• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • Art Deco Statuettes complete imagery
    I did a render of just the statuette's face.
    I didn't want to change the body shape. I assume it is in keeping with the Art Deco look as is, and changing the body would undoubtedly result in a lot of pose tweaking to fit the prop. But I did change the face. I dialed the V8 Head morph to zero and then dialed P3D Hailey in at 50%. From there I added in some head morphs of my own, created from G3 males, and tweaked with G8F Head Morphs.
    Here's the end result:
    Face Detail Art Deco Statuette
    Seen from this angle, the choice to use the short afro hair makes more sense, I think.
    I wanted to mention this so anyone reading this thread could see how easy it is to make their statuettes unique without a lot of hassle.
    Wonderful result and very unique. I love the overall look. heart
    By
    jepegraphics jepegraphics October 2018 in The Commons
  • Novica & Forum Members Tips & Product Reviews Pt 11
    P
    I just connect my iPhone to my USB port on my laptop & then copy/paste my entire iPhone photo directory to my laptop; then I delete the pictures from my iPhone.
    The problem with that was I have so many photos, it just sat there spinning and spinning. After ten minutes, still hadn't started loading. With the Simple Transfer, it was blindingly fast. :)  So yep, I did try that USB route first.
    ADORABLE frog!!!!
    If you get Dropbox or iCloud you can automate the whole thing over WIFI...
    By
    Wonderland Wonderland October 2018 in Art Studio
  • creating clothing in Blender
    Skirts (and the like) can't really be rigged using only the Transfer Utility, they need one or more of
    • posing bones that move the skirt around; SickleYield has templates for many figures which include these or you can add and weight your own additional bones
    • morphs for leg movements, created by sculpting or simulating in an external application, set as needed
    • a dForce Modifier simulated within Daz Studio
    By
    Richard Haseltine Richard Haseltine October 2018 in New Users
  • Where are the highly detailed, muscular HD-Addons for Genesis 8 female? Like Ophelia 7's HD-Addon?
    to see larger version click link to my gallery and the magnifying glass
    this is a seperate hd morph that comes as part of the Zelera 8 HD morph
    Zelara 8 Alien Hd
    https://www.daz3d.com/gallery/#images/669731
    By
    ANGELREAPER1972 ANGELREAPER1972 October 2018 in The Commons
  • Rigging issue
    It's like a invisible barrier cutting into the mesh of the figure.
    Issue:
    Now I get what is wrong, you are using a way too smale scle for the Halo 5 Male techsuit. You must have imported it in the wrong scaling compared to a default Genesis figure. You can also see it by the Floor grid the distance to the next grid line seems very far away behind the figure. The distance from one grid line to the next is 1 Meter. I guess your Halo 5 Male techsuit figure is currently about 10 cm high like a plastic toy figure. Thasts why you get all kinds of issues by zooming and such and the controlls acting too sensitive. The "invisible barrier cutting into the mesh" is actualy called the clipping distance of the Persepective view. You don't have this in the Orthographic views. The clipping distance tells the view to hide geometry that is too close to the Persepective or Camera view. Even on regular scale this clipping distance sometimes seems too big but you can't control it there is no setting for it. On Cameras you can change the Frame With and the clipping distance will become less noticable.
    Solution:
    Also load in a Geneisis figure into the scene, scale the Halo 5 Male techsuit up with the general scaling transformation in Parameters pane until its about the same size of the Genesis Figure. Next hide everything but the techsuit and export this mesh as OBJ keep an eye on the export Scale should be Daz Default Scale 100% (1 unit = 1 cm). But instead of starting over to rig this new mesh you could try the following. Open the Morph Loader Pro and load the exported OBJ mesh with the native Daz scaling as a morph and dial it up on the current figure. Next go to the Joint Editor and choose Adjust Rigging to Shape this should fix the current rig representing the propper scale. Then go to the Joint Editor Tool Settings pane and Memorize Figure Rigging. Next go to Edit > Figure > Geometry > Update Geometry and choose the exported OBJ. Again choose the Daz Default Scale 100% (1 unit = 1 cm) now everything the rig and the mesh is fixed to the propper Daz scaling. You can still use the morph you created as a "reverse shape" by dialing it downt to -100% and you get the toy figure scaling from before if that was what you intended to do.
    By
    Syrus_Dante Syrus_Dante October 2018 in New Users
  • ?? Merchant Resources: Identification, Collection, Installation ??
    I don't mind paying for an upgrade license across generations.  But, I think that if you've bought the product for previous generation(s), you should be paying a heavily discounted upgrade price to just have the same morph or skin set applied to the new generation.  And, I don't think that terms should change retroactively...meaning, if I have an open use for a product for G3F, then buy the G8F upgrade, the artist offering the MR shouldn't change the terms from one generation to the next.
    Oddly enough, is someone were to make a good open use, skin set that allows use for freebies (most say only for commercial character creation), they'd probably sell a lot.  It'd be nice to have a go to freebie skin set.
    I agree that a good set of MR license standards would be good.  However, I agree with Wil that some products lend themselves more to open use, while others are generation specific.    It's not a single solution.  But, standards for each category could be set.
    As to the OP...I apologize for not really addressing the issue of organizing MRs.  Since there is no standard tag, it really falls to us end users to go through our product database and do the organizing one at a time.  This is something that I really need to do as well.
    By
    cdpro_2831bbd990 cdpro_2831bbd990 October 2018 in The Commons
  • Fit Control for Genesis 3 Male
    If look like this seems trousers became smaller and he became invisible man surprise
    Can you screenshot how fit clothes without apply morph and sequence of morph you apply?
    By
    marco_pasqualini_foto marco_pasqualini_foto October 2018 in Technical Help (nuts n bolts)
  • Where is Ophelia 8?
    The HD add on is a morph so showing on an untextured figure gives a better look at it than on a textured figure.
    By
    jestmart jestmart October 2018 in The Commons
  • Gen X2 installation issues!!
    Again, sorry to necro a thread, but I only see V4 and Genesis as source, even though I have Gen X2 and the add-on for G2.  I'd really like to transfer some G2 morphs to G1.  I've read through several threads, tried Gen X2 at the Daz connect folder, etc., but nothing works.
    By
    Myds Myds October 2018 in Technical Help (nuts n bolts)
  • export ALL morphs with "Morph Export Rules" to C4D..!?
    and how must be the "naming" inside "morph export rules" for this aging morphs..?
    By
    larsnagler larsnagler October 2018 in Technical Help (nuts n bolts)
    Thank you for the explanation. Unfortunately, the dress doesn't follow the movements of my figure (see the image). I imported the dress with the right scale and location. Then I used the transfer utility and finally I saved the dress as a figure/prop asset. Am I missing a step?
    By
    maura01 maura01 October 2018 in New Users
    hi there,
    i know that i can export existing "head"-morphs with "morph export rules" with definition "head" and "export.
    is it possible to export ALL existing Morphs with "morph export rules"..?
    for example: if i buy "Aging Morphs for Genesis 8 Male", can i export this Morphs to C4D..?
    thank you, Lars
    By
    ADORABLE frog!!!!
    By
    Novica Novica October 2018 in Art Studio
    I'm getting there :)
    Hit a snag, the images are AWFUL going from the iphone to the PC. And they don't support/offer InstaPic anymore. So had to do an hour of research, and hit the jackpot. If you want a SUPER good phone to computer app, Simple Transfer Pro is fantastic. SO fast, easy, and NO COMPRESSION. You literally open it on your phone, type in the URL given, and within a short period of time (mine was lickety split due to the Titan, like a minute for 13,000 photos on my phone)  your images appear. You select the ones you want (or all) and it was blazing fast in transfer.
    I would get the Pro version so you have unlimited transfers. I can't remember if it was 3.99 or 4.99 but dirt cheap IMO. Hope this helps. More Finnigan videos on the way. The second one was done this morning (with a bit grainy video in it, before I found the SImple Transfer Pro. It's good enough, I'm not re-doing it.)
    @rgcincy   Thanks, it's Camtasia. Had about 14 tracks going to get all the transitions. Haven't used it in 6 years so am a bit rusty.  Here's the second Finn video, where he arrives home.
    Sorry to hear about your toe & foot. I broke one of my my collar bones once wrestling in high school and I had to where a harness for six weeks. Oddly it didn't hurt and I only knew it was broken when I had no control of my right arm. Dummy that I was I still tried to keep wrestling with my left arm. laugh
    By
    nonesuch00 nonesuch00 October 2018 in Art Studio
    By
  • Rigging issue
    I wonder what you are doing there in the screenshot, it seems it is not a default genesis figure but you are working on a Bodysuit.
    Before you do anything wrong here are some advices:
    Your correct its not a default genesis figure.  It's actually the Halo 5 Male techsuit. I do have the rigged  suits for Blender, although they were never properly weight mapped. So I decided to give it a shot here in daz studio. Unforturnatly I'm unable to move on to weight mapping here in daz because the bones haven't been aligned yet. Also,  I have  male and female techsuits that were done by kaotbliss here on the forums. Those were made by using the transfer utility function.  Problem with that is setting up armors becomes tedious when using the transferred utility suits. Proportions just aren't the same as the default model that I'm trying to rig.
    By
    joshuabouillion87 joshuabouillion87 October 2018 in New Users
  • All things The Witcher...
    I played Witcher 1 but I want to replay it and do it differently. I didn't like Yaevinn of the the Scoia'tael and sided with Siegfried of the order. I thought Siegfried was nice and Yaevinn was a looser. Well, I don't want to spoil it for anyone but that choice caused something horrible to happened to White Rayla. I'm going to play again and whip the snot out of the Order. I bought Witcher 2 and still haven't opened the package. You carry story and experience and items over into 2 with you right? I worked more on Adda tonight, a little on the morph and blocked out the dress. Give me a chance, I'm on track to have her by the weekend minus the textures. If you want to see my modeling skills I'm showing some work on the last page of the superheroes rebooted thread. I could really use a texture artist. I might release the models untextured and you all could just use shaders.
    By
    Type 0 Negative Type 0 Negative October 2018 in The Commons
  • Rigging issue
    You should be able to pan even in Orthoraphic views like Left, Right, Front... the thing you can't do in there is orbit.
    model the clothing to match the base shape of the figure, to fit clothing mesh on figures use the Transfer Utility, in the Joint editor there is also a command Transfer Rigging (Figure Space) both the Figure then holding Ctrl and the Clothing have to be selected in that order to transfer the joint possitions.
    Over the years I became an expert for the Daz Studio Viewport navigation controlls. If you like to know more about how to customize Daz Studio have a look at my thread.
    How to Customize Daz Studio - to speed up Workflow!? [WIP]
    Viewport Navigation Guide + My custom Mouse Button Modifiers
    Changing Mouse Button Modifiers (open Windows > Workspace > Customize)
    I also did some youtube videos about rigging. Maybe those can help you, even though those don't count as tutorials.
    DazStudio Rigging a Cylinder
    DazStudio Twi'lek for G8F 01 Editing ZarconDeeGrissom's Version
    By
    From what I've heard, I don't think that HD morphs can be transferred between generations of figures. You could try transferring Ophelia 7's morph to G8 and use another character's HD add-on for the musculature and details. The Gia 8 HD add-on might work for you if you're looking for some muscle tone and little details like veins and natural wrinkles. Or just take a look at Gia 8 herself and see if she'd be useful for you.
    The problem with the Genesis 8 HD-Addon advertisements is that they don't show any detail with a proper IRAY render.  It's just a white texture. So there's no way of knowing how detailed the HD addon texture is until you buy it and apply it, it sucks.
    It looks like the Genesis 3 HD-Addon's have a lot more detail and work put into them.
    By
    Flortale Flortale October 2018 in The Commons
    The Transfer Utility works with the model as imported, it ignores any adjustments to the parameters inside DS, so you need to fix the OBJ so that it loads correctly placed - then it should work.
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
