"Ps" files with duplicate content and no thumbnail appearing in Smart Content?
Exactly where in smart content are you seeing these files? And when you say they have no thunbnails do you mean triangles with exclamation points or just blank squares?
Are the thumbnails just greyed out? That means they are available and not installed.
Did you install them with DIM, DAZ Central, or from within DAZ itself? Possibly you've installed them more than once with different methods? Different methods of installation save files in different sets of folders so that can sometimes cause some confusion.
You've got to uninstall them the same way they were installed. That would include uninstalling them twice with different methods if you've installed them twice with different methods.
Problema en la instalación ayuda!!!!alump.dianaratejada said:
No me carga completamente daz 3d en daz central y cuando esta al 14 % se corta la descarga y me aparece instale
Me pasa igual cual es la solucion?
Problema en la instalación ayuda!!!!No puedo cargar daz central llega como alguien comento hasta un tal posentaje y se corta, me pone nuevamente instalar y nunca abanza. probe con desistalar todo, crear otra cuenta y nada, ningun resultado. ¿Que deberia hacer?
Daz Studio 4.20[.0.x] Pro, General Release! (*UPDATED*)@Ptrope Since nothing else seems to be working to fix your Daz Studio white interface problems, try this 12-step process:
1. Uninstall Daz Studio from Daz Central and/or DIM
2. Delete all Daz 3D AppData
C:\Users\username\AppData\Roaming\DAZ 3D\ (NOTE: Back-up folder first for safety)
3. Restart PC
4. Uninstall Daz Central from PC
5. Delete all Daz 3D AppData again (i.e 2nd-time)
6. Restart PC
7. Go to the Registry editor and Edit->Delete the 3 Daz files/folders (see below)
NOTE 1: If you want to backup your Windows Registry before making changes, follow the steps here:
https://www.howtogeek.com/197785/how-to-backup-and-restore-the-windows-registry/
NOTE 2: You may also want to create a System Restore point before you make any edits:
https://www.howtogeek.com/237230/how-to-enable-system-restore-and-repair-system-problems-on-windows-10/
Press Windows+R to open the Run dialog box, type "regedit" in the text field, and then press Enter.
A User Account Control (UAC) dialog appears asking if you want Registry Editor admin privileges; Click “Yes” and Registry Editor opens.Expand: HKEY_CLASSES_ROOT
1. .daz
2. dazfile
Expand: HKEY_CURRENT_USER
Expand: SOFTWARE
3. DAZ
File-->Exit8. Restart PC
9. Install Daz Central and/or DIM
10. Restart PC
11. Install Daz Sudio
12. Launch Daz Studio and hopefully your white interface is no moreLeprechaun Bundle - Happy St Patrick's DayHi. Yes, that's us. We're about 45 minutes east of Charlotte. When I tell Siri to take me to Albemarle, she always gives me a location near you, 6 hours away. Ha!
Charlie Judge said:
Greybro said:
Yay! Cool bundle indeed! I got to use it in a marketing piece earlier today!
Interesting; The bundle just came out today; so, I'm surprised it was useful in advertising this year.
The ad really attracted my attention because of the Albemarle reference. I live in the Albemarle sound area of eastern North Carolina; so I looked up Albemarle Nutrition and found it was in the south central part of the state just east of Charlotte. Are you also in that part of the state?
Impossible installation of Daz studioHi there,
Neither Daz central (stop at 93% after prompting daz helper installation) not DIM (one file is missing or can't be read) can install Daz on my computer.
I have tried on two different computers W10 and w11
Daz 4.15 Updated with strange effects - SortedUninstall through Daz central if that is what it was installed by, though Instal manager should also work since they behave in the same way.
Daz 4.15 Updated with strange effects - SortedDaz has updated itself, possibly via Daz Central but now looks like the attached screenshot.
How can I retore Daz to look and work properly as it is inoperable as it is?
Change file location for My Libraryronstringfellow said:
Sorry to necro the thread, but I followed these steps for the same reason as OP, and moved my library to a 5TB external drive. Now however it seems my Smart Content tab is empty. It's not a game breaker, obviously, as i use the Content Library tab for just about everything, but the smart content tab does *occasionally* make finding something faster, as i've started to amass a pretty hefty list of assets. It also appears the same is true for Daz Central. I've updated the base path location, it recognizes it as the new library on my external drive, yet the dashboard tells me that all of my assets are uninstalled. Is there a way to re-direct where these two are looking for the files? I've looked by can't seem to find a way.
Thanks.
Did you move the database, and did you update the path for it if so (and not if not).
Change file location for My LibrarySorry to necro the thread, but I followed these steps for the same reason as OP, and moved my library to a 5TB external drive. Now however it seems my Smart Content tab is empty. It's not a game breaker, obviously, as i use the Content Library tab for just about everything, but the smart content tab does *occasionally* make finding something faster, as i've started to amass a pretty hefty list of assets. It also appears the same is true for Daz Central. I've updated the base path location, it recognizes it as the new library on my external drive, yet the dashboard tells me that all of my assets are uninstalled. Is there a way to re-direct where these two are looking for the files? I've looked by can't seem to find a way.
Thanks.
How about a Simple (or not so simple) Smoke Detector/Alarm ?How about this? 125mm dia, 50 deep. Central circle of lower section is a different material (could be black to hide camera). Simple obj file, simple planar tex mapping from straight underneath which means the tex on the sides will be stretched a bit. Based on the one in the office I'm in today.
Regards,
Richard
Problem with recent purchaseI can assure you that its downloading the wrong file.
To one of of the above posters i didnt download it with both DIM and Daz Central. I only downloaded with Daz Central I checked the package files with the DIM
Installation Issue: Installation will begin after previous installationsHey guys am not very technical but i also had the same problem of being stuck at that install button, So i ended up going to task manager and ending the daz central that i was running..and when i re-opened it again i realised that the install button had disappeared, I went on my desktop and i saw that its already been installed...hope this helps and sorry i cant write proper english..if it makes sense then yah god bless haha !
Daz Studio 4 directory?Unless I have to redownload literally EVERY asset in my library, I'd be fine with just re-downloading daz. How do I go about that? Since I did install daz through daz central
Problem with recent purchaseI purchased this item today dForce Romantic Curly Hair for Genesis 8 and 8.1 Females
But the download file, both of them on the dim, as well as DAZ central and on the download product page present as this IM00085108-01_SciFiEssentialsTheCoilDS.zip
The hair isnt showing up in DIM or DAZ central but The Coil is
New Blog with Tips and Tricks to Help Get New Members Started!Hello everyone,
Several years back, I had to stop dabbling with CGI and only started again recently. DAZ Studio is kind of new to me and I am still trying to make sense of the tutorials. There is one thing that I haven't been able to figure out: While I am able to use old content that DAZ Central conveniently downloaded and imported, I can't get a specific scene to render. Other items and scenes render without issues. The item in question is Winter Kingdom: Castle Ruins (08.2011). I've tried loading it, then just pressed 'render'. The system shows it's doing several passes but the render window remains black. All props are visible as wire mesh etc. I thought it might be the camera position and zoomed out but it was the same result. Can anyone tell me if I'm doing something wrong or is the prop broken?
Sabrina
[Out Now] Space Trading Station: Central [Commercial]This is out now! https://www.daz3d.com/space-trading-station-central
Daz Studio 4 directory?Ethanreid123 said:
The problem I'm running into specifically is that I want to open duf files in blender, and I get an error saying that it couldn't find "program files/daz 3d/dazstudio4/shaders/iray" content path. I figure there's some sort of general installation step I missed when downloading daz studio? Or that I installed the addon wrong.
No, that is where the folder would be with a default Install Manager installation. Daz Central, or a customised Install Manager, will use a different path - I woudl hope that there was a way to modifiy the path (e.g. by setting the location of the application) in Diffeomorphic - but you should ask in the thread on the importer.
gen8 m keeps losing duf??If you have installed within Daz Studio, then that has priority if you also use other installation methods, even if that install is broken.
You can try inside DS to right-click the product icon and select uninstall, and after that try to install with Daz Central.
