• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Saving "full character", for sale
    A Character Preset will save shape and materials (and will embed any custom morph not save as an asset, but will load them only if used to load a new figure). Save any custom morphs (not containing shaping baked from other morphs) as morph assets (File>Save As>Support Assets>Morph Asset) before saving the Character preset.
    By
    Richard Haseltine Richard Haseltine February 2024 in Technical Help (nuts n bolts)
  • Crossing Generations
    You can use these products to transfer the morphs you used from G3 to G8:
    • https://www.daz3d.com/character-converter-from-genesis-3-male-to-genesis-8-male
    • https://www.daz3d.com/character-converter-from-genesis-3-female-to-genesis-8-female
    By
    FenixPhoenix FenixPhoenix February 2024 in The Commons
  • Problem applying custom eyelashes to figure
    You probably need to edit the weight-maps for the lashes on the eyelid bone (I can't recall its name) or add a custom close morph or both - projection, of morphs when they are applied or joint weights with Transfer tool, is fairly simple-minded adn does not cope well with mesh that is far from the skin, especially if it is angled rather than projecting straight out.
    By
  • AIUTO...CHI CONOSCE L’ITALIANO? PARTE QUATTORDICI
    Certo che avete la fissa per dover usare per forza le pose pronte di altre figure. frown Posate il modello e salvate tutto così da avere un set apposito quando vi serve.
    In ogni caso, ho spulciato un poco la loro licenza, non si possono usare i modelli in nessun modo al di fuori di VRoid o del circuito di appartenenza. Nemmeno come base per creare morph per G1. surprise
    Quindi, è ancora compito nostro creare dei morph degni. cool
    By
    Imago Imago February 2024 in The Commons
  • [Released] ManFriday's Seamster (clothes rigging for Daz Studio) [Commercial]
    Hello everybody! It's been a while, but I've been busy working on something big that came out today.
    https://www.daz3d.com/seamster
    ManFriday's Seamster is a plugin for Daz Studio 4.21 and higher that makes rigging clothes for Daz Studio significantly easier.
    Reduce your risk of Repetitive Strain Injury (RSI)!
    Making 3D clothing for Daz Studio usually involves the following phases:
    • Modeling and UV-mapping the clothing with 3D modeling software (such as Marvelous Designer) and exporting it in the OBJ file format.
    • Importing the OBJ onto a Genesis figure in Daz Studio and rigging it (giving it bones and making them work with weightmaps and corrective morphs).
    • Texturing.
    Seamster helps with step 2, which many consider the most tedious part of making clothes for Daz Studio. It greatly reduces the many clicks that are normally required, reducing the risk of forgetting something along the way, which can otherwise lead to a lot of lost time and frustration. It imports your clothing OBJ and runs Transfer Utility with just two clicks. It helps you with checking and painting the weightmaps for all the bones and with making corrective morphs for certain bone rotations. It can also help with creating rigid follow nodes (RFNs).
    Seamster has been developed with the help and support of some of the most respected clothing makers who are publishing in the Daz Store. I sincerely hope that this will make the tedious process of rigging clothes for Daz Studio much easier and produce more and better clothes for our favorite platform.
    Attaching the PDF user manual which has an overview of what the product does, an introduction to riggingin in general, and all the details.
    By
    ManFriday ManFriday February 2024 in Daz PA Commercial Products
    @Imago Si può esportare in FBX tranquillamente (al momento ho solo un problema con i joint che mi restano tutti orizzontali ma ci sto lavorando.. già ho appena scoperto come rendere la figura compatibile con le pose dei G9). Inoltre potresti usare le figure generate da Void Studio come sola base per creare dei morph tuoi (senza dunque distribuire il file).
    By
    Kainjy Kainjy February 2024 in The Commons
    I made a set of fibermesh eyelashes in Blender, then used the Transfer Utility to transfer the properties of the Genesis 8.1 Female Eyelashes to mine. It works, but when G8.1F's eyes are closed, the lash fibers get deformed. How do I fix this? Is there an alternate way of fitting the eyelashes?
    By
    Dark Matter Dark Matter February 2024 in Technical Help (nuts n bolts)
  • Free Flexion Enhancement for G8/8.1F. Also SWM Flex Vein Control
    takezo_3001 said:
    Any hope for a G9 version?
    G9 SWM Muscularity Morph Add-Ons, Adds Flexions, Bulk and Details - Daz 3D Forums
    Requires the SWM muscle package, unfortunately I haven't been able to figure out a way to do the Flexing veins on G9 yet, because the HD morphs available to date don't have individual left and right areas. TD
    By
    terry_duquette terry_duquette February 2024 in Freebies
  • Diffeomorphic - Animation not quite the same in Blender and DAZ
    Avoid any fancy IK feature as stretchy limbs and tweak bones since that will not transfer to save pose preset, essentially daz animations are limited to bone rotations.
    Nor will anything involving pinning hands or feet to a stationary object while the rest of the body is moving
    which effectively defeats the entire purpose of creating the animation inside blender with its  IK /Fk system in the first place.
    On this page: https://www.andre-gaschler.com/rotationconverter/ ,  enter WXYZ values into Quaternion fields on the left (invert X / Y axis !), then you'll get the conversion result in Euler Degrees XYZ field on the right. (-1*X / Y / Z). The values must be different from what you get in DS while selecting Right Upper Arm joint, at last Keyframe....
    Then as Padone also suggested, just try the way of "Keep Daz Rig" and "Mute Control Rig" ... Then you'll get the correct value by using the above calculation method. I got it work with no problem.
    I attached the calculation results with the way of MHX (ss1 ~ 2) only and the way of "Keep Daz Rig", (ss 3 ~ 5) as….eetc etc.
    And after drilling down to that tediously granular level intervention you are still limited to fairly simple bone rotations with your “animated pose” sent back to Daz studio angry
    Honestly it would be SOOOOOOOO much easier to just learn how to light render your Diffeo imports  in Blender Cycles or even EEVEE for some things.
    By
    wolf359 wolf359 February 2024 in Blender Discussion
  • Stretched fingers
    If you have weird posing issues with a custom morph it might be that you need to adjust the rigging to your morph (look for "adjust rigging to shape" command).
    Regarding pose presets in general: if you hold ctrl when clicking on a pose preset it should display a dialog where you can select which nodes it will apply the pose to, so you can apply a partial pose by selecting only some nodes.
    By
    Leana Leana February 2024 in Technical Help (nuts n bolts)
  • Blender 4.0 obj import/export.
    Blender 4.0 doesn't have the "legacy" OBJ importer/exporter, which has a switch for "Keep Vert Order".  Is there a workaround?  It exports all the vertices but they're in the wrong order and you end up with a mess when you apply the morph.
    By
    Pickle Renderer Pickle Renderer February 2024 in Blender Discussion
  • Stretched fingers
    Hello,
    Sometimes, when I apply poses, characters fingers are stretched. And I meet the problem with the body morph I've created though I haven't changed anything on the hand. The rest pose is fine. Is there any way to prevent this behavior?
    By
    arthenics arthenics February 2024 in Technical Help (nuts n bolts)
  • Problem with Anatomical Elements ending up partly inside the G9 & G8 body
    Thanks. That was it! Mesh Grabber was selected. I didn't expect that tool would alter the character on initial load into a blank scene like that. The previous scene I did a morph for a clothing item and must have left Mesh Grabber selected.
    By
    jay_4064091 jay_4064091 February 2024 in Daz Studio Discussion
    The simple IK rig needs revision as noted at bitbucket. For MHX and rigify you can use the "keep daz rig" option then mute/unmute for baking. Avoid any fancy IK feature as stretchy limbs and tweak bones since that will not transfer to save pose preset, essentially daz animations are limited to bone rotations.
    By
    Padone Padone February 2024 in Blender Discussion
  • Character Splitter
    Yes, Properties preset is what suits your workflow. It's a combination of :
    - a Shaping preset, which saves the value (in range 0 to 1 or 0% to 100%) of the morph targets that have been applied. Note that if you've applied unsaved morphs, for example using MLP, they can't be saved as they only exist temporarily
    - a Pose preset, which saves the transforms (location, rotation and scale) that have been applied
    - a Material preset, which saves the surfaces that have been applied
    You can "break" a base figure by saving any of its properties (morph, transform, material, render setting...) default value to something different than the base figure. For example, if you save a morph with a default value of 100% (or 1 if not using percent), it will be applied whenever you're loading the base figure. If you do this inadvertently, you can easily fix it by checking "Currently Used" properties in the Parameters panel to find the culprits, change their default to 0 and save them. This will permanently reset their default value to zero.
    By
    Mike3D Mike3D February 2024 in Freebies
    Mike3D  Just a quick update. I posted that question and got a reply from crosswind. When testing, crosswind didn't replicate my issue with loading in the MLP, however, did clarify the use of the shaping preset. And to my surprise, it doesn't save manual scaling. QUOTE: As for Shaping Preset issue, Scale belongs to Pose rather than Shaping..., so Shaping Preset won't work. You should save it as a Properties Preset with both Shaping and Pose (Hip + General nodes at least) checked.  I would need more info before saving as a property preset. I made G1 unusable for a while by saving a character as a morph asset incorrectly. Which reminds me how great it is to have the clear instructions for saving in your script - knowing I can't mess things up and how to easily delete unwanted morphs - thanks for making it so user friendly! yes / peace
    By
    3DmentiaNull 3DmentiaNull February 2024 in Freebies
  • Is it normal for it to be this frustrating?
    SilverGirl said:
    Richard Haseltine said:
    You shouldn't need to adjust the rigging for store morphs - they should do all that themselves, and the effects just get stacked. If you can figure out which shapes are causing the problem, and if they come from Daz (or another store) I would report them (to Daz Tech Suport for anything bought here, usually to the artist for other stores).
    Morph proction is pretty simple-minded - it just looks at how the adjacent area of the figure has moved and moes thata rea of the fitted figure accordingly. That does mean that enlarging or shrinking the breasts can look poor, especially if the artist had made some attempt to bridge the cleavage since the actual sternum area won't move and so the bridging section will be left behind as the areas over the breasts move. dForms and Push Modifiers can help, as can applying a Smoothing Modifier in Generic mode (the default, base Shape matching, tends to flatten out the effect of the morphs) but ideally you want clothing that has a custom morph to match the morphs you are applying to the figure.
    Thank you for the detailed response. Prior to getting Daz in in November I'd wanted to try ditgital art for years but never had a box that could handle it, so I'm walking in clueless and it all kind of looks like magic to me. Can I ask - when you say "custom morph to match the morphs you are applying to the figure" - does this mean you're just using store-bought characters and sliding the percentages (like, 25/25/50% of three different pre-bought characters) works, but sliding the separate body-part adjuster dials invalidates that? (Sorry, I'm still trying to learn the lingo. I'll get there!)
    A custom morph means that the clothing has been taken into a modeling or sculpting application (or adjusted with dForms and Push modifiers in Daz Studio, but that is trickier to bring off) to give a more considered match for the shape on the figure than the automatic match, then that is loaded as a morph with the same name (not label - you need to click the gear icon on the morph's slider and select Parameter Settings to see the name) so that when the figure is put in X% of Such-and-such morph the custom morph in the clothing will automatically take the same value. Without a custom morph of the same name Daz Studio just "projects" the shape, so that the clothing or other fitted item keeps the same offset relative to the new shape as it has relative to the base shape; that is why breasts frequently look vacuum wrapped, or every striation in a muscular morph is showing in the character's shirt. Unfortunately even restricting yourself to the base Body Morph set there are still so many shapes that clothing makers can't provide a custom shape for each.
    The only shape I used was the Caucasian woman who comes with Daz Studio, all alterations done with the Daz G9 expansion pack (can't remember the name) with all the sliders that was mentioned in the tutorials that came in my welcome email.  (Except the ears were mesh grabber, but I don't see why that ought to impact anything else.) She's not *drastically* different in build -- more athletic, scaled to 5' tall, and smaller-breasted (I'd say maybe a B-cup?), with a few other minor tweaks.  That 'adjust rigging' trick fixed the hands problem entirely; her arms still don't go the right spots for a few of the poses I've tried (they tend to be tucked unnaturally through her body) but I can compensate for that, even if I'd rather not have to. The hands part was what did me in the most, I think, especially since nothing I did seemed to really fix it (understandably, since her joints were apparently in the wrong places).
    It sounds as if the height adjustment is causing the issue - when you adjust the shape in a way that moves the modelled joints (the elbow, wrist etc.) the joints of the figure (the points about which it bends) need to move to match, otherwise you get really weird stretching. Adjust rigging to Shape looks at where the bending points are relative to the base shape and moves them so that they are in the same relative position in the morphed shape. How are you doing the height adjustment - using the Proportion controls?
    By
    Richard Haseltine Richard Haseltine February 2024 in New Users
  • Position coordinate transfer
    Is there an easier way to transfer the pose and the position all at once?  I've tried a few things and gone hunting on the forums/google and cant seem to find an answer.
    Right now I copy the orgional character -> paste pose to new character -> Manually set the location translations and rotations to match the origional, delete the origional.
    Apologies if there is a simple answer to this adn I have been too dense to find it cheeky
    By
    pazlen pazlen February 2024 in Daz Studio Discussion
  • RRRR "As the story goes" Render Contest *CLOSED*
    Block #2 Pull #2
    How Irina Met Sergei
    When Sergei showed up in his Remus Rover and strode confidently to the stage, Irina forgot her lines, overwhelmed by his smile and manly shoulders, and the aroma of his roast beef sandwich.
    Kept from pull #1:
    2937 i13 Sandwiches
    Pull #2:
    2718 H&C Weekend Casual Suit for Genesis 8 Male
    5003 Rustic Theatre
    4765 REMUS 02
    Also Used
    Vladimir 8/M3D Igor morph + Edward 8 texture
    The Business Hair for Genesis 3 Male and Female (Rendo)
    Time Soldier Outfit Textures
    Time Soldier Outfit for Genesis 8 Male(s)
    Russian Hats for Genesis 3 Male(s)
    Infinity Cove 3.0 with All New Morphing Terrain!
    Pixel HD for Genesis 8 Female
    Bernedette Hair for Genesis 8 Female(s)
    Colors for Bernedette Hair
    dForce Renaissance Dress for Genesis 8 Female(s) + Renaissance Dress: Milady
    Skies of Sylva - 20 Forest Themed 8K HDRIs for Iray
    Lawn Ornaments bench
    Wagner Ponytail
    Char Hair
    Pure Hair: Charming
    Pure Hair: Bubblegum for Genesis
    Reinoa Hair
    Pure Hair: Crazy
    Pure Hair: Classic
    Mathew Hair for Genesis 3 Male(s) and Genesis 2 Male(s)
    Eliot Hair for Genesis 3 Male(s) & Female(s)
    By
    luci45 luci45 February 2024 in Art Studio
    By
    SilverGirl SilverGirl February 2024 in New Users
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
