Geneva Hair fit and pose problems
Having a problem with the Genea Hair on G2f. When I auto fit the hair to G2f, it looks like the picture attached.  None of the posing presets change this position.  If I apply the hair and conform to none, the hair looks fine and the posing presets work but when I then fit to G2f, it goes back to the sticking straight out position.  What I had to eventually do was after posing and fitting, I parented to the head and all is well. A pain in the ponytail workaround but anything for great hair! Anybody else finding this?
  • vwranglervwrangler Posts: 4,987
    Autofit won't work with Geneva Hair. The autofit process strips out the extra bones in the ponytail itself, and it also reworks the base skeleton rig of the hair so that it matches G2F, who has a very different skeleton than G3F.
    TL;DR: Autofit kills rigged ponytails dead. You'll need to parent to her head to use that with G2F.
  • AeonmoonAeonmoon Posts: 53
    edited January 2016
    Also this works:
    I drag and drop the Geneva hair into an empty scene.
    Then I double click to add my Genesis 2 character into the scene, which fits into the hair. After this the hair morphs work.
    Post edited by Aeonmoon on
  • ALLIEKATBLUEALLIEKATBLUE Posts: 2,983
    ok
