• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • More Non-photorealisitic Renders (NPR II)
    mmitchell_houston said:
    vrba79 said:
    Also a reminder that if you just don't have the scratch for PWToon right now, D|S actually comes with a fairly versatile Toon shader set. It even renders faster than PWToon. Here's one render without and then with the outlines turned on.
    In my experience, I've found that when trying for any sort of NPR/Toon effect, you get better results by turning down (or completely removing) bump maps. In this case, I'm referring to the speckled effect on the column to our far left. It's kind of funny, though. Now that I'v shrunk the image, the speckling doesn't bother me as much as when I saw it full sized. Nevertheless, if you are having trouble with your textures, I suggest the first thing you do is look at the bump maps.
    Usually good about remembering that, but I was in a hurry to get that render done.
    By
    vrba79 vrba79 March 2021 in Art Studio
    pavsikakyj said:
    I was wrong about UberSoftLight. It gives even better result ans is way faster than AOA.
    The effect works well on the backgrounds and armor, but I'm getting a real disconnect between the flat, illustrated look of the cockpit and her armor and the much more realistic shading on her skin and hair. It could just be my preference, but the two styles are jarring when presented next to each other. BTW, the character design looks good, though.
    I used PWtoon only for her skin.
    Now I applyed shader on part of the suit and background.
    By
    pavsikakyj pavsikakyj March 2021 in Art Studio
    By
    mmitchell_houston mmitchell_houston March 2021 in Art Studio
    pavsikakyj said:
    I reopen PWToon for myself thankth to juvesatriani
    I'm not sure what I'm supposed to see here. This doesn't look NPR to me in any way. I just see a standard 3D render. It's a nice little scene, but this leans more toward photorealism than it does to traditional artwork or even cel shading. As I said, it is a nice scene, though, and I like the reflections and shadows. This looks like a nice set for a scene.
    By
    juvesatriani said:
    Very clean Toon render !! Glad to hear if those kit useful for you
    Which one you`ve used ? JS Smooth or Multipass ? or both?
    I`m in progress to find better and easy way to blend Multipass output  + IRAY  so we can utilize emmision + bloom without doing GLOW+Flare manually in Photoshop
    I`m also trying to simplify my Multipass kit  . I`ve found  Shadow  + AO pass  can be done in One click render rather than in separate process  (with help Simple Multiplass for 3Delight Script )
    But to avoid the photoshop  multipass action script failed to load , we should rename Ambient Light output as "AO" . I`ll be doing some test and post the update in main post
    Happy creating and have fun !
    I used default 3Delight one-step render with tweaked PWtoon shaders. And some of your Photoshop actions (Toons smooth, Toon sharpen and Make it flat). For lighting I used IBL Master, AOA Ambient and AOA Distant.
    This one I rendered with 16 sampling:
    By the way. In 3Delight for glowing efects you can try Ubervolume.
    By
    By
    juvesatriani juvesatriani March 2021 in Art Studio
    By
    JS Multi Pass is a collection of  helper tool that I often use as layer generator when doing NPR /Cel Shading projects in Photoshop
    This kit heavily depend on DAZ Studio - PW toon - AoA ambient light and Free SImple Multipass for 3delight script ,
    and occasionally need help from Free IRAY to 3delight converter and OSO TOON`s RANDOM MAT ID script for better and detail outline pass
    The main inspiration from this kit was from Youtube video called ROBOT WILL PROTECT YOU
    And my constant struggle with Environment - Props or Building which sometime great in standard render but suck when using toon shader . After all, I need to have more control and flexbility rather than let machine decide it for me about blend mode between element - opacity value etc
    NOTES :
    I  admit this kit maybe not for everyone especially  for people who want ONE CLICK SOLUTION . I guess there are better and excellent way to doing it in DAZ Studio . But until my little brain can grasp other technique and workflow, I think I`ll be stick with this one for a while
    Here some caveat you need to understand first before decide to use this workflow
    • You need to setup dedicated render output folder for each projects  . It sucks but it will save you in long run or bigger project
    • Render output name should be set like explained in MINI WALKTROUGH to make Photoshop action companion work properly
    • It run using 3Delight Render Engine only , so it would makes no speed different if you have FANCY GPU card
    • Use PW toon  because easy to setup and fast !!  even if I need to outputting  6-10K resolution for each image passes
    • Take a lot of HD Space if you use this workflow for animation
    • If someday newer version DAZ STUDIO offer ready to use solution like COMIC BOOK PREVIEW in POSER  maybe this will be obselete
    • The Photoshop Companion Action script only tested in CS6 and recent version , so I`m not sure if work in earlier version although it should be
    Here links all  tools you need
    JS Multipass and Photoshop Action
    https://drive.google.com/drive/folders/1Odv-RB5Q7RV_7WGSeEkkpMK5h3ZqQVlv?usp=sharing
    DAZ STUDIO
    https://www.daz3d.com/dazcentral
    PWToon shader
    https://www.daz3d.com/pwtoon
    Simple Multipass Render for 3Delight , check the bottom one
    https://www.daz3d.com/forums/discussion/451996/free-script-simple-multi-pass-render-iray
    Free IRAY to 3Delight script
    https://www.daz3d.com/forums/discussion/139326/irayto3delight-conversion-script/p1
    Advanced Ambient Lighht
    https://www.daz3d.com/advanced-ambient-light
    Optional for better outline solution
    OSO Toon
    https://www.daz3d.com/oso-toon-shader-for-iray
    The mini walkthrough will be in next post
    By
    I worked a lot with UE2. It is not the best thing for NPR. I got UberSoftLight and it is much better than UE2, but still not as good, as AOA lights. What shader do you use for transparent stuff and hair? PWtoon is not the best choice for it. I use Ubersurface with disabled occlusion. It saves render time dramatically and stil has good NPR look.
    Here is what I have done with your presets and AOA light (plus my humble personal tuning). You have done excellent work. Thank you once more.
    Nicely done !!
    Sometimes for better speed I turn off shadow option in each light . Or using SHADOW MAP than Raytrace . 3Delight seem slower if  raytrace and Opacity used at same time .
    Another option will be what @vrba79 told us . Keep using default shader for opacity stuff and Turning on the Cartoon render mode
    (It hidden in newer version . You can access it via RENDER SETTING > PREFERENCES > SHOW HIDDEN Properties.)
    In most case it passing through what default  3delight and PW Toon shader setting .  But @richard haseltine can confirm it that true or not
    And Yeah for AO passes , I love what AoA Ambient Light result than UE2 . It easy to setup and offer better control speed wise when dealing with Opacity map . You can flag it so occlusion will use lower setting or bypass it . Thats why my Hair Base preset having so much Glossy effect as default .
    By
    Also a reminder that if you just don't have the scratch for PWToon right now, D|S actually comes with a fairly versitile Toon shader set. It even renders faster than PWToon. Here's one render without and then with the outlines turned on.
    By
    juvesatriani said:
    pavsikakyj said:
    juvesatriani said:
    PW Toon And Photoshop
    Here`s another one, I`ll be posting mini tutorial how to get those styles (if someone interest)  after figuring out how to make easy to understand/follow since English not my first language
    I`l also including some PW Toon Presets for creating Flat - Multiple Shadow and 3d delight DAZ shader to get  Quick AO pass.
    All outline produced used DAZ outline script which included in every DAZ studio version
     Oh please do post your tutorials and presets!
    I am currently in the process of writing a tutorial about Multipass for NPR.
    Maybe tomorrow night ( GMT +7) I'll post it, after completing some test renders and recreating presets that are easy for everyone to use, as well as actions that will be useful when doing post processing in Adobe Photoshop.
    I will also test UE2 for alternatives to AoA Light in terms of AO Pass.  In theory, UE2 is more accurate, but for NPR purposes, accuracy may not be what we need.
    But at least for those who doesnt AOA Ambient Light still possible to duplicate this technique.
    I`m also considering to utilize IRAY`s clay render as AO pass alternative .
    By
    Richard Haseltine said:
    pavsikakyj said:
    juvesatriani said:
    You can get these PW Toon Preset in here . I`ll be posting in freebie forum after having "proper" promo images and better Readme file . But I want to share in this thread first, because you`re all the best !!!
    https://drive.google.com/drive/folders/1sNjIBqMTtX4r_WamJvOlhVZR3hlnd0F9?usp=sharing
    Readme
    JS Smooth toon Presets for DAZ Studio and PW TOON
    This freebie need DAZ Studio instaled in your machine and PWToon Shader from DAZ Store to make it work
    Each Folder contain several preset which organized to make it easy to use
    These presets only work for 3Delight so change your render engine first
    You can go to Render Setting and look at Engine option and Change to 3Delight
    I recommend to load JS Starter Light from !! SCENE SETUP folder and also Smooth Toon Render Preset before loading figures or props
    When first loaded , You`ll see that you have Starter Light Group set in your scene . Open it and toogle on off each light for get different render style
    The render Preset set Shading rate to 5, which in theory makes your render faster . But if your render really need outline or geoshell line you should manually resetting back shading rate value to 1 or smaller values
    One thing to note : All presets have No ( Zero- Non active) outline or internal line .
    Because I dont like it but feel free to make it active
    The PRESETS
    FULL MAT Presets contain One Click Smooth toon for Genesis 3 - Genesis 8 and G 8.1
    For another Gneration Figures try to use Skin Shader Presets which included in BASE SHADER ONLY folder
    In BASE SHADER folder also contain presets for Cloth and hair .
    You can use each shader presets for another figure or objects if you want .
    Make sure you select your object in Scene Explorer and the right surface first, before applying those presets
    If you want to retaining all textures use CTRL+ CLICK instead
    FULL MAT + Textures Presets is solution if you already have some texture set from DAZ Store or another sites
    All named with original character/figure where they came from . So check if you already those set or not
    Most presets already optimized and tested to get better results but feel free to tweak and change to suit your style
    All MODEL LINKS you`ll need it to use those presets will be include in MODEL INFO text .
    Right now it only have few presets . But I`ll be adding more in next update
    STARTER FIGURE folder contain each Genesis Generation Figure ( except G2 families) with basic Smooth Toon Shading applied
    Those presets for peoples who want to tweak and assign their favorite Texture manually
    G8 or G8.1 figures presets not loaded with Eyelash or Brow . You need adding manually and apply toon shader itself
    Thanks and Enjoy
    JuveSatriani
    Thanks for great presets! You helped me with Rim multyplier greatly!
    I tried your PWToon presets with AOA lights. It appears slower, than with your lights, but I like the result more.
    Please don't post renders or textured previews of bare female breasts.
    I'm sorry. Just didnt think of it as nudity
    By
    Readme
    The PRESETS
    Thanks and Enjoy
    JuveSatriani
    By
    Richard Haseltine Richard Haseltine March 2021 in Art Studio
    Readme
    The PRESETS
    Thanks and Enjoy
    JuveSatriani
    By
    Readme
    The PRESETS
    Thanks and Enjoy
    JuveSatriani
    By
    vrba79 said:
    Very nice!
    Yeah, you can't beat PWtoon for that mix of render speed and versatility. I bought it several years ago and have gotten my money out of it a thousand times over.
     I agree PW Toon really versatile . Its quick and easy way to get  several render pass/type  ( Flat - Hard Shadow & Ambient ) although I know Blender NPR is something I wanna tackle someday
     I`ve already bought several good rating  Blender NPR/Toon shaders , but  sadly  I couldnt make it work just like I wanted when using DAZ Figures .
    By
    Very nice!
    By
    Tracer IRAY and PWTOOn
    I`ve spent whole day to find balance between speed and easy to manage my personal Fan Art project . And after so many  failed atttempt using Blender (for NPR ), I decide to back and find ways to maximizing DAZ render and photoshop to suit my style.
    This image off course not perfect but I think I`m getting there , right ?
    PW Toon version have advantage because I can render as big as possible and fast ! So multiple pass really easy . The real challenge is to make  realistic material  blend with another elements .
    And For IRAY, Render size and my GPU is the culprit . But postwork process  for this image seem faster .
    Credit : Tracer model for g8F is freebie from Shinteo @ Devian Art
    By
  • Studio 4.15 and PwToon
    Cheers for the help guys. Have managed to get it working - had to uninstall and reinstall pwToon before it behaved, which was annoying. But it SEEMS to be working again...so far. :)
    By
    rindfan_2393f1598d rindfan_2393f1598d February 2021 in Daz Studio Discussion
    A little tutorial on how to use Photoshop to complement PWToon.
    It could probably use some improvement, but its here for whoever wants to use, modify or improve it! That's half the fun of sharing these kinds of tutorials, right?
    By
    vrba79 vrba79 February 2021 in Art Studio
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
