Steampunk cybernetics?
Riggswolfe
I've been looking but most searches for steampunk come up with 47 Billion Victorian dresses for Vicky. I'm wondering if anyone knows of any product with something like this:
Post edited by Riggswolfe on
Oskarsson's Time Traveler has a little of this vibe. http://www.daz3d.com/the-timetraveler
The Ant Farm and SickleYield's MAG2 Arm for G2F might also work with some different shaders. https://www.renderosity.com/mod/bcs/?search=gynoid
At Rendo there's SteamBetty, a texture, conformer, and prop set for V4: https://www.renderosity.com/mod/bcs/?ViewProduct=78465
Also at Rendo, Mihrelle's Cyborg Collection for G3F https://www.renderosity.com/mod/bcs/the-cyborg-collection-2-for-g3f-and-v7/113243/ and EdArt3D's Gynoid Series https://www.renderosity.com/mod/bcs/?search=gynoid could supply some useful bits, especially with different shaders applied.
And check out Cybertenko's store, if you haven't already done so. Maybe the M4 Military Exoskeleton https://www.renderosity.com/mod/bcs/military-exoskeleton/113164/ or even the Retrobot https://www.renderosity.com/mod/bcs/retrobot/113297/ could provide parts. Don't miss the M4 Steampunk Implants either! https://www.renderosity.com/mod/bcs/steampunk-implants/78838/ In any case, maybe his aesthetic will give you some ideas.
I hope this helps. If anyone has other ideas for steampunk cybernetics, I'll watch this thread...
--MW
EDIT: Check out Val3dArt's Flying Cadet Lola Pepper too. You could probably get something out of those wonderfully over-the-top boots... https://www.renderosity.com/mod/bcs/flying-cadet-lola-pepper/104210/
Thanks for taking the time to post this, MW - off to check out the products you've mentioned!
- Greg
Thanks Wizard!
I just need to figure out a good way to "merge" parts, IE, attach stuff built for one figure onto a figure from another generation as I generally prefer Genesis 1-3 and a lot of these are for M4 (and V4)
I use the Genesis base, and I created a cyborg character by using parts from Cyborg Version 4 (http://www.daz3d.com/cyborg-version-4). I'm no expert and I'm sure I did things the wrong way, but I started by making a custom Genesis morph. It's been a while, but I remember parenting pieces of the cyborg (got the pieces separated in Hexagon) directly to Genesis nodes (resizing/positioning as necessary) and I think there were some JCMs involved to keep things in place as the character is posed. And there were some pieces that I made into conforming clothing (chest/hip areas).
Anyway, that Steambetty model looks pretty sweet. Depending on exactly what you end up wanting to do, it may be easier to simply "sync" 2 different figures and hide/morph things as appropriate.
- Greg
There's also AntFarm's M4 Steam Pirate here at Daz: http://www.daz3d.com/steam-pirate
--MW
You'll want to explore "rigid nodes".
