• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • New update stuck at 86 percent with DAZ Central
    I installed my version of Daz Studio on an external drive (Z:). When I upgrade to the latest version (4.20.0.17), Daz Central installs Studio, and stops at 86 percent, then says the install is complete, but the install failed. It does not install Daz Studio.
    I uninstalled and reinstalled Daz Central, but the app keeps a trace somewhere and saves the settings, and the failed install data. Every time I try to install Daz Studio, it begins at 86 percent, and I get the "Installation complete message."
    Can somebody help?
    By
    Erdehel Erdehel May 2022 in Daz Studio Discussion
  • 8.1 and Expressions...
    AndrewJJP said:
    I don't think I am....? I don't have DS set to log in. Once, it complained that G8 Starter Essentials had missing components, so I logged in then, and that was a mistake! I ended up uninstalling them from DS and Daz Connect, then reinstalling from Daz Connect to make it work again. That's not a mistake I intend to repeat!
    DAZ Connect is the one within DS, DAZ Central is the 'simplified' DIM.
    By
    PerttiA PerttiA May 2022 in The Commons
    PerttiA said:
    AndrewJJP said:
    PerttiA said:
    DC as in DAZ Central or DAZ Connect?
    If you are using DAZ Connect for installing products and updating them, there is no point in installing products with DAZ Central, DIM or manually as the products will be installed to two separate locations => One ends up having 'everything' installed twice, taking twice the storage space and causing all sort of havoc when users think it's all the same, whether you do it with DAZ Central/DIM or DAZ Connect within DS.
    Sorry, Daz Central. I only use that.
    If you are logging in to DS to allow "updates", you are also using DAZ Connect with all the side-effects
    By
    AndrewJJP AndrewJJP May 2022 in The Commons
    By
    By
    By
  • UVW Templates for Genesis 8.1 Female
    Does anyone know where the UVW template for Genesis 8.1 is located?
    Daz Central and Daz Install Manager don't seem to have a listed for Genesis 8.1 uv templates.
    By
    corinthianscori corinthianscori May 2022 in Technical Help (nuts n bolts)
  • Bryce content for Mac
    Horo said:
    vindazi - what do you mean by "installer". Do not use any Daz installer like DIM or whatever. Download Bryce assets maunally (the zip file(s)) and save it/them to a temporary folder, than un-zip the set, using the retain folder structure option or whatever it is called. Then you get the parts in the folders. There is usually a ReadMe file and often a PDF that explains exactly where the stuff has to be copied to. You can also download the PDF: https://horo.ch/docs/mine/pdf/BryceContent_v4.pdf (Bryce Content FAQ: Where does Bryce content belong to? Where is Bryce installed, where the additional files and those which were purchased additionally? These questions appear in the forums again and again. This document answers these questions for the Mac and Win PC. 11 pages (692 KB).)
    DAZ does not give you the Bryce assets and forces you to download the DAZ central installer. Blows my mind they wont let you download an old sofware like this manually. Going to cause all sorts of issues. If you have a way to download them without using hte DazCentral DIM then PLEASE let me know.
    By
    atetraxx atetraxx May 2022 in Bryce Discussion
  • Need to download windows version on a mac. Wont let me!
    If you're talking about the Install DazCentral button then, thats what I did. It just takes you to dazcentral installer page.
    Though, I did figure it out. It wont let me download the .exe if i use safari. I switched to google chrome and it let me download the windows version.
    Thanks
    Edit: dazcentral doesnt seem to work through crossover on m1 mac... dang. Is there really no bryce 7 3d installer? Why do i have to use daz central?
    Edit again: Thanks for everyones help. DAZ apparently mislabled the bryce installer as DAZ studio in the product library. I was able to get it working in crossover on m1 mac!
    By
    atetraxx atetraxx May 2022 in Technical Help (nuts n bolts)
  • Back to the beginning
    Hi, I haven't used DAZ Studio for a couple of years and I just updated everything by downloading DAZ Central - this is the first time i have used it.I have always done everything manually up to now.  How do I get the Genesis 8.1 figure in my content library? Do I have to download and update anything like Genesis 8 Starter Essentials? When I look in my DAZ Central under plugins there is no Daz to Genesis 8.1 showing for me to install. I am updating my Victoria 8.1 which is taking a very long time to do. Any advice would be helpful :)
    By
    Bea Bea May 2022 in New Users
  • My problems...Your problems....what are you working on today? ** Solved **
    whispers65 said:
    I hope everyone is having a great day!
    For me, I think I'm going to tackle 2 problems today and see if I an get them fixed.
    1)  Try to get 4.15 installed.  I tried to update through Daz Central.  It says it updated to 4.15, but it shows 4.20 when I load the program.  See screenshot.  Oh and I had a problem where it got stuck installing, especially at 86%.  I did some research last night and others had that same issue.  It did say it eventually installed, but obviously it isn't correct yet.  Hence, I'm going to revisit this problem today.
    2) Everything isn't what it appears.  Usually when I create characters, I do one of two things.  1) click on the character and it shows up.  2) click on the base figure like in this case, genesis 3 male.  then select genesis 3 male, and then click on the figure I want and apply it to genesis 3 male.  However, now when I click on the character straight way, it creates a mini-me instead of the size of the figure.  Like "chase" in this case. Or if I click on genesis 3 male now, instead of the default genesis 3 male, I get this other default image.  I think it is "Chase".  However, that is weird because I've never gotten it to work properly and don't really use it.  So if I click on genesis 3 male, I get the "chase" figure at regular size (I think it is chase anyway).  I then save it as a scene subset.  I click on file>new to clear the scene out.  I load in the scene subset and I get the full size genesis 3 male instead of the one I just saved.  Things I've tried.  I looked into the female genesis 3 and don't seem to have a problem there at all.  I uninstalled/reinstalled genesis 3 male essentials through DIM / Daz Central and it didn't help.
    So this is what I'm working on today.
    What are you working on today?  Something fun, I hope!  Have a great day!
    #1 after multiple tries, I think everything is up to date and installed.  I'll be totally honest, I don't get the install process at all.
    #2 I have more than one content folder. One is strictly for trying out freebies and so forth.  For some reason, "Growing Up for Genesis 3 males" was installed in both places and it was the extra that was causing the issue.  I uninstalled and then deleted the 2nd one out of my "test content" folder and everything appears to be working normally again.
    #3 I mowed the lawn.  I'm 57, but feel like 107.  It was hot and humid and I either have a hernia or I am closer to one.  The doc always said I was close.  Mowing wasn't that much fun.  I still have a little bit of weed eating to do, but I need to charge my battery in more ways than one so it will wait until tomorrow.
    By
    whispers65 whispers65 May 2022 in The Commons
  • [Released] Turbo Loader for Genesis 8 and 8.1 [Commercial]
    PerttiA said:
    RiverSoftArt said:
    TATSU 3D said:
    @RiversoftArt
    One question I do have, is I've found that certain morph packs will only load one or 2 of the whole range. These were all definitely working a few days back.
    When I run the G8M Config script, and scan for new morphs, each and every morph is ticked. I can even expand the morph packs and see the individual morphs are all checked, however they seill don't appear in my parameters tab after loading G8M. One example is a pack of eye shapes - the morphs are named Eyes 01 - Eyes 10, however only Eyes 02 and Eyes 10 are available to use, even after confirming all morphs were checked in the config screen.
    That should not happen unless there are still morphs with the .tlOff extension.  You should search for that.  It might be that you had turned some off, cleared the morph list and rescanned, losing the turned off morphs
    How does it handle the quite common case, when 'everything' is installed at least twice, once with DIM/DAZ Central and the second time with DAZ Connect within DS.
    Which ones does TL turn off/on?
    If you tell it to turn off a morph (defined by its relative path), it turns off ALL instances of that relative path + morph, wherever they are located.
    By
    RiverSoft Art RiverSoft Art May 2022 in Daz PA Commercial Products
    RiverSoftArt said:
    TATSU 3D said:
    @RiversoftArt
    By
    PerttiA PerttiA May 2022 in Daz PA Commercial Products
    By
  • Connect Library Size Doesn't Add Up
    The "Smart" part of the Smart Content is derived from the metadata. The metadata can come from any of the installation methods (Connect, DAZ Central, DIM), they are all supposed to be identical. DAZ added the ability to install directly inside Studio, clearly their preferred method, but many prefer DIM. There will always be dissenters to any of the methods, but that is another kettle of fish. You are not wrong in believing that Smart Content and Content Library are different ways of displaying the same information, but it is not explicitly clear. DAZ has been rather vague on that point, whether by design or omission. You do not have to install content from Studio to use the Smart Content system. (Again, there are those who would disagree, and with some merit, it is not foolproof).
    Third party data isn't necessarily unwelcome, as long as it follows the conventions used by DAZ vendors (which is sometimes a problem anyway). However, it would be a good idea to keep it separate just in case. By default, those products have to be installed manually unless you make a DIM-compatible package (like with Content Package Assist)
    The content is smart if there are compatibility relationships established between items, like a figure or prop and material presets or preset poses. With the figure selected in the scene, Smart Content would show you only those products and files that would be compatible with it. Sometimes the net is pretty wide, but you can narrow down the results by drilling down in the categories on the left side.
    If you are sure everything is installed properly, you can re-import the metadata from the Content DB Manager -> Re-Import Metadata... (NOT in Smart Content, that will go and use Connect). Select all products and accept. It could take a while to complete. This action pulls in the metadata from the DIM-installed manifests for the products. Hopefully you won't have to re-download and re-install everything. My own personal concern is leaving it in the Connect folder. That might mess with Studio's head, thinking you should download it when using that folder. The content can be moved to a different folder with little effort (really, just move it) without breaking anything. (Well, almost nothing. There is a path in each product's manifest that says where it was originally installed, but that can be edited to point to the new location with a batch replace using something like notepad++ in 5 minutes).
    You can still have more than one library folder, just remember that Studio scans them in the order they are defined looking for files, taking the first one it finds (in case of multiple versions).
    By
    NorthOf45 NorthOf45 May 2022 in Technical Help (nuts n bolts)
  • Daz Install Manager Crashing
    Good day,
    Whenever I go to install something it will download fine, but then if I try to process it (install it) DIM freezes up.
    I will admit I have a large runtime already, DIM is reporting 8427 items Installed. Is there a product limit?
    I've tried uninstalling it, but can not find where the DIM Temp/User Settings are stored? Can someone point me to those?
    Do you, the collective, suggest a fresh install? If so, what are the current steps for that?
    Oh, I did try DAZ central and it too froze up on me.
    Thanks,
    Tom
    By
    Depa3D Depa3D May 2022 in Technical Help (nuts n bolts)
  • Looking for a straitjacket for G8 or G3
    alainmerigot said:
    https://www.renderosity.com/rr/mod/bcs/straitjacket-for-genesis-8-females/123785
    I have that one and while it's a decent one, the restraints on the arms are a bit dubious with only the single central strap and nothing holding the hands in place.  I think Second Circle's version, also at Rendo, is a lot better in terms of design and comes with matching pants. There's also really nice free one for the Genesis 3 Female by the adult artist Noone102000 on Deviant Art that I won't link to because the main image isn't DAZ safe (though nothing super explicit, just below the waist nudity).  Beyond that, Sixus1 has a couple of older ones for V4 and M4 at both Renderosity and Renderhub that work fairly well if you just hide the arms and torso parts of your figure since they can't be seen anyway, and then... let's just say that Renderotica has quite a selection, though they're not always refered to as straight jackets. blush .
    By
    Cybersox Cybersox May 2022 in The Commons
  • Oh, Misty, I forgot my Complaint Thread
    kyoto kid said:
    ...been unusually colder here in the northwest as well, temperatures between 10° and 14° below normal almost on a daily basis.  There is actually a frost warning tonight for the western valleys where the normal overnight low is supposed to be near 50°.
    Meanwhile, for the the central and eastern portion fo the nation, a record breaking heat wave is expected this week while we here will continue to be stuck in a pool of air more suited to early March than May.
    Keeping fingers crossed... The last time the temperature went below freezing, was last Wednesday. Still only about 10C (50F) in the afternoon, but at least the snow is gone.
    By
    By
    kyoto kid kyoto kid May 2022 in The Commons
  • [vent] The Fairies Mega Bundle => this is AWESOME!
    ...this was one of those rare bundles that caught my eye and I actually considered when it was on sale last month (I have a soft spot for the fey and they figure into my stories), until I noticed the central character is G8.1.
    The G8 to G3 character converter does not work on  G8.1 characters/figures.
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
