• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • Daz to Blender - Morph update - “Spring Cleaning Update” (2.3.1)
    DAZ_sam  I`ve just reinstall recent version  from DIM and its suddenly work .  Not sure what happen before but this bridge different from what I`ve been downloaded and installed before ( There are couple of notes , after export and in DTB`s UI ) But Thanks for this update !
    It also seeem faster in my viewport even in Cycles . I`m also noticing  about  3Delight AoA - DZ shader in material slots . So is possible for automatic connversion pwToon to Blender`s equivalent shader  in future ?
    Thnaks again
    By
    juvesatriani juvesatriani April 2021 in Blender Discussion
  • More Non-photorealisitic Renders (NPR II)
    juvesatriani said:
    ShadowSkillz said:
    vrba79 said:
    Also a reminder that if you just don't have the scratch for PWToon right now, D|S actually comes with a fairly versitile Toon shader set. It even renders faster than PWToon. Here's one render without and then with the outlines turned on.
    What toon shader set would you be refering to, never come across one out of the box with Daz?
    Check in Shader Preset >DS Default
    There are several nice toon shaders you can use it . You need to work or using 3delight tough > Change your render engine to 3delight
    Its a pretty good toon shader. You just have to coax it, as the default settings for it look terrible. But once you play around with it, you can get some very nice results!
    By
    vrba79 vrba79 April 2021 in Art Studio
    DOA
    Another style from PwToon and Pshop
    By
    juvesatriani juvesatriani April 2021 in Art Studio
    PwToonFlat PS
    Another combo PwToon and Pshop
    By
    By
    By
    amaragh2 amaragh2 April 2021 in Art Studio
    juvesatriani said:
    mmitchell_houston said:
    Thanks @artini . It just simple tricks which I`ve also learned from people in this thread
    Now back to my Multipass sample image . Stil not find a way to make it simpler but since this is using pwToon its really fast to render all passes
    <ultipass sample
    This has a nice, clean look The combination of simple lines and the subject matter remind me of the work of Mobius.
    Two questions:
    1. How is this process working on the more difficult things, like close-ups of faces (lips seem to be an issue) and hair?
    2. What about consistency? Can you get consistent enough results to keep the images looking the same for use in a comic book (in other words, do your results pass the scrutiny of side-by-side / panel-by-panel comparison)?
    I`m not sure how to explain properly , but as more Photoshop user than any other 3D software its easy for me to decide that all my styles controlled or dictated by what I did in  Photoshop ( via cafefully stacked bunch of layer adjustment and LUT profile) .
    What kind  of Dominant Hue value for some styles ( anime- Western toon or painted look like) - which Tint Saturations mostly used -   FX and Glow pallete  etc,  already locked before I`ve start doodling with material presets in 3D software
    For me , its easier . Even when I needed , I can copy over between projects to make sure its has the same styles, with some minor adjustment of course
    So when doing render from 3D.  I`m only concern with what kind of renders will be work  properly with my FIXED editing stacks? Thats how most my material presets created . For better suit my Photoshop sessions.
    Personally I dont think my photoshop stage as postworks, but as the main one, meanwhile all 3D software I`ve used as layers/elements generators .
    The problems I`ve had with render everything in one shoot mostly about large gap difference in textures quality for every elements in one scene - color values which sometimes clash one to another and occasionally 3D lighting behavior which sometimes multiplying everything !
    So although we`ve already set with right value in one object , other factors still need to be considered to get results I wanted .
    I hear PBR stuff can help us with that , but since we in NPR and not every textures we`ve been used , created by ourselves so its very hard to control .
    Except we dedicated to one PA  and she/he created every models we needed . Variety of products can be bless and torment for everyone who need consistency
    And the way Multipass work, I`m only  need to dealing with one layer which carrying color and texture informations ( FLAT DIFFUSE) . Another passes mostly Black - Grey and White . So if DIFFUSE layer not working/react properly in my Editing stacks, I`m just doing whatever I can to make it work .
    Shifting the color value - brightness - make less contrast  even denoising  mostly do the trick .
    The beauty with this workflow  is we dont tied with one style.. Just load different editing Stacks if I need different style . BW styles also possible since all shadow passes literally is Black and White Images
    About Line renders, I dont really find  (yet?) better way than manually draw those lines . Especially for commercial works .
    Some pro with reasonable price can do it in five minutes for single image and almost half of hour for full pages . Using all line render generator means we also need to erase - hide and make it bold by yourself .
    Most NPR games I`ve played mostly work with GeoShell and carefully painted line in 3D character textures
    The real challenge using premade content to doing specific need is you need to tweak a lot !
    In Future I want to learn about Stylized painting which possible in Substance Painter , so I can use and mash up PwToon render with what Blender`s EEVEE already great = Emmision Shader and Bloom
    Hey there. Sorry for the short response to your long, thoughtful post. I'm on deadline this week and need to minimize my online time.
    Sounds like you have a good process in general. I have found that writing it down helps solidify it in your mind, and also helps you recreate particular looks at  a later date.
    As for outlined work, so far Poser Pro 11 & 12 are really the only programs at this level that really deliver outlines in a consistent in a live preview. If you look through my gallery, or submissions in this forum group, you'll see a lot of examples of my Poser work.
    I've done some digital painting and have receieved solid results. But for me, hat's still a hit-or-miss process where I get slightly different results based on my inputs. Of course, I don't do paintings very often, so that's a big part of that.
    Finally, you may want to look more into how Daz Studio interacts with Substance Painter. I'm not sure it's still the case, but previously Substance Painter could't really work with DS because the texture nodes were too different. I know when I tried it about two years ago it turned out to be a complete dead end for me.
    By
    mmitchell_houston mmitchell_houston April 2021 in Art Studio
    <ultipass sample
    Two questions:
    By
    <ultipass sample
    Two questions:
    By
    juvesatriani said:
    Artini said:
    Wow - thanks again for your generosity. Wish you all the best.
    <ultipass sample
    Looks great! Yeah, I think we all struggle with "I want to balance simplicity with the end result I want"!
    By
    <ultipass sample
    By
    juvesatriani said:
    Overwatch Garage in Toon Style
    Here experiment using Blender EEVEE and Multipass to generate layers in EXR Format . Its far more complex though and not as eas and fast if ocmpared with my PwToon Pass trick . But i think I`m really start to understand what Blender really offer . There is no Toon Shader involve in this image, just blending and stacking layer and various color adjustment
     This is a great style.  And the lighting is superb.
    By
    FirstBastion FirstBastion April 2021 in Art Studio
    juvesatriani said:
    JSmoothToon Sample
    Revisit my Smooth Toon preset which I`ve already posted in this thread and create photoshop action companion to make more like illustration
    I hope I can finishingnew presets this week, so you ( pwToon users) can play with it . In meantime this is quick sample from recent version
    Transmap Hair still need works though
    Very impressive. Thanks. Can I ask you to make a tutorial for separate pass get glowing light effects? If it is possible of course.
    By
    pavsikakyj pavsikakyj April 2021 in Art Studio
    JSmoothToon Sample
    By
    More of tuned PWToon
    By
    pavsikakyj pavsikakyj March 2021 in Art Studio
    juvesatriani said:
    Looks very, very nice. I really enjoy looking at all of your creations.
    Thanks for nice words.. here`s another view from same scene
    Overwatch Garage Scene Another View
    Truly amazing result! How about using the shaders, you wrote about, in DAZ?
    By
    By
    juvesatriani juvesatriani March 2021 in Art Studio
    By
    Artini Artini March 2021 in Art Studio
    By
    vrba79 said:
    Also a reminder that if you just don't have the scratch for PWToon right now, D|S actually comes with a fairly versatile Toon shader set. It even renders faster than PWToon. Here's one render without and then with the outlines turned on.
    In my experience, I've found that when trying for any sort of NPR/Toon effect, you get better results by turning down (or completely removing) bump maps. In this case, I'm referring to the speckled effect on the column to our far left. It's kind of funny, though. Now that I'v shrunk the image, the speckling doesn't bother me as much as when I saw it full sized. Nevertheless, if you are having trouble with your textures, I suggest the first thing you do is look at the bump maps.
    Usually good about remembering that, but I was in a hurry to get that render done.
    By
    vrba79 vrba79 March 2021 in Art Studio
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
