• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Problem with texture clipping into the character (Genesis 9)
    crosswind said:
    PolytheGone said:
    crosswind said:
    I don't know if you've dialed any full head morph from a character (if so, better name it...) or you just customized this G9 figure yourself... but it seems to me a rigging issue. You better firstly try Adjust Eye Rigging function in G9's Dev tool with head morph selected in Edit mode (screenshot 1)
    It'll adjust / correct the rigging of both Eyes and Mouth. Then dial Jaw Open to see if it's solved or not...
    Thanks for the feedback, idk if i understood it wrong but i got an error message when i try the step u tell, am i doing it wrong?   And yes i used several different morph that i condensed in blender to only have one morph.
    You need to turn on Edit mode in Parameters pane, and select the character's Head Morph property before doing this Adjust Eye Rigging action. And this process may take some time (1 ~ 3 mins) depending on different character's morph(s) ...
    The issue is i dont really have a "head morph" applied, i combined everything in one morph
    By
    PolytheGone PolytheGone June 2024 in Technical Help (nuts n bolts)
    By
    crosswind crosswind June 2024 in Technical Help (nuts n bolts)
    By
  • Smooth Out Bump
    n.aspros123 said:
    crosswind said:
    Mesh Grabber can move the geometry but has no capability to directly smooth the geometry. That bump seems to be projected from whatever the character's body morph or partial morph(s) you dialed. You can fix it with a standard function in DS, Rigidity Groups.
    I don't know Hexagon either... not sure if it has any functionality of sculpting. But a recommended free way of fixing such an issue is to send it to Blender, smooth and move that area with Smooth and Grab brushes, then send back OBJ to update full body morph on the bodysuit.
    @crosswind
    I'm very very very new to blender as I've only been using 3D apps (Daz) for 3-4 weeks.  Any blender instruction videos or guides to perform the task you suggested I need to do with that bump, Please?
    I simulated your case and gave it a fix in Blender then brought it back to DS... check this short video: https://mega.nz/file/qeg10B5S#YYCh1mmeKcvL4IprIt0UJAP6eJsOZUIm4MRgaw0zU2M
    It's not difficult... just try it.
    By
    crosswind crosswind June 2024 in New Users
  • Smooth Out Bump
    @crosswind
    By
    n.aspros123 n.aspros123 June 2024 in New Users
  • Smooth Out Bump
    felis said:
    Are you working on the suit from a base model, and with resolution set to base?
    I don't know it the bridge takes care of that. Else you will not be able to make a proper morph.
    Although as it is the base mesh, you don't need to make a morph, you can update base mesh (Edit > Object > Geometry > Update Base Geometry)
    If you got the bump leveled out, and you can try export it as an Obj, and in DS use transfer rigging as mentioned above. It will be a new object, and you need to mark all surfaces on the existing and copy surfaces, and paste to the new.
    Mesh Grabber exists in different versions, e.g. https://www.daz3d.com/mesh-grabber-win
    Be aware that there should hit a new version in store anytime soon. It has been in queu for 1½ months or so.
    @felis
    Tried the text in bold and see attached pic. It was previously set to High Resolution. Doesn't work so changed it to Base and suit craps itself.
    By
  • Smooth Out Bump
    By
  • Smooth Out Bump
    By
    felis felis June 2024 in New Users
  • No Item Option After Send to Daz from Hexagon
    Hi. I'm Very new to Hexagon. I've been trying to adjust a bump in the suit in the lower back. When sending an adjusted item back to Daz there's NO Item Menu to select Reverse Deformations. I do select accept and it makes the morph menu option in Parameters. I find it and it warps the whole item, in this case the suit. I have Daz 4.22 installed and See attachments for version of Hexagon.
    By
    n.aspros123 n.aspros123 June 2024 in Hexagon Discussion
  • Smooth Out Bump
    felis said:
    I don't know Hexagon.
    But looking at your picture, you have the gizmo in the middle, and if you move that a bit in the Z direction, the bumb should get smaller.
    @felis
    I tried with Hexagon but no go. It's not importing the morph back correctly. Do you have a link for mesh grabber?
    By
  • Smooth Out Bump
    felis said:
    Yes, it looks like the spline is lifted.
    Does it look ok in base pose?
    If it looks ok in base pose, it seems to be the rigging. Then you could try to use transfer rigging (Edit > Object), with the character as source and the suit as target, and then I would assume it solves it.
    If the suit is bulging in base pose, it looks like the suit has an issue with the modelling, and then you must correct it with mesh grabber or dFormer inside Daz Studio, or in a modelling program. For a single shot I would correct it with mesh grabber. For a generic fix I would use a modelling application.
    @felis
    In T-pose it's lifted. In Hexagon you can see it's lifted in that area from the character body.
    I don't know what I'm doing in Hexagon. I have been selecting the suit, ticking soft selection, reducing the radius, select ring but i'm not sure How to "push in" the buldge so it looks uniform?
    By
  • Smooth Out Bump
    By
  • Smooth Out Bump
    felis said:
    If you hide the clothing, is it then visible on her body?
    If not then it must be the clothing. It could be caused by a slightly incorrect weigth map.
    The easiest solution would be to take it to a modeller, and sculpt it away and import as a morph (with reverse defomations). Or you could use mesh grabber to push it in a bit. If you wait for an updated/new mesh grabber it includes a smooth function, but it is unknown when it comes.
    For a single image I would probably fix it with the existing mesh grabber.
    @felis
    I've uploaded some pics and it looks like the suit is sticking out further.
    By
  • morphs on G8 clothing autofit to G9 [SOLVED, user error]
    crosswind said:
    SilverGirl said:
    crosswind said:
    Nope... you shouldn't have changed Preferred Base in Scene..ID, it's not the case like fitting G3 > G8 or G8 > 3 by using change SceneID + Transfer Rigging. The rigging of G8/G9 are different, you do need AutoFit based on Clone in your case.
    Just directly load the hoodie to G9, Accept in AutoFit.
    When I do that it fits great, but I lose the functionality of the morphs that come with it... which is the problem.
    You chose G8F clone in AutoFit dialogue box, right? Then all morphs will be there after autofitting and they mostly function well with no big issue, as far as I tested. Tiny issues happen when dialing multiple Open morphs... the zipper will be off the trim. You have to fix it.
    Ooooookay, here's me feeling like an idiot. I was looking in the shaping tab. I'd looked at parameters, but apparently I totally missed them amongst all the greyed-out stuff.
    Many thanks!
    By
    SilverGirl SilverGirl June 2024 in Technical Help (nuts n bolts)
    By
    By
    By
  • Putting G9 Character Texture on G8
    Matt_Castle said:
    Not that I am aware of.
    While there is the G8F product Catherine3678ab has linked, the vendor has stated there is insufficient interest in a G8M equivalent to make it worth the effort to create.
    And no, while people commonly suggest use of things like UV Swap in unison with the above product to resolve the issue, I can confidently state this will not work. While UV Swap adds G8F UVs to G8M, the G9 to G8F product does not provide G8F with the capacity to bake G9 textures to the G8F UVs (at least without extensive and technical modification), so there is no chain to transfer the textures.
    This kind of thing has to be done by using an external application like Blender to bake across the texture maps. (For which I admit which the mentioned products are *potentially* an aid, but they certainly don't provide a solution through only DS itself).
    Thank you for this bit of insight. I'm disappointed about no product for the G8M as I use male figures a lot more than female ones.
    By
    ArtsyDragon ArtsyDragon June 2024 in The Commons
    Autofit works in this case, as there's no custom bones on this hoodie and it won't remove any morph from it. But there're some issues when Open it, the zip will be off the hoodie, you have to fix it with Mesh Grabber or Blender.
    Better also check other morphs to see if they can work well...
    By
  • Morphing Dinner Plate, Round to Octagonal and then some..
    Now, I am well aware of just how many people are desperate for this prop (none). It is one I initially did in 2007 or so for Poser, but never got around to publishing it. I have re-vamped the prop so it's now got a few extra size morphs , but the original feature is still intact.
    So, it's a Round Plate that morphs to Octagonal. With a couple of size morphs.
    Yeah, so?
    Now extend the idea and push the Octagonal morph from -100% to +200% and you get something quite unexpected. Try it.
    Hope you like,
    Richard
    By
    richardandtracy richardandtracy June 2024 in Freebies
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
