• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • [Released] RSSY Character And Material Conversion Bundle Genesis 8 to Genesis 9 [Commercial]
    Looks like there are some problems withe material stuff. I'm trying to convert MSO Miley G8F and it comes up with some errors, which are kinda weird, claiming not to be able to find files which are clearly present for the material skin. They relate to the eyes and mouth. I get no materials copied. Also, the body shape seems pretty weird. I'm running on macos Ventura. Have I done something stupid here?
    For the installation, is the file in the location?  How did you install?
    The files are present in the specified folders and the cases match (which can sometimes be an issue with macs). The product was installed by DIM, automatically. Attached is a screen shot of the Material Suit folder, which is under the location shown in the second attachment. These match the missing file warning.
    I also tried loading a generic Genesis 9 dev load, loading the material suit for G8F using the relevent script and applying the Miley G8F uber skin to it. This did not report errors, but simply did not appear to work at all. This is attachment 3, following the material load - as can be seen, there is no material apparent in either the NVidia preview, nor in the textures preview (not shown). Clearly there is something screwed up with this installation, despite using DIM. Maybe something macos related??
    I'll take a closer look at the manual regarding the morph distortions - thanks.
    Here is the log entry for the material load onto the material suit loaded on the Genesis 9 dev character. I'm not sure this is massively enlightening, but anyhow.
    2023-05-20 12:33:52.804 [INFO] :: Prepare asset load (merge): /People/Genesis 8 Female/Characters/Mousso/Miley/Genesis 8 MATs/Iray UBER/Miley Base MAT NB Light.duf
    2023-05-20 12:33:52.804 [INFO] :: Locking viewport redraw...
    2023-05-20 12:33:52.804 [INFO] :: Viewport redraw locked.
    2023-05-20 12:33:53.105 [INFO] :: Native format content directories: 2
    2023-05-20 12:33:53.105 [INFO] :: Poser format content directories: 1
    2023-05-20 12:33:53.105 [INFO] :: Other import format content directories: 0
    2023-05-20 12:33:53.105 [INFO] :: Begin asset load (merge): /People/Genesis 8 Female/Characters/Mousso/Miley/Genesis 8 MATs/Iray UBER/Miley Base MAT NB Light.duf
    2023-05-20 12:33:53.148 [INFO] :: Determining missing assets...
    2023-05-20 12:33:53.876 [INFO] :: Setting textures...
    2023-05-20 12:33:53.877 [INFO] :: Creating materials...
    2023-05-20 12:33:53.882 [INFO] :: Applying animations...
    2023-05-20 12:33:54.053 [INFO] :: Setting up follow targets...
    2023-05-20 12:33:54.057 [INFO] :: Finished asset load (merge): 0m 0.951s - /People/Genesis 8 Female/Characters/Mousso/Miley/Genesis 8 MATs/Iray UBER/Miley Base MAT NB Light.duf
    2023-05-20 12:33:54.388 [INFO] :: Unlocking viewport redraw...
    2023-05-20 12:33:54.388 [INFO] :: Viewport redraw unlocked.
    2023-05-20 12:34:00.561 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: Received update to 01322 iterations after 106.642s.
    That does not look like you used the Material Suit Apply G8-G9 Hiearchical Map script.  Please use according to the manual.
    I followed the manual to the letter:
    1.  Loaded the G9 Dev load
    2. Selected the G9 Dev load and then ran the script entitled "Material Suit Add G8F Material Suit" from the Scripts/RiversoftArt folder.
    3. With Genesis 9 still selected, applied Victoria 8 all maps material (which you probably do have, given it's listed in the manual).
    Result: no textures - see attachment.
    (Clearly something is very wrong here. Incidentally, I should mentioned that just to be sure, before running the above test, I closed studio, un-installed and reinstalled G8F material suit product using DIM and restarted Studio).
    I should also note that this is a new mac running M2 Max chipset.
    Ok, figured it out. It WAS MY MISTAKE! My eye had skipped over the bit in the manual which says you have to select the hierarchical material (in this case Victoria 8 all maps) and then then NOT DOUBLE CLICK to load but select the script 'apply materials' which by default is in added in my 'Favourites' menu. It now works: shown in the attached.
    Onto the next issue, which is why the character converter is complaining about missing files... when they are present in the folder it specifies.
    Apologies for missing this, Riversoft.
    Not a problem!  Glad you figured it out.
    By
    RiverSoft Art RiverSoft Art May 2023 in Daz PA Commercial Products
  • AIUTO...CHI CONOSCE L’ITALIANO? PARTE TREDICI
    Imago said:
    RCR-2631227 said:
    ci sono rimansto con la mascella bloccata, veramente laugh
    Fa schifo, vero? frown Duemila euro di hardware per avere rumore, aberrazioni cromatiche, errori di fuoco e sbavature.
    Quanto al problema delle cartelle, devi solo "ricominciare daccapo", nel senso che devi eliminare tutto e mettere una cartella alla volta. Inizia con solo le librerie native, vedi se carica gli elementi o se perlomeno visualizza le categorie e i prodotti. Se va, fai la stessa cosa con gli elementi Poser e Other. Se manca qualcosa, dal menù dello Smart Content, sotto DB Management, riavvia il controllo dei metadata.
    In che senso fa schifo? Dai render che personalmente ho provato non ho notato nulla di tutto ciò, nessun rumore, aberrazione cromatica e sbavature varie, va beh che ho provato pochissimo, magari usciranno fuori. Non sapevo che ci fossero questi problemi! Ma non sarà dovuto, come è sempre successo, che Iray vada aggiornato a queste schede? Mi ricordo che quando passai alla serie 1000 proprio non funzionave Iray per qualche mese.  A me è risultato piacevolmente fulmineo il tempo di render, mantenendo le mie solite impostazioni, anche pressando con cose che con la vecchia scheda mi portavano a incartarmici un sacco di minuti, anche per i render di prova.
    Ora provo a vedere cosa succede seguendo il tuo consiglio! Grazie!
    By
    RCR-2631227 RCR-2631227 May 2023 in The Commons
    By
    Imago Imago May 2023 in The Commons
  • Military Rank Insignia
    The 5 pointed star is currently available as an earring here: https://www.daz3d.com/forums/discussion/610486/star-earrings#latest
    Wouldn't take a lot to delete/hide one side and/or put it on any bit you wished.
    To make things easier, I've attached a zip file with 2 obj files in it. 1) The Obj file for a single earring for you to import. Apply shaders and import the 'star shank longer' obj using 'Edit| Object| Morph Loader Advanced' to make the shank have a variable length morph. Then position the model and parent in place.
    Regards,
    Richard
    By
    richardandtracy richardandtracy May 2023 in Product Suggestions
  • importing from Daz3d to blender resulting in different material?
    trying to import clothing with a custom shader (Easy Pantyhose) from Daz3d to Blender, resulting in white plain material.
    What to do?
    I tried both diffeomorphic & daztoblender.
    By
    gagsly gagsly May 2023 in Daz Studio Discussion
    By
    w_r_brook_ec9f3e956e w_r_brook_ec9f3e956e May 2023 in Daz PA Commercial Products
    By
    By
    By
  • Is there a way to unwelded edges/vertices in daz3d?
    Not sure what exactly you wanna do but there's no direct way.. You may use Geometry Editor to 'cut' a part of polygons, export to obj and re-import, sort of 'unwelding'
    By
    crosswind crosswind May 2023 in Daz Studio Discussion
  • How to make a character undress
    Usually you may try:
    1. to use some products with undressed morphs like above mentioned;
    2. to make undressed morphs by yourself with modeling / sculpting software, blender, ZBrush, etc. and import back to the garment;
    3. or another trick is: you seek the garment (A) (having some undressed morphs) that is similar to the one (B) you use, and use Transfer Utility to transfer the undressed morph targets from (A) to (B) and finetune it with blender / ZB. In most case, it might be faster... even without tweaking sometimes denpending on the garments...
    By
    crosswind crosswind May 2023 in New Users
  • How to make a real brow squeeze on genesis 8 and 8.1?
    You may try to use some expression morphs from Daz.com, for instance: Compression HD + Brow Squeeze, uncheck Use Limits and increase the values a litttle bit. Then, use GoZ or blender etc. to make some crease in between the inner brows then import as a delta morph, so as to make some subtle change. (I made one with blender...) You even can mix the expression with other brows related morphs and create a unique single dial.
    PS: Normally we won't separately bake normal or displacement maps for expressions, but you can do it if you'd like...
    By
  • Poser 10 and DAZ
    I use Poser 2014 sometimes and am able to go to "Windows" tab in Poser, then click "Libriaries.  I guess this is the one that doesn't help.  I am not sure.
    You can add your Poser Librairies to Daz Studio.
    Open Daz Studio.
    Go to Content Library Tab
    Find "Poser Formats" and Right click
    From there, you can add all of your Poser Libraries.
    This doesn't import your Poser Libraries, it just links your Poser Libraries.  Therefore, your Poser Libraries stay where they are.
    Your Poser Characters and props will work just fine in almost all cases.  The Poser "Pose" files for different textures will work, however may not be as bright as in Poser.
    The Poser "Mat" files intended to be used in the Material Room for Poser usually don't even show up in Daz Studio.
    It is fun to learn to use Daz Studio shaders to make old products look new!
    Hope I helped a little!!
    By
    Jan_Scrapper Jan_Scrapper May 2023 in Poser Discussion
  • Poser 10 and DAZ
    I have not used Poser in a while, today I found out that because Flash player is not an option the library does not work. I have regular Poser so the edit library external fix does not help me. Is there a way to import all of Poser 10 libraries into DAZ Studio?
    Thanks
    By
    abonilla_8cf10b0f83 abonilla_8cf10b0f83 May 2023 in Poser Discussion
  • Computer hung, now database "is in recovery mode"
    All done. Got everything back, with a few modifications along the way. Missed a block of products' vendor data, so they all ended up in LOCAL USER when I imported the user data. Had to re-do those manually, since the user data is basically one big blob of entries with no way to limit or restrict what it uses, and you don't know what is where. You could search for it, but you still couldn't isolate it without making an edit and creating a subset to import. Maybe I'll export per product. A lot of files, but once done, the categorization is not likely to change. That way, I can select any product(s) to restore. Keep the exported data in a separate folder (you can choose where to send it), and copy the ones you want to the Runtime/Support folder for the DB Maintenance-Re-Import metadata to find. Seeing as it will be Read-Only, I just have to change the path for the Category to some throwaway destination in the dsx file before re-importing. Then I just have to copy that small subset back into the main tree, not the whole thing. Still going to do a full bcakup of the database, and the full user data export, just to cover all angles.
    By
    NorthOf45 NorthOf45 May 2023 in Technical Help (nuts n bolts)
  • Mesh deformation caused by transfer utility
    arthenics said:
    re-import a delta?
    Yea, like this:
    PS: For this case, re-importing the original obj file to overwrite bs morph will be fine.
    By
    Export again as it is to Blender, fix the deformation and import back as a morph to the skirt with reverse deformation?
    By
    PerttiA PerttiA May 2023 in Daz Studio Discussion
    re-import a delta?
    By
    arthenics arthenics May 2023 in Daz Studio Discussion
    arthenics said:
    I fact, I just need to manage to obtain the transfer utility to ignore one edge but I don't know what parameter in transfer utility allows that. My only guess is it is related to the distance.
    I 'replicated' the process you did, nearly the same issue... I haven't found a way in TR utility to improve it as it's just a 'weight' issue I believe... I could just fix it now by re-import a delta. Tweaking weight might work as well...
    By
    arthenics said:
    The process was  (simplified) :
    - importing the G9 (with feminine at the max) in Blender
    - creating the dress in blender starting from a cube
    - when done, importing the .obj in DAZ
    - using transfer utility with reverse option (the G9 used as reference for modeling is the same than the figure I'm using for the transfer utility)
    There's no lost edge, the same process done for G3 and G8 works fine.
    It looks like a problem with the distance between the dress and the body. The transfer utility gives to the G9 figure a too strong influence on the dress for this part.
    You may re-import the obj file with Morph Loader Pro as a delta only (+ reverse deformations) to overwrite the hidden blend shape 'BaseFeminine_body_bs_Body' on the skirt. Or try Josh's tutorial in Mada's thread. There'll be more steps but see if it'll work..
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
Create An Account
