DAZ Studio 4.9 Pro, General Release, Now Available!
1101113151620
  • DazStudio 4.9 is very slow to load products in the 'SmartPane'. I take at least 10-seconds to load the products from the library. Returning to a product category incurs the same wait every time!
    Clicking on 'Available', 'Pending' etc just shows products that I have not yet downloaded or installed from within the Install Manager. It does not connect to available products in the Daz3D shop. I thought 'Connect' allowed you to do that directly, as you can in 'Vue' for example.
    Whilst logged in using DazStudio, I have to login again when I access Daz3D from within DazStudio - what is the point of logging in whilst in DazStudio? (other than for just seeing what products I have waiting in the Install Manager).
    I don't see that iRay renders are noticeably any faster.
    DazStudio 4.9 does not appear to offer any advantage over version 4.8. Is there a problem?
  • DaWaterRatDaWaterRat Posts: 2,885
    icecrmn said:
    icecrmn said:
    Okay, re-importing Metadata (again) seems to have solved it.
    But
    I'm also going to log back in through DS and see if that messes things up.  I know it shouldn't, but considering that the first time I logged in, the only things after metadata updates that was grayed out were Genesis 3 Essentials and the Genesis 3 Female Ranger outfit, and then the second time I logged in and it did a metadata update, a lot more products were grayed out, I'm curious to see what a new log in (and potential metadata update) will do.  I'm not hopeful for it to work as intended.
    YaY  :)  , glad it worked,now lets hope it stays that way.
    Well, it ran a metadata update.  Did it work as intended?
    Yes and no.The products I previously discovered an issue with?  DS 4.9 still thinks those are installed.
    But others?  Now Grayed out in products as uninstalled and not showing in categories. - Edit to add - though it's not consistant, because at least one product is grayed out as uninstalled, but still showing up okay.
    Still, this does not encorage me to log in to Daz Connect.
    Your login status doesn't really have anything to do with your custom categories.
    Have you filed your help ticket yet?
    Maybe your problem is similar to someone else and they can get you sorted out a bit more quickly.
    The login status might actually have something to do with it, depending on how the custom categories were created. If they are created by adding it to the "vendor data" then loging in will cause a metadata update and it will remove any vendor data that does not agree with the store.  If it is saved as user data then nothing goes away when the store updates the metadata to "fix it."
    As far as the database is concerned, vendor data is controlled by the store, user data is controlled by the customer.
    Didn't create with Vendor data, at least I don't think I did.  It's been a while since I created categories in the Database Editor (about the time I realized they changed my User Categories to Non-User Categories - which I guess is the Vendor Data) and I've wiped my custom categories at least twice since then (I keep ending up not happy with how I have them organized about 1/3 of the way through)
    It appears to be down to just some products, since Mariah's Leatherize seems to be working fine, and that's "not installed" according to Daz Connect.  My installed version of 3DC Lola is in Lost and Found according to her categories (though she doesn't show up there either), so I'm thinking it may be limited to "broken" products
    I can take a bunch more screen shots and submit a ticket, if you think it will help.  (Be warned, my patience is thin with Tech Support not actually reading my complaint - which has happened more than once here at DAZ)
    If you do, make sure you mention that it is a ticket I asked for, concerning the database issues. :)
    Submitted.  Request #210645
    Hopefully it is of some use.  :)
  • DAZ_SpookyDAZ_Spooky Posts: 3,100
    RAMWolff said:
    OK... ticket submitted....
    Thanks
    icecrmn said:
    But
    Thanks
    Merged into main release thread.
    The Smart Content pane shows only your own products, outside the Shop tab. It will not show store items you have not purchased.
    I'm not sure what you mean by "Whilst logged in using DazStudio, I have to login again when I access Daz3D from within DazStudio " - should oen of those be a reference to Install Manager or to the website? You would want to log in inside DS so you could download content using Connect - or check for updates, downloading only the updated files instead of the whole product. Logging in from DS will also get you updated metadata, again without having to redownload everything. Not everyone will see advantages in these, but theya re features of use to some.
    Iray performance seems to vary - but no, it doesn't seem to eb a dramatic improvement for humans. However, there are bug fixes affecting the rendering of humans (an SSS fix) and models in gernal (a crash with CPU rendering on some models).
  • barbultbarbult Posts: 26,444
    mark128 said:
    icecrmn said:
    But
    How do you create custom categories that are added to the vendor data?  Is there a way to do that in DAZ Studio?
    I have a lot of custom categories I've created using the Categorize commands in the Content Library. When I export the user data it now writes 3 files for all the data, so I don't think any of that is in the vendor data.
    There is a way to do it in DS 4.8 and earlier. It was never intended as a customer tool, but apparently it has been used that way. Your way should produce user data, and that should correctly migrate.
    Are you referring to opening an existing Daz product's metadata files with the DB Editor to make fixes and then exporting the fixed Daz product metadata file? I've been doing that for a long time.
    What can we do now to fix bad metadata? For example, since installing 4.9, I've discovered that the Daz Connect metadata for Scott Hair is really bad (DIM metadata is OK). I've submitted a help request, but of course it is too soon to expect a fix yet. I want to use it with Smart Content. How can I fix it myself and get back to work? (I'm not talking about creating custom categories. I'm referring to fixing products with assets that have no Type, incorrect compatibility, assets missing from the product metadata file, Base Compatibility not defined...).
  • linvanchenelinvanchene Posts: 1,386
    edited January 2016
    solved.
    Was able to find the head, body, expression products by manually scrolling trough the Available subtab with filter set to:
    "Sort by Order Date: Recent First"
    - edit: deleted obsolete image.
    Post edited by linvanchene on
  • fixmypcmikefixmypcmike Posts: 19,707
    Those products have no user-facing files -- my guess is that the Da Librarian needs to add at least one user-facing file so that they will show up.
  • VoltisArt said:
    Murgatroyd said:
    Upgraded with no particular problems. The one thing I particularly want right now is a way to get rid of that bright green "Login" button that I will never click.
    Actually an easy one.  Can't remove it, but you can make it more polite.
    Window menu > Style > Customize Style...
    Select All or 2. Accents on left, then see 11. Special Interest Color on right – that mint teal beast.  Change it to a medium grey, click Accept (feel free to change other colors!) and the button blends into the interface without screaming at your eyes.
    Thanks. It's now the same grey as the background, and much less obnoxious.
    Unchecked the box, "filter by context."
  • ProPoseProPose Posts: 547
    edited January 2016
    Not quite sure what this tab >Advanced>Cloud(BETA) does.  Is there any documentation on this feature?
    Sorry, found my answer in another thread.
    510 x 600 - 37K
    Post edited by ProPose on
    edited January 2016
    I need answer as DAZ official..
    1.  I can see many preset or subset , which grouped as "LOCAL USER" product.
    I understand, it seems generated from imported "user_data" and if the files are not grouped as "product"
    these files seems to be gathered as "LOCAL USER" to see them in smart content.
    But It is just my suspect,  then please clear When "LOCAL USER" product was generated,
    and How we manage it as official answer.
    and  when user categorize, or assgined meta-data compatibility by themselfs, all files will be grouped as "LOCAL USER"?
    there is exceptional case, or not.  if there is exceptional case,  what is.
    2  IF  User try to make "product"  (eg "myproduct1" ) from files gathered as One "LOCAL USER" product,   these files assgined as "myproduct" will be removed from "LOCAS USER"?
    if it can not work,  we must see duplicate items in smart content, when we make new product. from them.
    Or it is not intended, I still keep problem to migrate DB correctly because of MY handmade product data, and User data
    which I have made in other version DAZ studio,  conflict in ds 4.9 DB?
    if so, what is the correct way, to keep clean database,  when user hope to make product meta-data  for assets offered from other shop,
    or user made assets?
    1120 x 804 - 317K
    Post edited by kitakoredaz on
    IF daz do not offer stable way to make "product" meta-data as we  like,,when we hope so,
     Smart content never can be  smart serching tool for most of  user.  or may be useful only for DAZ shop items (with DAZ proud Librarian meta-data)
    Such serching tool is not smart at all.  I do not request DAZ please auto-genearte product from items which I get from other shop,
    and items which I hand made.   but There should be Clear document as official, to make product about these files, safety.
    then use them with "user_data" (not categorized as product, or categorized as "LOCAS USER" product without confliction.
    edited January 2016
    Update / Edit:
    I ended up finding all the missing "morph only" files with DAZ Connect with "filter by context" off.
    A remaining issue nevertheless seems that those morph files may not show up when entering search words because they do not have dummy files with "tags" or "keywords".
    I get what you mean.
    Victoria 7 HD does show up when G3F is selected because there is an actor figure included that was set to be compatible with G3F.
    Without dummy file products may not show up in standard searches.
    Also with "filter by context" deactivated "morph only products" do not show up in searches.
    Why does that happen? At least the name of a product should show up in the search?
    Maybe the product name needs to be manually added as "tag" so the librarian can save that reference in its database?
    Searching for Genesis 3 Female Head Morphs gives me 2073 results:
    Searching for "Genesis 3 Female Head Morphs"  gives me 3 results:
    No clue why the Genesis Generation 1 Orcs show up in that selection...
    But the search term is exactly as the Product name so why does the product not show up in the subtab All with Filter by context off?
    Searching for expression gives me 72 Results
    What worked for me to spot the files was to set
    Order Date: Recent first and then scrolling down until  they showed up.
    Now I will try to do the same thing for Genesis 2 morphs.
    Actually what worked better in this case was to
    Sort by Name: A-Z and then I found all those products that started with Genesis in the Name...
    Seems all those morph products are there. I just had trouble finding them because they did not show up in searches because tags seem missing.
    I leave those search examples. Maybe someone else learns from my mistakes and then finds those products more quickly...
    Is there any way allready to search by entering an SKU number?
    Or to filter the search result to only show orders of a certain time period?
    683K
    355K
    641K
    584K
    586K
    I want to check on something, cos I'm a bit confused with all the terminology that is around.
    With 4.9, are we now basically relying on the Smart Content tab ONLY when browsing or looking for something? Doing it via the Content Library won't be sufficient any longer?
    With CONNECT ONLY products, will they ONLY show in the Smart Content tab (or the Products or Category lists)? They won't show at all in the Content Library?
    edited January 2016
    @jakiblue
    I do not think we can relying on the smart content tab only to looking for something even though you serch only daz shop items.
    eg I have several items which installed by DIM with empty product meta_data.  but these are not shown in smart content as files.
    it will be shown in smart content>product , when you log in , but it is only empty product. then we can not serch items,
    even though I have already installed it , and can find each items in content library with path.
    they may appear only when I install DAZ connect package , as actuall files we can access from smart content. (but without category,
    because there are many product which have not offered real meta-data, but only product name, to be shown in smart content.
    2  if the item have real meta data , then you installed the product already ,  these items must be shown in Content Library too.
    in ContentLibrary>product, and ContentLibrary>Category,  there is no difference, between ds 4.8 and ds 4.9,
    about Connect only product, there should be no difference.  because  smart content and content library
    see same database record.  and field.
    My admittedly limited testing says yes.  Anything you download through Daz Connect will only appear on the Smart Content tab (and maybe Categories in the Content Library - but I have not tested this)
    However, you can create folders in your Content Library and then Drag and Drop from the Smart Content tab into those folders.  This does not move the files, but it does create shortcuts (that may or may not need to be recreated whenever the product updates - that is also unclear at the moment) in your Content library that work the same way.
    They will show up in Products and Categories, but not in DS-Formats/Poser-Formats, although you can drag them there to create a link to the item which can be organized at the file-system level.
    edited January 2016
    Products installed with Daz Connect (e.g. Lynsey for Genesis 3 Female(s)) show up in the Content Library Products section and Categories section. They will not show up under the Daz Studio Formats section unless you create folders and shortcuts for the files there yourself, which I have not tried.
    Post edited by barbult on
    So that means,  we can not use simple file system serching for product installed by DAZ connect anymore.
    without manually making them as fake.
    (I can not believe it is useful, we need to make real  folda structure ,for reference (short cut) only for serch items .
    or yours often make short cut with real structure not only for desktop?
    You certainly can search for them using your file system, that has nothing to do with what shows up in Content Library > X-Formats
    Now I have one product which installed by DIM, but planed to test with daz connect package  to see how it work more clear.
    I arealdy log in daz connect, then there is already meta-data by DAZ connect  of the prodcut.
    1. I uninstall the product by DIM clean. (it is installed by DIM not daz connect),  I remove orphan data from daz studio.
    2. I serch the product to install it  by DAZ connect with log in.
    3  DAZ studio do not show me the product which I have bought anymore.
    maybe I need to delete manually DAZ connect installed meta-data from "DAZconnectdirectory"/cloud/meta/1_XXXX.json ?
    Now I believe User who hope to use product offered by DIM with DAZ connect Content, must get many funny problem about ds 4.9.
    without any clear guide.
    Was the product showing in DS for install before you uninstalled it with DIM?  What product?
    that means it work without problem for Mike?   I test with Cateye suit for genesis3female.
    after uninstall it by DIM, daz connect or smart content, not show me the product which can be install by DAZ connect.
    actually it disappeared.  (I mean product icon to install it by DAZ connect, as daz connect package
    of course it return, when I re-install same product by DIM again. but I can not find to install DAZ connect package of the product.
    (I do not test to delete daz connect meta-data. json )
    I uninstaleld it by DIM to try again, or maybe reset DB once more.
    after all I understand I need to  reset DB manytimes untill DAZ reply all clear.(as for me,   make original product mata-data with
    user_data (not grouped as product) about all items)
    edited January 2016
    And if you find wrong step of me, or it is not designed so , tell me please Mike.
    1. I uninstall product, by DIM.
    2. I lunch DAZ studio. and log in daz connect
    3  it still keep icon of product "Cateye suit for genesis3female" but it is empty.
    (I check it from smart content>show in content library)
    4   I can not find way to install the product by DAZ connect.
    5 I feel, I need to delete the orhpan product once. then delete the product from content library.
    6  yes it delete, then I never see the product anymore with daz studio only. (keep log in)
    in conetntlibrary>product
    7 but the icon of Catarena suit of product still in smart content with empty.
    I reflesh again.
    8 I double click it anyway.  but it just show product pag.
    9 is there any hidden magic door to order daz stuido, "hey install this suit " by daz connect?
    10 or I may forgot this product, just believe DAZ connect should find it when I need?
    11 or maybe better my DB seems perfectly corrupt for my fault, then reset DB again,
    without any original product_data,,
    12 or I may better forget DAZ stuido , then concentrate on blender and 3d coat to make more cute item. without
    daz content?   yes,, I often feel so.
    13 or maybe I may better to finish my work ,,without cheking here,,no time to play with this funny aprication
    just for load or install contents correctly.
    826 x 342 - 32K
    1117 x 879 - 187K
    1095 x 734 - 175K
    And I forget to reply your answer mike.
    yes you are always (almost) right .
    I certainly can search for them using my file system, that has nothing to do with what shows up in Content Library > X-Formats
    then what you were talking about ?   it was about daz stuido,and way to find content in content library to load items. I
    then we could  load items by file path in content library about all. (with some exception)
    or you have used file system, eg exloler of your windows,,(not content library) to load items in daz stuido?
    edited January 2016
    OK I found what is wrong, I serched Cateye suit by A to Z in all and availabe section. with input "C" or "Ca" only in serch window.
    it seems not work for the purpose. (though most of aprication serch system work, but daz studio is real gerat unique aprication, then
    it shoud be my fault angel (or may need install product once by DAZ connect? or the meta-data is corrupt,, I do not know, simply it is un-useful for my purpose,, boooooooooooooooooooo,,)
    And "ALL" show  product, firslt,,, already installed,,by A to Z order , then next show items "available" A to Z order.
    I needed to expect so,, most of user may expect so.  it is my fault,,
    I must needed to  serch items in available seciton without input anything,,
    Now I found solution, to install items by DAZ connect, which removed by DIM. thank you !!
    583 x 503 - 86K
    652 x 829 - 423K
    650 x 830 - 278K
    I have been asking and asking about the product search. I can't get an answer about how to search by product name. Even customer service cannot seem to understand what I am asking. It seems like a very simple question to me. I want to enter part of a product name and see a list of products that have that string in the name. It does not work that way. How do I search by product name?
    edited January 2016
    Hi burbuit,, I  reply more seriously ^^; (now I keep joking mode,,to clear complain ds 4.9 usability)
    the reason may be how discribed in meta-data as tagged key word or something   I feel.
    linvanchen seems state  it already, I feel.  (I can not see all topic,, to solve myown problem,,,one by one,,)
     But  I have not checked the meta-data which offered by DAZ connect,
    maybe the serch system need to use the keyword in the meta-data I feel..
    but I do not know, maybe mike or someone give you right answer.
     it can order item by A to Z by product name. But when I imput the product name, it can not serch the product ,  real unique!!
    maybe it is my fault ,....... angel
    I play with new meta-data and tag,, then find if I check keywrods in smart content pane,
    about each files,, then add new tag "c"  it can find the files with "c"
    there are already some tag about this file, eg "Cateye" , then if I input these words it can work.
    but actually I can only see these key words after I found the file.. (why I need,,after found it?)
    and it is real unique,, Cateye work, but jusi imput Ca not work.. after I add new keywords "c"
    when I input c, it work.. but ca still not work.. and when I change pane,, as category,,
    there seems no tag,, which user can easy find,, (I check meta-data,, but each keywords seems
    assigned with each file,, not product,,,, maybe,, if I tag keyword about one file,,the product can be shown
    with the keywords?    yes it worked!  DAZ studio is real Unique!!!
    then may be ,, we need all keywords "c" "ca" "cat" etc,,,
    671 x 797 - 72K
    671 x 797 - 82K
    622 x 829 - 94K
    642 x 809 - 73K
    I'm in the proccess of shutting down for the night so I can't check, but if you go to the Smart content tab, and then to the Products view, I think you should be able to search products that way.
