• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • How to change the way a texture is applied on a prop / surface ?
    richardandtracy said:
    One way may be to set the "Horizontal Tiles" in the cover material to -1 and then adjust the "Horizontal Offset' to line it up properly.
    I didn't know it was possible and doing solve the problem nicely: I played a bit with the offset to get a sligthly better look on the spine of each book, but the geometry is not compatible with the front cover being visible with this trick.
    But your suggestion made me 'remember' the -100% scale trick and it solve the problem at the price of reversing everything on the desk. I said 'remember' because when I loaded the desk preset I created (just two days ago… blush) after extracting all props from the "Desk item" I saw that I did use the -100% X Scale trick on the two books but didn't think of using it on the "Desk item" itself.
    crosswind said:
    I even didn't notice this issue before...
    Did you see that the lamp is a second away from falling on the floor, with its third feet not placed on the table ? angel
    Less visible, the leg of the photo stand is something like a couple of millimeters (to be fair, I only saw this when I was moving the lamp in Hexagon to create a morph fixing its position, so I created a morph for the photo stand in the process but I don't know if I'm allowed to share them).
    And on the wall with the painting, for a reason I don't understand, there is a layer of glass a couple of centimers away from the wall (maybe it's supposed to be the glass over the painting ? but from what I can see, the whole wall is covered).
    I like the product, but some decisions during its creation are a bit strange: why are the desk and the props on it merged when the shelf and the props on it are not ?
    As Richard said, you just set -1 to Horizontal Tiles on the surface of "desk_Book_B" of the Desk prop, but the book is still "flipped". To flip it... if you own Mesh Grabber, firstly select the "desk_Book_B" surface with Geometry Editor, swith to Mesh Grabber, with Normal orientation, zero Falloff Radius, then rotate and translate the book to the right position.
    I have Mesh Grabber, but didn't think of using it like you suggested.
    If you don't have Mesh Grabber, you also can "cut" the book surface from Desk with Geometry Editor, export / import it as a single book Prop...then rotate and translate it. However, making it with the prop "FE Book_D" will be much easier.
    I spent an hour listening to a podcast to extract every prop from the desk to create a preset for each of themblush Well, almost every prop to be honest: I didn't get as far as getting the pen in the three glass holders as independant props but I modified the magnifier to get a lens made of glass, added surfaces here and there. I also did the same with the wall and windows item, to get an independant ceiling and backdrop from the former and an independant painting and window from the latter.
    Regarding this process, do you know if there is a (hopefully easy) way to remove the baked rotations and translations and get these props at world center in a more neutral position ?
    crosswind said:
    As for the "photo issue", it results from its UV layout. If you check the UV layout, you'll find where the photo should be (in ss1). Then you use that layout to place your photo in the right place with an Image Editor (ss2). Save it as a PNG file with transparent background. Then add it to the Base Color slot with Layered Image editor. (ss3)... Finally set Horizontal Tiles and Vertical Tiles to 1.
    Or directly use another photo stand Prop... cool
    I don't think I have another photo stand prop like that, but after creating a surface for the photo in Daz Studio, I fumbled my way through Hexagon and I was able to change the UV map of that surface in Hexagon to at least remove the rotation (as best as I can) smiley
    I still had to play with the tilling and the ofsets to get the whole photo centered on the surface but I suppose it's fixable somewhere in the UV map (and one day I'll learn how to do it), but it does look good enough right now:
    By
    Elor Elor May 2024 in Technical Help (nuts n bolts)
  • No more "Young adult" shapes available for core figures...why???
    ...I've been creating younger characters since the Gen4 days (before K4).
    When Genesis came out with the first young adults (Young Teens 5 and later Josie) it made the workflow a little easier but to this day I still tend to favour creating custom characters and have a vast library of character shapes and morph utilities which make turning a full adult into a younger one far easier than with ol' VIcky 4.
    By
    kyoto kid kyoto kid May 2024 in The Commons
  • everyday clothes that drape nicely over pregnant G9?
    Actually, as long as the clothing product are not poorly-made, they all could well fit on a pregnant figure with proper settings / simulations. The trick is always "tweaking".
    Like the Olivine dress you mentioned, if go for static simulation with its default settings on a pregnant figure, you won't get good result. But if we use a timeline to make the pregnant morph(s) change from 0 to 100, make better settings on the dynamic surface of the dress, as well as adjust the weight on the dForce modifier weight node that the vendor originally made. We may get much better draping result, as the attached ss.
    So try these tricks... you can make every garment well fit on a pregnant character...
    By
    crosswind crosswind May 2024 in Product Suggestions
  • Ext3nd Studio Presents: Goblinette for Genesis 2 Female.
    Great, will give me time to get the creature morphs so I can use the morph, which by the way I really like.
    By
    Faeryl Womyn Faeryl Womyn May 2024 in Freebies
  • Dear Alessandro, What About the Rabbit? (Answered, Yay!)
    Dear @Alessandro Mastronardi, I really really don't mean to be a pain, please don't feel pressured in any way! But I just have to ask: What about the wonderful rabbit you teased us with a while ago and rendered such cute pictures of? In the comments, you said it would be ready in a few weeks, but we haven't seen anything yet, sadly. Is it still alive, the poor thing?
    I also remember that maybe a year or even two ago, there also was a thread about your rabbit figure, and that it was basically done and ready for release back then, and you would give it to us soon. Soooooo ... I'd just like to know, is it still happening, are we gonna get the figure anytime in the near future? Or is the project cancelled or something? I would really love to have a realistic rabbit and/or hare, and in the thread as well as in the comments to the renders in gallery, many users expressed the same wish. So I thought it was very much worth asking.
    Even if you don't feel you want to release it as a full product for whatever reason, I would love to throw my money at it as an add-on, morph, or in any other way, shape or form!
    It would be lovely to hear from you on this.
    Respectfully - Tina
    Edit: I still can't figure out how to tag users with names with a space included, dang ... Hope it's still seen ...
    By
    tsroemi tsroemi May 2024 in The Commons
  • Can't apply material to specific Wardrobe items
    Chungdan explained (https://www.daz3d.com/forums/discussion/comment/5947171/#Comment_5947171) the need to load the Wearables to get the proper hierarchy. Hierarchical materials presets must absolutely follow the same structure as when they were saved, there is no way around it. You could save out individual material presets for each piece (after loading a full outfit).
    You can load "MBR All" or, under Wearables, "MRB Boots", "MRB Coat" and/or "MRB Dress", while Genesis 8 or 8.1 is selected in the scene. Everything will be properly parented and fit to the target figure, and Hierarchical Materials will apply properly to the whole outfit, or the individual items.
    If you want to try loading the individual pieces (MRB Smooth Morph Makers and the separate Wardrobe pieces) there is a slightly different workflow. Load the Smooth Morph Makers first, then for each one, add the corresponding Wardrobe item. They will initially look terrible, all wrinkly and distorted, but that can quickly be remedied.
    The thing is, the Wardrobe item is being fit to the Smooth Morph Maker, but should be fit to the figure (G8F or G8.1F). However, they should remain *parented* to the Smooth Morph Maker. Doesn't seem intuitive, but that's how it works, otherwise the Hierarchical Materials presets will not work.
    True, the individual parts are redundant if the Wearables set everything up properly, so just ignore them.
    By
    NorthOf45 NorthOf45 May 2024 in New Users
  • genesis 9 butt cheecks
    You might have better luck looking at Renderotica for more morph packs. Be aware though, that site is INCREDIBLY nsfw.
    By
    zombietaggerung zombietaggerung May 2024 in Art Studio
  • Diffeo - Problem with ERC and G9, both new and old method
    Hello,
    I'm importing G9 unbaked, load all the stuff, load the Nina9 head custom morph, yet the position of the eyes is wrong when i dial it in, with ERC in global settings set to translation (new method) and armature and then "morph armature" (old method).
    I think i narrowed the culprit down to the "proportion head size" morph not moving the eyes (note the difference between armature and eyes). The "proportion head size" morph seems to be part of the nina9 morph?!?
    I added the baked imported Nina to the image for reference. Any ideas?
    By
    dmnmf dmnmf May 2024 in Blender Discussion
  • Problem with custom morph (Hands)
    I have a problem with my custom morphs. It comes from the fact that the hands have been edited to fit my character better.
    My morph works fine otherwise, but the hands are a problem. I would really like to keep my custom hands. Is there any way I can fix this?
    Thank you in advice
    By
    omen.kris omen.kris May 2024 in Daz Studio Discussion
  • Genesis 9 female deform with most poses
    Did anyone have a solution for this. I'm having massive issues wth this right now, I think it must be a 3rd party morph problem but can work out which one is causing this issue. Obviously I can't show a screenshot of the area because of where it is but I have spent months building 100's of renders that I may be forced to through away if I can't figure out this issue as I'm moving onto the more adult scenes in my project. Can anyone point me in the direction of trouble shooting at least?
    By
    michaelpomar michaelpomar May 2024 in Technical Help (nuts n bolts)
  • Royal Eastern Dragon 2 [commercial]
    Thanks for the  new textures RawArt. I love it when PA's take customer suggestions to heart and create for us.
    Do you know if you will be adding a morph package for this dragon in particular, to make it more cute or the parade version I mentioned.
    By
    Faeryl Womyn Faeryl Womyn May 2024 in The Commons
  • morph loader pro options no longer selectable
    I have created a G9 morph with mesh grabber. I exported the base mesh with the deltas as an .obj file. Then I tried to use morph loader pro to load the mesh as a morph. It is necessary to select "reverse deformations" when loading it. But there is now no way that I can see to set that flag. "reverse deformations" is set to "no" and I cnnot change it to "yes." I could do that some time ago. Not now. How do I change the value of "reverse deformations" from "no" to "yes" In morph loader pro?
    I an using Daz Studio 4.22.0.1 Pro Edition (64bit) Public Build on a widows 10 box.
    It is maddening when something I used to do no longer works. Am I making a mistake somewhere?
    By
    lamoid_5f20d3e469 lamoid_5f20d3e469 May 2024 in Technical Help (nuts n bolts)
  • Can't select or Deselect items in an environment
    Apparently, I had managed to delete unwanted items from the scene.
    Today, I wanted to work and do the render, to my bad luck, the figure components are gone crying, I used Face Transfer 2, because this kind of render is for a family member.
    I want to give a surprise with the polished result.
    Now I have to go back to the drawing board and work my way from zero to hero.
    Is there a way, to permanently save my work and use it again without any loss?
    I need to to get it done by today if possible, I will be packing a present later and include the finished artwork.
    I am going to use another environment I bought from the store, the other looked nice, but I need more room, also I am setting the image to about 6000 px if I increase more this will take more time to render, the idea is a crisp image output without sacrifying the quality. I am waiting for your reply, thanks!
    By
    Halcon Bluesky Halcon Bluesky May 2024 in New Users
    I wonder if "young adult" could be achieved by blending a small amount of teen in with the adult morph
    By
    Deecey Deecey May 2024 in The Commons
  • Coming soon: Mesh Grabber 4.0 [Commercial]
    carrie58 said:
    ManFriday said:
    Elor said:
    What was shown looks useful smiley
    A couple of questions:
    • Will the tools added by the current version addons be included with Mesh Grabber 4 or will the addons still be required ?
    • Are the changes created with the new version compatible with the current version ? I'm asking because I currently only have Mesh Grabber for Mac but I'm also using a Windows machine and I'm thinking about buying the new version for Windows initially, to get Mesh Grabber here too (right now, I'm using the saving morphs function to get the changes to the Windows machine).
    The add-ons are going away. There will be only one Mesh Grabber product any more. It will include both the Mac and the Windows versions. (The only reason that they were separate is that when I made the original Mesh Grabber I didn't know how to make Mac plugins yet, so Mesh Grabber for Mac was added at a later time.)
    The changes are compatible. The data format hasn't changed. All the changes are in the "tool" part of Mesh Grabber (how the vertex deltas are created: there are now new ways like a sculpting brush), but they are still saved to scene files the old way. And the Daz Studio morph data format hasn't changed either, of course.
    So if I already have Mesh Grabber and the add-ons will this version replace it or work with it?
    Both. Mesh Grabber 4.0 will replace the old and include all its features and the add-ons, and all the new things.
    By
    ManFriday ManFriday May 2024 in Daz PA Commercial Products
  • Recently upgraded to windows 11 and now it is "writing assets" when I load a scene
    Old style .DAZ scene files explains a lot.
    When you created those scene files DS added DSO (mesh), DSD (morph) and DSV (UV mapping) files to the "data" folder, and the scene file will load those files rather than use the original files, so losing those "data" folder files means the scenes wont load.
    Late on in DS3's life they added a new system to the scene files, basically it recorded the original files pathway into the scene file, that way if you lost the "data" folder files then DS had a good chance to recreate them from the original files.
    We still use a similar system in DS4.5+ when your saving scenes/subsets that have non DSON content in them.
    And I suspect that is where your problem lies, DS is loading the .DAZ files and can't find the "data" folder files, so it's using the pathways to load the original files, problem is that DS4.0 was the last version of DS that created DSO, DSD and DSV files, so what's happening is DS is adding DSF files to the "data/auto_adapted" folder, which is where the writing assets is coming from.
    The good news is that by the sounds of things your laptop still has all of the "data" folder files you need, the bad news is you have to figure out which files need to be copied over to the other system.
    By
    Bejaymac Bejaymac May 2024 in Technical Help (nuts n bolts)
  • Is there a way to partially remove morphs from an item?
    I've been working on kitbashing together an ID badge, the kind you see at conferences and such.
    I loaded it into Daz as an OBJ, then used Transfer Utility to get it to play nicely with Genesis 8. So far, so good! When the figure poses, the necklace/ID badge pose with her!
    The downside is that the ID badge itself now deforms and bends like a flexible object, when in real life it would be the one part of the prop that remains rigid. Is there a way to select the badge itself through the Geometry Editor and change the properties just for that sub-mesh alone? Or would doing that cause the badge to behave independently from the rest of the prop when the figure moves (for example, the badge remaining in place or moving ten feet away when the figure bends over)?
    I've attached some screenshots to give you the basic idea.
    (1) Standard pose with badgefit to G8F figure
    (2) G8F figure reposed; the chain part follows nicely, as desired;
    (3) But the badge 'bends' and squishes as a result
    By
    Blando Calrissian Blando Calrissian May 2024 in Technical Help (nuts n bolts)
  • G8F/M Pose Transfer to G9
    As I said earlier, I am going to try to get G9-G8 working to keep G8 as 'current' as possible, but it's not going to be immediately. Regards, Richard.
    Hey @richardandtracy - resurrecting this post, did you ever get G9 -> G8F pose transfer working? I use your script for the other way around a lot, but I recently found poses for G9 that I'd love to use with G8F and I can't figure out how to do it easily myself.
    And if I didn't say thanks before, saying thanks again - this one and V4 -> G8F I use a lot!
    By
    perlk perlk May 2024 in Freebies
  • Celebrity Look-a-Likes for 3D figures Part 4
    The TV series being referred to is https://www.imdb.com/title/tt0078659/?ref_=nv_sr_srsg_5_tt_8_nm_0_q_monkey%20magic about https://en.wikipedia.org/wiki/Monkey_King there have been many adaptations over the years. The character morph in question is good. The "muck rake" is great. The attached is my monkey statue. In the Chinese zodiac I am a monkey. I also own the full DVD box set for the TV series in the above link.
    By
    druc druc May 2024 in The Commons
  • AIUTO...CHI CONOSCE L’ITALIANO? PARTE QUATTORDICI
    Grazie a tutti delle dritte, ragazzi, cercherò di farne tesoro.
    Non mi ricordavo delle luci emissive, in effetti mi sembrano una soluzione interessante, sperimenterò.
    @Crios Molto bello l'effetto di quei riflettori. Si potrebbe anche usare per la luna o il sole in certe condizioni, tipo con la nebbia. Mi hai dato una ottima suggestione.
    Kainjy said:
    1 - Per il colore di pelle ti consiglio di usare dei personaggi appositi.. ci sono in vendita molti personaggi di diverse gradazioni (ogni personaggio ha morph+materiali, a te serve solo i materiali). Per cui carichi il tuo G8 e poi applichi i soli materiali del personaggio comprato.
    Si può anche modificare manualmente.. ma visto che non hai esperienza la cosa si fa un po' particolare.. riassumendo: più hai la pelle chiara e più la luce tende a viaggiare all'interno del corpo (mostrando vene, ecc..). Più la pelle è scura e meno c'è questo effetto. Dunque non basta cambiare solo colore di pelle ma bisognerebbe anche "aggiustare" come la luce viene assorbita e riflessa (pelli grasse sono più riflettenti). Se ti compri un personaggio di colore (a spendere poco oviamente) vedrai come a parità di materiali i settaggi sono diversi.
    Nel pannello surface occhio a cosa selezioni.. ci sono diversi pezzi del corpo e i personaggi sono divisi in più parti (se ti si colora un occhio ha selezionato per sbaglio anche l'occhio)
    Wet & Tanned funziona coi G8.. dunque usa i G8 se vuoi usare il prodotto. Nella pagina dello store https://www.daz3d.com/wet-and-tanned-skins-for-genesis-8-females  trovi dei video in basso: guardali che ti spiegano come usarli.
    2 - Per la luce posta un'immagine così magari si capisce qualcosa in più... Comunque controlla che:
    a. la serratura sia trasparente (e dunque possa passare luce)
    b. la luce sia di adeguate dimensioni e collocata fuori dalla porta
    c. che tipo di ombre vuoi ? Luci piccole e distanti creano ombre nette, luci grandi e vicine creano ombre morbide.
    Sì, io uso praticamente solo i Genesis 8, ho strutturato tutto il parco dotazioni e personaggi su di loro.
    Controllerò i tutorial di Wet and Tanned allora, perché il pdf l'avevo guardato ma non ci avevo capito nulla.
    Allego invece un esempio di quel che intendevo sui personaggi "oscuri".
    La prima vignetta è semplicemente uno screen di come appariva in fase di montaggio. Notare che c'è una luce perfetta che le illumina il viso in linea con l'apertura della porta, luce che io NON ho messo (quello scenario/stanza ha una illuminazione sua che non è modificabile, o comunque non ci sono proprio luci nella board!).
    E' passato del tempo da quando ho creato quella scena a quando poi l'ho renderizzata. Quando ho riaperto quella scena e rimesso l'inquadratura sul personaggio, quella particolare luce tagliata era sparita, senza che io avessi toccato nulla. Da lì ho cominciato a cercare di ricrearla col poco che ne capisco, ma non c'è stato verso. Alla fine ho renderizzato piazzandole una pointlight da 15k di brillantezza direttamente sulla faccia, letteralmente nello spazio tra la porta e il viso, ma il risultato è poco più di una lumeggiatura sul naso.
    Con questo personaggio in particolare succede spesso che sia mal illuminato, e da lì avevo il dubbio da neofita che fosse colpa delle texture magari, o che ne so.
    By
    vangelrise vangelrise May 2024 in The Commons
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
