 8
    09/18/18 - #27 The Brute 8
    09/05/19 - #52 Babina 8
    09/19/19 - #53 Silas 8
    October 10/03/17 - #05 Stephanie 8
    10/17/17 - #06 Lucas 8
    10/02/18 - #28 Gia 8
    10/18/18 - #29 Vladimir 8
    10/03/19 - #54 Teen Raven 8
    10/19/19 - #55 Yuzuru 8
    November 11/14/17 - #07 Monique 8
    11/28/17 - #08 Darius 8
    11/06/18 - #30 Mei Lin 8
    11/22/18 - #31 Lee 8
    11/05/19 - #56 Leisa 8
    11/22/19 - #57 Jenni 8
    11/28/19 - #58 Robyn 8
    December 12/12/17 - #09 Charlotte 8
    12/26/17 - #10 Sakura 8
    12/04/18 - #32 Eva 8
    12/18/18 - #33 Nix 8
    12/05/19 - #59 Darcy 8
    12/17/19 - #60 Rynne 8
    12/25/19 - #61 Tristan 8
    By
    Noah LGP Noah LGP November 2019 in The Commons
    More on GenX2 - I just put some links on this post in case you're interested in checking it out. I have loved Genesis 1 without any of this help for a long time, so I'm not trying to push in any way - just trying to be helpful.
    There are also Generation 3 addons as well.
    It's really easy to use. In Daz Studio, I just docked it with aniMate and the Timeline, so I can just open it up across the entire main working view of DS! LOL   By default, Genesis 1 is the Target figure, so any morphs added will go into the folder structure I was just talking about. With the G2 add-on, I have Genesis 2M and Genesis 2F as drop-down selections in the Source tab. Now that I've used V4 and M4 to add morphs to Genesis, they're in that list now too. Pretty slick.
    If I select a Genesis 2 actor, all I have to do is pick which morphs (any morph available to the selected Actor!) I want to give to Genesis 1. If I select or load Generation 4 figure, I need to use the Load button and browse to INJ morph files and load those onto that figure before I can select them to send to Genesis. If that sounds complicated, it's just my wording. So I have V4 as a Source, I browse to Daz's Victoria 4 in the Pose folder, Morph Injections, and then use those mass load files to just put everything onto V4. But I can also add custom morphs too, like the lovely faces by Thorne, Morris and others, horrific or warrior faces of MortemVetus, etc., if I have a morph available, I can load it and send it to Genesis.
    Whichever I select as the Source, I just put a check into any morph I want Genesis to have and click the button. It's fast and it works very, very, very well! Then I can load another figure or actor and add more morphs.
    Genesis Generation X2  |  GenX2 Genesis 2 Addon  |  GenX2 Genesis 3 Addon
    By
    Dartanbeck Dartanbeck November 2019 in Carrara Discussion
  • Loading Model Question
    Which Victoria? In general loading the Victoria # character preset gives the shape and base materials, but not the make ups and so on - they get added with additional presets.
    Its Victoria 8 Pro Bundle. But its more of a general question :)
    What exactly are the base materials? Also, how can i remove makeup like eye shadow and lip gloss? I cant seem to find them in the scene tab.
    Thank you
    By
    Banti Banti November 2019 in New Users
  • Victoria 4 ?
    Victoria 4 base figure is here: https://www.daz3d.com/victoria-4-2-base
    But even that says "
    Victoria 4"
    So it say... there is another vic4?... or why do they say its compatible with it, if that is not the Vic4 model O_o....?
    No, Victoria 4 went through several service packs (updates) but in geenral anything fro "Victoria 4" will work with Victoria 4.2 - at worst you might need to inject the morphs before applying a shaping pose, and if you use DS and have the PowerLoader run that should be taken care of for you anyway.
    You should be able to autofit most stuff for her to Genesis 1
    and from there to the later figures
    sometimes her bundle ends up in free stuff if you really want her
    Yeah I just try to grab some stuff to play with daz... happy about everything :D the basic clothes from the Genesis 8 starter are... just underwear not really the best thing :D
    And the most freebies this time, was only for excisting other products :(
    By
    By
    Hello everyone
    so, i bought the Victoria Pro Bundle and i have a question. When i load the Victoria character into the scene, are the skin, eyes, makeup etc. also automatically applied? Or is it the genesis default skin untill i apply it
    manually? And how can i tell what eyes, makeup, skin etc. are currently applied to my model?
    Thank you
    By
  • AIUTO...CHI CONOSCE L’ITALIANO? PARTE DODICI
    Che avete contro Vittorio 4 non lo so, io l'ho comprato e mi piaceva più di Micheal 4, e poi usavo i vestiti fatti dal suo creatore. Che la DAZ l'ha pure levato dallo shop, ma mica so cose ecco.....
    Io niente, solo che Victoria mi piace di più quando è femmina. cheeky
    Salve a tutti , sapete se anche Daz festeggia il Black Friday con supermega sconti ?
    Fossi in te conserverei i mortaretti. Viste le ultime promozioni dubito che ci saranno degli affaroni degni di questo nome. sad Spingeranno l'ennesimo personaggio anonimo e non molto altro... Spero, tuttavia, di venire smentito.
    in gran parte da soli 4 PA: RiverSoftArt, Syckleyield, Zev0 e MansFriday!
    Di quei PA non ho moltissimo, la maggior parte dei plugin e script che uso li ho avuti da MCasual, sul suo sito. Trovo assurdo che la DAZ non abbia ancora deciso di rapirlo per aggiungere tutte quelle cose fantastiche a DAZ Studio! surprise
    Gli ho già fatto un paio di donazioni perchè non smetta di sviluppare nuovi plugin. wink
    Imago, se ti stampo un bacio in fronte grosso come una casa si offende qualcuno? No, perché non conoscevo il sito di MCasual! Grazie per colmato questa lacuna! kiss
    By
    Ruthven Ruthven November 2019 in The Commons
  • Victoria 4 ?
    Victoria 4"
    By
    Loony Loony November 2019 in New Users
    By
  • Victoria 4 ?
    By
    Leana Leana November 2019 in New Users
  • Victoria 4 ?
    Hi, I saw this:
    https://www.daz3d.com/fashion-v4
    and many more, but... WHERE is victoria 4? :D I always see its for V4, but where is the model? or do I missunderstand something?
    I feel so stupid Q_Q
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
