• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • [Released] dForce2Morph [Commercial]
    Praxis said:
    WendyLuvsCatz said:
    I believe I tried Casual's script already  but it didn't work on the Sagan obj sequence but I will revisit it in case I am mistaken
    there is more than one script out there and I hadn't gotten any to work
    I've just done a quick test of Casual's script I referenced in my post above, and it worked as expected:  (using DS v4.15.0.30)
    1) New Scene: Loaded G8F, in default pose and position, Base resolution, deleted EyeLashes wearable.
      File > Export to 000.obj
      Copied 000.obj to 002.obj and 004.obj
      In an external 3d App I created 2 simple quick mods from 000.obj:
        001.obj = "Belly in"
        003.obj = "Belly Out"
    2) New Scene:  Timeline = 31 frames, File > Import 000.obj, selected it.
    Loaded Casual's mcjAnimObjsToMorphs.dsa into the Script IDE Pane (to see if it threw any errors when I ran it - it did not).
      (mcjAnimObjsToMorphs.dsa has file date 2012-06-01 17:32)
    Ran the script:
      [Browse...] - selected 000.obj
      obj import scale = DAZ Studio (1:1)
      [Objs to Morph] ...(Took about 5 secs per Frame)
      [Animate Morphs]  ...NB: Casual's instructions seem to omit saying you must do this.  If you don't then the Morphs and sliders will exist but will not be animated.
      [Exit]
    That created a new "Morphs" section in the Parameters Pane, containing 4 sliders named fr_1, fr_2, fr_3, fr_4, corresponding to Morphs 001.obj, 002.obj, 003.obj, 004.obj  - In the Parameter Settings dialog of each one you can see the KeyFrame values in the Keys sub-Page.  Because the Frame Range was 31 frames, the 5-Frame .obj sequence is repeated (30/5) = 6 times.
    When I Play the Timeline, the G8F belly snaps In/Out as expected.
    Of course, the result is not an animated morph of G8F - its an animated morph of a G8F-shaped Prop, but the script can easily be changed to create morphs of G8F, e.g. using Casual's technique per https://sites.google.com/site/mcasualsdazscripts4/mcjaddstretchmorph  - see https://www.daz3d.com/forums/discussion/47183/mcjaddstretchmorph-add-stretcher-morph-to-usually-a-prop
    Interesting.
    By
    RiverSoft Art RiverSoft Art July 2023 in Daz PA Commercial Products
  • Custom (non-Daz) character Mixamo animation import into Daz3d?
    FSMCDesigns said:
    This is why DAZ needs to put more work into their "import" functions. Not everyone wants to use DAZ content outside of DS
    to the OP, I have never been able to import a functioning rigged FBX figure into DS, the FBX import option just doesn't work for me. Even if you did, mixamo rigging and DS rigging are very different, so you would probably have to rerig it anyway. Your best bet is to import your OBJ, line it up with a DAZ figure and transfer the rigging
    Is there any GOOD tutorial on how to do that? I wasted most likely 2 days already tried to find some good information on that but to no avail. I would gladlyt even pay someone to do it, I really hope DAZ finally introduces a "paid request" type of sub forum. People on upwork or fiverr have no clue about daz.
    By
    ggrancharov ggrancharov July 2023 in Technical Help (nuts n bolts)
    or import it into Poser11+ and save as a cr2 with motion as pz2
    in D|S edit rigging convert to weightmapping general
    save as support asset figure
    By
    WendyLuvsCatz WendyLuvsCatz July 2023 in Technical Help (nuts n bolts)
    By
    FSMCDesigns FSMCDesigns July 2023 in Technical Help (nuts n bolts)
    Ran the script:
      [Exit]
    By
    Praxis Praxis July 2023 in Daz PA Commercial Products
  • Can the Unreal Engine 4 mannequin be loaded in Daz Studio?
    What format were you using, and what export and import settings? Most of the formats that attempt to preserve rigging are able to handle Z-up and Y-up coordinate systems correctly, but that seems to be the issue you are having with orientation.
    Orientation aside, getting a rigged figure into DS is not easy. I believe that FBX files from Motion Builder work, though I am not in a position to test, but beyond that the format is somewhat variable and as a result the outcome is unrelaible in general.
    By
    Richard Haseltine Richard Haseltine July 2023 in Unreal Discussion
  • how do you edit a clothing texture map when it doesn't show up on L.I.E?
    mding said:
    You have a template at
    \DAZ\MyRenderosity Library\Templates\CCox\80s Rad Swimwear\80s Rad SwimwearUVs.png
    Load this into a layered graphics editor like gimp or photoshop.
    Create a new transparent layer above that template and import the logo and place it where you want it to be.
    Delete the layer with the template. Create a new layer under the logo - layer and fill it with the color you want the rest of bottom surface to have.
    Export as .png and load into the base color slot.
    You should be done.
    adding to the good tutorial above   Give it a unique name and save in the same texture folder as the original if you can. (just makes it easier to find)  Use the surfaces tab to navigate to the newly made png and laod. Hopefully the original bump, displacement  and normal maps will interact nicely with your newly created base color texture.  Render to check.
    By
    FirstBastion FirstBastion July 2023 in The Commons
    Hi,
    not sure why did is so hard or what I do wrong, but I couldn't find any info anywhere.
    1.) Sculpted a custom character (OBJ)
    2.) Uploaded to Mixamo
    3.) Exported an animation as FBX
    When importing into Daz3D, all hell breaks lose.I can neither see the character, nor is the animation working. But when importing into Blender everything is working propertly.
    Can someone help out?
    George
    PS: I really like the way Daz3D renders, that's why its my preferred software for rendering animations
    By
    You should be done.
    By
    mding mding July 2023 in The Commons
  • Hair converter add-on for Blender
    Again, did you check the strands orientation ? You may post a picture of the hair uv map.
    Some PAs may use mixed strand orientations within the same hair style. If this is the case you have to check the uv map and separate the hair by strand orientation before converting. In general a good conversion to particle hair is not straightforward you have to spend time on conversion, optimization and strands editing. Unless the hair is SBH or dforce that will come the same as daz studio. So you may end up using the mesh hair if conversion to particle is not practical for this specific hair style.
    update.
    Just tried and I can't reproduce the issue, it works fine here. The wild loop is top-down so no need to change anything. I also added a note in the wiki to explain better what strand orientation is. Be sure to update to 1.7.2 since there's many bug fixes.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Setup/Hair/Make Hair
    steps:
    1. import G8F with wild loop
    2. merge rigs
    3. separate the scalp
    4. convert thair
    5. pose the figure
    p.s. It is possible that you selected the figure instead of the scalp for the hair conversion, in that case the hair follows the figure pose and deformations happen as in your picture. You have to separate and select the scalp, not the figure.
    By
    Padone Padone July 2023 in Blender Discussion
  • Daz Studio Pro BETA - version 4.22.0.15! (*UPDATED*)
    I don't ever want to sign in inside Daz Studio, unless it has an option to disable automatic metadata updates and Daz Connect installation.
    By
    barbult barbult July 2023 in Daz Studio Discussion
  • Viewport requirements
    Oh yes, fiber mesh stuff can make DS crawl, too.
    A 13700 is perfectly fine. There really isn't much you can do from a hardware standpoint. Software is the bottleneck. You can try some of the display options Zarcon mentioned, but all of the lag is coming from what you have in your scene. Dense mesh can do it, even without textures, it depends on what sort of mesh it is.
    You can always hide things in the scene tab until you are ready to render. Hide the denser mesh objects. Maybe even just hide hairs in general. Some Daz hairs are very heavy even if they are not mesh based. If you didn't know, you can hide everything parented to an object by holding down CRTL when hitting the button to hide it. This makes hiding and unhiding stuff a lot easier. So you can hide a character and all of their clothes and hair with just one click. Some 3rd party content can be very unoptimized and problematic in DS. If something is not rigged properly, that can cause some issues in a scene. This goes back to what I said above, it depends on what the mesh is. If this mesh was like quickly converted from some other software it may not be optimized for Daz.
    If importing stuff into Daz, you can try reducing the poly counts before import and making it so the object can be subdivided in Daz at render time rather than the viewport. Daz also has a product called Decimate, though I have not used it in forever and forget how to use it. I don't even know if Decimator still works, if you are interested in it, you can search for some forum topics on it (in you favorite search engine, not the forum search.)
    And again, smoothing can be performance killer. A lot of Daz products have smoothing enabled by default. It is worth looking to see if any items have it.
    By
    outrider42 outrider42 July 2023 in The Commons
  • Blender HD morphs for DAZ Studio
    You could in theory export a hi-res Base figure from DS into Blender and then re-import the .obj and transfer the rigging from the original figure, essentially giving you a higher res version of your DS figure that you could try to import the morph target within DS
    Or you could try to export the High Res figure into Blender, add subdivision or anything else you might need then sculpt your morphs and export the whole thing as a Collada file or an FBX file along with the created shapekeys (morphs) which means if you re-import the DAE or FBX into Daz Studio you will get a figure shaped prop with morphs included which you could then try to rig using the Transfer Utility (at least as a starting point)
    Another option (the non free approach) is exporting to Blender, adding subdivisions and sculpting, then exporting the end result and use a software like Wrap3DS (not free) and project your HD morph to the Genesis (or any figure you're working with) from the High Resolution mesh so you can use Morph Loader normally
    By
    felipe.a.v.lopes felipe.a.v.lopes July 2023 in Technical Help (nuts n bolts)
    ok uuh i used echo 8.1 with oot wild loop tail hair on this one, exported them to blender using diffeomorphic imported into blender using the import daz button,then i merged rigs, seperated the scalp from the hair and used the addon to convert the hair,added a pose to the caracter and that happands.image
    By
    onetrypwi onetrypwi July 2023 in Blender Discussion
  • Diffeomorphic DAZ Importer version 1.7.0 released
    Geometry nodes don't always work fine they are experimental thus removed from easy import. But you can always do it by hand with the standard menus.
    By
    In daz studio hairs are figures so they may have morphs and jcms for posing. If this is the case you can import them as custom morphs or via daz favorites with easy import. Otherwise you can do an example of a specific hair that doesn't work with exact steps to reproduce the issue.
    By
  • Wishing for improvements on importing fbx and obj
    Light shedder, sometimes shredder lol ... okay, to import .obj files into D/S with textures:
    1. name the .obj at export "one word" with no spaces or weird symbols, "-" "_" are okay. It's not that the name of the .obj matters so much as the name of the .mtl file. If one needs to edit the name of the .mtl file, be sure to rename it inside the .obj file, near the top of the codes. Have the export packaging up the textures AND the .obj to the SAME folder. This should import into D/S with the textures applied.
    If planning to save this as a D/S file, I would recommend having that texture with .obj file inside the desired destination folder for the textures: i.e. Main Content folder > Runtime > textures > your handle > subfolder. Then you won't have to put them there and reapply them inside D/S so it can find them all.
    n.b. "shaders" are program specific. If texturing with shaders, apply the D/S shader presets.
    By
    Catherine3678ab Catherine3678ab July 2023 in Daz Studio Discussion
    I have just begun my journey into importing stuff to Daz and trying to make them work inside the software. However, every model I import from Blender is always without textures, and I need to spend significant time putting the imported models "back together" so to speak. Now, I am not a technical guy when it comes to fbx and obj formats, or any format for that matter, but from what I understand, this issue appears to exist solely in Daz if I am not greatly mistaken...
    So what I am wondering is if this is something Daz could improve upon in future updates. Or if someone who understands this stuff far better than me could shed some light on me whether I am asking impossible and why that is.
    I would love to see a day when I can import stuff to Daz and start using them right away without having to retexture them. Resizing I can manage, but sometimes importing environments can have dozens and even hundreds of assets in them, thus making the retexturing process somewhat of a nightmare.
    If you are knowledgeable about this subject, I would appreciate greatly someone to educate me about this subject to know if there are far better ways to import assets in Daz and still have all the textures in place.
    By
    eroguysensei eroguysensei July 2023 in Daz Studio Discussion
  • Is there a way to transfer cc3 figures to Daz Genesis 8, at least for the mesh/morph?
    Nope. Any mesh you import into DS needs to be rerigged
    By
    FSMCDesigns FSMCDesigns July 2023 in The Commons
  • When i switch off CPU fallback and CPU for render IRAY showing black screen
    Hello guys, as I mentioned in the title, I am faced with a very strange problem. When I render with CPU it is very slow, any help suggestions?
    This my options: https://imgyukle.com/i/r15fwc
    And here it is my video card LOG
    2023-07-25 21:15:42.967 Iray (Scene Update) : Updating LPE labels
    2023-07-25 21:15:42.968 Iray (Scene Update) : Updating geometry
    2023-07-25 21:15:42.968 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2023-07-25 21:15:42.968 Iray (Scene Update) : Retrieving geometry
    2023-07-25 21:15:42.968 Iray (Scene Update) : Updating motion transform data
    2023-07-25 21:15:42.968 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating motion transforms.
    2023-07-25 21:15:42.968 Iray (Scene Update) : Updating section objects
    2023-07-25 21:15:42.969 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2023-07-25 21:15:42.970 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2023-07-25 21:15:46.978 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 54 M triangles, 0 fiber objects with 0 fibers (0 segments), 1 triangle instance yielding 54 M triangles, 0 fiber instances yielding 0 segments) took 4.008 s
    2023-07-25 21:15:46.978 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating section objects.
    2023-07-25 21:15:46.979 Iray (Scene Update) : Updating materials
    2023-07-25 21:15:46.979 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2023-07-25 21:15:47.618 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 265 textures, 0 lambdas (0 unique)
    2023-07-25 21:15:47.625 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Computing 2 flux compensation factors took 0.001 s
    2023-07-25 21:15:47.625 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Emitter geometry import (54 light sources with 2598 triangles, 1 instance) took 0.002 s
    2023-07-25 21:15:47.626 Iray (Scene Update) : Updating volumes
    2023-07-25 21:15:47.626 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating volumes.
    2023-07-25 21:15:47.626 Iray (Scene Update) : Updating environment
    2023-07-25 21:15:47.626 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
    2023-07-25 21:15:48.636 Iray (Scene Update) : Updating lens data
    2023-07-25 21:15:48.636 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
    2023-07-25 21:15:48.636 Iray (Scene Update) : Updating lights
    2023-07-25 21:15:48.636 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2023-07-25 21:15:48.637 Iray (Scene Update) : Updating instance topology
    2023-07-25 21:15:48.637 Iray (Scene Update) : Updating flags
    2023-07-25 21:15:48.637 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2023-07-25 21:15:48.638 Iray (Scene Update) : Updating backplate
    2023-07-25 21:15:48.638 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
    2023-07-25 21:15:48.638 Iray (Scene Update) : Updating portals
    2023-07-25 21:15:48.638 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
    2023-07-25 21:15:48.638 Iray (Scene Update) : Updating decals
    2023-07-25 21:15:48.638 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2023-07-25 21:15:48.652 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
    2023-07-25 21:15:48.652 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2023-07-25 21:15:48.656 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler disabled
    2023-07-25 21:15:48.657 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
    2023-07-25 21:15:48.658 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Available GPU memory has increased since out-of-memory failure. Re-enabling CUDA device 0 (NVIDIA GeForce RTX 3060 Laptop GPU)
    2023-07-25 21:15:48.661 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing OptiX for CUDA device 0
    2023-07-25 21:15:49.588 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2023-07-25 21:15:49.588 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3060 Laptop GPU)
    2023-07-25 21:15:49.588 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2023-07-25 21:15:49.588 Iray [INFO] - IRAY:RENDER ::   1.10  IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3060 Laptop GPU): Processing scene...
    2023-07-25 21:15:49.589 Iray (Scene Access) : Retrieving geometry
    2023-07-25 21:15:49.589 Iray (Scene Access) : Retrieving device geometry
    2023-07-25 21:16:00.343 Iray (Scene Access) : Retrieving volumes
    2023-07-25 21:16:00.344 Iray (Scene Access) : Retrieving textures
    2023-07-25 21:16:21.452 Iray (Scene Access) : Retrieving device textures
    2023-07-25 21:16:22.224 Iray (Scene Access) : Retrieving flags
    2023-07-25 21:16:22.225 Iray (Scene Access) : Retrieving device flags
    2023-07-25 21:16:22.226 Iray (Scene Access) : Retrieving lights
    2023-07-25 21:16:22.237 Iray [INFO] - IRAY:RENDER ::   1.13  IRAY   rend info : Importing lights for motion time 0
    2023-07-25 21:16:22.242 Iray [INFO] - IRAY:RENDER ::   1.13  IRAY   rend info : Initializing light hierarchy.
    2023-07-25 21:16:22.269 Iray [INFO] - IRAY:RENDER ::   1.13  IRAY   rend info : Light hierarchy initialization took 0.026 s
    2023-07-25 21:16:22.271 Iray (Scene Access) : Retrieving device lights
    2023-07-25 21:16:22.271 Iray (Scene Access) : Retrieving section objects
    2023-07-25 21:16:22.271 Iray (Scene Access) : Retrieving device section objects
    2023-07-25 21:16:22.271 Iray (Scene Access) : Retrieving materials
    2023-07-25 21:16:22.277 Iray (Scene Access) : Compiling custom code
    2023-07-25 21:16:22.277 Iray (Scene Access) : Retrieving environment
    2023-07-25 21:16:22.386 Iray (Scene Access) : Retrieving device environment
    2023-07-25 21:16:22.483 Iray (Scene Access) : Retrieving backplate
    2023-07-25 21:16:22.483 Iray (Scene Access) : Retrieving device backplate
    2023-07-25 21:16:22.483 Iray (Scene Access) : Retrieving portals
    2023-07-25 21:16:22.484 Iray (Scene Access) : Retrieving decals
    2023-07-25 21:16:22.486 Iray (Scene Access) : Retrieving device decals
    2023-07-25 21:16:22.489 Iray (Scene Access) : Retrieving motion transform data
    2023-07-25 21:16:22.490 Iray (Scene Access) : Retrieving device motion transform data
    2023-07-25 21:16:22.490 Iray (Scene Access) : Retrieving lens data
    2023-07-25 21:16:22.490 Iray (Scene Access) : Retrieving device lens data
    2023-07-25 21:16:22.599 Iray [INFO] - IRAY:RENDER ::   1.10  IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3060 Laptop GPU): Scene processed in 33.007s
    By
    randomedits1903 randomedits1903 July 2023 in New Users
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
Create An Account
