• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Tara 9, breaking your heart, stealing your soul.
    Tara makes a pretty cute incubus guy. I set the body to Masculine, used Minjun's body and Fitness 100, applied the head morph and scaled up the head a bit. And yet again I forgot to fix DAZ's weird skin setup...
    By
    Pax Asteriae Pax Asteriae February 2024 in The Commons
  • Who is this amazing character?
    Having worked with the guy who made the original 4 arms set for genesis 1, I can attest how much work went into it. Unfortunatly customers want it to have as many morph variations as the base figure, and that is not an easy task. It really becomes much more work than the return would bring, since it is such a niche product on its own anyway.
    I have tried a number of times to create various kinds of work-around projects to achieve this 4 armed look.....but they just would never be the quality I (or customers) would expect in the end...there would always be a level of post work required.
    Plus, like it was pointed out...clothing just would not work with it.
    There really is no good way to make this as a viable product...at this point (who knows what tech innovations may come in the future)
    By
    RawArt RawArt February 2024 in The Commons
  • Multiple characters sliders activated when I load a G9 characters
    The MGAB artist (not sure where it is sold) didn't save the morph the correct way. I would report it to the store. Beyond that you can edit the default value.
    By
    GhostofMacbeth GhostofMacbeth February 2024 in Technical Help (nuts n bolts)
  • Character Splitter
    Mike3D said:
    Version 3 available laugh
    Changelog:
    - excluding head bones for body morph and body bones for head morphs
    - addded tutorials for D-Former creation and 'Reference Vertex' use
    - added checks for mandatory plugins on startup
    - added checks for D-Former number of vertices matching base figure
    - 'normalized' becomes the default mode (previously 'WYSIWYG')
    - updated user manual (added plugins page)
    A great tool and really simple to use, I have converted about 20 characters until now (with v2) and always without problems. yes
    But it seems, there is a small issue with Genesis 8.1 - function SetRefVert() doesn't have a conditions for the 8.1 base. If you convert a character based on 8.1, the Vertex field on Body tab remains empty. Your lines in the script:
    else if (n.lastIndexOf('Genesis3F') === 0 || n.lastIndexOf('Genesis8F') === 0) v = '3127';
    else if (n.lastIndexOf('Genesis3M') === 0 || n.lastIndexOf('Genesis8M') === 0) v = '2926';
    I added G8.1
    else if (n.lastIndexOf('Genesis3F') === 0 || n.lastIndexOf('Genesis8F') === 0 || n.lastIndexOf('Genesis8_1F') === 0) v = '3127';
    else if (n.lastIndexOf('Genesis3M') === 0 || n.lastIndexOf('Genesis8M') === 0 || n.lastIndexOf('Genesis8_1M') === 0) v = '2926';
    And now G8.1 also works without issues.
    By
    stefan.hums stefan.hums February 2024 in Freebies
    Currently you can't save only the head or the body. However, before closing the script once finished :
    - go to the last tab : you will notice that the Head, Body & CTRL names are already filled
    - press "Find Morph(s)"
    - uncheck the morph(s) you want to keep (head or body). For the head, don't forget to also uncheck separate related morphs (Eyelashes, Tear, Eyes, Mouth, Eyebrows)
    - press "Delete Morph(s)"
    Alternatively :
    - remove the morph to keep (eg. remove Head name if you want to keep the head)
    By
    Mike3D Mike3D February 2024 in Freebies
  • Blender 4.0 obj import/export.
    As I said before, I just doubted the problematic morph you dialed was not the one you'd imported in such a way... otherwise it didn't make sense.
    Some tests can simply prove that...
    And as per my exp.,  that sort of distortion you posted usually comes from applied Modifier(s)...
    By
    crosswind crosswind February 2024 in Blender Discussion
                          Mike3D Thanks for the tutorial! QUOTE: Note that if you've applied unsaved morphs, for example using MLP, they can't be saved as they only exist temporarily.  That info could really help to avoid some confusion! And that very important point about how you can "break" the base (etc.) by saving the default value to anything other than zero - and how to fix it. 'Pretty sure that's how I messed up G1. And as I recall, it's also important to choose "modified" when you have that option (saving as a morph asset? I haven't done it right yet). I've saved things that wound up being huge, like 2 gig, probably cause they include every one of the installed morphs for the figure.surprise I did have a question: In one session, can you use the script to save only the head or body?(like when you have a good head but need to redo the body). That would create less unwanted files to delete, and avoid file naming confusion. Thanks very much for your support / HappyheartDay ... HappyheartDay everyone! / peace
    By
    3DmentiaNull 3DmentiaNull February 2024 in Freebies
  • Aniblocks and Animations Export - DazToBlender Bridge
    habibsoufi said:
    benniewoodell said:
    Check out the diffeomorphic plug-in, you can import animated sequences in as a pose preset. Just have to go to poses and then import action, have your animation saved as a pose preset and it'll be brought in. And there's sliders for viseme and expressions in diffeomorphic as well. Right now facial expressions do not transfer over, but in another thread it was mentioned Thomas is working on that right now, so hopefully soon. The materials have some differences between Daz to Blender Bridge and Diffeomorphic, if you prefer the DTB Bridge, just save the character as it's own file, bring it in with diffeomorphic and then append the materials from the other file and just switch the materials out. That's still way faster than importing pose by pose. For me it's really hit or miss, some characters look fantastic in diffeo and meh in DTB and vice versa, so it's just a matter of playing around with it.
    A whole freaking day I was looking for a solution to this with no success until I found this, thank you sir.
    You are very welcome, glad I could help!
    By
    benniewoodell benniewoodell February 2024 in Blender Discussion
  • What is your favourite G8F character?
    Zelara 8 for her skin as a hands down favourite, which looks great regardless of the underlying morph. Millawa 8 as a character, but the shading at her nostrils forces me to use at least 40% of her morph with her skin or the shading shows. Kala 8 as a character because she renders like a photograph out the box, but she's a bit too masculine with 100% of her morph, and I've found it difficult to retain the photorealism after altering her skin or morph.
    By
    xyer0 xyer0 February 2024 in The Commons
  • Crossing Generations
    If you don't want to buy any converters, try these videos. I used to use GenX, but it stopped working on my computer. I do use the Zevo converter from G3 to G8, but for other conversions, this method works well: https://youtu.be/ak6Nlfid5CQ?si=c0peS9UpjfOYcB_U
    If you have a character dialed in, it may be less work to convert it into a single morph, then transfer it to the other generation: https://youtu.be/mZ1TOAqIzeU?si=eJjAWX4OHUAsW5wK
    I've used these methods without any problems.
    By
    riftwitch riftwitch February 2024 in The Commons
  • No nipples on G9 ?
    felis said:
    You are not allowed to show barebreasted females. Not sure if ok, if you removed textures.
    That would be OK
    But essentially that is what you get with the base implementation.
    You could get something like https://www.daz3d.com/genesis-9-body-shapes
    that has some more, and then charcters might have a nipple morph.
    The issue with G9 is that although G9 overall has a higher mesh density, then it is more homogenious, meaning that in base resolution there is not enough mesh to shape nipples, so they require a HD morph, which is only avaioable for Daz PAs.
    By
    Richard Haseltine Richard Haseltine February 2024 in Technical Help (nuts n bolts)
    By
    felis felis February 2024 in Technical Help (nuts n bolts)
  • Clothes disappear in the figure
    You appear to have a morph applied to the figure - by design or because something isntalled was not set yup correctly - and that is not being projected into the fitted items - which generally any morph should be, certainly suggesting this is a badly done character shape from somewhere.
    By
    Richard Haseltine Richard Haseltine February 2024 in New Users
  • Cute & Simple Outfit Character in Main Promo Image
    Thank you for your reply, I missed that. Yes, maybe that is her. She seems slightly different but maybe a morph or two was used in the outfit promo. I just added Kui to my cart (and she is currently on sale which is great). Thanks again!
    By
    DollFace_Missy DollFace_Missy February 2024 in Product Suggestions
    If the vertex order has changed then the apparent vertex positions will have changed, so it will generate deltas on loading as a morph even though nothing was actually moved.
    As for scaling, that will depend on the scale on export from DS - OBJ doesn't havea  set size, so as long as it isn't scaled in Blender the only requirement is that export from and import to DS use matching settings.
    By
    Richard Haseltine Richard Haseltine February 2024 in Blender Discussion
    If so, that is wrong... even if there may be no distortion, there'll be a wrong Scale after importing OBJ with MLP...
    I don't know how your issue came from... or maybe you can double check if you dialed the right property / morph in the right path... because if you did nothing in between step 5 and 6 as you described..., you should have no way to import OBJ back to G8F as there's no delta change in terms of geometry... or if you did sculpt sth.. then you should have got wrong scale after import rather than a distortion. So "the issue" looks pretty odd to me....
    By
    Word of caution with the converters... If the converter converts individual morphs within the dialed-up character from one generation to another, there may be problems if one has the same morph packages installed for both generations (for example Growing Up)
    By
    PerttiA PerttiA February 2024 in The Commons
    kyoto kid said:
    ...it sounds as if the OP wants to be able to transfer characters that he/she dialled up in G3 to G8.without having to rebuild the character from scratch again as a G8 one
    Not sure how XTransfer would handle this as it targets individual G3 morphs and/or morph folders that are selected om the script.  Saving a custom dialled character as a "character" or "shape" preset wouldn't work as those are saved in the :Library>Presets>Character/>Shape, folder. Not the Library>Data one which is where all morphs are stored
    I tested that idea by saving a character preset of a custom G3 character I created but XTransfer does not "see" it in the Library>Presets folder even though it is there..
    I do not have the G3 to G8 character converter so I cannot test that.
    You can use XTransfer to transfer each individual dial you need (it can be done all at once) and the simply re-dial your custom character in G8.
    By
    Hylas Hylas February 2024 in The Commons
    By
    kyoto kid kyoto kid February 2024 in The Commons
    If I'm not mistaken, an element to keep in mind is that only PAs have the tools to convert HD Morphs: for end users, there is, as far as I can tell, no way to convert an HD Morph for Genesis 3 to Genesis 8.
    By
    Elor Elor February 2024 in The Commons
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
