• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • When try to loading any genesis 8 female model gives .duf file is missing error
    If you want to keep the morph then you will have to change the "parent" line.
    For G8F the line should read as "parent" : "/data/DAZ%203D/Genesis%208/Female/Genesis8Female.dsf#geometry",
    and that includeds the , (comma) at the end
    By
    Bejaymac Bejaymac January 2024 in Technical Help (nuts n bolts)
  • Face Transfer skin location
    What version are you using, Face Transfer or Face Transfer 2 ?
    The generated texture maps can be found in Surface pane - Surfaces, as attached SS.
    The texture maps locate in : %appdata%\DAZ 3D\Studio4\temp\Face Transfer\Generate\
    By
    crosswind crosswind January 2024 in New Users
    eris3d said:
    crosswind said:
    Bejaymac said:
    crosswind said:
    Nice ! though it's really odd... a DSF links to a DUF..., haha ~
    Odd, but sadly not all that unusual in my experience, I've found the parent pointing at non existing DUF files, non existing DSF files, hell I've even found long randomly generated strings of characters instead of a pathway/file name.
    No idea how the **** they do it, as DS will add the correct parent data to the morph as it's being imported into DS, which then get's saved into the DSF file.
    Odd and odder... I almost handle these stuff everyday...I've never experienced that there's a definition of DUF in DSF. As for long randomly generated strings, yep, I've seen that before with SBH geometry, more or less.... Well, "parent" data in DSF should be also a geometry / node definition from DSF rather than DUF...
    I'm still wondering... odd...
     Here I can't add dsf file but I can show.
    That was almost what I imagined but was what I could not reproduce either... Anyway, just follow the SOP and correct steps for saving assets in the future.
    By
    crosswind crosswind January 2024 in Technical Help (nuts n bolts)
    By
    eris3d eris3d January 2024 in Technical Help (nuts n bolts)
  • Partially Apply Body Morphs? (Fitness)
    For Genesis 8 these products have morphs that can be applied to specific muscle groups.
    Muscularity Morphs for Genesis 8 Female(s)
    Muscularity Morphs for Genesis 8 Male(s)
    Musculature HD Morphs Bundle for Genesis 8
    I find a full body skinny/emaciated morph compliments the above products if you do not want bulk.
    By
    dtrscbrutal dtrscbrutal January 2024 in The Commons
  • Daz Studio 5 development update
    inquire said:
    Is this an example of the AI we might expect in DAZ Studio? https://www.daz3d.com/face-transfer-2
    The Ai in face transfer is, as far a I know, entirely separate and part of a licensed product rather than something Daz developed.
    By
    Richard Haseltine Richard Haseltine January 2024 in The Commons
    By
    inquire inquire January 2024 in The Commons
  • The Mac FAQ
    Is anyone using the Face Transfer product? https://www.daz3d.com/face-transfer-2
    If so, how do you rate it?
    By
    inquire inquire January 2024 in Technical Help (nuts n bolts)
  • Can the Genesis 9 Femine Base Be Used in a Commerical Character?
    yes that set is licensed as a merchant resource so its ok.
    The DAZ Feminine base is not, so you need to set up coding so your morph + the DAZ fem morph get dialed up together. That way you arent baking in or otherwise distributing anything you shouldnt be,
    This goes for any non MR morph - so if you want to take JoeBobs BodybuilderDood and make SuperheroDood, you export BodyBuilderDood.  Then sculpt your superdood on that base.  Going back to DS,  turn Bodybuilder on the figure, and then use reverse deform to pull the BodyBuilder morph out of yours during the import, so you are left with just the differrence that you had sculpted. Then set up the coding to dial BodybuilderDood + HeroDood.  And plus probably also a custom proportion dial, since proportion changes also dont get baked in as part of the morph.  And then you get to chase the rabbit and make custom corrective morphs for every rotation of every bone, and then code them with if then programming so they only turn on for SuperHeroDood
    Complicated I know, it's a lot of work.  This is why I make pants ;)
    LM
    By
    Lyrra Madril Lyrra Madril January 2024 in The Commons
  • Modular Items
    Now how about the attachment points of various components adjusting to the length of what it's attached to?
    My thought process is to put bones on the objects, with the attachment point for each component being at the end of that specific bone, and the length of the bone changing with the morph.
    Say, for the pommel, it would attach to a bone at the end of the grip called "Pommel" (for simplicity's sake). The grip morph would control the length of that bone along with the mesh, and (hopefully) moving the pommel with it as the length of the grip changes.
    By
    ambaryerno_f18cf8da31 ambaryerno_f18cf8da31 January 2024 in Technical Help (nuts n bolts)
    One way - using a product, e.g. this one - https://www.daz3d.com/shape-splitter
    Alternative - by manual: Clear selected Deltas from the dialed morph with Geometry Editor + some necessary mesh smoothing in external sculpting software - A tutorial -  https://youtu.be/XuQwnTd4Fok?si=Z41IpYq0Wr4jLtty
    If you wanna partially apply a full body morph to the designated area (waist down, arms, as you mentioned), a manual way is to create a dFormer with weight (just like HeadSplit dFormers in G8/G9 Starter Essentials). Export the full body morph to OBJ, import it back to the figure with Morph Loader Pro by using Attenuate option. Reference tutorial - https://youtu.be/nEFI6keXU2c?si=ndkUVwAFCe58FqzT
    By
    crosswind crosswind January 2024 in The Commons
    Is there a way to apply part of a full body morph?  Explanantion, I want to use the Fitness Morph (shape) but I don't want the 'chiseled abs'.  is there a way to apply the morph from the waist down? Or to an individual body areas such as arms? (method, utility or product)
    By
    dlm4001 dlm4001 January 2024 in The Commons
    Generaly speaking, if you don't sculpt, you can dial the morphs (Merchant Resource) you bought on G9 as needed to make a custom character. Then export the character to a single OBJ file with Base resolution. Add HeadSplitter from G9 Starter Essentials to the figure, import OBJ file to the figure to create Head Morph and Body Morph separately by using Attenuate in Morph Loader Pro, with the settings - Reverse Deformations: Yes, Overwrite Existing: Deltas Only.  Then save figure assets / morph assets as needed, so on and so forth.
    This is the commonly-used and professional way, which you'll just sell "Deltas" while abiding by the EULA...
    Edit:~
    By
    By
  • ND Demonizer Shapes for Genesis 9
    @Van Hobo, indeed, there are so many variables to what sells and what doesn't, and that makes it difficult to gauge if it was something with the product, the prize, the timing, or the promotion it launched with. I'm happy to hear that some of our products have been useful, and I thank you for the support! Bullwarg's Alternate Textures was our first time doing skins and we had to do it on a very tight deadline, but it was super fun to work with! Since that became a buyout, I can't move it forward to Genesis 9, but I do intend to transfer Reptilian´s skins to G9 and work on the soft transition products for both G8 and G9. Of course, we plan to finish the Scars and Wounds series first (Esid already finished the HD Morphs, so I need to build the textures and presets). We plan also to do the shotgun wounds for G9 as well :).
    @Phoenix Knight, thank you for your nice words. I always have an eye on the forums and help whenever I can (be that troubleshooting my products or other issues) because I remember that when I started my journey with DAZ, I got a lot of help from people in the forums. So this is my way to contribute and pay it forward. Regarding Partreon, Esid (my brother) and I considered it, but neither of us is too keen to dip back into social media (which is seriously a full-time job). There's also the issue that many of our products require HD Morphs, which can only be sold in this marketplace. That said, we are not entirely close off to setting a partreon, but we would need to sit down and discuss how to make it work while submitting enough products here to help us pay our bills.
    If you have any suggestions for products, feel free to reach out. I can't 100% assure you we will do them, but they can always make their way into our (extensive) to-do list. :)
    By
    FenixPhoenix FenixPhoenix January 2024 in The Commons
    PerttiA said:
    crosswind said:
    PerttiA said:
    One can get strange things happening when one saves something as an Asset without knowing what it does and what one saves to the Asset - This type of problems persist over reinstallation of Essentials.
    Probably ~~ though that didn't make sense to me. So that was why I suggested him identify the root cause from that file.
    Lets say one has made or 'made' (with the dials) a morph and saves it as Morph Asset and doesn't realise that one should only select ones own dial (set to zero), saving copies everything to the users own morph folder.
    I can imagine a duf file being saved in such a process
    I have encountered such problems here in the forums and years ago on my own computer.
    So that would be the odd part because saving Morph Assets only handle DSON Support Files, and as default, DSON Support File never include any data of DSON User File... unless one modifies it with an editor. That was why I thought it was weird....
    By
    By
    By
    PerttiA PerttiA January 2024 in Technical Help (nuts n bolts)
  • Genesis 8 basic figure loads with morphs applied
    PerttiA said:
    This has unwanted side-effects with G9, but works for G8 and G8.1
    To fix any ill-behaving (non-zero default value) morphs, do as follows;
    1. Open DS and load "Genesis 8 Basic Female" (to an empty scene)
    2. Right Click at Parameters Tab->Preferences->Choose "Show Hidden Properties" (part 3 zeroes only 'visible' dials)
    3. Right Click at Parameters Tab->Zero->Zero Figure (Zeroes the value of all the 'visible' dials)
    4. Right Click at Parameters Tab->Memorize->Memorize Figure (Sets the current value of all the dials as their default value)
    5. Edit->Save As->Support Asset->Save Modified Assets (Writes the changed default value to the morph files that were changed)
    When saving "Modified Assets" DS shows a dialog and asks for confirmation;
    "The following file(s) will be permanently modified:" - "Accept/Cancel" - Choose "Accept"
    or make a note of what is affected and then Cancel - that should let you identify the problem and fix it directly
    By
    Richard Haseltine Richard Haseltine January 2024 in Technical Help (nuts n bolts)
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
