Only slightly tongue-in-cheek
A version of 4.9 without the Daz Connect.
4.9 works fine without using Connect.
Mine doesn't! Content tab all out of alphabetical order is bad enough without the rest!
Not arguing about that.
I suspect that DAZ simply built a lot of what became DAZ Connect on top of the old DAZ Store pane that has been in Studio since at least the 2.x days, so it's not likely that they will take the whole thing out just because some folks won't use it, nor will they be convinced to back port the newer stuff related to Iray and 3Delight to the depreciated 4.8 codebase.
Wendy, that's extremely odd, and probably going to be hard to recreate to fix. Not going to say they couldn't fix that, but it's not going to be easy to do.
