Fiddling with Iray skin settings...
Iris size is adjustable so that shouldn't be a factor in the discussion... unless someone were to do a replacement eye and not include that morph. In fact any replacement eye would need to have all of the morphs that the eye already has including things like cat eye pupils. Even if the eyeball is hyper realistic it still needs to be usable with fantasy type figures since they are rendered in Iray as well.
Zone Smoother for Genesis 3 Female Male(s) and Female(s) [Commercial] **PRE-RELEASE UPDATE :)one great plus is the possibility to remove a once created morph everytime with just two or three clicks. My biggest concern was that I will have a bunch of morphs one day that I do not need, but with the possibility to overwrite or delete once created morphs this is a really big plus.
As written above, this product worth the money.
Zone Smoother for Genesis 3 Female Male(s) and Female(s) [Commercial] **PRE-RELEASE UPDATE :)Hi,,, I serched this product topic,, because I actually content with product much,,(it was right decision for me,,, to get this product ,,)
and,, I hope to imporve (or up-date) this product too (version up!) ^^
I usually simply export current shape,, and modify it in other modelor,, then return ds as temp corrective morph for current scene only, this product is helpful for the purpose too,, when I can not content the final morph produced by this tool,I use low value smooth,,,, then export the smoothed mesh (if I need more adjustment) ,, it make my work easy.
then,, my request is,,,, now this product work well,,about each main nodes area mesh with bending,, (or each nodes zone?)
but,,, I hope to set smooth zone, more narrow area too,,, eg,, Now when I try to smooth Things and plevis,, ,,this product is good to smooth between joint area,,and it seems work well for abdomen ,,but it tends to shirink all Thighs too ,,, (so some how,, Thighs become clear thin.then if I keep low smooth,, the problem area not turn so smooth,,^^;)
though it may be best,, if I can manage zone, by somehow,, weight map,, or tool colored circle,(like default D-former weit,, or smooth selection,, like other app,,) but,, as substitue,, if zone smoother 2 (I expect it ) can set zone,, for, each nodes half area,, eg (upper Thingh , lower Thigh) it can be more useful tool I believe..
maybe it cause some problem or make distortion gap,, when smooth more narrow area only,, but I feel,, user can adjust the effect,,(eg,, 1,, I set smooth for all Thigh part,, then make morph,, return value zero,, 2. set smooth for only upper part,, then make morph2, user can make new morph with tchange hese 2 morph value,,, easy,,)
ANyway thank you offer good smart tool(and simple easy use) ,, ,please keep version up-date this product,,,(of course I buy it again, when up-daed but hope,,, vonus price ^^;,, I really feel this tool is useful when pose for genesis3female actors now.
Thanks for checking it out, kitakoredaz! I agree, it would be cool to be able to change the size of the zone. I'm not honestly sure if that's something I could implement (the tool works with predefined zones, which is one of the reasons it's figure-specific), but I will deifnitely investigate and see what's possible
.oh yes, a zone size value (slider) would be cool
Rigitdiy Map / GroupsA Rigidity group won't help with that - Rigidity Groups come into play only when DS is generating a morph in a fitted item to match a morph in the figure, where the fitted item doesn't already have a morph of that name. What you need to do is edit the weight maps so that the weight across the solid item is constant, not varying, and perhaps then add some correction morphs to move the solid item in or out to avoid poke-through.
Eyes, Teeth, and face bones problemI don't own those morph resource kits, so I can't test them. I think you should submit a help request describing your problem. Attach screenshots or renders showing your problem. It is best if you can list s step by step procedure to reproduce your problem. You can find the link to submit a help request on the Daz Store web page. Click in the Help menu. Then select Contact Us and then Submit a Help Request. Here is a direct link: https://helpdaz.zendesk.com/hc/en-us/requests/new
Eyes, Teeth, and face bones problemI'm using genesis 3 female base figure and I'm using Genesis 3 Female Body Morph Resource Kit - Genesis 3 Female Head Morph Resource Kit - Genesis 3 Female Head Morphs - Genesis 3 Female Body Morphs I mean, they seem to work together a part from the fact, that the inside stuff . . doesn't :-) Thanks.
Sorry abot the double post :-(
The Last Hiro not working at all in Daz 4.9!Are there moph dials in the parameters tab? select the character, go to parameters, then under 'model name'->Actor are different types of morphs like Full body, Real world, Head, upper, etc. Check those and see if your Last Hiro morph is in there. If it is, dial it up.
I can't remember exactly but I want to think that some injections didn't actually apply the morph, just "install" the morph dial for the character.
Eyes, Teeth, and face bones problemIf you have eyes protruding, it may be a bug in one of the morphs you are using. I recently had a problem with eyes protruding on Genesis 2 Male when I applied the Gabriel for Teen Jared 6 morph. It turned out that was a bug and Daz updated the product after I wrote a bug report.
I see you are using Genesis 3 Female. Can you give an example of a specific morph that causes the problem? Then other people who own that product can try it and see if they get the same result.
Eyes, Teeth, and face bones problemWhich base figure and what morph packs?
Tutorial: Converting Textures from Gen2 to Gen3Re:Transfering the anatomical elements, there is now a very useful freebie available over at Rendo: Torso UVs for G3F Anatomical Elements, by Cayman Studios. This allows you to project the G3F torso texture onto the gens, so once you have baked your torso texture to G3F, it is possible to just use the new UV on the gens, or to bake from the new UV to the default in Blender. As has been said, the internal details may still require some manual adjusting, but I find this a very simplified and cleaner way to transfer the textures.
.Zone Smoother for Genesis 3 Female Male(s) and Female(s) [Commercial] **PRE-RELEASE UPDATE :)Hi,,, I serched this product topic,, because I actually content with product much,,(it was right decision for me,,, to get this product ,,)
Shape Shift for Genesis 3 (Commercial)/Users/Shared/My DAZ 3D Library/data/DAZ 3D/Genesis/Base/Morphs/Zev0/Vascularity HD is an sset folder containing files that load with the figure, it isn't a user folder you should see in the content panes. It adds morphs to the figure that you use directly by djusting the sliders.
I understand that - I was just confirming that the files were installed in the correct location where the README said they should be - which is why I am left wondering why the morphs are not showing up in DAZ since they were installed correctly, esp. given gthe fact that the "Zero X Veins" morph removal files appear where they are supposed to in the Content Library.
Just to check: you are loading Genesis 1, not Genesis 2 or 3?
The Last Hiro not working at all in Daz 4.9!Dearest,
does anybody own and use 'The Last Hiro' ( http://www.daz3d.com/the-last-hiro , SKU:3265 ) in Daz 4.9? It does not do anyhting on my side when I use it with Hiro 3.
The Hiro 3 face and body don't morph at all when I click on The Last Hiro injections / morphs . The beard variations do actually show up on the Hiro 3 Figure./....but that is all... :(
Anyone with the same issue ?kind regards
Peter
Eyes, Teeth, and face bones problemHi there. I wonder if anybody can help me. It seems to me that when you change face shape, mouth and so on, with the morphs tools that you can buy at the store, it is likely to encounter problems with the positioning of the items inside the .. skull. I mean, eyes and teeth protruding and the rest. I'm trying to make a new "person" from a genesis 3 female. There is any way to automatically put them in their correct position fitting properly the morph changes?
Or it has to be done manually? Hope not :-( Thanks.
Reverse Deformation by ScriptI'm wondering now if there is some way to execute Morph Loader Pro silently.
I'd be interested in being able to do this via script, too.
- Greg
Started working on adding my files from Daz to DSAiko 4 like the other generation 4 characters (Victoria 4, Michael 4, Kids 4, etc...) uses a morph system that can't be installed through Connect. They install through DIM or manual install. Something about how they have to have all morphs in the same runtime to work properly...
Are we going to get the Creature Creator morphs for Genesis 3?I was disappointed with the Genesis 2 versions, too many of the heads had the mouth partially open. I used GenX to transfer the original Genesis version (mostly successfully) so I am impatiently waiting for GenX3.
