Beta for DazCentral, your new Content Manager
I can't use DAZ Central because when I purchase any new products, it forces DAZ Central now as the install method. HOWEVER, when you click the link to "Install product with DAZ Central" the page it pulls up is the DAZ Central Install page, and I already have it installed!! It never realizes that DAZ Central is installed on my system.
Am I missing something here??
Please put back Install Manager as the option after a product purchase. Or at least the option to use either one until DAZ Central issues are worked out.
Also, if you run DAZ Central from the Windows start menu, and then click on DAZ Studio on the navigation (left pane) it says DAZ Studio is not installed. What the hell.
Was this thing just rushed to release???
That sounds as if the needed file association isn't being set. Which browser are you using?
Thanks. I'm using the Chrome browser on Windows 10.
I uninstalled DAZ Central for now.
OK, but - if it works like DIM - should yu wish to go back to using Daz Central you may need to go into Chrome's preferences/settings and tell it which application to use to open a whatever file - I'm not sure what Daz Central uses, assumkng it's different from, DIM, and looking at an order page isn't enlightening.
The Mac FAQWhat is this latest version of DAZ Connect, or whatever it's called, that's for Windows Only? It says that the Mac OS is not supported. Are we being left behind again? Or, is this new thing worth messing with? I've seen so many problems with DAZ Studio that I'd be hesitant to jump in even if I could.
If your talking about the new Daz Central then theres a Mac version coming but its not ready yet. Its suppose to be a replacement for DIM but so far all the reports I have seem has not been good.
Yes, that was it: DAZ Central. OK, thanks for the info.
Problème installation disque dur D:Je voudrais installer daz studio sur un autre disque dur car il a plus de capacité sauf que Daz Central install systematiquement le logciel sur le C: (disque systeme) .
Comment faire pour l'installer directement sur le D: ?
Merci pour vos réponses.
Beta for DazCentral, your new Content ManagerI can't use DAZ Central because when I purchase any new products, it forces DAZ Central now as the install method. HOWEVER, when you click the link to "Install product with DAZ Central" the page it pulls up is the DAZ Central Install page, and I already have it installed!! It never realizes that DAZ Central is installed on my system.
AIUTO...CHI CONOSCE L’ITALIANO? PARTE DODICIL'ho visto anch'io. Il loro desiderio è farci usare tutti lo stesso metodo.
Ma fra installazione personalizzata, DIM, Connect, Central... stanno facendo un po' di casino. Spero almeno che Central per loro sia quello definitivo.
Comunque ho capito perché ci metteva generazioni a caricare figure G8F/M: più morph package e figure sono installati, e più tempo ci metterà a caricarli, in maniera direttamente proporzionale e quasi lineare.
Questo è dovuto al fatto che, anche se non stai usando un morph, Daz costruisce i rapporti fra tutti i morph disponibili installati per quel personaggio, ogni singola volta.
Mi è bastato disistallare un terzo delle G8F, e una ventina di morph package che non usavo spesso, e i tempi di caricamento si sono ridotti di più del 65%. Ma è sempre più di un minuto e mezzo.Non resta che fare un bell'upgrade di hardware, e ho cose interessanti in cantiere, vi dirò quando saranno montate nel PC! :D
Io spero di no, Central è terribile! Mancano un mucchio di funzioni del DIM tipo il link alle cartelle di installazione, export delle liste, verifica del tipo di installazione e via dicendo... Capisco che un buon 90% degli utenti di non vanno oltre il carica la figura nuda-metti la parrucca-metti la mutanda-applica una posa a caso-renderizza col primo set in lista.... Ma c'è anche gente che certa una certa professionalità.
Quanto ai morph, altro motivo per non usare G8 e amici belli, almeno fino a che non si decidono a sistemarlo un poco di più. Io ho qualcosa come 4000 e passa morph installati per G1, tra commerciali e custom, e il tempo di caricamento non cambia se aggiungo o rimuovo un pò di quei morph. Anche quando carico una figura con molti morph applicati non ci mette di più.
Lo avevo letto un paio di mesi fa sul forum e ho fatto una prova, il mio Genesis impiega quattro/sei secondi a caricare sulla scena sia con tutti i morph che totalmente senza. Oltretutto ha pure rallentato ulteriormente con l'ultimo aggiornamento per usare quel accrocchio di Face Transfer.
Più vanno avanti peggio fanno...
Sono funzioni di DIM che non ho mai usato, ma certamente meglio più funzioni che meno.
La mia intera libreria è basata su G8, sarebbe troppo un casino usare altro.
Poi non so nemmeno per quanto tempo ancora potrò continuare questo lavoretto part-time. Per ora va bene così.Peccato che abbiano cambiato sistema di gestione Morph rispetto a Genesis 1 allora. Mi piacerebbe molto riuscire a caricare i miei personaggi custom in 4 secondi.
In realtà no... E' molto più semplice convertire tutto da G8 a G1 rispetto a G1 a G8.
Io uso capelli, abiti e perfino morphs di G3/8 su G1 e funzionano correttamente.
Penso dipenda dal rig più semplice e dal maggior numero di poligoni di G1.Per assurdo posso far indossare a G1 moltissimi abiti di G8 utilizzando l'opzione "Not Supported" senza distorsioni quando G8 con il Clone apposito di G1 storta tutto.
Platinum Club Plus Sale!I too was well confused when it seemed that May had rolled over into October! (Thanks for the extra sale, guys)
I was so sad not to be able to snag a GC at 20% off in the Daz Central sale last week due to low funds (I get more income on the first of the month) but now I'm rather glad I had to wait
AIUTO...CHI CONOSCE L’ITALIANO? PARTE DODICIPerchè mi vogliono costringere ad usare DAZ Central? (ಠ_ಠ)
Ho fatto acquisti e pigiato il bel pulsantone verde senza accorgermi della nuova scritta e mi rimanda al download di Central. (ᗒ ͟ʖᗕ)Io voglio il DIM! (ノಠ益ಠ)ノ︵┻━┻
Beta for DazCentral, your new Content ManagerWhew! Dodged the Daz Central bullet. Very thankful.
Beta for DazCentral, your new Content ManagerWhy doesn't Daz Central look for a previous DIM installation on the computer and if it finds one, offer the user the option to use those paths and settings? New users wouldn't have an existing DIM installation, and Daz Central could do its default thing. For current DIM users, it seems like it could be a seamless transition if Daz Central would use the existing settings. Instead, Daz Central seems to be very disruptive for current DIM users.
DazCentral: One more example of the extremely low priority of Daz's Mac usersDaz has not made a business decision to drop max support. If they had, they wouldn't had released fixes for Catalina.
As for DazCentral, I obviously don't know what their reasoning was, but I work in IT and can tell you that releasing the first version of a new software on only one platform and porting it to the other once it's stable rather than having to fix early bugs on 2 platforms actually makes sense from a software development perspective.
Regarding your login problem with DIM, Daz has updated their security settings recently and password rules have changed (for one thing, they now need to be at least 7 characters long). Users whose password doesn't respect the new rules couldn't login into DIM, could it be the problem for you?
Thanks for your response. If indeed they are not dropping mac compatible Daz versions, that would be great. As far as the DIM issue is concerned, my password is 12 characters, and I updated it about 2 months ago. So I don't know what the issue is. But it looks like, at least for the time being, I'll be manually installing everything. It could be just a quirk. It hasn't worked since yesterday. I will try again tomorrow and it might have been fixed or reset.
Contact support to get access to your password.... The password thing seems to be happening to random people and is platform agnostic. As for Mac support, remember there are several things happening: first, for something like DazCentral, they have a relatively small tream so consider it a blessing that, by the time it comes to the Mac, it will be more stable, next is that Daz3d is a brokerage so that someome may come with a plugin that is Windows only and Daz3d decides to sell it but they didn't make it so they have no say in what platforms it is developed for, and finally, the are working on better combatibilty with Catalina.
The fact that it's a small team is why it is so frustrating to me that they would invest time and resources developing DazCentral instead of fixing issues with Daz Studio or innovating new features. I can already download content with DIM or directly in Daz Studio. Why do I need a new content downloader? It doesn't offer me anything that I didn't already have and DIM had the ability to hide items that I don't want to see. And DazCentral doesn't seggregate by items that are available and items that are installed. Sure, they can add these capabilities in the future but that just means more time and resources devoted to something other than their flagship program.
Maybe I'm in the minority on this and the vast majority of you love DazCentral. Right now I'm sticking to DIM or Daz Studio until there's no other option or until there's a convincing reason to switch to DazCentral.
Daz Central is, as I understand it, aimed to make the new users' life easier - as an experienced user you are not the target, though you may well benefit from updates to the core engine that is shared between the two applications.
[Released] Character Converter from Genesis 2 Female to Genesis 8 Female [Commercial]Hi,
I am having an issue opening the script for Character Converter G2F to G8F. Attached is the error from the log file. I just opened and ran Converter G3F to G8F with no issues. I restarted Daz Studio but the G2F to G8F script won't open. I also tried uninstalling and reinstalling it.
Thanks.
I believe you have Content Wizard installed. There is an issue that Content Wizard has an out-of-date file (I think RS2020HelperFunctions.dse). If you uninstall that product, I believe this product will work. Please let me know if that is true.
I got the script strated now. I'm not sure what exactly worked though. I tried removing RS2020HelperFunctions.dse but received the same errors in the log file. Then I tried uninstalling, close Daz, re-installing using Daz Install Manager instead of Daz Central. Restarted DazStudio and the script open with no issues. I'm wondering if Daz Central could have some bugs when installing certain content.
Thanks for your help and quick response.
You're welcome. FYI, I have submitted updates to CW and the Character Converters so hopefully this issue will go away.
Thanks.
What happened to my Install Manager links? Daz Central only.I bought a new computer so I could use DForce. I thought I would try DazCentral on that computer. I appreciate the links to the tutorials and the Plug ins. Instead of being able to Download and Install an entire order, I notice my recent purchases are listed. However unlike the Install Manager I would have to download and install them individually. I installed one and clicked on open. Daz Studio opened up, but the character I wanted to load didn't load. So... I uninstalled DazCentral but I noticed that I must have it installed in order to download the entire order. And on the older computer that I don't think Daz Central will work well on it, I notice it also won't install the entire order without DazCentral.
As for loading the Install Manager and putting the recent items up first. I have a lot of old Poser items that are listed. So I have to click each item I want individually.
If it seems like I dislike DazCentral, it's because I do.
Novica & Forum Members Tips & Product Reviews Pt 13Well, the GFS and European are both hinting at a Gulf of Mexico development for the West Gulf Coast states but it's of course varying by runs. This would be for this next week or the following week. That gyre is similar to the one which spun Category 5 Michael, simply meaning storms break off from the gyre. (Not that the one possibly breaking off will be a Cat 5.) Half the other models agree and have the tropical system varying landfall along the Gulf Coast. So folks in Texas, Louisiana, Mississippi, Alabama, and Florida will possibly see a storm/hurricane within the next two weeks. I always check wunderground's Cat6 blog, it's Jeff Masters. Levi does tropical tidbits (.com) but only posts when there's an active storm. He is the BEST in depth coverage once that happens IMO. That link is to the article.
