extremly slow scene loading?
In general it is a very bad idea to keep everything installed, because apart slow speed you may get conflicts, that the turbo loader will not help with. Personally I manual install what's needed for the current project. Not using DIM or Connect is much easier so you don't have to maintain the metadata, which may conflict/slow down as well.
[Fisio SB addOn released] Fisio: Physics Simulatorbarbult said:
I managed to get the soft body plugin installed using the download file in my Product Library. I can open the Soft Bodies tab OK. I will submit a ticket none the less.
Daz has been having a hard time preparing DIM packages correctly for about the last month. There have been numerous problems reported here in the forum about packages not showing up in DIM at all, manifest files that are wrong and prevent correct installation, file paths that are wrong, etc. I've been wondering if they are trying to use AI to do this or something. They've definitely lost the touch. Metadata has also taken at hit. The percentage of incorrect metadata is on the rise again.
I can see that my product is not the only one.
[Fisio SB addOn released] Fisio: Physics SimulatorI managed to get the soft body plugin installed using the download file in my Product Library. I can open the Soft Bodies tab OK. I will submit a ticket none the less.
Ûber shader and the shader mixerUncannyValet said:
Bejaymac said:
Never import a shader into the SM that wasn't built in it, and of the shaders DAZ supply with DS4 only AOA's SS shader was built in it.
Other shaders either wont import, or you will get a rough representation of the shader, which always has major issues when you apply it back to a surface.
Oh, could you explain that further? How are shaders for DS built if not in the Shader Mixer?
Directly coded in RSL or MDL, or for 3Delight (RSL) using Shader Builder.
DIM and DazCentral not finding installed content. No Smart Content in Daz StudioIt sounds like it's important to try and figure out exactly what went wrong. If the drive letter being reassigned broke Smart Content then it sounds like you also had your CMS path on that drive. In which case I would make sure that the CMS path is set to the correct location in both DIM and Daz Studio. If this had reset then what potentially happened is that the CMS could not find it's database files since the path was no longer there and thus created a new empty database. This would explain why you can see the files in Content Library but Smart Content is empty.
Hopefully, restoring the path to the correct location and then potentially restarting Daz Studio should bring it back. However, if all else fails, you can rebuild the Smart Content by going to COntent DB maintenance and selecting reimport metadata. This will read back in all the Smart Content as per the installed files from Daz - you will only get any custom changes you may have made if you backed up your UserData.
Hallelujah! Finally Got a DSON Core File to Load In CarraraDiomede said:
Yes, if the creator of the content included lights and cameras with the product, then they are generally available in Carrara. There may be exceptions, like 'ghost lights,' but most generic spotlights and similar should included if they were included in the set. The same is also generally true of older Poser scenes, I believe. If they are included in the saved scene file, then they should be available in Carrara in general. In practice, most single props and figures do not include lights and cameras.
A Poser scene file is in pz3 extension while a single figure is cr2 extension. I just did a quick test of trying to save a simple Poser scene with an additional camera and an additional spotlight. I loaded it in Carrara. Not only did the additional camera and spotlight come through, all of the default lights and cameras came through as well.
EDIT: I haven't opened Poser in who knows how long except when I was trying to get my copy of VWD working for Carrara. Have completely forgotten almost everything. Haha. Had not even added my Runtime library folders since my reinstall. Trying to do so now.
OK, thanks. I only rarely import a pz3 file into Carrara, almost always props and figures, so don't get cameras or lights. And yeah, if I do open Poser, it feels like its in Greek. But it does make me happy about Carrara's ease of use.
Too Many DAZ folders...Need Correct PathSofaCitizen
quote "This is what happens if you log into your Daz account within the Daz Studio application. On start-up it will download metadata for all your installed products and save these as json files in the DazConnect/cloud/meta folder - I think there is a message at the bottom left of the screen when this is happening. It will also download Product thumbnails and put them in a different folder under DazConnect/cloud and re-write the path to these in the database so Daz will no longer use the ones that DIM puts in runtime/Support. This is one of the reasons why, if you use DIM or Central to manage your product installs, you should never sign into your account within Daz Studio."End quote.
----ah! Big Duh! I start up a DAZ Studio session automatically defaulted to "connect" to store as I assumed it was just to make a bridge to the store. I will change that to "work offline", save a ton of space on my C drive, too.
Thank you for your patience in explaining this to me. Now I know I have a choice, and where the heck those json files came from.
Create animations from DAZ into 'pixel art' style animations?You can save out Daz animations as a Image series (individual frames) , and then apply any type of filter or effect to the output. Then you reassemble those by importing the frames into a video editing program. Or import the frames into a gif creation program.
Very doable.
I know, but i have been quite lucky tweaking the uber shader so far. I don't have the knowledge make my own shaders from scratch and simply not enough free time to learn.
Ûber shader and the shader mixerNever import a shader into the SM that wasn't built in it, and of the shaders DAZ supply with DS4 only AOA's SS shader was built in it.
Ûber shader and the shader mixerjergenoman_b33d4209f8 said:
If i import the shader into the shader mixer and then immediately apply it to the surface again the shader is corrupted.
Do all the settings of the Shader still look the same as that of the surface you imported into Shader mixer? it's just the preview that isnt showing correctly?
Ûber shader and the shader mixerHello
I stumbled upon an annoying problem: I used the über shader dial in a volumetric water material that i am quite pleased with but i need to customize the volumetric behaviour a bit. However the shader mixer doesn't seem to handle the über shader well. If i import the shader into the shader mixer and then immediately apply it to the surface again the shader is corrupted. The preview is wrong, the volumetric behaviour is gone, etc...
Is this normal behaviour? I have tweaked the über shader with my own MDL scripts many times using the "PBR Metallicity Base" node with good result. I can't see any obvious problem with the shader in the shader mixer. Everything is there including the "PBR Specular Base" node. All connections seem ok and valid.
/Jörgen
Weight Node Re-mapping helpActually there's still another way out, if you happen to know Marvelous Designer... Export the robe to MD, simulate + drag (with Pins) and import back to DS as a draping morph...if plus Blender as well, you can make lots of morphs + subtle changes that you have no way to make them in DS ~~ For instance, this Sheer Robe was just made with MD. Though you don't have the project file, you still can simulate it in MD... as below ~~
Too Many DAZ folders...Need Correct PathIceScribe said:
I checked the "My DAZ Connect" folder today dated as of yesterday There is nothing in the folder except a folder labeled "data", and that's empty. A few days ago, it had 2 kinds of records, one being json other meta. I don't know what was going on there, how those files got to My Daz Connect, and how did they vanish? Perhaps, those are the files I saw being uploaded which I tried to stop unsuccessfully. I think around 12,000 files! I have lost some thumbnails in Smart Content panel, but that's no big problem for me. I can rebuild new paths back to my local folders.
Finding Tutorials...It would be a welcome feature to apply filters to that degree of precision. The best I've come up with is to tick of "N/A" in the "Figures" panel when I'm at the "Your Search Results for" page. Still, without hiding the items I own, I come up with 3191 items, mixing in tutorials, sceneries, environment sets, flora, faura, vehicles, etc. A lot to sift through, yes.
Hopefully some greybeard in the community could come up with better tips.
Cheers!
Xandyr78 said:
Is there ANY way to filter the product library to specifically find tutorials, plugins, and/or utilities? The site/store has a "hide items I already owned" option, so why not add a "show items I own" option? I've purchased a great number of tuts, plugs, and utilities over the years, but it's often hard to narrow down what I still need to grab (if anything).
Maybe there's an easy workaround I'm just not considering. Anyone else interested in something like this...or have any ideas how to use it?
I use a product manager for DAZ Studio, and it's an amazing product, but not every tutorial, plugin, or utility has that word in its name/metadata.Daz to Blender Bridge - Meet the TeamGood afternoon. Please tell me what is the reason for the incorrect display of some poses. After successful transfer, I select the skeleton of the character and go to the import point, some poses are transferred with a strange offset or incorrect display, and sometimes such an error pops up(https://drive.google.com/file/d/1ZpVacMG2MCLUFHyElWKg85J48qp1EO6V/view?usp=drive_link). Tell me how to correctly transfer poses from the Daz with the removed restriction of bones.
SofaCitizen: Quote This is not quite right - the "meta" here refers to metadata that Daz Connect is downloading to your Daz Connect base folder - nothing to do with Facebook. This is happening because you have signed in to your Daz account within Daz Studio and so this process happens everytime you startup Daz Studio (I think you can disable that if you still want to use Daz Connect to install products). End quote
I appreciate your reply. However, I am driven to find out what's going on.
This is a good article about the partnership of Microsoft with Meta formerly known as FaceBook.Meta and Microsoft announce partnership to integrate Workplace and Teams (cnbc.com)
note snip "Although Workplace has integrations with Microsoft’s Office 365, SharePoint, Azure Active Directory, OneDrive and now Teams, there is no integration with Yammer, Singh said." end snip from above link
I saw the json files uploading to Meta, thousands of them all by themselves, after I'd unlinked, unsyched, uninstalled, and deleted as many OD files as I could. All by itself ithat uploading event started that process through OD, not FB. I had to chase that down, something else to get rid of. I have no other clouds associations, except with DAZ and Rendo, but have n't loaded Rendo products yet.. I do not use DAZ Connect at all. I use the DIM Installer without problems both to hard drive and external driveevery . I do my own categories when I chose to have a more specific category. My problems is with the OD product that I cannot rid my machine of its noxious interference in my work flow. Every day since I started my new computer, a new folder with parts of DAZ is made, such as My DAZ Library, and a stupid folder for Video placed in my Render Library, every day. I don't make, watch, or download videos. Dont do animation. Just want to create my scene, save that and render it "to the same place it was yesterday".
Apparently, "permission to uninstall" certain MS OD items is through "Trusted Installer" which I finally located. I may have to venture into unknown territory there. Spent so much time trying to locate my original files swept up to the cloud, and their folders in a daily made new folder, as names only, not "here". Thing is, I killed 2 previous computers with the cloud sucking up my rather full hard drives, then downlaoding those files again and again until the computers could take no more, over and over.
Now they do want to charge for cloud space over 5 GBs. What is that? A Gen 9 character and a couple of outfits? Not paying, I declare. Thank you for taking time to make your comments
Well, I am not doubting any posible/potential integrations between Microsoft and Meta/Facebook - I wouldn't trust either company as far as I could throw them. Just pointing out that the hundreds/thousands of json files under the "Daz Connect/cloud/meta" folder are being synced because you are using Daz Connect - if you install products via DIM you should logout of your account within Daz Studio ASAP and ensure that you are always "working offline" there. This will then stop those json meta data files from being synced/downloaded by Daz Studio. You should probably purge your Daz Connect installs too since those usually conflict with DIM installs but if you are not having missing file errors then perhaps best to leave that alone for now.
Again, there is no point in you fighting with OneDrive while you still have it running and logged in. You need to disable OneDrive first and set it to not start-up when the computer does. Also, have it "forget" your login details so it is not able to reconnect even if you do accidentally run it. If you have to, you can change your microsoft account via the web interface so that the OneDrive install does would not be using the correct one. This is entirely possible as I have done it on my Windows 11 machine - OneDrive is not loaded on startup and if I accidentally click on it then it complains that it cannot do anything because I am not signed in. Thus I am safe from it's interferance and this is what you need to do also.
Finding Tutorials...Is there ANY way to filter the product library to specifically find tutorials, plugins, and/or utilities? The site/store has a "hide items I already owned" option, so why not add a "show items I own" option? I've purchased a great number of tuts, plugs, and utilities over the years, but it's often hard to narrow down what I still need to grab (if anything).
I use a product manager for DAZ Studio, and it's an amazing product, but not every tutorial, plugin, or utility has that word in its name/metadata.Too Many DAZ folders...Need Correct PathSofaCitizen: Quote This is not quite right - the "meta" here refers to metadata that Daz Connect is downloading to your Daz Connect base folder - nothing to do with Facebook. This is happening because you have signed in to your Daz account within Daz Studio and so this process happens everytime you startup Daz Studio (I think you can disable that if you still want to use Daz Connect to install products). End quote
