Daz Connect - FAQ
Adding to Cart…
Will this update eliminate the Hexagon, Bryce, GoZ, or Photoshop bridges?
No, the bridges maintain their existing functionality.
Will the DSON Importer for Poser plugin work with products installed using Daz Connect?
The DSON Importer for Poser plugin will not work with Encrypted Daz Connect files; the plugin, in its current form, does not know how to decrypt the files so that it can load them. The plugin can be made to work with files that have been installed using Daz Connect and are not encrypted (provided the product page states that it is compatible with the plugin), though the conviences typically provided by the supplimental PoserCF packages in Daz Install Manager or the Product Library are likely to be missing.
The DSON Importer for Poser plugin will continue to work with products installed through Daz Install Manager (provided the product page states that it is compatible).
Will this update keep zip packages on my computer like Daz Install Manager does?
No. Daz Studio only downloads the portion of products that have changed using Daz Connect, and it only stores that data on your computer. This improves the performance of downloading as well as the local footprint of products.
Is there a reason to upgrade to 4.9 if I do not plan to use Daz Connect?
Yes, Daz Studio 4.9 has a lot more to offer. It includes updates to both native renderers (NVIDIA Iray and 3Delight), as well as many stability fixes, and a greatly enhanced Smart Content workflow.
How do I install Daz Connect products using Offline Packages?
On the computer that the Offline Package(s) will be downloaded to:
On the computer the Offline Package(s) will be installed to:
*Note: The *.sep and *.sea files for a given product will be removed from the ./data/cloud/install directory as that product is installed.
How do I change where Daz Connect products are installed?
You can change the path where Daz Connect products are installed by changing the "Daz Connect Data" path in the Content Directory Manager. The Content Directory Manager can be accessed from the Content Library pane option menu (right-click on the label of the pane or click the option menu icon for the pane group while the pane is forward-most in the stack), or from the Preferences dialog (via Edit > Preferences... > Content Library > Directory Managament).
Note: Changing the "Daz Connect Data" path mentioned above does not move the information already downloaded and/or installed to it. To move previously installed Daz Connect products, move the entire "./data/cloud" directory in the old location to the new desired location before changing the path in the Content Directory Manager dialog.
