• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • true iray skins for blender are on the way ..
    So is the alembic exporter by @TheMysteryIsThePoint available as a freebie? I have looked in the Freebies form but can't find it.
    It's on my Google Drive.
    Ok, I did download your Alembic exporter and now I see a DLL file. Sorry to be so dumb but what do I do with it? How do I run it?
    Also, does it export mesh only but no materials? If so, how do you get the materials into Blender? Some combination of the Diffeomorphic plugin and your Alembic exporter? Or Teleblender, perhaps? Once again, I'm sorry but I'm not clear on the process at all. My idea is to make an animation in DAZ Studio (I tried posing in Blender but found it so much more difficult than DAZ Studio almost certainly because I'm comfortable with what I am used to) - then export that animation (likely Alembic export) and render the animation using Eevee because IRay is soooo slow.
    (Dammit, I wish DAZ would get Google Filament working and fix the animation timeline while they are about it.)
    [EDIT] Ah wait ... I found your post explaining what the DLL does. I'll try to follow that and see how far I get.
    https://www.daz3d.com/forums/discussion/comment/5636136/#Comment_5636136
    By
    marble marble July 2020 in Blender Discussion
  • AIUTO...CHI CONOSCE L’ITALIANO? PARTE DODICI
    Ma alla fine IRay la usa la memoria video condivisa?
    Ah boh!
    Ma non credo, altrimenti troverebbero un modo per farci usare la RAM come VRAM, anche se più lenta.
    Non gli conviene, il senso di Iray è vendere GPU.
    Ecco perché ha senso muoversi verso Filament, che è opensource, oltre che molto più veloce.
    Infatti, stessa cosa che ho pensato io.
    Spero che implementino davvero Filament. Se è leggero come motore, lo userò volentieri ma se è un'altra trappola "Gombra sgheda bideo, belo belo, urk!" non mi prenderò nemmeno la briga di attivare il DLL. cool
    E' sviluppato da Google e open-source, no Nvidia!
    Però cercano di fargli usare i materiali Iray.
    Sto cercando magiorni informazioni ma non trovo molto... é GPU o CPU Based?
    Le demo non dicono molto, sono pur sempre delle preremderizzazioni... A me interessava vederlo applicato ad un ambiente manipolabile.
    E' ancora in sviluppo!
    Questa è la pagina ufficiale: https://google.github.io/filament/
    C'è un cosetto con la testa di una scimmietta che puoi muovere in tempo reale.
    Nel progetto su GitHub ci sono molti esampi statici invece, ma a quanto ho capito è sempre real-time.
    By
    LenioTG LenioTG July 2020 in The Commons
    Ah boh!
    By
    Imago Imago July 2020 in The Commons
    Ah boh!
    By
    Ah boh!
    By
    Ah boh!
    By
  • Home 3d printers?
    Meshlab and Cura are both free, good, easy to use, and work well with the Ender-3 (my son uses Cura a lot with his Ender-3).
    I used Meshlab when I had a filament printer. I quite liked it.
    My resin printer came with an absolutely awful slicer and I got Chitubox and think very highly of it.
    By
    kenshaw011267 kenshaw011267 July 2020 in The Commons
  • Home 3d printers?
    if you are using an XYZ build up printer of any sort, the model needs to be put through a slicer, holes filled and supports added for overhanging mesh.
    Resin this is not an issue
    don't ever buy a DRM protected printer like me!
    even buying the genuine filament it did not identify the built in chip in the cartridge and won't work and their customer service basically told me to sod off
    By
    WendyLuvsCatz WendyLuvsCatz July 2020 in The Commons
  • Home 3d printers?
    does ds print directly to the printer?
    does mudbox?
    like, what modeling software can print directly to the printer?
    my dayjob bought a 3d printer.  so excited.  dunno what make and model yet
    they deliberately torturing me.  been begging for one for years lol
    No
    No
    None that I'm aware of.
    DS, and mudbox I assume, can produce OBJ files which then need to be run through a slicer program. That converts the OBJ file into g-code instructions for the 3d printer.
    Get a good slicer as getting infill, supports and bases right will save you lots of filament and heartache from failed prints.
    TBH I'm not a modeler and do all my printing from files produced by others. For me STL has always worked out better than OBJ but YMMV.
    Also 3d printing is not one of those things where you can toss the manual and figure it out. Read your printers manual and find any tutorials you can online. Even very small issues can completely prevent the printer from producing useful prints.
    By
    E se selezioni entrambi?
    Faceva uguale. Parlo al passato perché dopo tre pulizie e reinstallazioni di driver video, parrebbe tornato tutto alla normalità; ma data la mia imbranataggine, tenetevi pronti che probabilmente salterà tutto di nuovo. Speriamo di no e Grazie mille per l'aiuto smiley
    Chiedi pure! wink
    Qualcuno ha già provato l'ultima General Release? Dal Chengelog sembra abbiano inserito Filament come nuovo DrawStyle... Mi piacerebbe provarlo, ma non mi posso permettere di rompere qualcosa con l'ennesima release rotta. sad
    Per cui, qualcuno può confermare questo e se hanno finalmente riparato la timeline, cortesemente? cheeky
    *EDIT*
    Fa nulla, ho provato io, grazie lo stesso. smiley
    Tutto fracassato come prima. La nuova build è ancora inutilizzabile. Io davvero non capisco perchè ignorino tutti quei bug. Un sacco di utenti sono rimasti fregati e stanno avendo gravi e numerose perdite di dati.
    Inconcepibile.
    By
    Imago Imago June 2020 in The Commons
  • Daz Studio Pro BETA - version 4.12.2.60! (*UPDATED*)
    I do so hope they fix the animation issue with saving morphs. I just wasted a morning rendering an animation that I saved yesterday only to realise that many of the morphs I had animated are now static. Damn, I could scream!
    It's strange because this bug occurs in this public beta and the normal current version of daz. The same thing happened to me. They are aware of this issue and I hope it is fixed sooner than later because it has been around for a month. I contacted customer support and they were able to send me the older version 4.11 which works for what I need. Maybe you could do the same if it fits your work style. I feel your pain though.
    For now, I'm just trying to make sure I render before I save and exit. Otherwise I have to try to remember what morphs I tweaked and try to reproduce them. It seems a while since the last fix version (Beta) so hopefully there is one due soon.
    There hasn't been a single entry in the Change Log since the release of 4.12.2.6 Public Beta. But then maybe they have stopped updating the Change Log, too. The Highlights Thread hasn't been maintained for several versions now.
    Probably means they are in really, really deep with the alpha. Maybe we'll get the Filament Renderer or Pro Renderer next beta? Now such a big deal for nVidia GPU loyalists but it is for everyone else.
    By
    nonesuch00 nonesuch00 June 2020 in Daz Studio Discussion
  • Something big is coming!
    "After I left my computer to go exercise, I remembered that the real time PBR renderer Google Filament was in the DS release notes a while back, but didn't actually show up in the beta. The more I thought about it, it makes more sense as the "something big", since they were obviously close to releasing earlier, but for some reason they delayed the release. For me, that would be pretty big news. I love Eevee in Blender, having something similar in DS would be awesome!!"
    Oh man, that'd be awesome if it's a render engine like Eevee! I just finished a ten minute short using Eevee and it turned out fantastic. The shots were rendering quicker than I could get up, get a drink and sit back down. I'm about to start a feature and would love to be able to just stay in Daz and do everything there. Let's see what happens tomorrow!
    By
    benniewoodell benniewoodell May 2020 in The Commons
    Google Filament replacing the realtime OpenGL renderer as the default viewport engine? One can only dream :)
    By
    t0mg_z t0mg_z May 2020 in The Commons
    The Filament or ProRender engine integrated directly into DAZ Studio. I'll guess ProRender. Or maybe DAZ Studio support of this new Disney open exchange format, USD.
    By
    DustRider DustRider May 2020 in The Commons
    Really - so much wishful thinking in this thread that it should merge with the Wishful Thinking thread. If the hint is something "big" and they show a picture of a new big character, then my guess would be that he is the something big. As for the wishes - soft body physics would be good. Google Filament slightly more likely. Please don't let it be G9 though - I'm still stocking up on G8F stuff and also G3M because I don't use G8M.
    By
    marble marble May 2020 in The Commons
    By
    nonesuch00 nonesuch00 May 2020 in The Commons
  • Novica & Forum Members Tips & Product Reviews Pt 13
    This is spooky: https://www.instagram.com/p/CAqRWRBJTir/?igshid=
    i wonder what Daz is up to?
    It looks to be almost definately a new pro bundle comprising of the 'muscle-bound' character that, either Soto or RawArt, I forget which, was asking about in the Commons of the forums.
    Or from the looks of that self smoking cigarette maybe the Filament renderer goes into beta in DAZ Studio?
    By
    nonesuch00 nonesuch00 May 2020 in Art Studio
  • 3D Printing
    Is there any information on how to do it please?
    great discussion !!! kindly help me out which 3d printer is  best of personal use.
    Will daz clothes 3d print, if not how do you fix it
    not without a lot of supports. you have to scrape off supports after you print it. And supports always leave a bad mark  on the print.
    However if you get a printer with 2 heads you can use a PVA filament for supports, which dissolves away in water.
    Or you can look into resin printers, which I hear are better for miniatures.
    heres a test print of a DAZ character I did, using the 3d Solutech skin filament.
    I know abought the supports but will clothing & hair print
    clothing is ok. hair will not print well because of the very thin strands. You will need to use a low poly hair like the ones in this promo
    https://www.daz3d.com/sculptural-genesis-8-ultra-fun-kit
    By
    davidtriune davidtriune May 2020 in Daz Studio Discussion
  • 3D Printing
    By
    diron_di_b47b68ada8 diron_di_b47b68ada8 May 2020 in Daz Studio Discussion
  • 3D Printing
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
