• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Correcting pJCMThighSide_85_L with morph loader pro missing step
    Thanks for the comments I've upldated the original post with the screen shots
    @ lilweep, I'm pretty happy its the correct morph, see the screen grabs.  It look s like the bone is overdriving the morph.   I've always loaded corrective morphs ove the top of the morph they are designed to replace at 100% so I dont think thats the issue, but I'm clearly missing something.  @ Catherine I've skimmed your guide (thank you btw!), one question, are you loading your morphs with the figure posed or zeroed?
    By
    Lzy Lzy May 2021 in Daz Studio Discussion
    lilweep said:
    Catherine3678ab said:
    Lzy said:
    Hi, is there a correct method for overriding the pJCMThighSide_85_L /_R JCMs?   I've exported the mashed mesh at base resolution with the pose in place and corrected both the left and right sides.   I've then created a blend map spliting the garment between left and right sides.  I've then used morph loader pro:
    Property Group: Hidden correctives
    Overwrite Existing: Deltas only
    Attenuate By:  The Afformentioned blend weight.
    The morph loads without error but the when I pose the figure left side to 85 it overdrives the morph so the garment looks like its doing a high kick.
    I've not had this problem before correcting other morphs, but I'm clearly missing some critical step when its a morph driven by a bone?
    Help....  Please...
    Thanks In advance!
    Each leg requires its own morph. Something in here might help: https://sharecg.com/v/97315/view/3/PDF-Tutorial/Making-pJCMs-for-Clothing
    I cant actually picture what the OP is describing (because i lack reading comprehension and I only help people if they post pictures) but i think the OP said they used a weight map to attenuate by, so theoretically they dont need to make separate morphs if they attenuate on import via morph loader pro.
    They are talking about a figure doing the splits. There's an excellent video on YouTube covering the topic of weight maps.
    By
    Catherine3678ab Catherine3678ab May 2021 in Daz Studio Discussion
    i think their problem is they probably mislabelled their Thigh bend morph as their thigh side morph.
    Load the .obj thigh side morph into Daz using obj import (instead of by morph loader pro) and see what it looks like by itself.
    By
    lilweep lilweep May 2021 in Daz Studio Discussion
    Help....  Please...
    Thanks In advance!
    By
  • The My Bucket's Got a Hole In It Complaint thread
    Non-complaint:  Wheee...  My primary machine "Saturn" that I use for DAZing is now hardware complete.  Yay!  It's only taken 21 months and three case swaps.frown  Finally it has a suitable graphics card.  And ooh, ooh, it has an RGB light too.yes  Too bad that it's in a case with no window.  The RGB front fans show through the air grill, but everything inside hides its glory.
    Not a good photo, but a record for posterity before it gets enclosed in the dark and shoved under the desk again.
    Now, to get busy and open up my secondary machine ("Janus") to transfer the old GTX-1660 graphics card from Saturn into it to replace the native on-board graphics.  Wheee... fun all day.smiley
    By
    LeatherGryphon LeatherGryphon May 2021 in The Commons
    Help....  Please...
    Thanks In advance!
    By
  • Dial Fusion for Genesis 2 to 8.1 (Commercial)
    hansolocambo said:
    One of the (many) things that's really impressive is the fact that sliders are created on the fly and instantly visible without the need to restart DAZ (which is ultra annoying)
    Do you please know a way to kind of manually "refresh" DAZ without restarting to make new sliders (morphs, etc) visible ?
    Scripting - write a script to create the properties, insert the morph deltas if need be, and establish the ERC links.
    By
    Richard Haseltine Richard Haseltine May 2021 in Daz Studio Discussion
  • Using Marvelous Designer to refit clothes across generations?
    CHWT said:
    Hmm, I originally thought about importing a different generation base figure as avatar in MD, drape the clothing, export clothing as obj, then importing obj clothing into DS and use transfer utility to transfer target figure rigging into the obj clothing.
    transfer rigging is imperfect.
    why not just use marvelous designer to sim the clothing and then import in the final sim...? (And then dont do anything else that would ruin the sim, like transfer rigging)
    By
    lilweep lilweep May 2021 in The Commons
  • How to transfer morphs to non-autofitting clothes?
    If the morph is set with the "auto follow" tag it should get projected into the clothes automatically.
    By
    Leana Leana May 2021 in Technical Help (nuts n bolts)
    Faeryl Womyn said:
    You can bring in different base models, however I'm currently waiting for an answer about bringing in already made clothes to MD and refit as you suggested. As soon as he gets back to me I will let you know.
    Ok while I'm waiting I found some information for you and yes you can bring obj's into MD as a garment and make them fit.
    https://www.marvelousdesignerhelp.com/viewtopic.php?t=519
    for this video you should read the comments...
    This gives very good instructions on how to do what you asked.
    Got an answer back and he doesn't use Marvelous Designer to refit clothes...
    my goto method is to just use the autofit feature .  Sickleyeild & RiverSoft have provided clones for G3F going back to V3 and for G8F going back to V4.
    If that doesn't work my next method is in Daz to pose and shape the source figure to match close to the pose and shape of the target figure.
    Add the clothes to the Source figure, Export the clothes OBJ (tweak if desired in Blender)
    Use the Transfer Utility to convert the clothe to the Target figure.
    Then Update the Base Geometry of the Transferred clothes the saved OBJ.
    This work only with Weighted mapped target figures.  Non-weight mapped Source figures and clothe need to be coveted to weighted mapped to work.  This way will retain the original morphs of the clothes
    Awwwww, thank you! You are the best!
    By
    CHWT CHWT May 2021 in The Commons
  • [Released] Look At Me Pose Control [Commercial]
    RiverSoftArt said:
    Artini said:
    Are you saying, that Look at Me is better than its second version, regarding its work with Genesis 8.1?
    That's interesting.
    No, they are the same. 8.1 does not have a couple of the properties that Look at Me I or II need to work with the eyelids.
    What does this mean exactly? Does it means Look At Me II doesn't function correctly with Genesis 8.1F? I'm currently using LAMII with Genesis 8.1F, and i noticed the eyes always seem to look just below the camera, instead of directly at it,  even with Adjust Eyelids unchecked.  I'll do more testing with just Genesis 8.1F/Victoria8.1F default.  Has everything worked fine on your end with LAMII and G8.1?
    I was using LAMII with the head locked, so only the eyes move.
    Edit: It seems if I unlock the head, then the re-adjustment causes the eyes to look at the camera just fine again. There's some kind of process here I need to follow. I'll figure it out.
    Edit: if anyone does have any issues, you can use the Eye Look Up-Down morph to make the characters eyes look up more.
    By
    vozolgant vozolgant May 2021 in Daz PA Commercial Products
  • Darwins' Schtuff Pt Deux
    Facial morphs done, will go back a third time for the HD version later.  Tweaked the skin shader a bit too far- now he needs a bit more gloss. lol  Will fix that and move onto checking the UV/textures of the eyes to make sure they line up (haven't done that yet) and then the HD version of the facial features. Oh, and the brows are done, with textures/shaders, but not saved yet.  Ended up adding a bit of a third actor to blend his features out a bit more for my 80's Actor face morph.
    By
    DarwinsMishap DarwinsMishap May 2021 in Art Studio
  • Star Trek Builders Unite 8: THE REBOOT
    randym77 said:
    Good start, but I think her face needs to be squarer. Your morph is a little too long and thin, IMO. I think her eyes are rounder, too.
    For first season hair...I like ali's HR-099.  It used to be for sale at Renderosity, but is now available only at his own site, Mankahoo.com. (Just because of the way Rosity used to remove anything that didn't sell a certain number of copies per month.)  It's cheaper at his site, and he sometimes has 50% off sales.
    Thanks for the suggestions.  This is a Genesis 8 dialed-in head morph, my first attempt.  I'll give her the suggested tweeks.  I've put the hair in my bookmarks and will wait for a sale.  HR-99 is for V4, but I can still work with it.
    By
    jimkluza_00106d944d jimkluza_00106d944d May 2021 in The Commons
    By
    Faeryl Womyn Faeryl Womyn May 2021 in The Commons
  • Ahmunet Duplex Pupils
    Hi ;-)
    After applying the morph go into the materials folder and apply the mumy materials "Ahmunet All Mummy A Skin Only" or "Ahmunet All Mummy B + Glyphs" and it loads up the eye textures with the mummy textures ;-)
    By
    JeniMorris JeniMorris May 2021 in The Commons
    By
    randym77 randym77 May 2021 in The Commons
    Hello friends!
    I'm hoping I can find some guidance here on how to use the duplex pupils that come with thr Ahmunet character.
    I'm very new to rendering in general. I've been trying to find information on how to apply this morph. When I try to apply it, it makes the pupils look cross-eyed.
    Any help would be appreciated!
    By
    arctic_shadows arctic_shadows May 2021 in The Commons
    Help....  Please...
    Thanks In advance!
    By
  • Something Wild
    watchdog79 said:
    WillowRaven said:
    As a book cover artist, I have to agree that I need more dragons or even more modifications to dragon 3 or any older dragons ... once I use a dragon on a book cover, it's just bad business to use the same dragons on other covers for other authors. Same goes for all critters, fantasy and reality. I don't even buy 'babe' characters unless there are also 'interestingly unique or cool' sff variants with it. Versatility. And I know PAs need to see a profit from their hard work, but wouldn't it stand to reason expanding existing figures into new heights be profitable, too, rather than more cookie-cutter characters?
    Perhaps you know of these, but just in case. There are quite a few wyvern variants available too:
    https://www.daz3d.com/wyverdreki-the-wyvern
    https://www.daz3d.com/raw-wyvern
    https://www.daz3d.com/wyvern-2-0
    https://www.daz3d.com/the-great-wyvern
    https://www.daz3d.com/hh-wyvern
    https://www.daz3d.com/hh-wyvern-textures
    https://www.daz3d.com/born-in-fire-for-hh-wyvern
    The HH Wyvern is customizable nicely.
    There is also a skeletal dragon available:
    https://www.daz3d.com/dforce-dragon-wraith-skeleton-and-accessories
    You can dial-spin Dragon 3 all day long, but almost every time you'll still end up with those cartoony feet and claws. Dragon 3 is always given away by those feet.
    As I said already, HH Wyvern is nice indeed, but it isn't very customizable at all. Texutres, yes...but you can't really alter the shape unless you morph it yourself. Longer neck, longer tail, wings/arms carried/folded lower...I'd love to know how to do that...then again, if I did, I'd be making the figures myself to begin with, haha.
    By
    MelissaGT MelissaGT May 2021 in The Commons
    Not that I know of. The figure has to be reloaded to reflect any other new morph additions. The reason It reflects with DIal Fusion is because it is populated in the current scene on the current figure. If I add more morphs in via a normal copy paste into data it won't show unless I load in a new figure that scans the data folder again.
    By
    Zev0 Zev0 May 2021 in Daz Studio Discussion
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
