Object Scaling
Hello,
A wall in a preset scene only has a "Y" locator parameter assigned to it. is it possible to assign the existing geometry "X,Y,Z"scaling parameters? thanks
Hello,
Hello,
i took goofy pills today. mental block. i exported the as wavefront then added the materials and saved as prop. sorry
Generally, if the scaling isn't showing it is because the item is parented to something else and will inherit that scaling (most of the time) or the controls were hidden (usually to preserve a relationship with another piece). If it is parented, it can be unparented and then scaled. If the controls are hidden, "show hidden'' in the Parameters tab options will unhide them. Those two will cover most of the reasons the sliders won't show up...
Thanks mjc !!
