• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Transfer Utility error
    bluelight special said:
    I know to click the Reverse. On both the Transfer Utility and for a Morph Target. I thought I'd be clever and just load a morph target of the pre-rigged OBJ, and that worked. Until i moved the model.
    Make sure your transformations are baked before doing Transfer utility. (I.e., make sure your clothing transformation parameters are at X,Y,Z = 0,0,0)
    If it's not at zero, you need to export and reimport the clothing.
    By
    lilweep lilweep March 2024 in Daz Studio Discussion
  • Genesis Beard like morph
    May I ask why you want to transfer it to G8M?
    There is not enough geometry on G8M to make a beard. PAs can make a HD morph, but I doubt any PA would be interested in doing that?
    So I would assume that a geograft is your best option.
    By
    felis felis March 2024 in Daz Studio Discussion
    This is what I would like to transfer to Genesis 8 morph
    By
    oscarcasin_c905ee79d3 oscarcasin_c905ee79d3 March 2024 in Daz Studio Discussion
    Good morning everyone, I would like to ask for some help: the product "Classical Morphing Bust HD" allows you to apply a morph to create the beard and hair. I'm wondering if there's a similar product for figures, like Genesis Male 8. Or how can I transfer this morph to Genesis 8. Is it possible? Also, how could I create it with Zbrush? In other words, create a morph for Genesis 8 that adds the beard. Thank you all
    By
  • FaceTransferUnlimited: Can'tSendParticular Character Only!
    Hi I'm back. Still not working. I was using Daz 4.21 before . Now I'm using 4.22 i still can't do it and it's Bruce Lee face transfer unlimited( 2019). All the others can be sent with Daz to  Unity Bridge except Bruce Lee. I have tried Face Transfer with different pictures of Bruce Lee. And just the Bruce Lee doesn't work with DTU Bridge. All the others transfer fine.
    Maybe there's a rule or something in the software that does not allow Bruce Lee? or something?
    It may happen with other people too but so far i've tried Morgan freeman ( fine), various presidents( fine). All could be sent to unity with Official DTU bridge latest version. Just Bruce Lee can't and it crashes my PC. When i look at the Task Manager when doing a DTU bridge transfer and it can't even begin..but the Power Usage is really high. It's strange. Again only Face transfer unlimited characters where i use Bruce Lee pictures.
    By
    nokoteb99 nokoteb99 March 2024 in Unity Discussion
    By
    bluelight special bluelight special March 2024 in Daz Studio Discussion
  • FaceTransferUnlimited makes characters body skin too dark, can you do anything about that?
    You might try reducing the value in the translucency channel, (under the surfaces tab) that can be hit or miss though.
    I have never used face transfer, so bare that in mind. I am assuming that there must be images created that are used by the UVs of the character. If you can find those images it is a pretty simple process to lighten them in a editing program such as GIMP. You will need to lighten both the diffuse and translucency images for best results. Be sure to back up your original images before making any changes.
    By
    dtrscbrutal dtrscbrutal March 2024 in Daz Studio Discussion
  • Lesbian Manicure nails?
    Does anyone know of a fingernail morph that lets you select which nails are lengthened?
    By
    soulstorm.paradox soulstorm.paradox March 2024 in Product Suggestions
  • Converting Version 4 figures to Genesis
    There is actually still plenty of v4/m4 stuff available here and other places. If you have a lot, it may not show up in the store unless you uncheck "hide items I own." Clones will allow you to use v4/m4 clothing on Genesis figures and you can use https://www.daz3d.com/genesis-generation-x2 to transfer morphs and various legacy uv products from https://www.daz3d.com/cayman-studios to use v4/m4 skins on later generation characters.
    By
    Torquinox Torquinox March 2024 in The Commons
    So the clothing was made on a non Base figure and, with Transfer Utility, you chose "Current" from Source - Item Shape and ticked "Reverse Source Shape from Target", but the rigging result was still wrong ?
    By
    crosswind crosswind March 2024 in Daz Studio Discussion
  • Genesis 9 Eye shut weird
    You don't need to learn how to add bones to fix it... just follow what Ninefold suggested to check if there's any corrective properties unexpectly dialed, with Show Hidden Properties by the way. It seems an issue coming from some morph dials (with wrong setup of 2nd stage control...) rather than joints or rigging...
    Besides, joints on G9 have been optimized. As for such a case of eyelids control, two bones on upper / lower eyelid are enough for human figures.
    By
    crosswind crosswind March 2024 in Technical Help (nuts n bolts)
    [Transfer Utility is] It's causing the clothing OBJ to rise up after the transfer, even after playing with all of the "Current" and "Default" settings for both the Source and the Target. I even used it on older characters that were previously successful. Something appears to be broken in both Daz Studion 4.22.0.15 and .16.
    By
    This could also be the opposite thing, which is a corrective morph for a specific character which is activating when it shouldn't. A lot of G9 characters seem to have this problem. So if this isn't a character you exported and then reimported as a new morph, the thing I would recommend is going through the "currently used" dials in the parameters tab and looking for dials with "blink" and the name of a character who isn't currently activated in their names. If you find any of those, try turning them down to zero.
    By
    Ninefold Ninefold March 2024 in Technical Help (nuts n bolts)
  • Looking for a digital scale
    It's not a digital one, but if you don't find one perfectly fitting what you're looking for, HerYun shared a scale on Deviantart and there is a morph to change the weight:
    https://www.deviantart.com/heryun/art/Daz-Freebie-BathRoom-Scales-923869765
    By
    Elor Elor March 2024 in Product Suggestions
    Since it's an issue with a particular piece of content rather than the Daz Studio application it is better in Technical Help, to which i have moved it.
    That looks as if there is a morph chnaging the eye shape which lacks, or has lost, the corrective morph that fires when the eyes are closed and the morph is applied. That may be an issue with one of the shapes you have applied, or it may be that you have exported a figure with multiple morphs applied and imported as a new morph, to back them to a single property, which breaks all kinds of adjustments and is therefore not recommended.
    By
    Richard Haseltine Richard Haseltine March 2024 in Technical Help (nuts n bolts)
  • The older generation: Victoria 2/3, Michael 2/3 and their children renders
    Thanks Richard, I've misunderstand, I've understand that has possible load V3 morph, in a Genesis whit V3 morph. Thank you the same.
    By
    Crios Crios March 2024 in Art Studio
    If you're talking about GenX2 to transfer the character shape to Genesis, then all I can say is that I have failed utterly with every attempt. The converted character looks vaguely reminiscent of the V3 character, but that's the best I can say for it. Regards, Richard.
    By
    richardandtracy richardandtracy March 2024 in Art Studio
    Not too sure what you are asking? It's possible to load all the Generation 3 characters into a TriAx version of V3 with Morph Loader Advanced or Morph Loader Pro via Obj files, and they appear as morphs. Doing this V3 can morph into M3, GV3, GND2, A3, IV, GV3, H3, F3, SP3 and She Freak 3 and any other Generation 3 Unimesh character with ease. However, morphs included only in the separate GV3 CR2 file also get cluttered up with the GV3 shape when trying to make something like 'Breasts AA Cup' work with vanilla V3. So, if you dial in 'Slender' and 'Breasts AA Cup', the GV3 body morph is applied once with the slender morph, and a second time with the AA Cup morph, and things go a bit weird. Regards, Richard.
    By
  • Celebrity Look-a-Likes for 3D figures Part 4
    Madame Nightley by johnnyk2005 at RenderHub - Kiera Knightley
    By
    Haruchai Haruchai March 2024 in The Commons
    Bt is possible transfer morph from V3 to a Genesis V3 character? Without Gen or similar software?
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
