• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
Daz 3D Forums > Search
  • My Discovery - of interest to Filament / Cartoon shaders
    Drogo Nazhur said:
    vrba79 said:
    Filatoon is almost as versatile as the old PwToon shader for 3DL was, but it inherits all of the limitations that are native to Filament itself. After using Filatoon for about a year and a half I ended up migrating back to using Sketchy Toon for Iray.
    What is this "Sketchy Toon" of which you speak?
    Sketchy Toon for Iray. Bit of a learning curve, but it can produce nice results. https://www.daz3d.com/sketchy-toon-edge-and-art-style-shaders-for-iray
    By
    vrba79 vrba79 March 13 in The Commons
    By
    Drogo Nazhur Drogo Nazhur March 13 in The Commons
    By
    vrba79 vrba79 March 10 in The Commons
  • Remixing your art with AI
    A few months ago I started using an AI art program with thoughts of using it to make my DAZ renders more cartoonish or comic bookish. I was blown away when I saw how easy it was to get a toon render from my 3D ones. I've tinkered since I was fortunate enough to get a beta copy of the first Poser program and have tried all types of DAZ plug-ins (like pwToon) that took a lot of work and never *quite* gave me what I wanted, as well as using Photoshop plug-ins and actions in conjunction with the pwToon renders.
    Now, AI does what I wanted many, many times faster and delivers so much more.
    I started my current process by spending a few weeks creating a custom ai model style by either feeding it my original artwork or by rendering out samples from DAZ and "tooning" over the renders to make them look closer to what I was after.
    After I had hundreds of custom and personal images I fed them to the AI.
    Once it had digested them all and created my custom style, I had something that I could either feed it prompts and see what it gave me (some wild stuff, some awful, a lot of very neat renders that mostly fit the same style, though sometimes more cartoonish than other times).
    Feeding it an image, like a 3D render, would redraw the 3D render in a 2D style. Cool.
    I then started feeding it props and backgrounds and finally... clothing.
    Where I am now is with the ability to feed it a DAZ character, have it toon it, then have clothing renders fit to it and finally, a character that I can use the same way I would if they were created, morphed and dressed in DAZ but in some cool toon versions and reuse in 2D without DAZ Studio.
    Here's some samples.
    First, the original Girl, converted using my Toon style, a male version of Uzilite's New Adventure (with the top tinted green), a retro blaster prop and a render of the character in action.
    By
    wsterdan wsterdan March 2 in Art Studio
  • Where did the cutie pie cyber goth mask and hair go?
    EightiesIsEnough said:
    I suspect that the products you are wondering about are likely gone due to the demise of the 3Delight render engine as of today.  I also noticed yesterday that pwToon is also gone from the Shop, and pwToon required 3Delight.
    Removing shaders that will no longer work may well be down to the removal of 3Delight but I doubt other products will be pulled, at least not preemptively.
    I suspect that the users who had products in the Shop that were designed for 3Delight have removed their products, as they knew the end was coming.
    That said, I expect that more products will be or are removed from the Shop or other sites selling 3D items.
    By
    Richard Haseltine Richard Haseltine December 2025 in Product Suggestions
    By
    EightiesIsEnough EightiesIsEnough December 2025 in Product Suggestions
  • Announcement about phasing out 3Delight - do we lose our 3Delight products?
    Havos said:
    Silent Winter said:
    Masterstroke said:
    There are 3delight to Iray converters here in the store.
    But will they be compatible with the new Studio version? Will we still see 3DL-era products load in with the 3DL shaders in the surfaces tab to then be converted?
    If so, then all's well at my end. As much as I'll miss 3DL for PWToon, the FilaToon shader does all but one thing for that now. Beyond that, I haven't used 3DL in years (but have used one of those converters you mention - https://www.daz3d.com/rssy-3delight-to-iray-converter which works great).
    All older products that only have 3DL shaders will load up with the Daz Studio Default shader exactly as they do now, and will work with the Iray renderer exactly the same as they do now (the renderer auto maps all Daz Studio Default shaders to Iray Uber) . The shaders will still exist, only the renderer is going away. https://www.daz3d.com/rssy-3delight-to-iray-converter ;should work the same way as it does now.
    Groovy :)
    By
    Silent Winter Silent Winter December 2025 in The Commons
    By
    Havos Havos December 2025 in The Commons
    By
  • Asha 9
    Censored said:
     I'm always oddly surprised when people recognise our work, I even went back to see if our name could be found anywhere, but then again, our info slides aren't the most original aha!
    The shape I sadly can not take credit for as before it's the texturing that I do, but I'm glad you seem to like it!
    I don't like your textures, I love them.
    For decades (literally) I've used many different methods to get a comic/toon look and feel in DAZ Studio that I never quite got, though often close with things like PWToon and a gazillion Photoshop plug-ins and actions.
    When Filatoon was finally available for Mac users and the Willow 9 sci fi stuff came out, it re-ignited my interest in using DAZ Studio again (I'd paused my 3D used to pursue 2D avenues like Cartoon Animator and Moho).
    Your Toon textures for Lucas 9 and Mira 9 (and now Asha 9) are my current go-tos.
    The only problem with them is that there's not enough of them. I really want to buy more, so if you're not too busy, please make a bunch of them. laugh
    Here's the three Censored texture sets that I'm using for my next animation (the Mira 9 and Asha 9 are both used on the three females to give a little shading variety):
    By
    wsterdan wsterdan August 2025 in The Commons
  • New purchases going MIA
    memcneil70 said:
    Also knowing what the item is, would help to determine what version of a program is needed to be ticked in DIM for download.
    I bought a pair of V4 highheels and found out I needed to have a very old version of DAZ Studio ticked so they would be recognized. I was so new I didn't understand there were 'Legacy' products that would not show up for Daz Studio 4.5 if that was all that was ticked. (And now I get ALL the Legacy products available for the earlier generations. I just don't install them.)
    Where does this Legacy content install? Is Legacy the same as DAZ Studio 3? It's not is it, as for example, I have pwToon for DAZ Studio 3 but I don't have DAZ Studio 3 installed, I have DAZ Studio 4 installed along with pwToon for DAZ Studio 4 installed.
    OK, nevermind, it turns out except for one solitary updatte to an old product all the legacy product content was installed in newer version. I did check all the application checkmarks, even 32-bit, in DIM now though. And I did download all of it, but instead of installing it, I just hid it in the Ready to Install Tab.
    By
    nonesuch00 nonesuch00 August 2025 in Technical Help (nuts n bolts)
  • Need some help with pwtoon and lighting
    Hi all! Using Daz Studio 4.22. As you can see from the screengrab, the lighting I've got in my scene is very minimal and is concentrated on one specific point. This isn't my final lighting but I'm just using it to demonstrate how little lighting is in the scene yet the output render shows a fairly even lit scene. I'm currently using the pwtoon shader preset on my scene but right now, the lighting is providing this default lighting across the whole scene when it shouldn't be lighting anything other than this one tiny section. I am rendering in 3Delight as I'm not aware of being able to render pwtoon outside of 3Delight, I have "Auto Headlamp" turned to "Never", I have set my Environment Mode in "Environment options" to "Scene Only" but still nothing. I've even turned down the environment intensity just in case. I also have headlamp mode off in my camera. Does anyone have any ideas here? Thank you in advance for any help you may be able to provide!
    r/Daz3D - Desperately need help with pwtoon lighting
    r/Daz3D - Desperately need help with pwtoon lightingr/Daz3D - Desperately need help with pwtoon lightingr/Daz3D - Desperately need help with pwtoon lightingr/Daz3D - Desperately need help with pwtoon lighting
    By
    nathan_1a2fc3c3d6 nathan_1a2fc3c3d6 August 2025 in Daz Studio Discussion
  • Need help with Oso Toon Shaders
    I am trying to render a toon image using the original Oso Toon Shaders (not the FilaToon variety), but after applying the shaders, when I try to render the image as an iRay render, it comes out as a 3D version.
    I added such shaders to a Genesis 3 figure that previously had a pwToon shader treatment.  What do I have to do in order to render as a 2D toon image and not as a 3D render?
    By
    EightiesIsEnough EightiesIsEnough July 2025 in Daz Studio Discussion
  • Toon Eye Problem
    Yes, Macs do not get Filament in DS 4.
    The toon characters are set up for Filament, so they won't work immediately in Iray and even with tweaking won't look as intended. If you want toons you could also look at using pwToon in 3Delight - though you would have to do all the material set up yourself, and probably not use the special toon eyes.
    By
    Richard Haseltine Richard Haseltine July 2025 in Technical Help (nuts n bolts)
  • Easy FilaToon [Commercial]
    wsterdan said:
    vrba79 said:
    I too noticed how the presets for this look a LOT like PWtoon presets, and that is a VERY good thing.
    Since Mac users only got Filament and Filatoon this week, I wasn't watching the thread "Anime Toons and Filatoon Shader Q&A". I'm reading through it now and see that you were posting about the benefits over pwToon since last year, I'm sorry if I've been preachign to the choir. Thanks for being a good sport and just nodding quietly while I gushed non-stop, much appreciated.
    Mac users are finally able to enjoy Filatoon? Welcome to the party!
    By
    vrba79 vrba79 April 2025 in The Commons
    By
    wsterdan wsterdan April 2025 in The Commons
    By
    vrba79 said:
    3Diva said:
    noshobawolf_f994bf986d said:
    Ok. Let me say not any specific complaints about the product. What I am talking about is being able to do something with it. That is not a product problem. Sorry if what I said came across wrong.
    Oh! That's a relief! lol :) I am not sure what is meant by "do something with it" - something specific that someone was trying to do? Or just not able to do anything with it? I would love to see what face book page and post you guys are talking about. I don't normally use face book so a link would be appreciated.
    As for doing American comic book style, I think that's achievable.
    Here are a few different styles that I think could work with a comic.
    I think if people play around with the different presets, they can find a large variety of different styles can be made. :)
    Wow! This really is just like PWToon!
    I was a huge fan of pwToon and rendered hundreds, if not thousands of images with it, but this is easly 10x better. Imagine having all of or more than the control of pwToon, but it's instantaneous. No minutes- or hours-long renders, it's in the viewport, all the time. Huge posters in seconds, a minute of 1080p animation finished in an hour.
    I'd been hoping to have something this to use in my retirment, and now... it's here.
     It's been a great week for me for DAZ Studio, and Easy Filatoon has sped things up immensely. It's paid for itself the first day or two.
    By
  • Have you guys had any success creating 2D style images from your Daz Studio renders?
    wsterdan said:
    Diaspora said:
    I think filatoon might be the better approach for the time being. 3Diva, I'll buy your product soon because it sounds spot on for what I need.
    I picked it up when it came out and now that I can render Filatoon on the Mac, I actually used it today! It worked perfectly. I've been trying to get a nice. consistent  2D look out of DAZ for decades, and while pwToon came close, it was too slow and tended to give me varying qualities (I found I had to have different settings if a character was closer to or further away from the camera, etc.). Easy Filatoon gave me better results toon-wise in the first hour I used it than I got out of pwToon after months of usage.
    I'm still experimenting, but this is what I got pretty much on my first try; here's my first two attempts at a 2D-style animation using her product on the character, clothing and starship bridge.
    NOTE: the forward-facing animation used a lip sync pose I made years ago with DAZ's 32-bit lip sync, the second one is my very first attempt at hand-keying the lip sync, head movements and eye blinks. Man, soooo much practice is needed!
    https://sterdan.com/wp-content/uploads/2025/04/Captain-Corbett-Opening.mp4
    https://sterdan.com/wp-content/uploads/2025/04/Capt-Knight-Not-to-me.mp4
    very tidy
    By
    WendyLuvsCatz WendyLuvsCatz April 2025 in The Commons
    By
Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
