Accessing Tutorial Products
Hey guys - I've finally got around to starting in on all those tutorials I've been snatching up when they's on sale. Only a couple appear in DAZ Central or in my Smart Content pane. Where would I be likely to find most of them?
Wood-Sided Longhouse/Mead HallHavos said:
Given you are a fan of Roguey & Strangefate I imagine you already own the Red Crow Inn (https://www.daz3d.com/rog-red-crow-inn), which certainly has the wooden details and excellent modelling, but of course stone walls, so they would need replacing. You could use all the props from this set inside the Celtic Great Hall, and it might look pretty good.
Other Dante78 sets you might consider are Medieval Manor and Medieval Tavern 2. The latter is probably closest to what you want, it has no throne area, and does include a central fire pit. I do however find Dante78 sets a pain to customise, as a lot of the modelling is a single big obj, and some of the textures don't look great in close up.
Yeah, I own most of Dante78's sets, and they do require work to get them converted to Iray...and sadly, they don't look the best closeup. But they do look amazing from a distance -
It's just that in this case, I'm looking to do a piece that focuses on two characters having a quiet, peaceful moment in their steading. They are both considered heros to their people (one is my GW2 Norn main character, and the other is a GW2 Norn NPC), so they'd have a more elaborate steading, which I suppose would be considered a hall. (Norn are pretty much 9' tall Vikings, with a little variation in that they worship animal spirits rather than gods). But it's a close-up piece, so even though the architecture will be in the background, it will still be quite visible.
Wood-Sided Longhouse/Mead HallGiven you are a fan of Roguey & Strangefate I imagine you already own the Red Crow Inn (https://www.daz3d.com/rog-red-crow-inn), which certainly has the wooden details and excellent modelling, but of course stone walls, so they would need replacing. You could use all the props from this set inside the Celtic Great Hall, and it might look pretty good.
Wood-Sided Longhouse/Mead HallI do have this set, which is by Dante78 on Rendo...it might have to do as a base and then I'd have to kitbash in a bunch of stuff to add the detail. It's a wonderful set, on the outside mostly. But what I'm really looking for is that big, warm, central firepit and no raised throne thingy.
So in the last 2 installs of DS Pro 4.15 goes in application folder why...?foleypro said:
Richard Haseltine said:
That is one of the defaults, up to the My Library folder. I'm not sure, though, if it is used at all in a Daz Central install (I'd expect it to be there unless changed, since it isn't the default for Daz-installed content by any method so not relevant to the installer used). However, this is stuff you need to work out if you are writing a plug-in as not everyone will use the default paths.
wouldnt there be a way to show paths of said plugin...man this is just way past my brain cells..I can get it to work and I can compile problems....is it really worth it...been a 5 year problem and here I am trying to figure out why again...
What do you mean? What are you wanting to get?
So in the last 2 installs of DS Pro 4.15 goes in application folder why...?Richard Haseltine said:
So in the last 2 installs of DS Pro 4.15 goes in application folder why...?That is one of the defaults, up to the My Library folder. I'm not sure, though, if it is used at all in a Daz Central install (I'd expect it to be there unless changed, since it isn't the default for Daz-installed content by any method so not relevant to the installer used). However, this is stuff you need to work out if you are writing a plug-in as not everyone will use the default paths.
tjm5635 said:
Ok so I uninstalled it from both DS and S Central. I reinstalled using only D Central. I seems to be working now. BUT it does show the install arrow/triangle on the DS icon. Just so you know... Thanks for your help. :-)
That's expected - the icon means it is available to install through Daz Connect (through Daz Studio itself) - when that icon isn't there it has been installed through daz Connect which can cause issues for some scripts.
That's not completely accurate. When the user never logs in inside Daz Studio, products that are installed with DIM, and probably Daz Central, will not have the "available to be installed with Daz Connect" symbol on them. So one cannot assume that the absence of that symbol means the product has been installed with Daz Connect.True, but geneally if people have logged in through DS it's likely to be the case. A way to distinguish is to right-click on the product and see if it offers an Unistall command.
Modular Medieval Village [Commercial]Uthgard said:
Yes and no. People devoted a lot of time and energy to keep things in tip-top condition. My grandmother's house had a clay floor for quite a few years, and she once described in loving detail the two kinds of clay she used to first polish the floor and then leave it in a usable condition. On her knees, daily, for the whole first floor. They wouldn't have a modern finish, but a deteriorated image would be far from the norm.
I think that conditions in the actual Middle Ages might have been rather worse. William Manchester, in "A World Lit Only by Fire", gives this description of the home of "a prosperous peasant":
Lying at the end of a narrow, muddy lane, his rambling edifice of thatch, wattles, mud, and dirty brown wood was almost obscured by a towering dung heap in what, without it, would have been the front yard. The building was large, because it was more than a dwelling. Beneath its sagging roof were a pigpen, a henhouse, cattle sheds, corncribs, straw and hay, and, last and least, the family's apartment, actually a single room whose walls and timbers were coated with soot. According to Erasmus, who examined such huts, "almost all the floors are of clay and rushes from the marshes, so carelessly renewed that the foundation sometimes remains for twenty years, harboring, there below, spittle and vomit and wine of dogs and men, beer, remnants of fishes and other filth unnameable." [...]
The centerpiece of the room was a gigantic bedstead, piled high with straw pallets, all seething with vermin. Everyone slept there regardless of age or gender -- grandparents, parents, children, grandchildren, and hens and pigs ...
If this familiar situation seems primitive, it should be borne in mind that these were prosperous peasants. Not all their neighbors were so lucky. Some lived in tiny cabins of crossed laths stuffed with grass or straw, inadequately shielded from rain, snow, and wind. They lacked even a chimney; smoke from the cabin's fire left through a small hole in the cabin's roof ... These homes were without glass windows or shutters; in a storm, or in frigid weather, openings in the walls could only be stuffed with straw, rags -- whatever was handy.
Manchester has been accused of exaggeration, although his quote from Erasmus is actual source material. Ian Mortimer in "The Time-Traveller's Guide to Medieval England" has his own description of "the house of a moderately prosperous Midlands yeoman, with thirty acres to his name."
His house is likely to be a wooden structure of three bays (about forty-five feet by fifteen or so) built on a stone foundation plinth. The hall extends to two bays; the third bay at one end is a storeroom at ground-floor level, and the family bedchamber above, reached by a ladder. Normally the frame of the house is made up of two pairs of curved oak timbers (crucks), joined by a heavy ridge pole across the top of the house, with oak or elm purlins forming the frame of the walls. The whole structure has a slightly warped look since it is built with unseasoned timbers which twist into their own shape as they harden over the first few years. The walls themselves are made of ash struts encased in cob. The roof is framed with ash struts across oak beams and thatched with osiers, or rye or wheat straw. A few slates or tiles cover the parts likely to be affected by sparks from the fire. One problem with this organic design is that, while it holds heat well, it attracts vermin which burrow into the walls and roof of the house.
You enter by way of an oak door set on iron hinges. This fits into a frame which is strong enough to warrant the door having a lock. Immediately inside is the hall, which is quite dark, being lit only by a central fire and shuttered unglazed windows which are small enough to keep the heat in and the winter weather out. The furniture includes a chair, a pair of benches, several chests and little else. The walls are not painted but might be plastered. Looking up, you will see that the beams and upper parts of the room are blackened with smoke. Some of the householder’s possessions are hung on the walls or suspended from the beams: some tools, joints of salted meat kept over the winter, tubs, tripods, hoops and buckets. The floor is strewn with rushes and herbs. Beneath the rushes is bare earth which is swept with a broom of clustered twigs when the rushes are replaced.
... The poorest villeins live in cottages which are little more than hovels. They consist of a single room of one bay only, perhaps just thirteen feet square. The roof is of thatch or turf, which leaks after a few years if not repaired. In winter it is quite likely that you will have to step over a puddle of water which has collected in the rut worn in the doorway. The door itself swivels on a stone at its base and is tied to the frame of the house at the top; therefore it does not swing easily. There is no lock, only a latch. The shutters are hinged with pieces of hide on their upper edge and propped open at the bottom with a stick. The floor is bare earth, covered with straw. The whole house is damp. It is smoky: ‘full sooty was her bower,’ as Chaucer would say. The arrangement of the shutters means that the house is often dark, even in the daytime. Eating facilities might include a trestle table, an earthenware jug, wooden bowls, a bench and a stool. The sleeping area is tucked behind a wattle screen along one side of the room: a bed made of three planks, a mattress of dried heather or fern, a single sheet and an old blanket on top. Other possessions might include a brass cooking pot, an old cauldron, a basket, and a tub outside for storing water brought back from the well.
I've been in earth-floored houses in the developing world, and while they aren't as squalid as described in Manchester's book, they aren't as pristine as some people have described here. In dry climates, they're often dusty; in wet weather, even hard-beaten earth can turn to mud. An earth or clay floor is easier to maintain if you have solid stone walls and a good roof; if your roof leaks, it's a different matter. And keeping it clean, as @Uthgard observed, requires constant work. Peasants who were also laboring in the fields to get enough to eat wouldn't have had the time or the energy -- hence the use of rushes to protect the floor.
In the pieces I've quoted above, there are two interesting observations. Manchester talks about a "sagging roof"; Mortimer says "The whole structure has a slightly warped look since it is built with unseasoned timbers which twist into their own shape as they harden ...". Medieval houses wouldn't have had neat, regular lines, and each one would have been different, depending on the materials available, the skill of the builders, the exact location and so on. Dante78 at Renderosity does a nice job conveying this kind of chaotic, haphazard look.
That's not completely accurate. When the user never logs in inside Daz Studio, products that are installed with DIM, and probably Daz Central, will not have the "available to be installed with Daz Connect" symbol on them. So one cannot assume that the absence of that symbol means the product has been installed with Daz Connect.Richard Haseltine said:tjm5635 said:
200 Plus Puppeteer Interface for Genesis 8 & 8.1 (Commercial)Ok so I uninstalled it from both DS and S Central. I reinstalled using only D Central. I seems to be working now. BUT it does show the install arrow/triangle on the DS icon. Just so you know... Thanks for your help. :-)
The We Will Miss You, Chohole Complaint ThreadThose big computer rooms always facinated me.
The main computer in the central area of the 2nd floor of the LCC building was something like that, except that it was more for real-time launch related operations (rocket switches, valves, pressures, temperatures, etc.) rather than business related tasks. I only was able to get in there once or twice but there was lots of stuff in there.
In my lab we would get VIP visitors once in a while and I got a chance to show off my babies. I kept hoping that someone would ask, "What's it all for?" I had a canned answer but I never dared use it. I would love to have said: "What's it all for? Uh, sometimes the gauges register a little when the buck deer fight in the Autumn, or the birds fly over in the spring. And nearly a whole dial became active when your ship approached from deep space".
Product INSTALL issuePerttiA said:
john_97a982ce said:
Are you saying that I do not need to have DS open when I install through DIM?
No you don't
I thought the point was that DS doesn't need to go online unless you are using Connect to install - but DS can be open or closed while installing through DIM, the thing to avoid is closing DS and immediately starting DIM or Daz Central as the timing can lead to the database not being available to the installer, which can cause issues.
So in the last 2 installs of DS Pro 4.15 goes in application folder why...?Because the whole point of Daz Central is to provide a simplified experience for new users, so they make one choice (where to put the Daz 3D folder) and everything then goes into sub-folders of that - the Applications folder is used for applications, with sepaarte sub folders for 32 and 64 bit versions. In Install Manager you can set the individual locations for differnt types of content. Your plug-in should have no occasion to refer to the application folder directly, any associated content or settings should go elsewhere (e.g. AppData/Application Support for settings and other non-user files, or a content directory, or the registry) and you can, as far as I know, acess all those through methods in the SDK.
So in the last 2 installs of DS Pro 4.15 goes in application folder why...?No custom installer needed just drag and drop right now...Will find out if it works on the beast today later..I am wanting to know why DAZ CENTRAL puts the main daz folder in apllications...? I am going to try today get the plugin working then make some IRAY presets and see if it works in filament...just want to know why DC is putting main program in 3d applications....must be new...?
That is the correct behaviour for Daz Central - in order to simplify the process of installation it takes a single setting, for a base path, and places everything (including the applciation) in a specific sub-folder of that.
But why would it place it in Application:C:user\username\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4... why in applications... and why is the 64 bit folder there...?
200 Plus Puppeteer Interface for Genesis 8 & 8.1 (Commercial)PerttiA said:
tjm5635 said:
no, it is fully installed. In fact each icon is duplicated. Duplicates seem to be a common thing in DAZ. And yes, I installed it through DAZ Central. Then in All Products I installed it and it no longer has the install or update arrow.
So, you have installed it twice, first with DAZ Central and then with DAZ Connect (within DS) - That is the problem as any and all DAZ Connect installed products are overriding any and all other installation methods.
DAZ Connect uses non-traditional path to install products and therefore can cause problems with scripts that expect to find files in traditional locations. You need to uninstall the DAZ Connect installed one the same way you installed it within DS.
The only reason to log in to DS is to use DAZ Connect to install products, if you are using DAZ Central, DIM or manual installation, DO NOT LOG IN to DS.
This is absolutely 100% true and extremely important. Listen to this advice and act on it!
200 Plus Puppeteer Interface for Genesis 8 & 8.1 (Commercial)no, it is fully installed. In fact each icon is duplicated. Duplicates seem to be a common thing in DAZ. And yes, I installed it through DAZ Central. Then in All Products I installed it and it no longer has the install or update arrow.
