question that uses multiable slider for a character
"Multiple" is the word you are looking for in the title, LOL Most addon characters come with a slider for the full body and full head morph. You just slide that slider part of the way and slide another character slider a part of the way. Sometimes combining morphs gives you great results, sometimes not soo much.
Corrupted Base Figure (Genesis 2 Female)At some point, my brilliant phlying phingers did something that corrupted the Genesis 2 Female base figure. Instead of the 'normal' G2F figure, I have a G2F infused with the morphs for another figure (in this case, "Dionne" from most-digital-creations).
I can 'recover' the base figure by zeroing out the figure, or going into the shaping tab and setting all Dionne-morph dials to '0'.
Saving as a character preset doesn't "replace" the base figure so that next time I select the G2F figure, it's back to the corrupted figure again.
My thought is that I'll have to uninstall the Genesis 2 Starter Essentionals, re-download the package and install it again. (Un install from DIM; remove the associated files from my computer; download a fresh package from DAZ; reinstall with DIM).
Any ideas on an 'easier' way?
THanks!
Felix/FFDS
question about It's Magic outfit...So Rod is correct in that the morphs I have made are tailored to a specific outfit. If the edges do not line up then things may not look right. However, at Rod's insistence I am working on a more general package that might work on a wider array of items. Although this morph was made for the skirt this gives an idea of what can be done by making RealFit morphs for more than just bikinis.
Cheers!
pst....g2f :)
Outfit fit-to, but maintain shapeDoes the clothing line up with the zeroed figure when you import it, or was it modelled around a morph?
Thank you for you reply.
It was modeled around a morph, and your question actually started my brain thinking in a certain way and I was able to solve it myself.
Here's the full situation in case anyone in the future needs it:
The problem : I wanted to decimate an outfit so that a character could wear it in Unity3d. When decimating the outfit though, it lost it's shape. I read elsewhere on the forum that to do this well, you should decimate the model, then export as an fbx, then import the fbx and apply to the Genesis. However, the now decimated figure did not fit my G2f properly.
The solution : Load a part of the outfit from you library (in my case the corset), but without the figure to conform/fit it to (ie, just the outfit, not Genesis 2). Decimate the outfit, them export to fbx. Create a new scene, load up your Genesis 2 character without clothing. Now, import the fbx version outfit you created. Have this item of clothing 'fit-to' the Genesis figure. You should now have a decimated item of clothing that is fairly low res and fit your character perfectly. Repeat for as many items of clothing you need.
Clothing Creation Rigging Template for Genesis 3 Female(s)?I spotted a placeholder in the Readmes for this product, which I assume will be showing up soon. Anybody hear anything about this? I'm interested because I have had an absolutely miserably time with rigging clothing for Genesis 3.
Don't get me wrong, the Transfer Utility handles almost all of the heavy listing. But things like leotards and so on are proving to be an absolute nightmare. And if this template(s?) can make this any easier, than I can't wait to get my hands on it!
Question about subd and creating morphsThe process of making HD morphs is basically two steps
- make a geometry morph at subd zero to get the overall shape and proportions of the new character
this will be your base shape for sculpting- based on the base shape above, make a sculpt morph then save it as displacement map
Back in DS you will have to apply the base morph and the displacement map to get your new character
optionally you can use the bump map too for fine detailsJust Released: The Exile Alien HD for Genesis 3 Male [Commercial]Daywalker:
It comes down to the varying definition of 'seams'. There's the seam where the map is split but the mesh on both sides is the same surface. SP2 is fine painting across that.
SP2 just will not paint from one material to the next. You need to either be very careful painting on one and then the other side, or rely on procedural stuff (which is what I've been doing).
Josh Crockett:
Using the 'bake Normals from high -> low poly model,' the seams are perfect (at least on the intended morph). So A+ for SP2 there.
Otherwise, I've had decent results with masking based on World Normals, but poor results (across material seams) with other baked textures. Like the Redskin job I did, I used Dirt mask (which is based on World Normal baked textures) to capture the nooks and crannies, and it worked like a charm. Everything else looked terrible at the seams. C. ;)
morphs that show genesis 3 female ribsThanks for the reply!
I was hoping there was a morph pack that could give me that...
There is, but I'm not sure if it's a default one or which pack it's in. Look for one called Emaciated, as that's the only one I know that shows them.
[Just Released]- The Fallen One for Genesis 3 Male [Commercial]Your avatar, is that an existing figure for sale? Or a morph for your Exile figure?
Josh Crockett Suggestion Page for Monster Characters!Xeno makes a good point. It's a lot more work, but basically it'd be something like a series of morphs, so that you could shrink/expand different elements of the figure.
Yep. I am going to do that with one myself.
It's certainly something I've considered doing. I wouldn't want to step on Daz's toes with their morph packs and also most of my creatures are meant to be and designed as a full "character" with specific elements designed very specifically for that creature.
I get what you're saying, Josh, but the way DAZ does it is usually paired symetrical morphs rather than individual morphs that can be applied to varying degrees. That's how I am doing them for the "pretty boy" I posted an image a page back.
Product Updates: DIM Zips starting July 2013Updated April 16 2017
Tsukiko for Aiko 5 PoserCF 4/7/2013 no change Meara for V5 5/28/2013 corrected bad morph id Johan for M5 6/6/2013 updated mouth materials Johan for M5 PoserCF 6/6/2013 updated mouth materials Tsukiko for Aiko 5 6/27/2013 unknown Tropical Cave 7/13/2013 metadata update only Meara for V5 9/16/2013 updated head morph? Maki Outfit Looks 12/12/2013 replace product thumbnail Maki Outfit Looks PoserCF 12/12/2013 no change Dark Moon Textures 7/8/2014 corrected folder structure Dark Moon Textures PoserCF 7/8/2014 corrected folder structure DSF Toolbox (Win) 2/25/2015 version 1.31 bug fixes Victoria 7 Attitude Expressions 10/22/2015 updated naming and metadata Victoria 7 Attitude Expressions 10/22/2015 updated naming and metadata Victoria 7 Attitude Expressions 12/10/2015 updated dial limits Victoria 7 Attitude Expressions 12/10/2015 updated dial limits EXO Suit for Genesis 3 Male(s) 1/27/2016 update helmet texture map The Bard Outfit for Genesis 3 Male(s) 1/29/2016 replace product thumbnail Gianni 7 1/29/2016 no change Metal Magic Overlays 3/3/2016 no change Growing Up Skin Merchant Resource for Genesis 3 Female(s) 3/15/2016 metadata update only Growing Up Skin Merchant Resource for Genesis 3 Female(s) Adult Add-on 3/15/2016 metadata update only Growing Up Skin Merchant Resource for Genesis 3 Male(s) 3/15/2016 metadata update only Growing Up Skin Merchant Resource for Genesis 3 Male(s) Adult Add-on 3/15/2016 metadata update only Growing Up Skin Merchant Resource for Genesis 3 Male(s) 3/16/2016 update Iray mats to correct thigh maps Growing Up Skin Merchant Resource for Genesis 3 Male(s) Adult Add-on 3/16/2016 update Iray mats to correct thigh maps SSFW Tenshi HD for Genesis 3 Female(s) 4/13/2016 Updated 3delight makeup option specular. SSFW Tenshi HD for Genesis 3 Female(s) 5/11/2016 no change First Light Skydome and HDRI DS 5/27/2016 metadata update only Victoria 7 Attitude Expressions 8/18/2016 no change Victoria 7 Attitude Expressions 8/18/2016 no change Classic Axes 8/31/2016 unknown Epic Hero Poses for Genesis 3 Males 11/28/2016 corrected typo and product thumbnail Montana Outfit for Genesis 3 Male(s) 12/28/2016 material presets updated Montana Outfit for Genesis 3 Male(s) 1/4/2017 emission removed from remaining surfaces Diesel Hair for Genesis 3 Female(s) 1/4/2017 Corrected issue preventing both versions from showing correctly in Smart Content when installed through Connect. Diesel Hair for Genesis 3 Male(s) 1/4/2017 Corrected issue preventing both versions from showing correctly in Smart Content when installed through Connect. Eliot Hair for Genesis 3 Female(s) 1/4/2017 Corrected issue preventing both versions from showing correctly in Smart Content when installed through Connect. Eliot Hair for Genesis 3 Male(s) 1/4/2017 Corrected issue preventing both versions from showing correctly in Smart Content when installed through Connect. EXO Suit for Genesis 3 Male(s) 1/7/2017 metadata update only Hoodie Outfit for Genesis 3 Male(s) 1/7/2017 metadata update only Tools and Toolbox 1/25/2017 corrected Daz Studio materials to load, added metadata FWSA Halina HD for Kalea 7 3/20/2017 lashes morph and metadata update FWKJ Lien HD for Mei Lin 7 3/20/2017 lashes morph and metadata update FWSA Lexi HD for Rune 7 3/20/2017 lashes morph and metadata update FW Phoenix HD for Victoria 7 3/20/2017 lashes morph and metadata update FW Sushmita HD for Victoria 7 and Her Jewelry 3/20/2017 lashes morph and metadata update Victoria 7 Attitude Expressions 3/22/2017 unknown Lilinoe for Kalea 7 3/22/2017 correct typos in labels RDNA Mushrooms Vol 3 3/23/2017 no change Water Spirit Warrior Outfit for Genesis 3 Female(s) 3/23/2017 no change Winter Fantasy for Genesis 3 Females 3/24/2017 unknown CallaCascade Hair for Genesis 2 and 3 Female(s) 3/25/2017 combine G2F and G3F installers, no content changes Winter Fantasy for Genesis 3 Females 3/29/2017 probably no change? Technophilia Arcane: Quantum Eye 3/31/2017 replaced rsr's with png's Makoa for Kimo 7 4/4/2017 metadata update only FW Sushmita HD for Victoria 7 and Her Jewelry 4/4/2017 no change Pavilion Walkway 4/4/2017 metadata update only Technophilia Arcane: Quantum Eye 4/6/2017 no change Leather Jacket for Genesis 4/11/2017 add Iray materials, update paths Growing Up for Genesis 3 Male(s) 4/11/2017 support link filename fixed, metadata update Fern Lake 4/11/2017 replace incorrect texture jpg Makoa for Kimo 7 4/11/2017 metadata update only Evening Gown for Genesis 3 Females 4/11/2017 added morphs and Iray transmap Havoc Outfit for Genesis 3 Male(s) 4/11/2017 no change Gentle Paladin for Genesis 3 Females 4/11/2017 add hand poses Rodents by AM: PolyMorph 4/11/2017 Update Tail poses, add additional Tail pose control dials. RenderGuyNY's Freebies (latest freebie updated 5-24-20)Cale for G3M
Cale is your typical young professional just trying to find his place in the world. This new character includes full textures, face morph, and 11 eye choices (went a little overboard here). I hope everyone enjoys!
https://www.sharecg.com/v/87884/view/21/DAZ-Studio/Cale-4-G3M
Llynara's Loony Bin (WIP Thread)I have a lot of Xurge's stuff but I;m not happy with them at the moment. I lost more than half my files in the transfer to the external drive, i've emailed my reciepts etc several times with no respons. NOT a happy camper. So if you buy from them make sure you back it up
Question about subd and creating morphsYou can sculpt it at hi resolution and export the obj format file, but it will fail on import with morph loader.
Will's WIP threadMay as well call ARISE on this thread.
So I'm poking around at figures and such. One challenge is that morphs are limited to Subd1 unless you are a PA, so I'm thinking of ways to capture fine detail to make cool figures. I'd heard that it's common to take a low and high resolution model and generate normals, so that the low poly figure looks more detailed.
Theoretically, then, I could create a detailed model, then come up with a Subd1 morph, THEN make Normal maps to add critical details.
To test my ability to do that with the tools I have, I used Exile for G3M as a base, because it has VERY highly detailed morphs (SubD4, even, which is more than most models shoot for).
The results are very promising.
The first face is the standard figure with Subdivision 4. The next one is at subd 1, and you can see how much fine detail is lost. The third is the same subd1 figure with Normal maps... and while it's very slightly different from the standard figure, the differences aren't that significant (IMO).
So... yay!
Of course, the big challenge is learning to make figures even VAGUELY as good as Crockett's work, sheesh. ;)
I used Substance Painter 2 to do the low-high poly Normal baking, and, again, this model isn't mine at all.
http://willbear.deviantart.com/art/Exile-Comparison-675291549
Question about subd and creating morphsSo I understand that you can't create high definition morphs in Daz (IE: SubD above 1).
If you TRY to create a morph from a higher subd figure, does it simply make a lower resolution morph, or does it fail outright?
Critters and beasties?looks cool is this a daz dragon 3 morph or a brand new standalone you say can ride him will there be a saddle+ reigns or again will it use dd3 stuff or horse 2 stuff
Wear Them All@greymouse69 Nice! The Casablanca Suit looks pretty snazzy!
Boopsie is a doll!.
That's what friends are for! LOL If it makes you feel any better, I just dropped $30 over there. Couldn't resist $3 and $6 outfits. Here's Xurge's Necromancer for M4 using the original Wear Them All on Darwin's newest character, Evan for G3M. He's got his elf ears and Creature Creator settings on too. He looks badass! I just need to tweak the outfit's materials a bit more, but having fun with it.
This is amazing Llynara
Thanks! I tied up my computer all day trying to get the version with TD3 Atmos fog and snow rendered. Wow, is that ever slow. Will post that version soon.
I
The Dress! The Blue Moods texture for it is that one that caught my eye and made me fall in love with V3 and her amazing wardrobe. It's fitted "the old way", to Genesis with Gen 3 Iconic Shapes for Genesis and then to G3F with the original Wear Them All. I'll try again with the new expansion and see how that works. iI know, I picked up the whole collection yesterday for $21. Have you figured out a way to make the sleeves work?
The sleeves aren't dynamic, but anything that hangs down like that is very awkward to autofit. Dangling sleeves tend to have extra bones these don't usually transfer when autofitting.
It might be better to put the figure into a T pose, then parent the sleeves to the arms instead of autofitting. Sometimes that works, sometimes it doesn't. That trick works GREAT with older hair that won't autofit.
I've also fit new hair to old figures that way- parenting to the head instead of fitting. Here's an example with two Gen 3s wearing newer hairs (V3 has Fantasy Warrior Hair for G3F and M3 is wearing SAV's Alpha Moikana hair)
It would be fun to redo this pic with G3F and G3M and see how they look.
On The Dress, I will try the sleeves a few different ways and see if I can get any to work. I love The Dress and want to have those sleeves working too. Gotta go out to family stuff at the moment. More later!
