Daz Central? No more updates to 4.x??
It looks like the stand alone origianal DS is dead? What's this new "Central" and can I install it without it interfereing with the DS 4.12?
Daz Central? No more updates to 4.x??I decided to check on latest release to download and all I can find is this "Daz Central" thing which looks like it will break everything I have set up.
I DO NOT need a "launcher" or an asset manager and don't want it. I just want the DS program.
Why?
Because I use a separate PC as an asset server so I can render on multiple machines on network which all need to point to the exact same resource on the server so I don't need to try to keep multiple sets of identical assets with idential paths on more than one location. If I produce a DUF file on my production machine than copy to a couple of render machines across network and the assets don't match I'll get scenes missing textures and other bits.
If there will never be any updates to DS 4.12 just tell us so I know I can plan on there never being any future improvements.
I will turn off all updates and block DS with firewall and just chug along with what I have...forever. ( keeping a spare install file in reserve just incase )
It looks like the kind of move Adobe made to eliminate anything but cloud computing basically dooming anyone without a fast, active internet access from using their products. Hurray GIMP to the rescue.
- 1. Production Machine
- 2. Asset Server
- 3. Render Machine
- 4. Render Machine
[SOLVED] Daz Central not showing purchased itemI don't think Daz Central can be used for installing items for other applications, you may need to use Install Manager for that.
[Released] Content Wizard [Commercial]I'm relatively new to Daz but have accumulated a lot of products through sales, all installed through Daz Central. A large number of these (inlcuding recent products) have ended up in "Lost and Found" and I wanted to be able to edit the metadata to get them into more sensible locations and be able to find them. I bought Content Wizard because the listing specificaly says "Create or update Smart Content for any product!"
However it seems it only does this if the item is being newly installed or you have zip files. Because I used Daz Central I don't (I think?) have any zip files for products. So it seems this product is completely useless for my intended purpose (of correcting Lost and Found metadata for already installed items).
Have I misunderstood something? What should I be doing? How should I be doing what I want to do?
Thanks very much for any help or advice.
Content Wizard is more intended for products that don't have smart content at all. As far as zip files, you have them, even if they are not on your system right now. Go to your product library on the daz site, select a product, and then a download zip button is available to the right.
If you are only worried about fixing the categories, it might be easier to just drag and drop between the Content Library pane and the Smart Content pane (I think it was @Barbult who had this great tip but I can't find it right now)
[SOLVED] Daz Central not showing purchased itemDid anyone on here had issue where you purchase something from the shop (in this case it is actually free but still takes you through the purchase process), your purchase history states 'purchase completed' but then the item is not available on your Daz Centre and is not available on DIM either?i. The product in this case is Daz to Unity bridge. I contacted support two days ago but they did not resolve this issue for me.
Thanks,
[Released] Morph Editor for ManFriday's Mesh Grabber [Commercial]Sorry, but I'm not familiar with how to download the zip files via DIM or Daz Central. Am I missing something?
You should seriously re-think using DIM. Although it uses the target directories specified by the PAs which are sometimes not optimal or even include typos it makes your like in >90% of cases much easier. With DIM & ContentWizard I am rarely touching my library folders manually.
Regarding MeshGrabber its a tool. Therefore after install you neither will find it in Smart Content or your library folder. Instead it installs to the program folder (usually under applications). You invoke it using the tools menu in DAZ.
Had no problems with installing under Catalina (10.15.6).
[Released] Morph Editor for ManFriday's Mesh Grabber [Commercial]Unfortunately, I dislike installing via DIM/Daz Central ... prefer to put things in place on my own. Guess I'll have to bite the bullet on this one.
dForce Kay Hair Loading Without Textures or ColorI think you found one reason I backed myself out of Daz Central after it was released. I messed up my file structure and took me a bit to fix it. I stay away from it like the plague now.
Good luck on your renders!
dForce Kay Hair Loading Without Textures or ColorOkay, I found the problem. I reinstalled with DIM instead of Daz Central, and suddenly there were options for "Preview Hairs" and "Preview Render" that didn't show up previously.
[Released] Morph Editor for ManFriday's Mesh Grabber [Commercial]It's totally ready for primetime, I think. In fact it's been tested since December on Windows so the early bugs have been ironed out, hopefully.
There are currently some problems with stand-alone installers for the Mesh Grabber for the Mac. We decided to not delay the release until these issues were fixed because it seems a bit difficult and release the Mesh Grabber products for DIM / Daz Central only. Even if you don't use them otherwise I would recommend to use them this one time for installing the Mesh Grabber products. Or at least use them to download the ZIP files and then you can place the files into the /plugins folder manually.
Sorry for the inconvenience!
OT, Mornington Crescent: Round 8 :- (Tudor Court Rules)Well, if you are going to go all quantum I will perform a Schodinger triple Axel and Jump to end up with
Archway>Holborn>Arsenal>Tufnell Park>Hyde Park Corner> Hounsow Central>Archway>Monument>Archway>Stepney Green
Mor
[rolls dice]
den
Oh.
[Released] Materials Wizard Bundle [Commercial]Hi RiverSoft and Community!
Bought MW Bundle a couple of weeks ago and had installed and reinstalled it several times through Daz Central and also Daz Connect. It presented errors that were fixed (at least once) and now again, I cannot load the script... any ideas?
Attaching screenshot...
Here it is the log file (regarding this issue):
2020-10-18 23:00:20.737 Loaded image izanami legs diffuse.jpg
2020-10-18 23:00:21.113 Loaded image izanami face diffuse.jpg
2020-10-18 23:00:21.531 Loaded image izanami torso diffuse..jpg
2020-10-18 23:00:21.649 Loaded image eyelashes2.jpg
2020-10-18 23:00:46.015 Loading script: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_70675/scripts/riversoft art/akrs materials wizard/akrs materials wizard.dse
2020-10-18 23:00:46.043 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_54451/data/riversoft art/common/rsconstants.dsa
2020-10-18 23:00:46.200 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_70675/data/riversoft art/common/rsmaterialswizardconstants.dsa
2020-10-18 23:00:46.216 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_54451/data/riversoft art/common/rsbuildpanels.dsa
2020-10-18 23:00:46.235 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_54451/data/riversoft art/common/seedrandom.dsa
2020-10-18 23:00:46.250 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_54451/data/riversoft art/common/rshelperfunctions.dse
2020-10-18 23:00:46.260 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_70675/data/riversoft art/common/rsadvhelperfunctions.dse
2020-10-18 23:00:46.296 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_64785/data/riversoft art/common/rs2019helperfunctions.dse
2020-10-18 23:00:46.310 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_64785/data/riversoft art/common/rs2020helperfunctions.dse
2020-10-18 23:00:46.319 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_70675/data/riversoft art/common/rsmaterialswizardfunctions.dse
2020-10-18 23:00:46.381 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/My DAZ 3D Library/People/Genesis 8 Female/Materials/AKRS Materials Wizard
2020-10-18 23:00:46.401 WARNING: QString::arg: Argument missing: /Volumes/XDISK/Users/Public/Documents/My DAZ 3D Library/People/Genesis 8 Female/Materials/AKRS Materials Wizard/Ultimate Body Salon, Genesis 8
2020-10-18 23:00:46.401 WARNING: QString::arg: Argument missing: /Volumes/XDISK/Users/Public/Documents/My DAZ 3D Library/People/Genesis 8 Female/Materials/AKRS Materials Wizard/Ultimate Body Salon, Female
2020-10-18 23:00:46.401 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/My DAZ 3D Library/People/Genesis 8 Female/Materials/AKRS Materials Wizard/Ultimate Body Salon
2020-10-18 23:00:46.402 DEBUG: Preset Directory /Volumes/XDISK/Users/Public/Documents/My DAZ 3D Library/People/Genesis 8 Female/Materials/AKRS Materials Wizard/Ultimate Body Salon
2020-10-18 23:00:46.402 WARNING: QString::arg: Argument missing: /Volumes/XDISK/Users/Public/Documents/My DAZ 3D Library/People/Genesis 8 Female/Materials/AKRS Materials Wizard/Ultimate Makeup Salon, Genesis 8
2020-10-18 23:00:46.402 WARNING: QString::arg: Argument missing: /Volumes/XDISK/Users/Public/Documents/My DAZ 3D Library/People/Genesis 8 Female/Materials/AKRS Materials Wizard/Ultimate Makeup Salon, Female
2020-10-18 23:00:46.402 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/My DAZ 3D Library/People/Genesis 8 Female/Materials/AKRS Materials Wizard/Ultimate Makeup Salon
2020-10-18 23:00:46.402 DEBUG: Preset Directory /Volumes/XDISK/Users/Public/Documents/My DAZ 3D Library/People/Genesis 8 Female/Materials/AKRS Materials Wizard/Ultimate Makeup Salon
2020-10-18 23:00:46.402 WARNING: QString::arg: Argument missing: /Volumes/XDISK/Users/Public/Documents/My DAZ 3D Library/People/Genesis 8 Female/Materials/AKRS Materials Wizard/Ultimate Masks, Genesis 8
2020-10-18 23:00:46.402 WARNING: QString::arg: Argument missing: /Volumes/XDISK/Users/Public/Documents/My DAZ 3D Library/People/Genesis 8 Female/Materials/AKRS Materials Wizard/Ultimate Masks, Female
2020-10-18 23:00:46.403 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/My DAZ 3D Library/People/Genesis 8 Female/Materials/AKRS Materials Wizard/Ultimate Masks
2020-10-18 23:00:46.403 DEBUG: Preset Directory /Volumes/XDISK/Users/Public/Documents/My DAZ 3D Library/People/Genesis 8 Female/Materials/AKRS Materials Wizard/Ultimate Masks
2020-10-18 23:00:46.406 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_70675/data/riversoft art/data/materials wizard/genesis 8 female/themes/themesreadme.txt
2020-10-18 23:00:46.410 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_70675/data/riversoft art/data/materials wizard/genesis 8 female/themes/missing icon.png
2020-10-18 23:00:46.412 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_70675/data/riversoft art/data/materials wizard/favorites.png
2020-10-18 23:00:46.415 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_70675/data/riversoft art/data/materials wizard/missing favorites.png
2020-10-18 23:00:46.418 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_70675/data/riversoft art/data/materials wizard/genesis 8 female/themes/missing icon.png
2020-10-18 23:00:46.419 DEBUG: sThemesDirectory /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_70675/data/riversoft art/data/materials wizard/genesis 8 female/themes
2020-10-18 23:00:46.422 DEBUG: Found: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_70675/data/riversoft art/common/trash.png
2020-10-18 23:00:47.303 WARNING: Script Error: Line 1807
2020-10-18 23:00:47.303 WARNING: ReferenceError: Can't find variable: ChangeFileExt
2020-10-18 23:00:47.303 WARNING: Stack Trace:
<anonymous>()@/Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_70675/scripts/riversoft art/akrs materials wizard/akrs materials wizard.dse:1807
2020-10-18 23:00:47.390 Error in script execution: /Volumes/XDISK/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_70675/scripts/riversoft art/akrs materials wizard/akrs materials wizard.dse
2020-10-18 23:01:02.772 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
2020-10-18 23:01:11.635 "Materials Wizard": Uninstall Succeeded.
2020-10-18 23:01:47.451 WARNING: Object::disconnect: Unexpected null parameter
2020-10-18 23:01:47.451 WARNING: QCoreApplication::postEvent: Unexpected null receiver
2020-10-18 23:01:47.608 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): Tcp shutdown called on a Tcp connection without a shutdown
2020-10-18 23:03:00.096 Iray [INFO] - IRT:RENDER :: 1.1 IRT rend info : Shutting down irt render plugin.
2020-10-18 23:03:20.210 *** Scene Cleared ***Thanks in advance... really looking forward to use the bundle!
Lots of sunshine...
I am sorry for all the trouble you are having. Please make sure ALL of the RiverSoftAVG products are updated. This script is pulling in files from 3 different products: 54451, 64785, and 70675. If any of these are out of date, you will have errors. Personally, I prefer using DIM to install my products, which puts all the files in one place so you do not have these issues as much.
[Released] Character Converter from Genesis 8 Male to Genesis 3 Male [Commercial]Hi Riversoft and community.
I cannot load the script...had installed it through DAZ Central (several times to see if it was a Mercury Retrograde issue
) but the error continues to appear. Here it is the screenshots https://share.getcloudapp.com/JrugxGZY Also the pdf file is corrupted ...
Any suggestions?
The log file (changed the actual disk name for 'XDisk')regarding this operation:
2020-10-19 09:50:50.258 File loaded in 0 min 2.1 sec.
2020-10-19 09:50:50.387 Loaded file: genesis 8 male eyelashes.duf
2020-10-19 09:50:50.485 Loaded Morph Deltas in 0 min 0.0 sec.
2020-10-19 09:50:50.529 Loaded file: XT_PHMMouthRealismHD.dsf
2020-10-19 09:50:50.552 Loaded Morph Deltas in 0 min 0.0 sec.
2020-10-19 09:50:50.554 Loaded file: XT_PBMNavel.dsf
2020-10-19 09:50:50.603 Loaded Morph Deltas in 0 min 0.0 sec.
2020-10-19 09:50:50.605 Loaded file: PHM-BriarHead-LLF.dsf
2020-10-19 09:50:50.617 Loaded Morph Deltas in 0 min 0.0 sec.
2020-10-19 09:50:50.619 Loaded file: LLF-BriarEyes.dsf
2020-10-19 09:50:50.667 Loaded Morph Deltas in 0 min 0.0 sec.
2020-10-19 09:50:50.669 Loaded file: FBM-BriarBody-LLF.dsf
2020-10-19 09:50:50.788 Loaded Morph Deltas in 0 min 0.0 sec.
2020-10-19 09:50:50.790 Loaded file: PHM-BriarHead-LLF.dsf
2020-10-19 09:50:50.796 Loaded Morph Deltas in 0 min 0.0 sec.
2020-10-19 09:50:50.804 Loaded file: FBM-BriarBody-LLF.dsf
2020-10-19 09:50:50.805 Loaded Morph Deltas in 0 min 0.0 sec.
2020-10-19 09:50:50.806 Loaded file: PHMEyelashesExpand.dsf
2020-10-19 09:50:51.485 File loaded in 0 min 0.3 sec.
2020-10-19 09:50:51.489 Loaded file: base mat eyelashes.duf
2020-10-19 09:50:57.535 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
2020-10-19 09:51:01.931 File loaded in 0 min 10.2 sec.
2020-10-19 09:51:01.935 Loaded file: briar necksmoother.duf
2020-10-19 09:51:01.945 DEBUG: Failed to load addon
2020-10-19 09:51:03.193 File loaded in 0 min 0.8 sec.
2020-10-19 09:51:03.197 Loaded file: briar nose.duf
2020-10-19 09:51:03.213 Loaded Morph Deltas in 0 min 0.0 sec.
2020-10-19 09:51:03.217 Loaded file: PHM-BriarHead-LLF.dsf
2020-10-19 09:51:03.277 Loaded Morph Deltas in 0 min 0.0 sec.
2020-10-19 09:51:03.294 Loaded file: FBM-BriarBody-LLF.dsf
2020-10-19 09:51:03.309 DEBUG: Failed to load addon
2020-10-19 09:51:03.602 Finished Loading Character Addons
2020-10-19 09:51:03.751 File loaded in 0 min 52.0 sec.
2020-10-19 09:51:03.757 Loaded file: briar (llf).duf
2020-10-19 09:51:15.105 Loaded image llf-briarbase-torsofreckles.jpg
2020-10-19 09:51:16.552 Saved image: /Volumes/XDisk/Application Support/DAZ 3D/Studio4/temp/d2.png
2020-10-19 09:51:16.717 Loaded image llf-briarbase-headfreckles-nobrow.jpg
2020-10-19 09:51:17.023 Loaded image llf-briarbase-headeyebrows.jpg
2020-10-19 09:51:18.256 Saved image: /Volumes/XDisk/Application Support/DAZ 3D/Studio4/temp/d3.png
2020-10-19 09:51:18.500 Loaded image llf-briarbase-teeth.jpg
2020-10-19 09:51:19.242 Saved image: /Volumes/Xdisk/Application Support/DAZ 3D/Studio4/temp/d4.png
2020-10-19 09:51:19.465 Loaded image llf-briarbase-armsfreckles.jpg
2020-10-19 09:51:20.716 Saved image: /Volumes/XDisk/Application Support/DAZ 3D/Studio4/temp/d5.png
2020-10-19 09:51:20.944 Loaded image llf-briarbase-legsfreckles.jpg
2020-10-19 09:51:22.040 Saved image: /Volumes/Xdisk/Application Support/DAZ 3D/Studio4/temp/d6.png
2020-10-19 09:51:22.172 Loaded image llf-briarbase-torsofreckles.jpg
2020-10-19 09:51:23.364 Saved image: /Volumes/XDisk/Application Support/DAZ 3D/Studio4/temp/d7.png
2020-10-19 09:51:24.675 Loaded image llf-briarbase-torsofreckles.jpg
2020-10-19 09:51:25.022 Loaded image llf-briarbase-headfreckles-nobrow.jpg
2020-10-19 09:51:25.100 Loaded image llf-briarbase-legsfreckles.jpg
2020-10-19 09:51:25.219 Loaded image briar_eye_3.jpg
2020-10-19 09:51:25.315 Loaded image llf-briarbase-armsfreckles.jpg
2020-10-19 09:51:25.421 Loaded image llf-briarbase-teeth.jpg
2020-10-19 09:51:25.612 Loaded image g8mbaseeyelashesmaptr_1006.jpg
2020-10-19 09:52:20.947 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
2020-10-19 09:53:15.313 Loading script: /Volumes/Xdisk/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_64785/scripts/riversoft art/character converter/character converter g8m to g3m.dse
2020-10-19 09:53:15.314 Failed to load script: /Volumes/Xdisk/Users/Public/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_64785/scripts/riversoft art/character converter/character converter g8m to g3m.dse
2020-10-19 09:54:12.493 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0Lots of sunshine.
Thanks in advance.
It's definitely not installed properly. The icons do not even show up. Do the files even exist in that location?
Beta for DazCentral, your new Content ManagerDaz Central isn't designed to install the whole library on a new computer, all the products are not displayed at once.
Show Us Your Iray Renders. Part VIIOne of my most favourite figures is Alexandra 8. Here is a render with her HD add-on version. Standing ovation to the artist(s) responsible for her creation.
The lighting comes only from the default scene light, and the room lights. I removed a wall infront of her, but I left the wall light in place to make it seem like there is a balcony or a large window reflecting on her brooch, which was originally white. I changed the large central pearl to a red gemstone to allow a better lighting effect. I also recoloured one row of the smaller gemstones to dark red.
I hope you like the scene.
A Warm Smile
Gallery link with a list of the products used: https://www.daz3d.com/gallery/#images/1107707
An excellent portrait with beautiful lighting.
Cheers,
Alex.
OT, Mornington Crescent: Round 8 :- (Tudor Court Rules)Some research would indicate that the boffins at CERN have released an addendum to the rules (The Tube Quantum Tunneling and Interdimensional Variant) that thus allows for a move thusly:
Stepney Green
A Warm Smile
Update: DazCentral Version 1.5.0.19DazCentral is getting an update!
We’ve made a few small adjustments based on user feedback to continue to improve our newest Install Manager, and now offering offering DazCentral Version 1.5.0.19.
Adjustments to DazCentral 1.5.0.19 include:
- Mac OS/Catalina
We’ve added notarization for Mac OS. This resolves issues that Mac OS users (especially those running Catalina) experienced in previous iterations.
- Multiple (Same) Products
We’ve also resolved the error that makes some products show up multiple times with bridge downloads, despite being the same product.
- New Font
Because of a few reported issues with the previous font, we’ve adjusted DazCentral to use a new font that resolves them.
These changes come in addition to a few other minor bug fixes.
We thank all DazCentral users for your continued feedback and hope you enjoy DazCentral: Version 1.5.0.19!
