First time animating
Mynyori
I found this video on youtube for creating a simple rotating animation. I have mine set up the same way with my own character. The problem is, this video was done back in 3.1 version. And I have a few shaders that only work in IRAY. Most, if not all the videos I have found only show end results. So I would like to know how/where I can set up the video to render in IRAY settings. Or at the very least, a link to a youtube video that shows the process of creating an IRAY animation in the latest version of DAZ so I can follow step by step.
I dont use iRay, but I think you just change the Render Setting to iRAY, and from Still Image to Make Movie (or whatever its called, I dont have it open) and specify the frames.
This should be accurate (even though old) but you would choose iRAY as the renderer and not 3delight: https://www.youtube.com/watch?v=PRz5dQ5oriQ
Thanks. I'll try that.
you can do all this with iray the same way
its an animation technique that has nothing to do with the renderer
try it in opengl then it goes a lot faster
