really like the look of the bangs in the promo for dForce Strand-Based Autumn Style Bob Hair for Gen
It is not difficult to morph a dForce root radius hair. I made this quick morph to scale the back of the hair down and move it inside the G9 head, as an example. I wrote up these instructions a couple years ago and posted in some forum thread. These reference G8, but the technique still worked today in DS 4.23.0.4 with G9 and the Autumn Style Bob hair strands.
I don't know if all these settings are critical or not, but this is what works for me:
- Load G8F
- Select G8F and a load dForce hair (I'm using dForce Neroli Hair).
- In the Scene pane, select dForce hair object (not the cap).
- In Parameters pane, make sure Generate PS Hairs, Generate PR Hairs and Preview PR Hairs are On. Make sure Line Tessellation is >0? It is 3 on the hair I am using.
- Zero out any morphs in the dForce hair that are set when the hair is loaded.
- Select the Geometry Editor Tool.
- Hide everything except dForce hair object in the Scene pane.
- Export to OBJ.
- Import OBJ to modeler (Blender, etc.) modify and export modified OBJ.
- Back in DS with dForce hair object still selected and Geometry Editor tool still selected, run Morph Loader Pro.
- In Morph Loader Pro, load the modified hair OBJ and create the morph.
- Save the morph as a morph asset.
Instead of editing an OBJ in a modeler, you can drape the hair with dForce and export that as an OBJ. Clear the simulation, and import the OBJ with Morph Loader Pro. Save the morph as a morph asset.
Remember to select a tool other than Geometry Editor or Mesh Grabber before rendering.
Lost and Found growing! Is that right?geekydad123 said:
I just purchased a product that went straight to Lost and Found. It's got over 300+ files associated with it (it's a complex environment), I really don't want to have to sort that myself. Hopefully a support ticket will get things straightened out.
If it is part of a bulk transfer from Renderosity then it probably won't get official metadata - but if someone, using the default install locations, created metadata for it that could be shared.
How to import animations from Daz to Blender using Diffeomorphic?For the missing FACS, I also clicked that box when I imported my characted with easy importer so I'm not sure why they wouldnt be working.
Another Issue... some morphs just arent working that ARE imported, for example the custom morph BC 3 Depth Adjust is listed and has a value of 1 but does nothing and changing that value does nothing.
Need help with G9 hair.Silas3D said:
@crosswind you're right, though I have since instances of auto fitted hair that don't have custom bones, where the included morphs also stop working!
Okay, probably... though I personally haven't met such a case so far.
Normally there're two types of "hair shapes", one type is true morph made with hair geometry, which should always work no matter with or without auto-fit; another type is Pose Control whic is ERC linked to Bones or Custom Bones, so if the Custom Bones are gone, they'll stop working ~ The latter case can be frequently seen, in which folks would rather go for direct parenting.
[Released] Turbo Loader for Genesis 9 [Commercial]johnjohn808 said:
RiverSoft Art said:
johnjohn808 said:
RiverSoft Art said:
johnjohn808 said:
HI
After Turbo Loader disables the morphs, I click on the character thumbnail to load the character and I get the message "The files listed below could not be found" which is expected.
But If I type in the name of the same character in Parameters, that character`s morph sliders show up and are enabled.
In previous versions, the character`s morph sliders down even show up when disabled by Turbo Loader.
Are the morphs actually disabled and Is there a fix for this?
Thank you
I am unable to reproduce this behavior. Are you sure the morphs are truly disabled. Did you perhaps disable the morphs AFTER the character has been loaded into the scene? (In that case, the morphs stick around until a new scene is loaded)
Thank you for your reply.
It does not seem like the morphs are disabled since I can still access working sliders. It just seems like it only disabled access to the morphs when clicking on the thumbnails in the content library. (I don`t use smart content)
When I disabled the morphs through Turbo Loader, I had no characters loaded.
I went through the process of disabling the morphs three times
I am using DS 4.22 on Windows 11, 8GB Ram, Nvidia RTX 3090
There would be no sliders if the morphs are disabled. You can try using the parameters on the slider to find where the morph it controls is located.
I just ended up reinstalling and it seems to be working fine now.
Thank you again for your replies
Well, I am glad you got it working.
Need help with G9 hair.Auto-Fitting does not remove morphs on the hair, however, it'll remove custom Bones... unless one make a Bone Mapping before auto-fitting.
I helped with resolving some hair fitting issue of G9 > G8 for other folks recently and found out that the trick to make auto-fitting G9 hairs really work on G8 while keeping dForce still functional is to: after fitting, further make a Fix Base morph on the root node of the hair by using G8 clone on G9... no matter the hairs are polygonal or SBHs. Then save a Figure Asset.
But still, if the hair has custom bones, do not auto-fit, direct parent it to head node instead. Bone Mapping is too cumbersome ~
It's said that Daz will release enhanced updates for auto-fitting funtion, we're keeping eyes on that ~
Need help with G9 hair.What @felis said - unless there are no morphs on the hair then autofitting isn't a good idea anyway because all the morphs would be lost. Given that most hairs come with a scalp surface, I usually hide all other surfaces after parenting the hair to the head, which I then use as a guideline to scale/morph the hair to fit as close to the unsupported figure as possible. I usually apply the smoothing modifier after this as well.
IIRC correctly there isn't currently a G9 to G8 hair converter available in the store.
Anyone else having trouble with the new Pug?The Pug's shape was made based on Dog 8... the issue seems to be a wrong sculpting on its shape or wrong morph importing ~~
If you remove delta vertices from selected eyes, the eyeballs will "jump out" as Dog 8 has a different body shape / size... (if with partially selected vertices...it might be distorted in another way...) So, with the "jumped out" eyeballs, you have to "re-rig" them to the Pug by changing their Transforms in DS or directly in external software, e.g. Blender , export the Pug to OBJ and import it back to update Pug morph with deltas. Or, wait for the fix from the vendor ~~
[Released] Turbo Loader for Genesis 9 [Commercial]RiverSoft Art said:
johnjohn808 said:
RiverSoft Art said:
johnjohn808 said:
HI
Thank you
if I open an old duf where does Daz look to find the source of the items?yes, I'm split between two computers now and have tried to build matching HD with the same path letter on each machine.
But sometimes it's hard to keep track of thousands of files.
even if daz uses a relative bath ... in order not to fine these files it has to look in drive letter X or Y.
Where it looked makes it easy to figure out what is missing, what didn't transfer etc.
It's a program it has to get the letter somewhere and then use the letter to look for the item so all that's need is
I looked in E/ 25 fantasy/Runtime/Textures/DAZ/Characters/GenesisBodysuit/Chainmail2_DiffuseBlue.jpg and it wasn't there.
that lets me figure out where it needs to be or is corrupted etc and also tells me if that data is not in E it could have been on G when I created the scene.
/Runtime/Textures/esha/ForestScout/blaze hood_Belt1.jpg
/Runtime/Textures/RD/Defiant/BlazeBootsTx.jpg
/Runtime/Textures/RD/Defiant/blazeBracersTx.jpg
this first image of the cats is from the older computer (just loaded) the second from this one (just loaded) so all I have to do if I locate the files missing is fix them
The alternative is copying 62 gigs between to machines again.
Fixed... but how in the heck did a half dozen content manager folders get changed from G to E when the folders are on G.
Fairly simple fix once I knew where daz was looking at where they were.
And "GenesisBodySuit" is not the product name, argh.Anyone else having trouble with the new Pug?Richard Haseltine said:
Check that the JCM isn't affecting the eye geometry - if you use the Geometry Editor in Vertex mode and have the Parameters pane in Edit mode a right-click on the slider will let you seelct the affected vertices. As long as it isn't an HD morph you can make the morph a favourite (click the heart icon, and mke sure notning else is favourited) then deselect the body vertice and right-click in the Viewport>Morph Editing>Remove Deltas from Favourites.
I forgot to mention that I checked those, since cleaning up morphing errors is something I do with my own figures.
Anyone else having trouble with the new Pug?Check that the JCM isn't affecting the eye geometry - if you use the Geometry Editor in Vertex mode and have the Parameters pane in Edit mode a right-click on the slider will let you seelct the affected vertices. As long as it isn't an HD morph you can make the morph a favourite (click the heart icon, and mke sure notning else is favourited) then deselect the body vertice and right-click in the Viewport>Morph Editing>Remove Deltas from Favourites.
HELP - custom morphs causes mesh explosionlukon100 said:
Bejaymac said:
A mesh explosion is usually caused by the winding order of the morph being different to the winding order of the mesh, as a result each vertex in the mesh has the wrong morph delta applied to it.
Anyone know how to get Blender to be consistent in how it exports .obj's so that it creates matching winding orders?
According to the experiments I just ran, Blender will produce different winding orders if you end your session and re-start Blender.
This means: For those of us using Blender to create morph targets, never re-boot blender between when you make a base mesh and when you make a morph target for that base mesh. It may also be important that you export to OBJ all your base meshes and morph target meshes within the same Blender session as well.
This is how it is for Blender 2.79.
But I don’t expect it to be any different in current versions of Blender, as I don’t think the Blender folk cater to us Daz morphers.
Searching for ProductI'm looking for a product for Daz Studio for, I believe G8F. I saw it online, and forgot to note the product name. I remember its a "vampire-type" morph. But it can have a human looking vampire, or a very much "evil-undead" version. The think
I remember are the ears, I've attached a pic of similar ears. Hopefully someone can help me find it.
Arc~
Premier QuestionsPhoenix Knight said:
jjmainor said:
Nyghtfall3D said:
OrangeFalcon said:
johnjohn808 said:
I`m asking as a semi prodessional Daz artist.
Am I getting this correct? If I as a comic book creator, used a morph from one of the exclusive characters to create a new character to add to an ongoing comic series, I`d have to keep subscribing every month to keep that character in my storyline?If so, Premier is not feesible as it would cut into profit from the sales of my comics.
It`s hypothetical because I make my own characters from merchant resources, but just incase ( It doesn`t have to be a character) I wanted to kit bash something like a chair from an interior that was exclusive to Premier membership.
You would be correct. Once you unsub, no more Premier content.
Worse, according ot the FAQ, if you unsub and then resub, there's no guarantee you'll regain access to the content you lost when you unsubbed (I've bolded the relevant part of the answer to Question #5 about content):
5. What is the exclusive Premier Only content mentioned on the Premier page that is only available while you have an active Subscription?
- With each Character Bundle release (2-3 per month) there will be exclusive content that will be auto-added to the accounts of Premier members at that time. You can keep and use this content for as long as you have an active premier membership.
- Examples would be Aiko 9 and Dark Elf Shape for Vicky 9.
- Content that is removed due to letting a Premier subscription lapse is not guaranteed to be available on reinstating the membership at a later time.
- We currently do not plan to offer Add-on Licenses to the exclusive content. (3D Printing, Interactive etc.)
Wow. Other sites offerring their 3D assets on a subscription basis make it clear you retain ownership of and the rights to use any content you downloaded before your subscription lapsed. This makes Premier semi-useless for commercial use.
I'm surprised not to have seen it directly mentioned yet, but this feels like an initial attempt by Daz to add DRM to content. I've largely given up on Daz for other, somewhat related reasons, but that's what this really feels more like to me - in a poorly thought out manner, I'd add. The idea that DRM protected material, once purchased properly, may not be able to reactivate after properly resubscribing is...mind-boggling, to me. Most likely the support staff doesn't know if/how that can be reliably applied, but that - at least in my opinion - should have been a CORE issue to resolve before launching this. Are customers expected to "buy" the exclusive content again every time you restart a subscription?
"Protecting" content while forcing additional subscription fees I'm sure feels like a "win-win" for the business, until it kills off the customer base. I'm not saying that will for sure happen, but it's certainly a possibility. I suppose time alone will tell what this does for Daz.
Oh yes, the exclusives are definitely using the loathsome Connect Encrypted Content DRM they tried forcing on the market years ago. And I recall one of the concerns back then was the idea that something with that DRM could easily be disabled by accident if there were an account glitch. In this case, remote disabling content is an actual feature.
White Raven for Lady Raven Outfit - what is the model name?n.jmurov said:
SapphireBlue said:
n.jmurov said:
What is the name of the model used in the main promo image here:
Thanks
I think it's Mousso's Maud, the skin textures also match (see second promo on the page).
Thanks so much! Obviously, these questions wouldn't arise if artists bothered to specify the names of other products used in the promos. Only about 10% do
There are numerous reasons why they might not. Product is sold elsewhere, they don't do their promos, character is a dial spin personal morph etc.
Best and easiest to use NAS for storing Daz content in 2024I use a TERRAMASTER F5-422 10Gbe, can't say I recommend it, the model is a bit outdated. From the disadvantages - when reading from disks, when starting the synchronization server - you can always hear HDDs working (creaking). But it is the disks themselves, HDD for NAS always heard during operation, in any NAS. Therefore, I will choose to replace ALL FLASH models, for example QNAP TBS-h574TX-i5-16G although I consider its cost overpriced, and 8Tb SSD in general cost is not adequate. TERRAMASTER recently released a line of 2 new NAS ALL FLASH, but they have only 10 gigabit port (max 1024Mb/s) but at a very affordable price. The QNAP model has a 10 gigabit port and 2x Thunderbolt4. 2 of my 3 computers have these ports and the transfer speeds on them will be 20Gbe. Compared to my current NAS 2 HDDs in RAID1 give a speed of 300-430Mb/s (although in advertisements write that up to 650Mb/s), in the QNAP advertisement promises a read speed of up to 2876 MB/s. I can't recommend you anything, this is my upgrade plan, this is the maximum read speed I could find. But I have gigantic scenes, I have an employee and hopefully the number will increase, well I work at 3 computers at the same time. I use Daz Studio to create content that pays off, so I can and am interested in increasing speeds and simplifying processes. Well and my current NAS will remain, 5 disks up to 100Tb. I will make copies of operating systems and Daz content from ALL FLASH NAS on it.
RiverSoft Art said:
johnjohn808 said:
HI
Thank you
