Please help! My offical figure's mesh have became ugly.
Well sir thanks for the reply, I have digged into everything, but there are no updates and stuff.
However I can now confirm my genesis basic female mesh is wrong, can I somehow do a fresh reinstall of G8 package? That might work.
Richard Haseltine said:
There is a morph loading with a defulat value of 1, which is not mixing with the other shapes. First check that there are no updates for your content (if you installed through Daz Central or Install Manager, or through Daz Studio itself, updates should be flagged).
UltraScenery - new territory [Commercial]Doc Acme said:
Ah. Read the postings above regarding USC products & Daz Central.
What's the purpose of Daz Central? Even the moderators recomend NOT using it. Silly.
Don't confuse Daz Central and Daz Connect.
UltraScenery - new territory [Commercial]Ah. Read the postings above regarding USC products & Daz Central.
UltraScenery - new territory [Commercial]They just disappeared. So I uninstalled them reinstalled them. From both Daz Central and DIM. Still not showing up in UltraScenery. Doing a complete reinstall of Daz with DIM. Just to see if that fixes it.
Content Disappearing?Smart Content is not smart. It relies on metadata and the CMS database, that database can become corrupted making Smart Content useless. If you installed with DIM or Central all your content should still be available from the Content Library pane under either DAZ Studio Formats or Poser Formats.
Missing a bunch of products *SOLVED*Richard Haseltine said:
PerttiA said:
mding said:
I also experienced this recently the other way: assets, which I couldn't install with DIM, but that could be installed without any problem from inside DAZ.
Installing products inside DS, when you are also doing installations with DIM/DAZ Connect/Manual installation, is one way to mess up your content libraries and it will also fill up your storage devices as everything is installed twice in completely different locations.
I assume you mean Daz Central? You are correct that using one of those methods and Daz Connect (which is the through Daz Studio one) will duplicate files, but it certainly shouldn't have any other deleterious effects.
I have to disagree with that statement. I think you were too quick to generalize. You know that some products do not work when installed with Daz Connect. A user may have a perfectly working product installed with Daz Central or DIM, but it they install it again with Daz Connect, the product stops working. I have had to help several UltraScenery addon users resolve exactly this issue. I am convinced that it is absolutely "deleterious" to install some products with Daz Connect.
Instalation question about the Bank Heist BundleQuasar said:
I have a quick installation question about the Bank Heist Bundle. If I install the Bank Heist Bundle installer (It looks like it includes the bank set and props), does that mean I don't have to install the individual set and props installers?
Why would you want to use a different installer? There is no such thing as a "bundle installer"; a bundle consists of individual items and those individual items get assigned to your account as soon as you buy the bundle. After you get the items (heist environment, heist props, morphing masks, Goran HD and Ajisai) they can be installed using the methods available for them. Usually the Daz Install Manager ("DIM") or that new central stuff.
So basically... you buy a bundle, open whatever installer you normally use (DIM or Central) and then install all the newly available stuff.
Fair warning with bundles though: always check the prices of the individual items as well because sometimes the individual items combined can cost less than the bundle.
Missing a bunch of products *SOLVED*PerttiA said:
Taoz said:
I had problems with some products that included Poser files which I installed with Connect while they were already installed with DIM, they acted strange in Smart Content. I did some tests with several similar products and there were definitely something odd going on in the Cloud file system when installing something with Connect that was already installed with DIM. I reported it to DAZ and QA responded: "The user needs to pick one way to install DIM or Connect, by using both they will get conflicts..."
Yeah... The problem is caused by DAZ, especially for new and inexperienced users, as there is no warning anywhere about DAZ Connect installing products to a different location than DIM/DAZ Central/Manual installation.
Why would it give a warning for the intended behaviour?
When a new user starts with "Download Studio", they are lead to believe that they must use DAZ Central for any and all installations, and when they start DS, 'Smart' Content asks them to install stuff which they already have installed -> Automatic double installation of everything without the user being aware of it or even being warned about the consequences.
No, if the system is working anything that is already isntalled will open without needing to download the Connect version. If an installed product is not showing as installed then there is a problem - content directories not matching, comminication between the CMS and the applications, or something else.
It is so sad to read about the resulting problems every day.
I think that is something of an exaggeration.
I can't open Dag anymore?What I meant is that you can't install or open the beta program itself with Daz Central.
You can still install the content with Daz Central and use it with the beta, just make sure that the directory where you installed your content is set as a content directory in the preferences of the beta.
I can't open Dag anymore?Leana said:
Daz Central can't be used for betas.
You should have a shortcut in the programs list to open the beta you installed.
Okay thanks i now found the Daz studio and i can open it. Its still the Beta. So if i cant use it with Daz Central, how do i get all my figures and stuff over there then?
I can't open Dag anymore?Daz Central can't be used for betas.
I can't open Dag anymore?Daz Central will not install the Public Build.
What are your system details?
I can't open Dag anymore?I have read and read and read... I have the Public beta version installed and i still cant open it.
When im try to Daz Central it just want to install daz studio i really dont know what to do now?Missing a bunch of products *SOLVED*Richard Haseltine said:
Has anyone else had the update mess up their previous DAZ Studio?BETAS CANNOT BE INSTALLED WITH DAZ CENTRAL, USE DIM.
Daz Studio 5 preview release is delayed and that's good news.wbmultimedia_86c7a1e221 said:
On my macOS Big Sur 11.5, sorry to say that I downloaded the Beta Daz3D and Daz Central, and where the Daz Central seems to be working, Daz3D refuses to engage and open. Thoughts?
Thanks!
You can’t install betas with Daz Central, only with DIM. So my guess would be that you didn’t install the latest beta but the latest release version, which doesn’t work with Big Sur.
Geirrod the Giant for G8.1M [commercial]RawArt said:
Dig the action shot!
Wish I had the patience to set up so many figures
Actually, those are the Now-Crowd Barbarians using the Now-Crowd Utilities to make a nice crowd (they still need manually positioning a bit to avoid the scenery and the scripts to change the angle but it really makes this kind of scene easy. That way I can focus more on the central figure). Got another one brewing with just the giant and hobgoblin. Then I'll try out the frost + rock giants at weekend (if I've time, things keep piling up).
Thanks!
Based on what you wrote, you have not installed the beta version but the released version DS 4.15.02 that does not work on BigSur.
Have you 'purchased' the beta version?
https://www.daz3d.com/daz-studio-betaThat page includes installation istructions as well.
