Question? How do you save a rigged prop in Carrara 8
in New Users
What I mean is I have a rigged prop with a bone system in it that works fine in Carrara and it wont work in Daz. Is there any way to save it and use it in Daz 4.8?
HI :)
Depending on the format you're using to export from carrara,. the rigging can be lost,. and I believe the bone and weighting is different in Studio
You can re-rig the model in Daz Studio depending on the model, you can use the transfer utility in Daz Studio to add the rigging from a figure,.
for example a dress for genesis 2 made in Carrara
When you add bones to a model,. that's generally called a Figure,. ..Prop's don't have bones.
You could also just load your figures into Carrara, and use the model. ...much simpler
Hope it helps
