Adding to Cart…
Interesting looking product!
It was just a thought...
Yeh. I was worried about the render time if they were volumetric. And it's interesting and exciting to see him branch out from architecture.
Looks great... except some of the promo pics do look a bit too grainy making them look unrealistic to me. Perhaps they don't render as some of of the promo pics? Still I did add it to wishlist.
I've been experimenting with exporting Softimage particles (tiny, tiny, pyramids - hundreds of thousands of them) as objs and importing into Daz Studio for things like mist. They render really quickly in iray once they're in memory.
how about animateable clouds ?
Jimbow: Interesting... I've enjoyed using particles/blobs in Iray, like Magic of Serpio and Liquid pack. Making them into foggy or liquid shapes is fun.
Does it help to use Instances? It seems to me that manipulating large numbers of instances might help, but I don't know what limitations the instancing system has.
@Will: All I'm doing is exporting a reference object from DS to get the space in Softimage right, then creating my particles in the latter using the ICE system, then exporting the particles as a single mesh of tiny little pyramids. If the particles are generalised enough (dust in a room, for instance) then there's no reason why they can't be instanced and rotated, etc. I'm using them for my next render of Saga, which has dust motes, a bit of ground mist, and smoke coming off a candle. Certainly in Mental Ray it became a kind of standard practise, for some at least, to just light particles for atmospheric effects rather than struggle with raymarching and procedural volumetrics, etc. All I'm doing is taking the particles from one 3D prog to another via the obj format and doing the same with Mental Ray's sister renderer.
For my experience, these actually work surprisingly well. I think we might be a ways off volumetric clouds (at least, realistic looking ones), so this is a really cool compromise. And they look really great even when the camera is fairly close. I'm working on a piece which uses them, but it killed my PC last time I tried to render it, so I'm changing a few things first.
When they came out and I saw these in the store and I texted my hubby ::squee!!!:: Now I am waiting to be able to purchase them, hopefully this weekend, so I can go ::SQUEE!!!!!!!!!!:: (and of course, find the time to play with them)
I was driving into work earlier in the week looking at the clouds in the sky, triggering the thought that outdoor scenes in IRAY would really benefit from being able to place clouds in them (rather than relying on a full blown HDRI or something similar). Then these show up a couple of days later. Instant purchase. Well, not instant, but I picked them up today (and got 75% off Olympia 7 HD as a result). Looking forward to trying these out. Any plans for cirrus type clouds?
This was an immediate buy! This will be an eminently useful product. Thanks Stonemason!!!!
I'm wondering if I can generate new cloud images with Carrara or Bryce or something and add variety, but I have to buy the thing and see how it's laid out first.
(I did something similar with Iray Worlds and skydomes)
Just playing 2 QUICKIES. I like the brightness and trans contols to. Great product.
Must admit, I was somewhat sceptical and hesitant to pick this up. I have Vue Infinite and I am pretty experienced with it, so I do have acces to volumetric clouds. However, curiosity won and I am am now offically impressed. A very good and highly recommended asset for anyone using Iray (or Octane, they work in there too!). Easy to use and adjust. Renders pretty fast. Here is a quick example result from my initial experiments: "Mech in the Mist"
Ciao
TD
Nice!
Yeah, more and more I'm seeing the best way to do clouds is in post.
Jimbow, I would be curious to see your experiments with this if you felt up to starting a new thread in the commons about it and adding some renders.
No...the best way to do clouds...
http://www.openvdb.org/about/
And yes, 3Delight has it. Just getting access to it through Studio is not going to be easy...
i would like to have a morphable object for clouds - impossible ?
I'm not sure exactly how this product is laid out, but could you possibly use deformers on it?
Why do things like this show up right when I get laid off? Ah well, wishlisted for better days. Best looking clouds I've seen.
These are really great except when used very close to the camera, since the perspective means the angle at the edges will reveal they are billboards. You do have to orient them towards the camera though. The one disapoint for me is that "Point To..." e.,g. Camera 1 does not appear to work, which would be extremely handy for billboards. Still, a lot can be done with these. As a side note, Dreamlight has a tutorial covering billboards/2.5D. Also, pretty much every computer/video game out there with 3D graphics makes use of 2.5D elements.
Edit1: If you parent the clouds to a Null, you can set the Null to -90 XRotate and then Group it, then point the group to the camera. Then you just have to adjust the YRotation. There's probably a away to avoid that too (maybe place the Null in the center of the clouds?) but having to adjust just one axis is pretty handy.
Edit2: I have not tried it yet, but for closeups it may not be too hard to Photoshop the obvious billboard edges in closeups.
What I usually do when orienting stuff is switch to XYZ translate tool, and then use rotation in the parameters. That way, when you see the one arrow becomes just a dot, it's pointed right at you.
How can I bring the cloud to zero or the ground please ?
I want a mist effect but they are way up in the sky.
Thanks !
Select the cloud, use the move tool? At least that's what I did for the image I posted above.
TD
I tried that, but it's so far up that I can no longer tell or see where the ground plain is.
Tired that but the cloud went up.
I think it might just be the cloud I was using. scCumulus14 is miles away.
But the earlier clouds are much closer and I was able to move them into my scene with ease as they are quite nearby.
Select the cloud and in parameters set Y translation to 0?
Y is already 0 - that's the problem. This is why I was wondering how to move it to the world origin or the centre of the grid.
