DAZ Connect doesn't show addonTextures as avalible
DAZ Connect doesn't show the avalilable produsts I purchased such as Texture add ons to Wardrobe products I purchased are they in a different catorgory or do Ineed to download them manualy for example Troubadour Textures
Did you select "All" in the category? And did you deselect "Filter BY Context" at the bottom? And at last, are you loged in or in Work Offline Modus?
And even if you have all that, currently there is an unusual load on the servers, so if it was a recent purchase it may take some time to show up.
Thank You very much!! that worked
The connect-only, troubadour textures add-on download option showed up when I selected the costume in the veiwscreen, then went to the Product menu. That might be a shortcut if folks are still experiencing this issue.
