UltraScatterPro Experiments and Experiences
Marshian said:
Hi lilweep. Thanks for responding. Oh sure- Just want it to lay flat, not bend. Think of flat armor plates. I could create a texture but I'm looking for more dimension, like super clunky chunky plates. Like Some giant built it quickly and doesn't care how heavy it is
lilweep said:
wouldnt that involve morphing the shape to get it to "wrap around" rather than just being on a tangent with the surface?
I dont think ultrascatter claims to be able to morph shapes.
Would it be easier to just use a texture of riveted metal sheets?
Something like this?
Click on image for full size.
Carrara Community Art Gallery - Show us your Renders!!!Mystiarra said:
i been playing with the troop carrier since 2009
2009-10-30
best 1.99 i ever spentit has an open windows morph
added a tube light to the interior. scifi-ish eshaust cylinders
next need to make glowy amunition for the gunners. and a very,very lo rez pilotI love that ship!
I also love using either of the LoRez 14MU Workers as LoRez pilots.
They animate well! So I make a generic pilot animation that's really long, doing different things throughout the timeline, then make an NLA clip that I can add to any LoRez Lorenzzo/Loretta based figure, and slide the clip around for each, so they're all doing different things - works Great!
Suggestion for a future DS updateWith all the huge amount of .../data/... files, it would be nice, to have the option to browse directly to the referring .../data/... file from the parameter tab.
It has now become a true PITA to search the whole .../data/... folder, in order to find one particular morph file.Transferring skinHow can I transfer the skin from one character I created to another? I have gotton the shading, tan, ect. down perfect and would like it on another person. Thanks! - Ski
UltraScatterPro Experiments and ExperiencesHi lilweep. Thanks for responding. Oh sure- Just want it to lay flat, not bend. Think of flat armor plates. I could create a texture but I'm looking for more dimension, like super clunky chunky plates. Like Some giant built it quickly and doesn't care how heavy it is
DAZ not freeing up VRAMmichaelmszabo said:
Hi, thanks for your answer :)
It's either a Daz Studio Process that never finishes instead goes on about 10% CPU usage forever or a process with the DAZ icon but no name.
It probably will close, it sounds as if it has a lot of clearing up to do - often the case with morph-heavy figures. It's single-threaded so you see only one core's worth of activity. Force-closing can damage the settings files or even the database, so it is to be avoided; you could start a fresh instance instead Daz Studio Pro 4.12 - instances
AIUTO...CHI CONOSCE L’ITALIANO? PARTE TREDICIKainjy said:
Imago said:
Silvhe said:
Imago said:
Silvhe said:
perché ci sono le figure,Sai che le figure ci sono anche nel DIM?
Ti basta selezionare i prodotti, fare click destro e scegliere "Retrieve Thumbnail" e ce le hai tutte.
Solo che alla DAZ non hanno aggiustato gli archivi e le immagini sono 6000x6000, per cui una volta che ha scaricato tutto devi ridurre le dimensioni delle immagini usando un batcher.
Questa non la sapevo, interessante. Grazie
Il povero vecchio Zio Imago continua a ripetervi di leggere le istruzioni ma nessuno da ascolto al povero vecchio Zio Imago...
Di nulla, comunque!
E' giustissimo Zio Imago, solo che le istruzioni di DAZ sono come un puzzle da 1.000 pezzi da ricomporre da solo. Tra un manuale che non spiega quasi nulla, pagine online risalenti alla vecchia wiki, link a pagine non più funzionanti, video su youtube di gente che ha smesso anni fa (molti non hanno più pubblicato nulla e i video vanno dai 5 anni fa in su) e una valanga di post del forum in cui provare a cercare info ai vari problemi... trovare qualcosa è una vera caccia al tesoro.
Non ti dico quanto ho sudato per cercare info su come creare morph, ora le sto cercando sulle weightmap (vorrei creare/editare dei vestiti e il Transfer da problemi..). Inoltre anche Iray non mi è ancora chiaro in alcuni punti...(per Filament mi sono dovuto andare a vedere la guida ufficiale di Google !)Appunto...
Can't find/install face transfer unlimitedI got puzzled by this when I purchased it. Have you entered the serial number? Face Transfer is already installed so you do not need to install anything extra, you just need to enter the number to unlock the full version. Look under My Serial Number on My Account for it.
UltraScatterPro Experiments and Experienceswouldnt that involve morphing the shape to get it to "wrap around" rather than just being on a tangent with the surface?
Di nulla, comunque!
Non ti dico quanto ho sudato per cercare info su come creare morph, ora le sto cercando sulle weightmap (vorrei creare/editare dei vestiti e il Transfer da problemi..). Inoltre anche Iray non mi è ancora chiaro in alcuni punti...(per Filament mi sono dovuto andare a vedere la guida ufficiale di Google !)How to get Genesis 8 expressions working on Genesis 8.1Drogo Nazhur said:
Is there a way to use G8F expressions on G3F?
Not to my knowledge. If you are willing to sink some effort into it, you could try this method to dial in an expression, export an .obj, import as a morph that relies on a single slider, then transfer that morph to G3. But I honestly don't know if that would work.
New! Novica & Forum Members Tips & Product Reviews Pt 14After many hours with the Strand Based Hair Noggins Hare and Rabbit it still looks like a Hare even with the Rabbit Morph :)
2021-05-09 13:59:10.992 Total Rendering Time: 2 minutes 48.84 seconds
Sand Bunnies
2021-05-09 16:03:20.560 Total Rendering Time: 1 hours 9 minutes 48.13 seconds
CPU
Show Us Your Iray Renders. Part VIIIAfter many hours with the Strand Based Hair Noggins Hare and Rabbit it still looks like a Hare even with the Rabbit Morph :)
Sand Bunnies
CPU
My WIPS, renders and animations :)After many hours with the Strand Based Hair Noggins Hare and Rabbit it still looks like a Hare even with the Rabbit Morph :)
Sand Bunnies
CPU
067
Carrara Community Art Gallery - Show us your Renders!!!i been playing with the troop carrier since 2009
2009-10-30
Can't find/install face transfer unlimitedI bought face transfer unlimited a while ago, but only now I'm trying to experiment with face transfer. (without much success). The characters appear with a watermark, so face transfer unlimited either isn't installed or doesn't work. But I can't find the files to install it anywhere. They don't appear in the not yet installed files, nor in the already installed files. The product definitely shows up as "purchased" on the catalogue page.
What am I doing wrong, if anything? Thanks in advance.
Where does Face Transfer save your Morphs to?Simple enough question. Where does face transfer save your morphs to?
I made a character and want to tweak the morph using an external tool but can't find where it's been saved to.
Anyone figure out how to get a sweet, but seductive smile with Victoria 8.1?All these smile morphs make her face look bizarre.
I was wondering if any of you guys figured out how to get V8.1 to have a sweet, but sexy & seductive smile?
There's this ugly line that forms right inbetween the eye and the top part of the cheek when she smiles, it doesn't look good. Thank god for Zbrush, I can fix this with Zbrush, but that means I need to create a Zbrush morph patch for every expression.
New or Returning Anime Models for Genesis 8Hi
I'm making a morph of Hiro 5 for G8M...
The image is a preview of the morph at 0-25-50-75-100%.I'm sending the product to DAZ to see if they would pubblish it.
Correcting pJCMThighSide_85_L with morph loader pro missing stepLzy_2239363 said:
Thanks for the comments I've upldated the original post with the screen shots
@ lilweep, I'm pretty happy its the correct morph, see the screen grabs. It look s like the bone is overdriving the morph. I've always loaded corrective morphs ove the top of the morph they are designed to replace at 100% so I dont think thats the issue, but I'm clearly missing something. @ Catherine I've skimmed your guide (thank you btw!), one question, are you loading your morphs with the figure posed or zeroed?
With morphs fixing issues I leave the figure/clothing posed; use "reverse deformations" when loading the morph corrections.
However for the replacement pFBM, in the clothing the one I'm remaking I dial out so that the replacement morph will do the entire job. As it is loaded, the program dials the new morph back in to 100%. [figure/clothing remains posed throughout]
For making the pFBM replacements, be careful with the renaming steps. I'm not an expert at this. In my tutorial I'm making real morphs and using those to replace the generated morphs. I think some people rather than making replacement morphs, use the 'deltas only' to change the existing pFBM in the clothing, and then save them out properly of course. And for those situations the original pFBM would be left dialed in as only changes are being added to it.Whichever way works for you is fine AFAIK.
