Female Head Model for Earring Display
Hi all,
I'm looking for a female head model that I can place earrings on for rendering purposes. I don't know how to use the Daz3D software so I'll be importing the model in either an STL or 3DM format into Rhinoceros and using my own rendering software.
Some of my preferences/requirements:
- model should have hair
- model should be famale
- model should be true-to-scale 1:1
- no color detail is required, model will be rendered with a white plastic look.
Also, if someone could explain how these packages that I found in the Daz3D shop works, that would be great! Thanks!
Post edited by the988 on
I finally got around to actually installing the program. I thought I did at first but it turns out that was only the install manager for the packages. Anyway, Genesis 3 fits the bill and I think I found an extra hair pack that I need to purchase that satisfies all of my requirements. For those interested, I exported using the OBJ format which is compatible with Rhino.
Is it possible to re/move the strand of hair that's infront of the ear in this model?
http://www.daz3d.com/thalia-hair
Edwardian hair might be a good choice to showcase earrings.
http://www.daz3d.com/edwardian-hair-for-genesis-and-genesis-2-females
Thank you, FirstBastion. I ended up getting the Krayon Hair.
http://www.daz3d.com/krayon-hair-for-genesis-3-female-s
I like the way the hair looks behind the ear. I'm about to export the model and run a render test.
