How to move feet around in Shoes G2, G3
anthony.luigi_05ebfcd7e7
Is there a way to move a characters foot around, in or out of a shoe after its been loaded to the figure? For instance after loading a pair of shoes I would like to be able to move one of the feet legs out so it appears the character is pulling out of one of them.
If I choose fit to none the pair of shoes moves far away from the character and are useless.
Thanks in Advance!
Post edited by anthony.luigi_05ebfcd7e7 on
If the shoes load individually, load the shoe you want to 'remove' and manually position it...don't fit to the character, then once in position, parent it to the character.
For shoes that load as a pair, you need to load two sets...and hid the opposing shoes (for the right foot, hid the left shoe). And basically do the same as above.
It's also easier to do this before you move the character around the scene, at the default zero load position (as that's where most shoes will load if not fitted).
Thanks for your help!
