Which export target to use in Quixel for use in Iray?
Lissa_xyzLissa_xyz Posts: 6,116
edited January 2016 in The Commons
I'm thinking the Metalness PBR (Disney), but I want to make sure. There is also an option for Unprocessed PBR, but not quite sure what that one does.
Post edited by Lissa_xyz on
  • Jan19Jan19 Posts: 1,109
    Probably the metalness option that you're thinking of.  :-)  Isn't that the only metalness option available?
    Or...you could choose one of the spec options, but add an albedo for metalness map, along with a plain metalness map to the outputs.  I believe I've done that before.
    Yea, I've been using that metalness option, and then just adding extra maps if I needed them. I wasn't aware you could add new maps other than those pre-created until I saw something in one of their live streams @ Twitch.
