• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Is There A Plan To Speed Up G8 (and future generations) Loading Times?
    thenoobducky said:
    I interpret Richard's comment as saying reading the file from disk is not the bottleneck, which I think is correct, it is converting from the text file to objects that Daz can use that is slow. Put it another way, reading file not slow, scanning the content of the file to figure out what to create slow. Daz would need to parse all the formulas to figure out what the figure would finally look like. Because there is no mechanism for Daz to figure out if a formula is active or not (my limited understanding is a formula can either by an input like a dial or applying the dial to something so daz need to figure out the value of all dials and apply all the formulas even if most inputs by default are zero). This is also the reason for morph corrupting the default figure. Now I think about it, this part what is what is causing the load time to be slow cannot be skipped unless there is a way to tell Daz don't load this morph (currently done by hiding it from daz). Why this is not trivial to multithread is addressed below.
    If parsing the file would be a bottleneck then multithreading would be an obvious solution  as I understand bottleneck is the function that populates morph dependencies with appropriate formulas
    No what I mean is if I have a figure loaded and then I unhide a character preset or morph set, I can't use it unless I reload the figure because there is no other way to get new shape dials and pose dials to appear.
    This is not a problem because Daz should read all names to get a list of sliders and built all that property tree, It should just not go any deeper and don't loom at their dependencies until something from that tree is activated.
    The senario I want to be addressed is this: I have a figure loaded. I install zev0's Shape Shift, how do I use it without reloading.
    Getting a way to delay load morph / reload morph contained in a base directory would really improve
    This would be pretty easy to do if morphs are straightforward, but unfortunately, the Daz logic is too perverted here. which I will explain later
    I agree its possible to multithread, just the implementation will be non trivial. The issue to consider is: thread 1 load morph A which reference morph B, at the same time thread 2 is loading morph B. How can thread 1 figure out morph B has been loaded or not. Its solvable but care must be take to ensure the solution dont accidentally end up being single threaded. Another issue: thread 1 create morpha A with name X, thread 2 create morph B also with name Y, how does Daz ensure the names are unique because duplicate formula is an issue that need to be detected.
    If you look at the morph properties it is not that hard, after all, you can see that every property parameter contains Sub-components and controllers  list which has to be populated, (I think populating that list takes most of the time.)
    I can't see any problems with multithreading because every entry in that list is independent. You load a morph and then add the appropriate formula to the appropriate list the order of how things will be added to the list does not matter.
    What do you mean correction morph, I guess you are talking about erc formulas? Can you give some concrete example? I find all the talk so far about high level concept a bit confusing and too much guess work. I think what is slow is loading formulas, but a lot of formulas are actually morphs and expressions. For example, Victoria 8 have something around 60-70 morph file, each file contain around 2 formulas. Whereas eJCMSilly_HD_div2.dsf from Genesis 8 Female Expression pack can have 100+ formulas.
    Now a formula looks like this:
        "output" : "Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Base%20Pose%20Head/eCTRLNostrilsFlex.dsf#eCTRLNostrilsFlex?value",
        "operations" : [
        { "op" : "push", "url" : "Genesis8Female:#Z%20FO%20Angry?value" },
        { "op" : "push", "val" : 1 },
        { "op" : "mult" }
    As you can see, Daz know where to find the formula it references. So that is no a problem. One problem would be in a multi thread safe way to figout out if the output it refernces already exist or is being created by another thread or it need to create it. Again now I have think about this a bit more, the issue is Daz dont know if this formula will result in no change at all or cause some morph changes until Daz parsed the formula and applied it, which is the slow process we are trying to avoid here. There is no mechanism to tell Daz to skip formula in this folder until I tell you to load it functionality. I think something like this for advanced user would be useful.
    Another problem, for example I like to use Zev0's shape shift which contains lots of formulas, but I use it often when creating a character so I would like Daz to always load it. How would Daz know which morph need to be loaded? Currently the only way is to selectively add base folders, this is almost workable with manual curation of installed files, or program to automate it, maybe Daz can come up with a better approach (maybe by reworking the way files are installed).
    In short we need a better way to optionally tell Daz skip loading certain folder until it is needed by some file.
    I can't comment on that because I need to see a complete picture, I will give an example in the next post
    By
    onix onix April 2021 in Daz Studio Discussion
  • The Newest Evolution Is Here: The Daz Season Pass!
    Brooke 8.1 in the Season Pass — does this hint at the return of Liquid Rust??? yes cool
    Remember Brooke 2.0 for Victoria 4?
    https://www.daz3d.com/brooke-2-0
    By
    Kaleb242 Kaleb242 April 2021 in The Commons
  • What’s the deal with G8.1?
    ArgleSW said:
    The 8.1 generation appears like an art direction change rather than an update. My issue is that the art is shifting towards a more stylized look (cartoony/exaggerated features). When you mix classic 8.0 with 8.1 models in the same scene, they don't match well. Yes the older gens offered a mix of cartoony and photoreal characters, but my point is more about the overall art direction as a whole for Daz. Not sure if Daz got a new artist recently but the direction is changing fast towards this. Maybe stylized sells better and more people prefer this, but in my opinion this is not ideal in the long run. Hopefully this was just the case for the first few 8.1 models released.
    Look at the comparison in this image. Using the same textures, the only difference is the face morphs using Michael/Victoria 8.0 vs 8.1. Which one looks closer to real?
    8.1s  victoria and Mike are college age so their look is a lot younger than Version 8. Daz store seems to equate youth with toony.
    By
    Serene Night Serene Night April 2021 in The Commons
    What's even the difference between a $45 "core" or "base" figure and a $20 PA character these days, aside from $25 price hike for an official Daz endorsement? In the old-old days, all characters were built off the small number of base characters so they were essential. In the less old days, they became characters that lots of other characters were built off of, not necessarily essential but nice to have with good quality textures and shaping. Now, they're pumping out new characters faster than they can QA and it doesn't seem like many other characters use them as a base (probably why they've been renamed "core" figures).
    Can't imagine wanting to collect them all sight unseen, but at the very least, I'd wait until a better sale than the season pass. Something like Victoria/Michael has brand recognition at least but the rest of the traditional base figures (Aiko, Hiro, Gia, Monique) seem to have been skipped for things like Cleopatra.
    Damsel said:
    And why the heck would I want to buy a sprite of somebody I've never heard of? NFTs? I know I'm old, but that makes absolutely no sense to me. Why spend money for a gif that's all over the Internet, for God's sake?
    You're not old. I mean, maybe you are, but that's not why you're confused why anyone would want the $100+ Shudu sprites. They unstickied the NFT thread presumably because no one wants or likes the NFTs. Most of the NFT sales, and only a couple have sold, seem to be going to one buyer. From what Diigitals has said, it looks like they got into NFTs for the hype and didn't bother doing research first. The only artists who seem to defend them are a small number of established, already highly successful professionals (but none here, even Shudu's creator seems to regret not doing research first), and for buyers it seems to just be wealthy tech enthusiasts, the kind who get enthusiastic about new tech for the sake of being shiny new tech, and even then largely just wealthy folk interested in speculative trading through the block chain.
    By
    ArkadySkies ArkadySkies April 2021 in The Commons
    A while back, there was a blog entry that said DAZ got a new art director. https://blog.daz3d.com/daz-interview-series-corey-belina-daz-3d-art-director/ But I don't think that has to do with the 8s and 8.1s that were Art Station buyouts. Those characters seemed to have been done independently before DAZ got involved with them. I personally don't mind the toon look ("realism" gets dated fast), but with toons you're often limited to that one style, unless you can shape your own with another app.
    By
    MimicMolly MimicMolly April 2021 in The Commons
    onix said:
    I was talking about different issues here. Building your morph on top of another morphs is normal.
    Let's say you want to create a smile expression morph for your character which will reference victoria 8 smile.
    normally you would just create an expression folder for your character and populate it with your custom expression morphs that refer to morphs of other vendors.
    but some perverted vendors rather do this:
    They insert extra logic into the genesis 8 smile expression morph which tells it that if character X morph is activated activate Smile correction morph for character X. You will not even be aware that you got a custom expression morph along with that character.
    So if you will ever install this character it will be sucking your CPU power forever because every time you use smile morph that formula for character X (which you maybe never even used) will be executed.
    And how many vendors may have JCMs that are constantly hooked to character joints and every time you change your pose Daz has to process hundreds of those parasitic formulas that do nothing else but just check if character X is loaded?
    What if the vendor screws up and makes that his JCM gets activated all the time not just when their character is loaded? Now your figure will be screwed up forever because you have no way to even identify buggy JCM
    Can you give an example of this? I would really like to see it.
    Edit: Also I dont get the point of it, For example, anything in /data/Daz 3D/Genesis 8/Female/Morphs get loaded when you load genesis 8 female. Normal convention is morph for a product go to /data/Daz 3D/Genesis 8/Female/Morphs/Vendor/Product. So it would get automatically loaded already, placing things in /data/Daz 3D/Genesis 8/Female/Morphs/Daz 3D/Character would give no benefit and would not be treated any differently by Daz. The buggy JCM would easily be part of the vendor's file.
    By
    thenoobducky thenoobducky April 2021 in Daz Studio Discussion
    onix said:
    I think Daz already have those infomation stored with the formula, but the question is what would be the trade off. A system that delay load everything would have less consistant performance when applying a pose or expression as daz have to find missing morphs. It could be slower for people with fewer morphs installed as it makes harder to cache things, resulting in more file I/O that would be slower. Should Daz scan all morphs files to create all the sliders for shapes and poses, because this is very useful for novice user to find things they need. But scanning all those files and creating slider might be half of the required work already and might just as well go ahead and finish creating the formulas so it will just work.
    Richard explained that all this scanning task is not really that time-consuming to care about and it can be multithreaded easily. also it can be safely deferred and just continued after your scene is already loaded.
    Hiding stuff from Daz wont fully fix the issue because then you can't use an expression or morph that is not loaded until you reload the character / scene. Some sort of load formulas used by this character / expression / shapes function would be super useful.
    Of course, you cant use what you hide, but the reason to hide things I precisely because they are not required in that scene
    With regard to multithreading I can see how to figure out if a formula referenced in another formula already exist or being made in a thread safe way being a difficult problem to tackle and have potential to accidentally make everything single threaded.
    If you think more actually there is no reason why multithreading cannot be implemented even now.
    My guess in how Daz works is that first, it loads a full list of morphs then it iterates through every one of those morphs and populates controllers and subcomponents lists. so every correction morph that has controllers has to scan at least half of the full list every time to find where it will inject references to itself.
    This process can be easily multithreaded as you can process multiple morphs at the same time
    In short, any way to solve a complex problem will have advantages and disadvantages. I would prefer things to work correctly over being fast, and beginner friendly over complicated to use but faster for advanced user. But there are definitly still rooms for improvement. For example some sort of rescan a selected base directory to add newly installed morphs functionality would be useful.
    In my understanding, the main problem here is with correction morphs as this functionality srews up everything and possibly can be the reason why loading times are so long in the first place (unless Daz actually spends most of the time allocating memory for formulas and inserting them into the table)
    Correction morphs are the reason why you can't know in advance what files you need to load because any of those new files may decide to hook up on something random in your existing system.  And if you are very paranoid about not missing any of those correction morphs you have to rescan everything every time you load a new file as you probably can not even know if some of the correction morphs wanted to reference your new file and did not find it at that time.
        "operations" : [
        { "op" : "mult" }
    By
  • How to fit V4 (victoria 4) hair into G8F (Genesis 8 Female)
    Hello Friends,
    I want to add a V4 hair (preferably the wet hair for V4) to my Genesis 8 Female. I used RSSY Hair Converter v4 to G8F tool, but they are not loading the files at all. I use the latest Version of DAZ Studio i.e. 4.15
    So I am now looking for an alternate way to do so.
    If anyone can help, please let me know.
    With regards,
    Souwrit Ray
    By
    souwritray2009 souwritray2009 April 2021 in Daz Studio Discussion
    By
    ArgleSW ArgleSW April 2021 in The Commons
    PerttiA said:
    It's not only JCM's, but also morphs and characters from some other PA, as one cannot copy the work of someone else to one's own product.
    If you make a character that is built on top of Victoria 8, then the dial for your character should activate the Victoria 8 dial as well. The same with products like "Growing Up" or even the DAZ Head and Body Morphs.
    By
  • IRAY Photorealism?
    Padone said:
    j cade said:
    So I went into the shader editor and added backscattering ..
    How does this differ from the sss direction in the uber shader ? Below an example with Victoria 8 where I added backscattering via sss direction, first and after. Also it seems that the sss backscattering reduces the transmission backscattering that comes from back lights, that makes sense. So I'd not go with very high sss backscattering to avoid a "plastic" effect.
    It's... Completely different? The backscattering node is a specular effect it works roughly like the velvet node in blender. What you're doing would have no effect to counter the darkening of the specular at the edges which is what I am using it to correct for.
    By
    j cade j cade April 2021 in Daz Studio Discussion
    Jason Galterio said:
    Granted this is a gamble, but I weighed the risks and figured it was worth it.
    Length of the Season: Already stated ~2 months. I am expecting it to be about 10 weeks. Which would mean a new base figure every two weeks. Maybe once or twice with only a week between. So that would be 8-10 weeks.
    Random Figures: I would have probably picked them up anyway. They are usually fairly varied as they are the skeleton that the derivative morphs require. I usually don't buy those. At the very least they should have varied texture maps.There is usually enough difference between the bases that this will make it worth while.
    HD Morphs: I don't normally add these on since I don't usually do close up renders. However I have been trying to get better at these and with the advent of 8.1 facial rigs, this seems like a good vehicle to experiment.
    Random Package: This is probably the biggest gamble of it for me. If the ad text had said five or ten random items then I would be concerned that they would be minor or inconsquential give aways. Since there is only two I expect they will probably be moderately substantial; an environment or a wardrobe set that might be themed around one of the base figures.
    Contest: Honestly, probably won't participate. But I don't see this as quantifiable benefit anyway.
    Forum Flair: Don't really care for it, but then I am not overly active in the forum anyway.
    Early Access: If the timing is right, this might be useful, but again, not something I can quantify into a value.
    Online Lesson: This caught my eye as I was curious what might be covered. If it will be about using the 8.1 facial rig, then I would be interested in that. DAZ hasn't really given online lessons themselves and documentation has been lacking in the past. I am hoping that participation in this might set a precident going forward.
    I really don't think this "Season Pass" will be an every two month thing, just because of the overhead. If it was..
    1. There would be 30 new base figures in the next year. (5 Base Figures x 6 Season Passes.) As well as 6 online lessons. I just don't see this happening.
    2. The "Season" part of the Season Pass denotes no more than four times a year. The games I can think of usually use 4-5 month seasons. So maybe this will go for ~2 months with an equal amount of cool down.
    3. I don't mind "paying in advance" for the development of new models. I've paid years in advance for albums, knowing that the prepayment was going directly towards the development of the album. So it's not a foreign concept to me.
    It's the first time out for this, so I am willing to give it a shot and take a leap of faith. Will I regret it at the end? Possibly. I doubt it though. At worst I might have a "meh" attitude.
    However, being in on the ground floor means I may be able to offer input to the development. Whereas, if I hadn't bought in, my opinion would mean nothing. I'm not banking on having an input, but as many people said, talking with your wallet works.
    Victoria 8.1 launched on 20 January IIRC. Now we already have Michael, Cleopatra, Torment and August, so having 30 core figures in one year is not unattainable
    By
    CHWT CHWT April 2021 in The Commons
    By
    Padone Padone April 2021 in Daz Studio Discussion
    Many years ago a couple of friends and I saw a sign for an outdoor auction about to take place as we were walking home.  None of us had any money, but we decided to take a look.  For entertainment value it was a good decision.  The auctioneer was a great salesman - he was funny, he had all the patter and he kept things moving, even though he looked and sounded like a sleazy used car salesman.  What I remember the most was that he asked the crowd if anyone wanted to take a £1 gamble on the next lot.  He managed to convince about 15 people to do so and then revealed that they had all just bought a box of laxitives.  No one really cared and there was some good-humoured laughter from the people who knew they had just been conned.  I seem to remember some people getting good bargains on used office equipment that day, but it's the, "Come on, risk a pound on a gamble..." part that I remember.
    I mention the story because this is how I felt that day (my friends and I didn't fall for the £1 "deal" because we had no money anyway).  With the Season Pass, Daz is saying, "Give us your money and trust us that we will give you something nice in return."
    I made my first Daz purchase in 2004, and then like many others I spent a lot of money here over subsequent years until around 2012-13 when I stopped buying anything here other than an occasional item once or twice per year because I felt very betrayed by the company over the whole Poser/DS thing.  But..I came back to give Daz Studio and Daz3D another chance in 2017 after seeing the results possible with iray and the newer Genesis 3 and 8 models.  In the next few years I bought every pro bundle because of the fantastic deals - usually a few of the Genesis 3 Pro bundles that I had missed in my time away.
    Lately though, I haven't bought any of the new bundles.  I've got about half a dozen of the later Genesis 8 pro bundles wishlisted and I bought Victoria 8.1 to take a look at how much of a leap it was from Victoria 8.  This is the first "March Madness" in years where I have not bought anything.  Some of this may be because I have a lot of content to work with now, but a lot of it is because I don't like to feel that I'm been ripped off or taken advantage of and many of the latest bundles are starting to feel like that.  These days I am more likely to go for a PA product such as Ultrascenery or Analglyph3D that adds some more functionality to DS.
    Add to this the recent NFT thing and the movement of the Forums and Gallery into a single tab on the front page to accomodate the NFT link.  To me it is the same as what a lot of companies do - "We'll put our old customers over there, they'll put up with anything, whilst we try out a new market and see if we can get some better customers."
    Right now, I'm torn between going for what may indeed turn out to be a great deal on new figures and the HD add-one, versus Daz3D's recent history.  Daz3D also have a long history of over-hyping upcoming products/events.
    Like many other people here, I WANT to trust Daz3D and buy the season pass both in the interests of getting a bargain and to support a company that does have the best 3D content available for non-professionals like myself.  But...There is way, way too little information on what we are getting.  I keep thinking back to that auction salesman from 25 years ago and can't help feeling the same way I did then.  Give us all some more information - what will happen to discounts on whole bundles, how many male/female characters will there be in the 5 base figures, what are the 2 free items?  Are they going to be something new, or are they going to be from the ancient back catalogue of items that I don't have because I didn't want them the first time around?
    By
    Dim Reaper Dim Reaper April 2021 in The Commons
    onix said:
    Also, not every character is the same. I just now noticed that some very clean and contain just one of a few morphs while others litter everything with correction morphs for an unknown reason. Probably some creators believe that they are super smart when they inject correction morph into existing morph from another vendor rather than inserting that existing morph of another vendor into their own morph.
    By
    PerttiA PerttiA April 2021 in Daz Studio Discussion
    nicstt said:
    I don't need more characters - especially as I'll put money on them being merchant resource textures.
    So... Pass.
    ...+1
    As I primarily dial spin most of my own characters, unless I see a new character base that will add something unique to what I refer to as the "gene pool" (like custom sculpted facial details or a unique base shape that isn't just another "supermodel" or "hunk") I'll pick it up.
    I work so heavily with morphing (I have lots of morph resource kits for both G2 & G3  which I can combine through GenX2) tothe point that sometimes clothing will not autofit well on some characters.
    AbyssalEros said:
    Up to Victoria 8.1, I bought every single Pro Bundle since I joined DAZ. Although, the buying enticements for them have deteriorated bundle for bundle while at the same time the quality of the included assets deteriorated noticeably.
    Since Genesis 8.1, the bundles are even more expensive with near to null buying enticements at all.
    While I was initially curious about 8.1, I read about enough issues with 4.15 to keep my distance from it.
    Many creators who depend on a working DAZ Studio installation recommended me not to upgrade, as they regret having done it or have fallen back to an older version, where possible. Thus 8.1 is no question for me before DAZ Productions, Inc. is able to fix all the know issues.
    Therefore I have not bought a single 8.1 bundle, and I do not see myself buying one soon.
    For not having bought any of those new bundles, even though I own all Genesis 8 Pro Bundles and most of the Genesis 3 ones, and many more assets worth several thousand dollars, DAZ is not offering me anymore "Loyalty" banners on new bundles. I do not count those bundles where DAZ graciously offers me a 70%+ discount when I own every single asset or only miss one.
    I really see no good in this Season Pass at all.
    And "loyal" but somewhat unruly customers like me that do not have embraced Genesis 8.1 or even Genesis 8 cannot feel differently than feeling affronted by this season pass.
     [bold ephasis mine]
    ...+1 as well.
    I have very few character bundles, several of them only because they were offered for free on a banner (or extremely discounted) or, as in the case of V5/M5, was a bonus offer with my purchase of Carrara 8.5.  In the few bundles that I actually purchased, I pretty much everything that was included had a use (which is a rarity).
    By
    kyoto kid kyoto kid April 2021 in The Commons
     I think a short tutorial on ERC formula and how Daz store / find / load / use those formula would be beneficial in this discussion. That way people would understand how things work, why it work that way, the benefit and limitation and possible alternatives.
    onix said:
    Because of that behavior, I potentially could create a morph that turns on morph A from vendor X if Morph B of vendor Y is activated without the user even being aware of what is happening which is a huge security issue.
    I can see this be very useful for things like clothing fixers or conversion tool.
    Also, it seems that the loop could be formed when CM's start correcting each other
    This is a bad design in principle which was not that visible in the beginning but now manifesting itself and pretty hard to fix. Probably it would be still the best idea to get rid of all those correctives entirely.  There are better ways to get the same result.
    Daz have logic to detect circula references as can be observed by reading log file.
    " If you hide morphs how do you know you are dealing with all the associated files? "
    Now I understand what you mean because by the Daz architecture if I load Victoria morph  Daz is supposed to load a Corrective for the smile expression which will change the way how "smile" works specifically when Victoria morph is activated and since this Corrective is not mentioned anywhere in the Victoria morph it cannot be loaded.
    Although when we hide files manually this is not an issue.
    The most obvious solution would be to add an extra file to each morph which will list all dependencies of what else should be loaded when this morph is activated.
    By
    In my opinion, MorphSoandso should contain references to JCMSuchandsuch,  and BendThatone.   If not, they should not be loaded.
    But by your explanation, it seems, that's exactly what is happening. This JCM gets loaded then it monitors morph changes and possibly does some corrections by itself without getting permission from the user.
    Since this JCM can't be aware when a certain morph will be activated until it gets activated, Daz creates some kind of complex structure of signals to trigger appropriate CMs which still slows down everything and takes lots of time to load. (which would explain why you don't want post-loading. as that would require a lot of time again to rebuild all that complex structure)
    I would guess that Daz reads all morph files first then it will parse everyone of them and fill the list of controllers and subcomponents for each of them
    And actually just now, I noticed what kind of mess is happening with parameters and how some vendors could be potentially screwing up things accidentally or on purpose by adding CMs to various base morphs without me being even aware of that. Many Daz-provided base morphs are littered with various irrelevant CMs that are not going to be used ever. Nobody even knows what effect they may have.
    All that stuff could be safely removed without any loss and may even speed up everything.
    By
  • [Closed] RRRRR - Coming Late Excuses - Render Contest!
    Ken OBanion said:
    I have to wait until my data plan cycles (tomorrow) before I can upload my render; once I hit my bandwidth limit (which typically is about four days into the billing cycle), I get throttled back to damn near dial-up speeds!  Meanwhile, it’s five o’clock (well, five-till; close enough!), and there’s a Martini in front of me (and a little to my left; thank goodness I’m at least semi-ambidextrous -- well, for the important things, anyway!), and that means it’s time to move on to Round 2!
    The pull:
    2963 – Colors for Love Me Hair (Love Me Hair is for V4)
    37 – Giselle for V4 (How convenient!)
    1724 – Gamine (G3F; that one’s a little freaky-sounding, I don’t know…!)
    6574 – Cozy for Day Dreamer (G3F)
    Victoria 4 and Genesis 3; I haven’t done anything with V4 in ages!
    *Sigh*  Whatever….
    UPDATE: While searching for the Colors for Love Me Hair package, I discovered an entire order that I somehow neglected to download!  From August of 2015!  Thirty-three items, mostly hair and hair textures.  (Practically all Platinum Club, too, so you know I got some really tasty deals on them!)
    You can blame the Martinis if you want.  I am.
    I pretty much knew what I wanted to do with this render from the very start; then, when I saw that nothing in my pull would prove to be an impediment, I just went for it!  I did have to do a bit of experimenting, to get the effect just right, and I made the mistake of thinking the Day Dreamer outfit (required by the Cozy textures) was a Genesis 3 clothing set; it was actually for Genesis.  I tried to fit it to a Genesis 3 figure, and when I imported the clothed figure into the scene, the skirt and blouse kept blowing up!  I couldn’t very well leave her sitting in the car naked (although that is my usual modus operandi), so I swapped her for a genuine Genesis character.
    This entry consists of two separate renders: the first is for validation and verification, to demonstrate that I did, in fact, use everything in my pull; because, in the second image (the “money shot”, as it were), a lot of those items are not readily discernable.  And I jacked around with the camera for more than an hour, in an effort to make them so.  Alas…, it didn’t happen.
    I gave up on trying to visualize the Mach wave.  I figured out a way to do it using Blender, but it also would have required some seriously inventive shader work, and I really don’t think have the shader chops to pull that off – yet.
    Also used:
    Divided Highway by First Bastian (purchased explicitly for this entry!)
    Jepe’s PillarZ and PillarZ II
    Bunny Dazed outfit for Victoria 4 (and dForce worked on it!  I was not expecting that!)
    Shiloh HD for Genesis 3 Female
    Tinkerbell Hair
    Casual Style for Genesis 3 Female (required by the Gamine textures)
    Victoria 5
    Pure Hair Crazy for Genesis
    Day Dreamer Outfit for Genesis (required by the Cozy textures)
    Roads Royds (from Renderosity; they had to name it that, due to copyright considerations.  It is, in fact, modeled after the Rolls-Royce Ghost; unfortunately not the Black Badge Edition.  That is one seriously sexy-looking ride!)
    (And I re-used the Eliot character from my last render, suit, hair, and all, only I made him lose the face-diaper!  Yeah, I recycle; what’s your point?)
    TAG: obanion#2
    Title: Well, This Morning Commute Went Seriously South in a Hurry…!
    “Um…, you probably ought to take the bypass.  Because that thing is liable to booger-up traffic like you cannot even BEGIN to imagine!”
    By
    Ken OBanion Ken OBanion April 2021 in Art Studio
    By
    AbyssalEros AbyssalEros April 2021 in The Commons
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
