• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • [Released] RSSY Clothing Converter from Victoria 4 to Genesis 8 Female [Commercial]
    If you are talking about looseness, there are a ton of helper morphs to fix things like that.  The helper morphs are in the Parameters pane, below Actor->Converter Morphs (see Figure 10).  Adjusting the Tighten All morph and turning on Smoothing can fix most issues.
    If you are talking about shoulder armor becoming all bendy, that cannot be fixed.
    I was having problems with bodysuits and coats and such, not armor or props that were supposed to be stiff. So far nothing I can do fixes the problem--all my V4 outfits look like they were morphed to fit Wilt Chamberlain while the actual characters are Tom Cruise--but I do have to give you props for putting in the hard work to get this program together. Even if it doesn't work for me, I salute your creativity and technical savvy.
    By
    The Brig The Brig April 2020 in Daz PA Commercial Products
  • SCI-FI Celebration
    Here's a character from an upcoming sci-fi comic I'm working on. The figure is Michael 4 with a cool morph applied: Grotto's Insectoid (available at R'osity).
    The character's real name is unpronouncable by humans, so he just goes by the (very) shortened version, "Chitz."
    Rendered in Poser Pro 11 using the Comic Book Preview. Clean up in Clip Studio Paint. I think I spent an hour and a half on this quickie illustration.
    By
    mmitchell_houston mmitchell_houston April 2020 in Art Studio
  • Report sales errors here: "There's Always Another Sale™"
    Added the new pro bundle, three required add ons, was happily adding freebies, cart got to $61 after four categories, added Face Transfer Unlimited, cart jumped to $292, removed Face Transfer Unlimited, cart did not return to $61, emptied cart and gave up.
    By
    Lorraine Lorraine April 2020 in The Commons
  • Best model to start with?
    I would recommend the Aurore HD character. You get different skin tones, HD morphs, brows, piercings and size morph.
    By
    alienarea alienarea April 2020 in The Commons
  • Can't find scene subsets
    I think I had the same thing happen when I had to move everything to a new laptop. DS now only shows the files saved before the transfer if I uncheck "filter by context." Try that and see if the files show up in the content tab.
    Thank you for answering!  Where do you find that option?  I go to "Content Library", then click in the searchbar.  I have the option to choose File or Database.  That's all the options that I see on mine.
    By
    Fae3D Fae3D April 2020 in The Commons
    By
    jjmainor jjmainor April 2020 in The Commons
  • Cannot save my custom morphs
    Morphs are not going to show up in the Smart Content ... they show up on the Parameters and/or Shaping Panes.
    ? what these 3 different paths are you are referring to. They would have saved to be seen exactly where they were planted in the first place.
    The data files would be in the data folder, subfolder for the figure [normally under DAZ 3D] under Morphs, base, your handle. You can only have one working morph with the same name so if you have saved it to 3 different places, 2 of them must be deleted from the data folder.
    If you forgot where you parked them: in the file in the data folder search for "group" ... and there will be where it is located when you open D/S to use it.
    {the figure has to be loaded and selected in the scene in order for any of its shapes and morphs to be seen}
    By
    Catherine3678ab Catherine3678ab April 2020 in Technical Help (nuts n bolts)
  • Endlessly ongoing... playing cards/casino chips/coins/banknotes scatter... hiatus time (still)
    ...and tangentially speaking - just slapping the doubloon face on the casino chips with a pseudo-metallic Poser Friefly shader...
    I'm rather surprised that the edges actually appear knurled/reeded - that's definitely a lucky bonus !
    So coins may actually be easier than I thought.
    However, I can't use a morph to change the thickness or diameter of the coin, because such morphs would screw up when combined with the mid-air rotation morphs.
    I can't see any solution to changing the diameter:thickness ratio in the scatter prop.
    However (again), different diameter coins could be achieved by simply using scaling and a bit of simple mathemagics. E.g. a US quarter is about 1" diameter, and a cent about 0.75". So if I scaled a chip scatter prop to 6.51% the chips would be 2.54cm (1") across. If I scaled another chip scatter prop to 4.88% the chips would be 1.9cm (0.75") across. If I then set 'Mid-Air Scatter A' of the first prop to 0.2, and set 'Mid-Air Scatter AB' of the second prop to 0.267, and applied appropriate quarter/cent textures... then (if I've got my maths correct) you should have $13.04 up in the air !
    I'm not going to even pretend to understand what you're talking about, love the image though!
    By
    Catherine3678ab Catherine3678ab April 2020 in Freebies
    Hi there
    Im using the genesis 8 starter essentials, went to brush, created a morph. Brought it back, everything works wonderfully.
    Except when I go to file/save as/support asset/morph asset
    I add my morph to the checkmark list(only thing I check the x) ,but for the life of me, it never saves anything. i tried saving in the 3 different paths it allows me to, but the morphs don't show up in neither of them, and in the smart content search doesn't show up either.
    what am I doing wrong?
    thanks in advance
    By
    ItsaMe ItsaMe April 2020 in Technical Help (nuts n bolts)
  • XTransfer Module 1- Genesis 3 to Genesis 8 Morph Converter (Commercial)
    If for some reason the transfer process is interrupted or you are forced to quite Studio itself, some users
    have experienced that Studio or Genesis 8 will crash apon loading. To Fix this issue simply navigate to the transferred
    morph location on your Genesis 8 Figure and delete the Product Folders inside XTransfer Directory, or last known set
    that did not complete. You can also delete the entire XTransfer folder if issue still exists and start again.
    Location for XTransfer folder is
    Your Content Library\data\DAZ 3D\Genesis 8\Female\Morphs\XTransfer
    or
    You can also navigate to this location via the Browse to my saved XTransfer Morphs button within the script.
    Please make sure the right content library is mapped inside your studio.
    Also did you download version 1.2?
    It fixes the crashing issue. If the problem persists I need to see your log file please.
    By
    Zev0 Zev0 April 2020 in Daz PA Commercial Products
  • Chevybabe's Dforce SBH Hair Thread
    OK.. In that case:  I would absolutely change the simulation settings:
    You may not have to increase the settings as high as I have here in the attached image.. but it usually solves that "pull" problem.
     The ear issue.  The hair will not just follow like you want.  You would have to add an ear morph and have the ears completely clean throughout the animation.   Poke through like that can equal an explosion.  The hair sims and collides but its not smart ;)
    Wind.. yeah thats a bit tricky..  Im still looking to get more info on it.
    By
    chevybabe25 chevybabe25 April 2020 in The Commons
    You already have the base Genesis figures, assuming you mean human models. While daz would obviously like you to buy add-ons you can certainly get your feet using the free bases. Beyond that, a lot will depend on what areas you are most interested in - do you buy morph packs to sculpt your own figures or are you wanting  a series of pre-rolled characters? Do you want to do figure art (portraits), action scenes with the focus on the figures, environments with figures used simply for scale and completeness? Are theer particular genres that catch your fancy - some period of history, some type of fantasy, some style of SF? Thinking about what you want to end up with will probably help to focus your thoughts on what (if anythng) you need to add to your content library.
    By
    Richard Haseltine Richard Haseltine April 2020 in The Commons
  • Log File WARNING woes!
    Holy Crap Batman!!!
    Where the hell to start with this mare of a log file.
    "Could not find parent for modifier", "Failed to prepare modifier" and "Failed to create modifier" are all linked. The fact I don't see any missing file errors has made me wonder if these are tied to your animation errors. Basically DS has no idea which mesh those four nail morphs are meant to be applied to, the "Parent" line in the  morph files is probably empty or missing. Now if they have "adjust rig to shape" and "ERC freeze" applied to them and no parent data, then DS wont have a clue what properties to adjust, which just might be the source of all those animation errors.
    Most of the rest of the errors are the regular "Could not find target property for formula". Basically DS has a morph property with an ERC link to a morph property in another file, problem is that DS either can't find that property anywhere in your content directories, or it's found it just not at the location it was told to look for it at.
    Now the majority of these errors are created by Corrective morphs, morphs that control how other morphs look, if you don't have the other product installed then DS can't make the link and creates an error message.
    Some of them are created by changing folder names/changing file names/changing property names etc after creating the files with the ERC links. Some are simple typos, someone has decided to do a spot of hand editing and messed up and hasn't spotted it.
    Ran into all of those in the past, not a lot you can do about the Corrective morphs if you don't own the products they are tied too, the other forms of this error can be "fixed" if you are willing to spend a few hours editing DSF files.
    By
    Bejaymac Bejaymac April 2020 in Technical Help (nuts n bolts)
  • Star Trek Builders Unite 8: THE REBOOT
    Curious to know what you're using for your uniforms, Draven.
    So for the uniform the Top is from MightyMike over at Renderosity https://www.renderosity.com/mod/bcs/tops-034-mmkbg3m-/126714/
    The bottoms and shoes are from the Cyberpunk Everyday Clothes here at Daz3d https://www.daz3d.com/20-50-cyberpunk-everyday-clothes-for-genesis-3-male-s
    On the Bajoran's, I've textured my way out of it for them moment using a photo of DS9's Major Kira, though still very interested in a nose morph for the G8's
    By
    draven_11_74c1296a16 draven_11_74c1296a16 April 2020 in The Commons
    You are very welcome Simon. I understand you were not directing these at any product or vendor.  This was more about dealing with the tech involved, and I feel like they are good examples or questions on how to deal with them :).
    "Poke thru with elf ears and explosion! One of the things I was hoping for was to be able, with SBH, to 'plonk' the SBH on a figure, then have an animated pose from base figure toposed and morphed figure at, say, frame 30, with the hop (expectation?) that the ear morph would slolwy push the SBH out of the way. Um, nope. Or at least not yet with any hair that is remotely long and covers the ear area."
    Now I understand.  That is a little more hopeful of the tech.  I would expect it to animate to an extent.  If you had dialed in an ear morph when you dialed in the morphed figure, then, maybe?
    "Leaving a trail: doing an animated simulation with the figure moving forward, the hair seems to leave a trail dangling in the air behind, from start position to end of animation (it would be a few strands of hair around 20' lng in RL terms)"
    If this is for a still render, then its definitely a simulation setting as I stated above.  If it's a full blown animation and you have one hair hangin in the breeze, then I don't have an answer to that, and I would have to ask someone with more knowledge.
    "Wind nodes: I have put the wind node in front of the hair and cranked it up to 100 and ... nothing."
    Wind is a finicky pain in the..   You have to animate the simulation ( I usually use the start bones from memorized pose) to get the wind to work.  I don't use the timeline.  If the wind node is not pointed precisely in the right spot, it does nothing. I have also asked tech to please give us more information on it.
    By
    Some general dhair issues were discussed in a different dforce hair thread and I want to share them here along with solutions. I placed the info towards the bottom of the first post.
    Thank you for addressing some of the points/opinions I made in a deifferent thread, I will try and clarify! None of these are aimed at any PA or nay particulat hair product, just in reference to the actual underlying engine!
    By
    SimonJM SimonJM April 2020 in The Commons
  • Can XTransfer transfer from G8F to G8M and from G8M to G8F?
    Would the G8 Cross-Figure Resource Kit enable/aid in cross gender morph transfer at all?
    No. That product is used for clothing or hair creation, not morph transfer.
    By
    Leana Leana April 2020 in The Commons
    By
    jeylien jeylien April 2020 in The Commons
  • Does Morph Loader Pro produce junk?
    i would have thought that the morphs were just saved as part of the scene file unless you actually save your morph asset separately - but i dont know.
    Yes. I'm not sure if it is still an issue but in the past embedded morphs (saved in the scene) have not projected into fitted clothing after the scene is saved and reloaded.
    By
    Richard Haseltine Richard Haseltine April 2020 in Technical Help (nuts n bolts)
    By
    lilweep lilweep April 2020 in Technical Help (nuts n bolts)
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
