DELETE
I can agree with a lot of the sentiment in this thread. I just did a count up and I have 63 Genesis 8 pro bundles and a lot of Genesis 3 pro bundles that I got free when I first came back to Daz after a long break. I think I've bought two pro bundles in the past five months.
I do have to wonder though what it is like for someone coming new to Daz - they could build a small library of core figures, clothing and hair from a huge choice of pro bundle content, a lot of it often on sale. Perhaps part of the reason that I don't buy a lot of content lately is that when I start building a scene and realise that I need something, I can search through content that I bought years ago for Michael 3, Victoria 3, Victoria 4 etc and then adapt it with iray shaders to look good enough for a one-use still image render.
Right now, I can't see what Daz can add to a Genesis 9 figure to make me want to buy it, given the existing technology within Daz Studio - it really would have to be a massive leap forward. But, when they do eventually start a new Genesis series, I plan to buy a couple of core bundles and then be much more selective in what I buy after that - likely adding just a few PA figures to the mix instead of the core Daz figures.
What the heck is Tafi?Thanks - not for me. Curmudgeon that I am, I've been on-line since 1983 and I've avoided real-time interaction the entire time.
If it is well modded and a non-toxic community, it can be absolutely wonderful.
Agreed, wish I could spend more time in there than i do.
It's funny seeing some of the reactions to VR (virtual reality) in this thread and to be honest, it sounds like me to a point before i got my headset last year. Since then my Steam game library has increased to over a hundred games, I don't play any non VR games any more and I get into VR almost daily (I am typing this right now in my virtual beach room).
I truly wish DAZ would get involved more into VR other than avatars for VRchat. I already use DAZ models in other VR apps (which is amazing working with lifesize victoria), but would love a VR option for DS.
i just preordered a new HP Reverb G2 and if it lives up to the hype, it will be a game changer for me.
July, 2020 - Daz 3D New User Challenge - Portrait Rendering and LIEUpdate for my Beginner's Challenge
Victoria the 1st
Shortened her hair on the right side to eliminate (I hope!) clipping... gonna be a busy week, so I suspect this is my "final" entry... but i'm still interested in advice, comments, and critiques.
~ Andy
Shortening the hair really changes her look. It is softening and eliminating some of the shadows. It isn't always easy to deal with hair clipping.
Thank you very much for your comments, Kismet2012...
Not that I'll have the time (or skill) to do anything about it, but do you have any suggestions on how do deal with the issue? I played around a bit trying to move her hair without shortening - but those still had clipping issues except moving the hair back, which totally changed the look and practically eliminated the shadows all together...maybe move/mess/add/change the lighting? Right now there's just the HDRI (stock) and a single spot, coming from her right and above...
~ Andy
Hair can be tricky and I can understand you not wanting to lose the shadows the hair created on her face.
A deformer might have moved those strands just enough to prevent the clipping. A push modifier might work. No one tool seems to work in every instance. Sometimes, if you have the time and patience, you have to experiment with different things to see what might work in any given situation.
"Blade Runner's" Rachael head INJ files. See page 3. Face texture added.Need a good laugh? Watch me trying to fix eyes lol ...
1. We did succeed in making a new .cr2 to load the original plus the new morphs, so that is doable.
2. The Rachael morph needs a little more work about the eyes and eyelashes. {I'm seriously not good with those lashes}
@ mic685_ddf880de57 When you can get the eyes, lashes fixed and also applied on the Rachael figure ... if you send the mass over to Hexagon, rename it to Victoria 4.2 then ship it back over to a Fresh Load of Victoria 4.2 - make the morph. Then run the script again but this time make it to have a new name. Hopefully that is how we can get all the morphs together.
HD Add On VS Normal Mapping Brawl!It certainly will not kill your GPU, it will run at the same clocks and temps as it always does when you run Iray. So play around as much as you like. I monitor my temps with with software like MSI Afterburner, which I also use to control the GPU fans. I have it set so my fans kick in harder and quicker in order to keep my temperatures down. I always advise users to do track their temps when using Iray or gaming. Morphs that are not HD will not show any additional detail when dialing up subD. Dialing up subdivision increases the mesh density, that is all it does. So if imagine for a moment a ball, and this ball is made of 100 polygons, it is going to look blocky. If you increase subdivision, it will increase exponentially. The first step up will be minor but still visibly smoother. The next one will have a lot more density and look quite smooth. If you have carved details in the ball, it depends on what subdivision you sculpted them at. To sculpt a fine detail like a vein you need the subdivision to be high enough to do it. It is almost impossible to sculpt details like that on a base mesh. So if you do not use any HD morphs, you will not see much improvement beyond subdivision 2. It might make edges smoother at higher resolutions, but not increase fine detail very much. The HD morphs can only replace their respective normal map. Like Victoria 8's HD is made for her, so you will not need Victoria 8 normal maps in conjunction with her HD. Beyond that, you are mixing and matching things, and results will vary. That is the more fun part of Daz, the models are very modular and you can mix and match whatever you want to your heart's content. So the only way to know how things will turn put is to experiment a bit with what you want to do. It is going to depend a lot on your render resolution and how close to the camera your model is. If you are not in a close up, odds are that you do not need EITHER normals nor HD.Genesis 3 Female example and improvement discussionGenesis 3 Female example and improvement discussionCelani 8Post-Apocalyptic is an okay theme, but it's not one that I do. Not in the Mad Max sense, anyway.
The outfits for Celani 8 seem more tantasy/post-apoc. I guess the sci-fi wrasslin was only a temporary thing, and now we're headed back into fantasy-land?
Just thinking back to Genesis 3. Victoria 7 came with a little more daring Post-Apoc outfit (oh no, human skin, the horror), and Gia 7 did the Walking Dead Michonne outfit with the Wall Ranger. Celani 8 is deifnitely not in the same apocalypse as the Wall Ranger, IMO.
If I were more into this theme, maybe I'd be more interested. It's just a lot to buy for only a few things I'd end up using.
DIM Installers missing tags - are you missing content?Part 2
Product Name Product ID
M3 Sci-Fi Outfit 1541
M4 Enhanced / Mina for M4 8371
Magic Falls DS 2318
Make It FUZZY!!! 20704
Makoa for Kimo 7 32201
Man Down Man Down 9070
Marauders 13312
Martial Arts Hand Pose For Genesis 2 Male M6 Set 1 27562
Meara for V5 16327
Medieval Hall and Garden DS 32467
Medieval Matt & Maddie DS 4644
Medieval Storage Room 22265
Mediterranean Passageway 37561
Men of Action for David 2679
Merlin's Oak, Plants and Props Set DS 17817
Michael 1.0 Map 76
Michael 2.0 Character Pack 1 516
Michael 2.0 Character Pack 2 524
Michael 2.0 Morphing Clothing Pack 1 & 2 687
Michael 2.0 Reduced Resolution Figure 880
Michael 2.0 Texture Maps (high res) 121
Michael 2.0 Texture Maps (standard res) 391
Michael Clothing Pack 1 211
Michael Clothing Pack 2 210
Michael Fantasy Maps 80
Michael Football Gear 863
Michael Suit Coat Pack 599
Michael's Conforming Long Hair 575
Michael's Face Morphs & Textures 704
Michael's Morphing Trenchcoat 641
Michael's Wedge Cut Hairstyle 163
Michiko for Aiko 3.0 2877
Millennium Baby 561
Millennium Beard for Michael 2 799
Millennium Boys Clothing Pack 122
Millennium Dragon Animations 815
Millennium Girls Anime Hair 459
Millennium Girls Clothing Pack 1 369
Millennium Girls Clothing Pack 1 Mappak 371
Millennium Girls' Morphing Clothing Pack 1 372
Millennium Horse Unicorn 2122
Miriam for V4 7575
Mishka Hair G2 30603
Mitsu Hair for Genesis 13521
Mixamo Animation Sampler Pack for M4 and V4.2 11443
Moler Hive Berserker Warrior 3650
Monstrosity Weapons 16300
MoochTail_Basic 3583
MoochTail_Extra 3597
Morphing Boot Pack 628
Morphing Rocks And Formations DS 20778
Multi-Sword Pack 877
Musculature HD Morphs for Genesis 3 Female(s) 22745
Musculature HD Morphs for Genesis 3 Male(s) 23916
My Best Friend 15357
MyLilAlien 3058
Mystical Touch DS 12923
Nadia 17758
Nadia V4 Ps 17758
Nagase Hiro 4 8537
naiar ar' edana character pack 1813
naiar ar' edana clothing pack 1806
naiar ar' edana texture pack 1808
Nana Hair 5653
Natalie 7870
Native Cheyenne Village DS 10848
Natural Curls 5420
Nature - Forest Flowers DS 20386
Navarre DS 8332
Nazar 12902
NeanderMan Action 15052
Need a Lift - Poses for M4 and V4 10826
Neo Station DS 5893
Neoclassical Gown and Robe Accessories 9148
Neoclassical Gown and Robe DS 9148
Nerd3D Soggy Bottom 9827
Nerd3D Thunder River DS 9497
Neve for Genesis 16309
Neve for V4 10193
Neve for Victoria 4 16309
New Groove DS 11238
Niara for Victoria 5 14086
Nick 12331
Nifty Poses for David 5 and Gianni 6 16387
Nigel for Genesis 13308
Nigel for M4 13308
Nigel for M5 DS 4.5 14966
Night Guardians 13628
Night World Lone Wolf Michael 3 5794
Night World Lone Wolf Michael 3 StudioCF 5794
Nighthawk for V4 11932
NightHawkTextureExp 12289
NightHeart Outfit Textures 17334
NightOut for NightLife V4 12466
Nimos Thorns- DS version 11313
Nindo for Mei Lin 7 30809
Nine to Five 4993
NinjaSuit 1058
Now-Crowd Billboards - Medieval City Life (01of16) 50397
Now-Crowd Billboards - Medieval City Life (02of16) 50397
Now-Crowd Billboards - Medieval City Life (03of16) 50397
Now-Crowd Billboards - Medieval City Life (04of16) 50397
Now-Crowd Billboards - Medieval City Life (05of16) 50397
Now-Crowd Billboards - Medieval City Life (06of16) 50397
Now-Crowd Billboards - Medieval City Life (07of16) 50397
Now-Crowd Billboards - Medieval City Life (08of16) 50397
Now-Crowd Billboards - Medieval City Life (09of16) 50397
Now-Crowd Billboards - Medieval City Life (10of16) 50397
Now-Crowd Billboards - Medieval City Life (11of16) 50397
Now-Crowd Billboards - Medieval City Life (12of16) 50397
Now-Crowd Billboards - Medieval City Life (13of16) 50397
Now-Crowd Billboards - Medieval City Life (14of16) 50397
Now-Crowd Billboards - Medieval City Life (15of16) 50397
Now-Crowd Billboards - Medieval City Life (16of16) 50397
NRH Vulcan DS 9546
Nybras 3866
Nyoko Pigtail Hair 2874
Nyssa 16408
Ogre 229
Ola 29220
Old West Undertakers Ps 8236
Old World Knight for Genesis 2 Males 23252
Oneiros DS 8949
Opus Magnum DS 13631
Oriental Seasons 4555
Outland Marauder for Genesis 13559
Outlander for Michael 5004
Outlander for Michael 688
Outlander for Michael Texture Pack 5003
Outlander for Michael Texture Pack 689
Outlander for Victoria & Stephanie Texture Pack 5001
Outlander for Victoria & Stephanie Texture Pack 701
Padded Armor for David 4681
Paper Dress for Genesis 2 Female(s) 20676
Paradise Pavilion Texture Bundle 1213
Pharos Fantasy for V4 DS 4833
Pharos Fantasy for V4 Ps 4833
Pheobe for V3 4335
Phoebe for Aiko 5224
Phoebe for Aiko 805
Picaro for Michael 4 DS 8294
Picnic Area Exterior 38667
Pier View Ps 5744
Piggy Bank 618
Pirate Pack 630
Pirate Pack for M3 1529
Places Of Summer DS 5784
Planetarium DS 11717
Pocket Filler 9453
Pocket Filler StudioCF 9453
Police Accessories Pack 446
PoseMaster for DAZ Studio 13968
Precious Petals for Morphing Face Masks 2285
Precious Petals for Morphing Face Masks 5045
Prep Gear Textures 15437
Preschooler Ultra Bodysuits 3105
Props Pack - Fantasy Banquet Set 28644
PS-Tia 28169
Queens Court 2 DS 5385
Queens Court 3 DS 5386
R.O.1 4456
Rag-Erator for DAZ Studio 10541
Ragnarok 27369
Rain Tool 6931
Ranch Pavilion 35503
Rays of Dreams for Enchanted Forest 12130
RDNA Egyptine Bast Statues 28307
RDNA Egyptine Peacock Feather Fans 28300
RDNA Mushrooms Vol 3 28460
RDNA Mushroomz SmClusters and Rings 2 28380
Real Curls 759
Real Emotions for M4 8022
Real Emotions for Michael 3 1620
Real Emotions for Victoria 3 1523
Real Emotions For Victoria 4 4845
Real Fur for DAZ Big Cat 2 17843
Red Fox by AM DS 21745
Red Sands Temple DS 14043
Regency for M4 Expansion DS StudioCF 10159
Regency for M4 Expansion Ps 10159
Robot 244
Rock Demon 15894
Rodent Base by AM 38537
Rolf 27366
Roman Tunic for Genesis 14937
Ronin for Genesis 13694
Ronin for M4 Ps 13694
Rowan 7748
Royal Eastern - The Asian Dragon 19471
Rust Icator for DAZ Studio 10550
Ryuu International Genesis 13693
Sacred Barge DS 4201
Santa for David 3891
Santa Hair and Beard 3903
Santa's Elf 272
Sci Fi Quantum 3000 977
Sci-fi Outpost DS 21151
Scuba Gear 314
Sensation for Hiro 3200
Sentinels Texture Pack 1 for the Gargoyle Hound 1344
Seraphnia Dark Elf for V4 6924
SGM Explorer DS 3805
Shadow Dancer for Victoria 3 4303
Shadow Kin for Michael 5 and Genesis 14412
Shape Presets for Genesis 2 Male(s) 20794
Short Curls Hairstyle 598
Short Style Cut 165
Simple Living - Fireplace 20712
Skate Clothing Pack 737
Skating Snowman 3896
Skin Builder Basic for Genesis and Genesis 2 Female(s) 18900
Smoking Room Poses 10982
Smoking Room Poses StudioCF 10982
Smugglers Keep StudioCF 9573
Songbird ReMix: Corvus Corvus 16223
Sosie V4V5 13771
Space Dweller V4 Unimesh Fits 11437
Space Dweller V4 Unimesh Fits StudioCF 11437
Spanish Rose Jardin de Sevilla DS 3580
Spanish Tack for the Millennium Horse 3549
Sports Pack 48
Spring Garden DS 4112
Springy 23615
Spuggles Special Edition 23065
SS Hooded Cloak MAP Pack Vol. 1 1331
SS Marcoor Corridor 2 Addon DS 21400
Stalker Girl Pants for Genesis 14680
Steamworks Interior Ps 3778
Stefan for Genesis 14111
Stefan for M4 14111
Stephanie 531
Stephanie African American Maps (high res) 619
Stephanie African American Maps (standard res) 620
Stephanie Texture Maps (high res) 592
Stephanie Texture Maps (standard res) 593
Stolz 15498
Stolz Michael 4 Ps 15498
Stolz the Younger for Genesis 15503
Stolz the Younger for M4 15503
Stormguards 1159
Storybook Dragon 212
Storybook Dragon Poses 420
Strike Long Hair 3801
Style Magic for Ultimate Changing Ponytail 2458
Stylized Business Man & Woman 125
Summertime Grill 14716
Superhero Training Gear 13016
SY Christmas Lights 20672
T-Shirt Dress for Genesis 17700
Table Props 29
Tanky 20660
Tanya for V3 4314
Teahouse Treasures 1989
Tech Staves 15888
Technophilia Arcane: Quantum Eye 28645
Temple Ruins 1812
Texture Map - Knight 128
The Alchemist's Apothecary 2155
The Artemesia Gown for Genesis 2 Female(s) 20833
The Bearded Lady 38699
The Bedchamber DS 37365
The Bridge Collection 16572
The Conservatory Ps 18047
The Darkness 2358
The Drop Box DS 17047
The Duelist for David 2689
The Dungeon Gallows 15493
The Forest Whispers DS 13477
The FREAK 4 Weapons Ps 9111
The Gargantual 16335
The Graveyard 2717
The Heart of the Matter DS 12996
The Hidden Waterfalls DS 11362
The Igigi 15986
The Legendary Griffin 3491
The Master for Wolf King PoserCF 15919
The Old Waterhole DS 10497
The Pit 18548
The Pit - Iray Edition 18548
The Rattler 1060
The Ray Sled 3488
The Ray Sled 4988
The RHS Stagecoach DS 5783
The Round Table 2078
The Rulers of Egypt 746
The Sorceress Ps 9388
The Sorceress StudioCF 9388
The Spray Tool DS 8597
The Steamboat Machine Legacy 3732
The Steamboat Machine Ps 3732
The Tavern of Mog Ruith DS 7934
The Tomb 1528
The Village 1 - Houses 27276
The Water Fall Tool DS 9482
The Whispering Wall 2540
Thomas for M4 Ps 15001
Thomas for M5 15001
Tiny Tim 3943
Tommasina for V3 3842
ToolGirl 10157
Toon Furniture 17712
Totally Bazaar 1 14447
Totally Bazaar 2 14449
Toy Soldier and Train Set 4861
Tra La La Hair for Genesis 3 Female(s) 31701
Trey for M4 9414
Tribal Trogs 1790
Troubadour for Genesis 2 Male(s) 22292
Troubadour Textures 22293
Tru Ceremonial 3527
Tudor Living 2 DS 48731
Tudor Living 2 Ps 48731
Tulip Garden DS 4174
Twister TT Ps 10350
Ultimate Morphing* Hi-Res Millennium Cube 1287
UltraGenesis: Expressive 30702
ULTRAGENESIS: Faces of G 30713
Urban Fae for V4 12208
Urban Fae for V4 StudioCF 12208
Urban Fae V4 Unimesh Fits 12209
Urban Fae V4 Unimesh Fits StudioCF 12209
V3 Bikini 1110
V3 Fantasy Collar Set 1274
V3 Male Clothing Pack 1454
V4 Buccaneer 8465
V4 Buccaneer StudioCF 8465
V4 Creature Wings 9771
V4 Male Millennium Ultimate Madness Fit Bundle Pak 6602
Vega for V3 4336
VI Circus - Decoder 25691
Vicki's Gel Cut 155
Vicki's Subdividing Material Poses: Hosiery & Gloves 705
Victoria 2.0 Character Pack 1 8
Victoria 2.0 Character Pack 2 9
Victoria 2.0 Fantasy Sci-Fi Uniform & Mappak 1070
Victoria 2.0 Fantasy Wrap 188
Victoria 2.0 Light Texture Maps (high res) 95
Victoria 2.0 Light Texture Maps (standard res) 98
Victoria 2.0 Medium Texture Maps (high res) 96
Victoria 2.0 Medium Texture Maps (standard res) 97
Victoria 2.0 Morph-Mapped Fantasy Wrap 477
Victoria 2.0 Morphing Clothing Pack 1 169
Victoria 2.0 Reduced Resolution Figure 659
Victoria 4 for Genesis 2 Female 16559
Victoria 7 Attitude Expressions 22162
Victoria and Michael Sweaters 189
Victoria Clothing Pack 1 168
Victoria Gladiator 180
Victoria Stephanies Morphing Trenchcoat 695
Victoria Suit Coat Pack 698
Victoria Up-Do 152
Victoria's Changing Ponytail Collection 734
Victoria's Changing Ponytail Expansion Maps/Poses 706
Victoria's Changing Ponytail Expansion Pack 730
Victoria's Layered Flip Hairstyle 154
Viking Longship 27365
Viking Male Hair for Genesis and Genesis 2 Males 19280
Vintage Boy 10251
Warrior DL DS 11132
Water Spring DS 33097
Waves on the Beach DS 7400
Wedding Day DS 5808
Wheely 17880
Whispering Wall -Amplified- 2541
White Tiger for DAZ Big Cat 2 18043
Willow Creek 38095
Wolf 2.0 by AM 23354
Wood Chipper 9439
Wooden Rocking Horse 3893
Woodland Props - Tree Trunk and Ivy 2125
World of Fantasy V4 Poses 7598
Wound Makeup Artist 3Delight for Genesis 3 Female(s) 32745
Wyvern Inactive 1598
Young Teens Morph Pack 2768
Young Teens Ultra Bodysuits 2772
Youthful Diversity 3084
Yukimi (Stone Lantern) DS 9567
Yuletide Joy Ornaments 35531
Zac Hair for Gen4 14287
Zavia Red Martian Princess for V4 7473
Zebra 340
Zed Hair 8684
Zen 1809
Zena V4 7325
Zendal DS 9659
Zenia for Victoria 4 5303
Zere for Vittorio 4 7332
Zoey for Victoria 5 13512
Zombie for Genesis 15100
Zombie for Michael 4 15100
Zuri for Genesis 3 Female 36199
Zweihanders DS 22218DIM Installers missing tags - are you missing content?Yes, I reported a bunch of these, but they generally won't fix them unless there's something else they're updating. Here's my current list:
Part 1
'Demon Dogs' for the Gargoyle Hound 1347
'Millennium Woman' Victoria 1 85
18 Shirt Styles for David`s Clothingpack 5034
3 Piece Suit for David 3219
3 Story Craftsman Home 6839
A2Z for Victoria 2.0 88
Abigail for Genesis 13287
Abigail for V4 13287
Above the Clouds for 3Delight: Stratocumulus 24471
Abraxas 5279
Abraxas StudioCF 5279
Action Poses for Genesis 15322
Actual Hair 2 V4 17509
Actual Hair Genesis 14917
Ad Gladio for Genesis 17688
Additional Blood Layers for Genesis 3 Male(s) 28219
Addy for V4.2 6526
Addy for V4.2 StudioCF 6526
African Blades for Genesis 3 and 8 Male(s) and Female(s) DS 32985
Age of Warriors - Celt 1 for Genesis 16794
Age of Warriors - Celt 2 for Genesis 17520
Agony Poses and Expressions for Genesis 14087
AH 1SS Cobra StudioCF 9179
Aiko (Anime/Manga Character) 673
Alcarine DS 7923
Alchemy II 8823
Alien Dogs - Morphs and Textures 3400
Alisha for Genesis 14493
Alisha for V4 14493
AMS RT05 DS 4484
Analeigh for Genesis 13277
Analeigh for V4 S4 13277
Ancient Trees DS 4642
Anders hair for David 3885
Angel Of Death 28796
Angel of Retribution for Genesis 2 Female(s) 20873
Anime 101 4638
Antique Clocks DS 44857
Antique Furniture Pack Historical Maps 33
Aoife Hair 2 16505
Ape World 2590
Architecture Pack 27
Arctic Fox DS 21744
aredhel ar' tariena character pack 1811
aredhel ar' tariena clothing pack 1805
aredhel ar' tariena texture pack 1807
ArtemisX Expansion Pack 3121
Artificial Christmas Tree n' Poses 20790
Arvid for Lockwood 10007
Awesome Eyes Genesis 3 Female 22610
Axes of Power 11923
Azrea & Sylph for A3 4310
Azrea&Sylph for V3 4337
Baby for Genesis 14065
Backpack 468
Balloons 10984
Balneae DS 32927
Barbarian Clothing Pack for Victoria 184
Barstool 565
Basketry DS 53731
Bast for Victoria 4 30718
Battle Bundle - Vikings 27838
Battle Pack 1 631
Bear 358
Beautiful Styles for Girl`s Resorts Collection 5032
Belly Control For Genesis 2 Males 17841
Beloved Poses 1.5 23317
Birkitta V3 7548
Bits 'n Pieces - Dogtags and Chain free material settings 30458
Bits 'n Pieces - Necklace and Pendants free material settings 30483
Bits n Pieces - The Sealring for Michael 4 30584
Black Panthers for DAZ Big Cat 2 17822
Board Of Souls 28858
Body Board DS 739
Bone Smasher 9651
Bounty Hunter for Victoria 90
Braided Hair 27368
Breakfast Nook Furniture 44193
Breaking the house 9606
Brow Remover for Daz Studio 34387
Bucket List 16848
Bugle 63
Butcher Block and Knife Set DS 9438
C-Elegance Jewelry 20649
Camel 325
Camel Map 326
Camel Saddle & Bridle 49
Camera Magic: SketchCam Basic 17776
Camera Magic: ToonCam Basic 17782
Cannon 686
Cannon Accessory Pack Ps 3448
Canoes 23155
Castle Interior 35601
Cat Character (w/ poseable nails) 92
Catoblepas 8292
Celtic Great Hall DS 4332
Celtic Great Hall Interior DS 4407
Chain Mail Fantasies for V3/SP 2219
Chain Mail Tunic 2095
Charming Affair 6232
Cherub 3899
Chest 494
Cheyenne for M4 10654
Cheyenne for M4 StudioCF 10654
Cheyenne M4 Unimesh Fits 10656
Cheyenne M4 Unimesh Fits StudioCF 10656
Children of Aten DS 4833
Chinese Blades for Genesis 3 and 8 Male(s) and Female(s) DS 34831
Chionee for V3 6989
Chip Dynamic Ghost 26369
Chip Dynamic Halloween Outfit 27451
Chip Dynamic Skeleton 26368
Christmas Foot Stool 23628
Christmas for Something Wicked 23697
Clock 455
Clockwork Familiar 11139
Clogs for Genesis 2 Female(s) 20737
Clothing Cleavage Modifier 13973
Colors Viking Male Hair 19281
Columbian Mammoth 12066
Combat Pack 461
Controllable Dynamic Cloak for DAZ Studio 13613
Cookie Dynamic Ghost 26372
Cookie Dynamic Pumpkin Dress 26370
Corrected V4 UV for Genesis 16504
Corset Hat DS 23538
Corsetted 12007
Corvena 16237
CorvenaV4 16237
Cottage Tree House 6906
Cowboy For M4 and Hiro 8648
Cowboy For M4 and Hiro StudioCF 8648
CP - Winter Circlet 23683
Creature Creation Pack 39
Cuban Diabolo for Genesis 13311
Cy-Tex for Cy-Girl 2616
Cy-Tex for Cy-Girl 5031
Cyclorama Gardenland Backgrounds DS 941
DA Bar Stool 23582
DA Festive Tree 20674
Daedalus Peasant A3 DS 3983
Dane for M4 8463
Dane for M4 StudioCF 8463
Darcassian Rocket Bike 26468
Dark Haven 2497
Dark Lord 8065
Dark Matter For V4/A4 7639
Dark Matter For V4/A4 StudioCF 7639
Dark Storm Sword 22662
Dark Temple Light Set for DAZ Studio 10572
David 3 for Genesis 13239
David Clothing Pack 2255
David Millennium Beard 2402
David Santa Suit 2705
David Ultra Bodysuit 2345
David Universal Texture Maps (High Res) 2253
David Universal Texture Maps (Standard Res) 2254
Deadly Beauty DS 3423
Deadly Daggers for Genesis 3 and 8 Male(s) 32737
Decor Basics - Floor Vases 22589
Default Resources for DAZ Studio 4.9+ 13176
Denver Hair 13283
DG IBL Light 20770
DG Metal Overlay Shader Presets 17833
DH Breakfast Nook Rug DS 5272
DH Foyer Living Room DS 5419
Dial-an-Elf 20705
Dierdre Character Pack 397
Digital Tourist - Ta Prohm 1971
Disconsolation DS 10820
DM Amarcord 1640
DM's Queen's Chamber DS 17719
DNA The Dragonessa for Victoria 2 29375
Double Dare for MeriMay Dress 23684
Dragon Ballista 6642
Dragon Head Battering Ram 7567
Dragon Hoard & Sacrificial Altar 1226
Dragon Hunt Weapons 37219
Dragon Lord Horse Armor 4011
Dragon Master Poses for Dragon 3 and Crystal Dragon 45305
Dragon Mortar StudioCF 6508
Dragon Throne 2712
Dragonstone Fortress Lookout Towers 19697
Drakkar Crew Action 20722
Drako for Ivan 7 32417
Drop Jewelry 20786
Dungeon Lighting Kit 1155
Dynamic American Flag 10944
Dynamic Fantasy Robe 12127
Easter Island Head 66
Easy Environments: ExoPlanet V Ps 60067
EM - Aspen Billboards And Forests 31471
Emperor's New Clothes 18709
Epic Heroine Poses for Genesis 3 Females 35895
Epic Shields for Genesis 3 Male(s) 23308
Equestrian Props 15304
Eustoma 3813
Eustoma-ExpansionsPack1 3814
Expressions for Ivan 7 and Genesis 3 Male(s) 32473
Extension Ladder 291
Eye Maps: Generation 4 5117
Eye Maps: Generation 4 StudioCF 5117
FaeMate: Redhead 2494
Faerie 253
Faery Tales for V3 and Laura 4098
Fan and Reticule Set 20723
Fantasy Camp 12522
Fantasy Camp StudioCF 12522
Fantasy Castle Corridor 32607
Fantasy DragonFly 4057
Fantasy Fort DS 19201
Fantasy Guard Tower 32469
Fantasy Hall 36333
Fantasy Room Interior 35409
Fantasy Scene 34777
Fantasy Separates Vol 3 10284
Fantasy Shapes for Genesis 12847
Fantasy Texture Pack for The NinjaSuit 1243
Fantasy Throne Room 45351
Fantasy Tower Hallway 24018
Fantasy Weapons Collection 2 18238
Fantasy Weapons Collection 2 Gen4 Ps 18238
Flight Attendant Outfit 204
Flight of the Swan Ps 3851
Flirty Hair for Genesis 3 Females 24182
Flower Child 3869
Fly Away Hair 1896
FM Fight Club Boxing Shoes 14566
Fober's The Lake Ps 10076
Fober's The Lake StudioCF 10076
Fog Tool Deluxe III 4095
Foliage Pack 1 19850
Frankenstein Character (for Michael) 406
Freaky Horns for Minotaur 6 Horns 20803
Free Stand 27099
Frostbite 8525
FTC Darktale Castle DS 3161
Furry Friends Mouse Garb 1996
Future Law Textures 9409
Future Quiet DS 14182
FW Yasmin 16310
FW Yasmin V4 Ps 16310
FWKJ Lien HD for Mei Lin 7 31717
FWMA Brogan 16859
FWMA Brogan V4 Ps 16859
FWSA Soft Light Probes 23751
FWSA Stacia for Victoria 6 20783
G4 Hooded Cloak 8965
G4 Hooded Cloak StudioCF 8965
Gabriel for Michael 4 14411
Gabriel for Michael 5 14411
Gabriel Hair 11038
Gabriella for V5 14153
Galaxy for Genesis 14194
Galloping Action 15367
Garbage Cans 12238
Garden Escape Arbor 9985
Garden Escape Arbor Gate 10130
Garden Escape Bridge 10148
Garden Escape Patio Furniture 11178
Garden Escape Pergola 12318
Garden Escape Planters 13225
Garden Escape Porch 10089
Garden Escape Well 13114
Garden Furniture 9991
Garden Pavilion 12998
Garden Pond 2697
Gargoyle 2662
Gargoyle Hound DS 1328
Gargoyle Hound Poses 5411
Gas Can 61
Gateway DS 9431
Gathering Moss DS Shader 14069
Gatwyck Bundle DS 17420
Gatwyck Houses DS 17295
Gatwyck Marketplace DS 14663
Gatwyck Shops DS 17208
Gem for V5 13722
General Troll Chronicles 6081
Generation poses 12937
Genesis 2 Starter Essentials 3DPrint GeoGraft Female 16280
Genesis 2 Starter Essentials Female 16280
Genesis 2 Starter Essentials Male 16280
Genesis 3 Starter Essentials Female 21630
Genesis 8 Female PowerPose Templates 42071
Genesis 8 Female Starter Essentials 42071
Genesis 8 Male PowerPose Templates 42071
Genesis Boys of Atlanticca 28884
Genesis Bracers 13366
Genesis Expressions and Face aniBlocks 13419
Genesis Eyebrows 13029
Genesis Rage Outfit 1542
Genesis Rage Outfit 5244
Genesis Timeless Fantasy Textures 13673
Genesis Womens Business Wear Textures 13539
Genesis: Shape of a Figure 14223
Geni Tank Top for Genesis 26472
Get Emotional Expressions for V4 10748
Get Real David 5608
Ghost 1085
Ghost Agent for Michael 4 and Hiro 4 8623
Ghost Agent for Michael 4 and Hiro 4 StudioCF 8623
Ghostly Alien for RDNA Greyling 26377
Ghoul Poses for Creature Creator Genesis 2 20148
Gia Hair - Genesis 13406
Gia Hair - Genesis 2 Female 13406
Gia Hair V4 13406
Giantology 15828
Giants Poses 1 1801
Gillian 10847
GIS Link DS 11365
GIS Nova DS 10995
GIS Orion Poses 12530
GIS Poses 14676
GIS Series Lights Bundle 12228
GIS Sigma DS 14084
GIS Skyway DS 13068
GIS Terminal DS 11253
GIS Terminal StudioCF 11253
Gladiator Arena Action 11589
Gladiator Sandals for V4 4793
Glitter for Morphing Mask DS 1275
Gloria Short Hairstyle 7283
Glorious Goth 2593
Glorious Goth 5248
Glyn Hair 7833
Good as Dead 3068
Good vs. Evil Adventurers Mappak 392
Gothic Construction Kit 380
Gothic Ruins 381
GreekFantasy 6894
Gregoria Hair for Genesis 14556
Gregoria Hair for V4 14556
Ground Shaders for DAZ Studio Part 1 21468
Ground Shaders for DAZ Studio Part 2 21468
Growing Up for Genesis 3 Female(s) 23720
Growing Up for Genesis 3 Male(s) 23983
Growing Up Skin Merchant Resource for Genesis 3 Female(s) 24373
Growing Up Skin Merchant Resource for Genesis 3 Female(s) Adult Add-on 24374
Growing Up Skin Merchant Resource for Genesis 3 Male(s) 24375
Growing Up Skin Merchant Resource for Genesis 3 Male(s) Adult Add-on 24376
Guineveres Bower DS 2211
Gwenbleiz HD and Beard for Michael 7 34801
Gwennili HD for Victoria 7 36303
Gypsies & Genies 957
Gypsy Couture Package 1 952
Hadley for V4 8495
Hag Character (for Victoria 2.0) 91
Hair Care Products 9854
Hair Conversion System II for Victoria 4 7903
Hall of Lore-Naz 1929
Handcuffs 289
Handy Dandy 17126
Hardcore 4750
Hardcore M4 9738
Hardcore Textures 9893
Hatchling Dragon DS 433
Haunted Depths DS 3917
Haunted Mansion DS 2699
Haunted Mansion Poses DS 11509
Hawaiian Tatau 14446
Herne 26626
Hibiscus Garden DS 4307
Hidden Places 6804
Hidden Waterfall Pool DS 46331
High Drama One 16824
High Drama Three 17197
High Drama Two 17049
High Elf Defenders DS 7246
High Elves: Riders of the Sun 5043
High Elves: Warriors of the Forest for M3 5042
High Fantasy Props 1962
Highland Wilderness 13682
Highlander: Wildenlander for Genesis 13681
Highlanders DS 8196
Hip Hop Outfit for M3 5245
Hip Hop Outfit for M3 1663
Hiro 3.0 3226
Hiro 3.0 Ultra Bodysuit 3242
Hiro 4 Pro Bundle Poses Expressions 8586
Hiro 4 Realistic Textures 8531
Hiro 4 Starter Pack Poses Expressions 8585
Hiro Hair 3206
Hiro Sci Fi Suits 3244
Hiro's Anime Poses 3235
Hiro's Anime Poses 5005
His EarStuff 17710
Historical Armor for V4 6266
Historical Curls 14278
Hither and Thither DS 10731
HMS Victory 5442
HMS Victory StudioCF 5442
Holding On Drama 10797
Holiday Accessories 13708
Holiday Decorations 3900
Holiday Hot Tubbing 23425
Holiday Joy for Aiko 19 7060
HOMME 3 for M4 8057
Homo Erectus K4 13609
Homo Erectus V4 13606
Hooded Cloak for Genesis 14009
Hoops 19604
Hope Gear 3207
Horatio for Genesis 14502
Horatio for M4 14502
Horlamin DS 10207
Horse Poses Bundle 7272
Horseback Combat 3455
Horses of Courses 2129
Hosta Garden DS 4334
Hot Tub DS 4289
Hot Tub Pergola DS 11911
Hothead: A V3 Fantasy Hairstyle 1256
House of Mog Ruith - Interior DS 3986
House of Mog Ruith DS 3941
Huang Ze DS 9280
Hunter DL Plus DS 10827
Hunter DL Poses DS 11330
Hunter for David 3 3259
Hunter Gear for Genesis 3 Male(s) 34805
Hunters Moon DS 4623
Hydra 875
Hypergenetic Bio Armor 5963
i13 Heated Debate Poses and Expressions 24397
Ibrahim for Genesis M5 15947
Ibrahim for Michael 4 Ps 15947
IG Iray Essentials - Aiko 6 23639
IG Iray Essentials - Darius 6 23649
IG Iray Essentials - Gia 6 23640
IG Iray Essentials - Gianni 6 23650
IG Iray Essentials - Girl 6 23641
IG Iray Essentials - Giselle 6 23642
IG Iray Essentials - Lee 6 23651
IG Iray Essentials - Lilith 6 23643
IG Iray Essentials - Mei Lin 6 23645
IG Iray Essentials - Monique 6 23646
IG Iray Essentials - Olympia 6 23647
IG Iray Essentials - Stephanie 6 23648
IGD_Valborg 27370
InaneGlory's Votive Candle 20755
Indoor Shoes 20572
Intense G3F 29299
Into The Woods 10406
Intrepid Explorer Phoenix DS 21576
Ishtar for V4 30434
Islander Action Gen 4 14910
Islander Action Genesis 14910
Iyeyasu's Tomb Ps 5645
Jack of Hearts for Genesis 15985
Jennifer for V4.2 6331
Jennifer for V4.2 StudioCF 6331
Jepe's Body Jewels 3 for Daz Studio 31449
Jepe's DragonFire 6628
Jepe's SteamZ 3884
Jeweled Finery 13219
Jinchuu Ken (Sword of Vengeance) for M3 2019
Kai Outfit 2878
Karate Suit for Michael and Victoria 172
Kasha for A3 4311
Key Chain 9416
Kids 4 UVs for Genesis 2 Male(s) and Female(s) 20692
Kieran 6175
Kieran StudioCF 6175
Knight 127
Knight's Monument for The Tomb 7023
Knight's Monument for The Tomb StudioCF 7023
Kung-Fu Clothes for M3 1753
La Plume 2428
Lands of the Sun DS 4730
Lani for A4 V4 7111
LB Fantasy Unicorns 2121
Le Village Pharmacy 7665
Le Village Road Pack 7685
Le Village Tree Pack 7691
Le Village Bistrot 7642
Le Village Book Store 7651
Le Village Church StudioCF 7648
Le Village Wine Store StudioCF 7664
Leg Lamp Iray 23637
Legendary for Outlander 10021
Leilana for V4 6630
Leisure Pants for Genesis 2 Male(s) 20605
LIE Wound Makeup Artist 14589
Light n' Go - Dark Corner of the Dungeon 12088
Light n' Go - Temple Ruins 11829
Light n' Go - Tree House 11828
Lil' Costume Shoppe 457
Limousine Prince DS 14628
Lisa's Botanicals - A Curious Proliferation DS 10408
Lisa's Botanicals - Autumn Excursion DS 11048
Lisa's Botanicals - Blood & Pitch 3382
Lisa's Botanicals - Briar Rose 3275
Lisa's Botanicals - Cinnamon Fern DS 7390
Lisa's Botanicals - Climbing Vines DS 3140
Lisa's Botanicals - Cottage Plants I DS 8456
Lisa's Botanicals - Creepier Trees DS 9896
Lisa's Botanicals - Creepy Trees 2707
Lisa's Botanicals - Creepy Trees II 4622
Lisa's Botanicals - Creepy Trees II StudioCF 4622
Lisa's Botanicals - Creepy Trees Textures 2732
Lisa's Botanicals - Curious Grass and Vines DS 10752
Lisa's Botanicals - Dead Bushes DS 4639
Lisa's Botanicals - Elephant Grass DS 11279
Lisa's Botanicals - Forest Jewels 4433
Lisa's Botanicals - Forest Jewels StudioCF 4433
Lisa's Botanicals - Hibiscus DS 4306
Lisa's Botanicals - Honeysuckle 3424
Lisa's Botanicals - Hosta DS 4316
Lisa's Botanicals - Jungle Mist 2657
Lisa's Botanicals - Mighty Oak 3620
Lisa's Botanicals - Mighty Oak StudioCF 3620
Lisa's Botanicals - Pansy 7208
Lisa's Botanicals - Pansy Parade 7211
Lisa's Botanicals - Pansy Parade StudioCF 7211
Lisa's Botanicals - Pansy StudioCF 7208
Lisa's Botanicals - Pond Life Plants 2913
Lisa's Botanicals - Potted Palm DS 9788
Lisa's Botanicals - Ravens Rest DS 8038
Lisa's Botanicals - Signs of Spring DS 4111
Lisa's Botanicals - Tropicals DS 4860
Lisa's Botanicals - Tulips DS 4172
Lisa's Botanicals - Wisteria 3404
Lisas Botanicals Beanstalk DS 3585
Lisas Botanicals Coleus DS 5544
Lisas Botanicals Indian Grass DS 4664
Lisas Botanicals Ivy Textures for Vines DS 3157
Lisas Botanicals Tropicals II DS 5491
Livia for Genesis 15000
Livia for Victoria 4 Ps 15000
Lollipop Lovely 2490
Look At Me Eyes DS 13710
Lord of Battles for M4 and Hiro 4 8547
Lucifuge's Grave 13603
Lucky Charms for Millennium Girls & Faery Wings Deluxe 999
Lumina Hair MATs 20872
LY Brynn 18864
LY Kennedy Genesis 18328
LY Kennedy Victoria 4 Ps 18328
LY Peppermint Cheer Make-Up 23516
LY Waverly 17530
LY Waverly V4 Ps 17530"Scooby" Daphne outfitHere's a front and profile render of my current Daphne WIP:
I punted on the shoes and put some sneakers on her for now. I've had no luck finding suitable shoes that'll match the source art that'll fit G3F without issues...
As promised, here's the morphs and character packs that you may need and my settings for my current take on Daphne:
- https://www.daz3d.com/fwsa-finley-hd-for-victoria-7-and-her-jewelry
- https://www.daz3d.com/victoria-7
- https://www.daz3d.com/teen-josie-7 (*not absolutely needed)
- https://www.daz3d.com/genesis-3-female-head-morphs
- https://www.daz3d.com/genesis-3-female-body-morphs
- https://www.daz3d.com/200-plus-head-face-morphs-for-genesis-3-female-s
- https://www.daz3d.com/genesis-3-female-body-morph-resource-kit-2
- https://www.daz3d.com/genesis-3-female-body-morph-resource-kit-4
- https://www.daz3d.com/sf-anime-character-builder
- https://www.daz3d.com/aiko-7-head-morph-resource-kit-1
- https://www.daz3d.com/growing-up-for-genesis-3-female-s
My morph pack list is pretty extensive, but you may be able to 'make do' with other morphs if you don't have one or more of the morphs listed below. FWSA Finley and Victoria 7 are pretty much essential, though...
This should give you a decent starting point, and you are of course free to make your own adjustments. I'm sure that others may be able to improve on this formula - Please share with the class if you are so inclined!
I used Finley's skin textures as well, so it's probably easiest to just load Finley and then start dialing/adjusting from there.
- Finley Head 100%
- Victoria 7 Head 0% (Dial her out)
- Finley Body 100%
- Victoria 7 Body: 50% (may need to adjust this dial to 50%)
- Teen Josie 7 Slim (Face, Body) 100% (this one is optional)
- Nipples: 0% (zero them out if they aren't already, otherwise you may notice them standing at attention underneath the dress...)
- Youth Weight: -25%
- Youth Shape Narrow: 100%
- Face Angle: -10%
- Face Flat: -25%
- Face Center Depth: 25%
- Face Middle Depth: 50%
- Face Lower Depth: -50%
- Face Depth: -50%
- Eyes Width: -25%
- Eyes Iris Size: -75%
- Eyes Height: -25%
- Eyes Angled: 50%
- Eyes Angle: 1.00
- Eyes Lower Middle A: 75%
- Eyes Lower Middle B: 50%
- Eyes Lower inner: 100%
- Chin Width: 25%
- Nose Tip Depth: 25%
- Nose Size: -25%
- Nose Height: -25%
- Nose Depth: -25%
- Nose Bridge Slope: 50%
- Nose Angle Up: 10%
- Mouth Height: -25%
- Cheek Shape young: -50%
- Head Width Narrow: 100%
- Cranium Size Larger: 50% (makes hair at the top back part of the head more prominent)
- Anime Character Eye round 01 Stylized: 25%
- Anime Character Face Stylized: 25%
- Waist Hourglass: 50%
- Figure Hourglass: 25%
- Hip Size: 5%
- Thighs Size: 10%
- Calves Size: 10%
- Ribcage Shape: 100%
Note that some morph dials control other morph dials, so if you see 'extra' values, this shouldn't be a problem. Just make sure the ones listed above are set to the right values once you are done.
It might not hurt to do an Edit > Figure > Rigging > Adjust Rigging To Shape... when you are done.
I think that's it. As for skin adjustments (all of them, plus the lips)...
Translucency Weight 0.15
Translucency Color: 0.65 - 0.00 - 0.00
SSS Reflectance Tint 1.00 - 0.93 - 0.87
Again, adjust to taste!
For the face makeup, I swapped out the default 'Base Color' map with FACEMU09_1001.jpg for the purple eye shadow. Note that if you don't assign this manually, you'll need to go back and change the translucency color, weight, and reflectance tint again, hence why I suggest assigning this manually. You could also change the Translucency Weight, Color, and Reflectance for the Skin and Lips after you've picked your makeup and lip options...
For the lips, I went with FWSAFinleyFaceLips02-10001.jpg (base) and FSWAFinleyFaceLipsSSS_1001.jpg for the Translucency map. Use whichever ones you like of course!
For the eye color, I went with FWSAFinleyEyes03_1007.jpg (purple color)
Again, consider this a baseline. Feel free to adjust to taste! Also, as I noted above, if you are missing a few of these morphs, there may be other morphs in your collection that might get you to where you want to go with the face and body shape, if the results aren't quite where you want them...
Best of luck to y'all! Happy morphing!
Show us your Blender Renders@andya There's definitely something odd in your blender settings then. I see a strange "black" skin in your render. I mean Victoria 8 is what we used for testing the volumetric skin together with other characters and they all look good with the default settings. You just have to let the plugin update for minimal requirements. It may be that we overlooked something though.
What blender version are you using ? The plugin is tested with the 2.83 stable release. Also can you please make a render with cycles and full global illumination settings ? This will check if the issue is in the render settings.
Another useful test would be if someone else can check Victoria 8 with diffeo. She works fine for me and the others at diffeomorphic.
https://bitbucket.org/Diffeomorphic/import_daz/issues/24/i-believe-i-nailed-v8-aka-true-iray-skins
@Padone, thanks for the suggestions.
I don't want to hijack this thread to discussing how to improve the results I get using a fresh download of Blender (2.83.3, portable zip) and leaving the settings as provided (N.B. 'full global illumination' is not selected). I am certain there are many ways to improve them, for both plugins, and enabling the full global illumination light path preset is very likely one such way). Instead, my intention was to share the results obtained in Blender with the bare minimum of user input. I think one advantage of Iray in Daz Studio is that you can often get a pretty good render with the standard settings. Now that Daz has released the 'official' Blender bridge, some people may think of trying Blender for the first time. As Blender newcomers, they may well not make any changes to the default settings initially, whereas you or I would. So I was interested to see what results they might get in that case.
If there are particular settings required to get the best results from either plugin, I believe they should be clearly documented as necessary, or enforced by the plugin itself. (The Daz Importer does not enforce the selection of full global illumination for me, and I don't see it mentioned in the docs but perhaps I missed it.)
To stay somewhat on topic, here is a Blender render - the result of 5 minutes updating the materials on Victoria 8 from the Daz Importer, face/lips/ears only (full global illumination not selected, rendered in 21 seconds to 100 samples).
Genesis 8 Female example and improvement discussionThe Ultimate Super-Hero Freebie List!Just spotted Miss Fury for V3 here: https://sharecg.com/v/96108/view/11/Poser/miss-Fury-for-victoria-3
"Scooby" Daphne outfitOOPS............hit the wrong button, didn't mean to post that so I'll finish the thaught.............
"OK, I have tried dialing all manner of combinations, and I cannot nail down the Daphne look. She seems to have a fairly simple face but getting her to look right in 3D just might be impossible. Tj I'm not having any luck replicating what you did either...........*sigh.
No worries! I wasn't very happy with my 'stand in' so I took a more serious stab at Daphne. What do you think of this one?
She's based on FWSA Finley for Victoria 7, with some additional morphs. I was trying to keep the angled eyes without her looking Asian, if that makes sense...
If you like this version, let me know and I can post up my morph dial settings. I have a number of different morph kits in my collection, so hopefully you have some/most of them...
Also, I used the mesh grabber tool to adjust the hair so some of it draped over the head band better, while pushing in other parts of the hair underneath the headband, in an attempt to clean up the headband area so that I wouldn't need to do a lot of post work/edit out a bunch of strands that were poking thru the headband. I didn't do any post work to this image, other than to apply the gradient background behind the render after resizing the image and adding my sig.
super
GENERAL FREEBIE REQUESTS part 3Other than the cybernetic implant over at Rendo which requires Victoria 4.2 Boydsuit Expansion, are there any sci-fi/android/Borg occular/cybernetic implant freebies?
I might buy Jennica next Lyoness sale because her one looks great, but in case there's an alternative that can save me some pennies (I love pennies)
https://www.renderosity.com/mod/freestuff/borg-implant/77544
https://www.sharecg.com/v/37915/browse/11/Poser/M4-Eyepiece
Edit To Add: This is currently on sale in Fast Grab: https://www.daz3d.com/borg-for-genesis-8-female-s
Thanks, Charlie!!
Scooby-Doo characters?Finley for Victoria 7 is now added to my wishlist, considering the second attempt looks very close to that of the cartoon counterpart.
HD Add On VS Normal Mapping Brawl!Saving them as png will loose information; they are enormous because of all the information they contain. How much it will matter (if at all) will vary between rendered images.
Compared side by side at 100% in Photoshop? Yes. In an actual render? Not likely. I'm super anal when it comes to image fidelity and I've never noticed a difference.
On a separate note, I took a look at Babina 8's normals and they seem much smaller in file size than other normal .tifs that I remember...I wonder if they are now compressing their .tifs. (Yeah, they have to be because Victoria 7's normal .tifs are 48mb compared to Babaina 8's at ~3mb...so what I said above would only apply to uncompressed .tifs.)
Scooby-Doo characters?That idea of yours looks very close to what Daphne should look like. I may consider this idea when I have some extra money. I already do have the Lollipop Hair, so the hairband is taken care of. I do have a scarf, but it was a bigger one and it was a freebie on another site.
So all I really need is Ruby, The Girl 7, Aiko 7, the Layered Fringe hair, and the Super dress and leggings. I may already have restaurant server shoes, as I believe I have a waitress uniform in my inventory, unless it's an underestimation.
So now that we got Daphne taken care of, all we need is to find out how to do Shaggy and Fred and even Scooby.
I wasn't all that happy with my previous attempt, so I gave it another go, using FSWA Finley for Victoria 7 along with some other morph tweaking:
This looks a bit closer to the cartoon art IMHO, for the face (body is a bit wider ATM). What do you think?
Star Trek Builders Unite 8: THE REBOOTI'm having a devil of a time figuring out how to use any of these - seems they all require figures that are only available for purchse? I can't seem to find any that will work with only the free content you get with Daz. Paid content is a non-starter for me as I have no income at the moment thanks to all this crap going on. I'm not trying to do animation or anything, I just need a variety of characters in TMP and/or TWOK uniforms in a couple of different natural poses (walking, standing at a console, standing and talking, etc.) to populate still set renders like the one attached (which was made in Blender). The reference image I used in creating the attached render shows some good examples of what I mean. I'd greatly appreciate any help anyone could provide.
I was about to call you out on lifting pictures from seanr on scifi-meshes to use for your own nefarious purposes...lol. I enjoyed your bridge renders back in the early 2000s, and am glad to see you're back at work! Daz just released a free (at the moment--I'd grab it immediately) Daz-Blender bridge that might be of interest to you, in terms of rendering Poser/Daz figures within blender itself. I use both, but personally prefer Daz for figure work, given how it was designed for that purpose in particular. If you go to the first page of this thread, there is a compliation of free Trek stuff for Poser/Daz. If you're looking for a TWOK uniform to match that set you're working on, that's where I'd start looking. The best TNG-era stuff I've found is by nvent3d on Rendo, in my opnion, but it's not free. There are still some uniforms to be found on sharecg that mostly make use of Valiant and Courageous, which are outfits for the old Victoria 4 and Michael 4 figures. Those outfits can be used on the newer Genesis figures with auto-fit and figure clone techniques. As for poses, the free Genesis figures come with basic poses that can be used for getting started. You just need to install the "essential" packages for Genesis, Genesis 2, etc. For free or nearly-free stuff, that's where I'd start.
