DS 4.8.0.59 can't find my installed content
Hi, as the title says DS 4.8.0.59 can't find my installed content, I uninstalled everything after a complete mess the first time trying to install months back' I re-started the machine and DIM reports that DS is still installed and can't continue, then installs anyway' but no content shows at all.
I then installed PostgreSQL CMS 2016 which should install automatically if the content won't show without it  and at least it now shows that I have some content but when trying to load into a scene, DS can't find the working data files and displays a pop-up window titled 'missing files' with these paths.
/data/DAZ 3D/Genesis 2/Female/Genesis2Female.dsf
and
/data/FWDesign/Shaded Haven/Planters/Planters_1816.dsf
/data/FWDesign/Shaded Haven/InsideIvy/InsideIvy_162783.dsf
/data/FWDesign/Shaded Haven/Pergola/Pergola_33589.dsf
And
/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Base/PHMEyeLidsTopDownL.dsf
/data/SWAM/Toulouse Gen 2/Toulouse Gen 2/Morphs/SWAM/Base/Side out.dsf
/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Base/CTRLrIndexToeBend.dsf
/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Base/PHMEyeLidsBottomDownR.dsf
/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Base/CTRLToesSpreadR.dsf
/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Base/PBMNavel.dsf
/data/Bobbie25/PersianBeauty/Pants/Pants_14263.dsf
/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Base/PHMSmileOpenFullFace.dsf
/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Base/PHMEyeLidsBottomDownL.dsf
/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Base/CTRLEyesUpDown.dsf
/data/SWAM/Toulouse Gen 2/Toulouse Gen 2/Morphs/SWAM/Base/LeftOut.dsf
/data/SWAM/Toulouse Gen 2/Toulouse Gen 2/Morphs/SWAM/Base/Front longer.dsf
/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Base/CTRLrBigToeBend.dsf
/data/SWAM/Toulouse Gen 2/Toulouse Gen 2/Morphs/SWAM/Base/lower Neck longer.dsf
/data/DAZ 3D/Built-in Content/Environment Sphere/environmentSphere_1923.dsf
/data/Bobbie25/PersianBeauty/FullTop/FullTop_42769.dsf
/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Base/CTRLrMidToeBend.dsf
/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Base/PHMEyeLidsTopDownR.dsf
/data/SWAM/Toulouse Gen 2/Toulouse Gen 2/Morphs/SWAM/Base/Neck bend out.dsf
/data/SWAM/Toulouse Gen 2/Toulouse Gen 2/Morphs/SWAM/Base/Volume side.dsf
/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Base/CTRLlHandStraighten.dsf
/data/SWAM/Toulouse Gen 2/Toulouse Gen 2/Genesis 2_35228.dsf
/data/DAZ 3D/Genesis 2/Female/Morphs/DAZ 3D/Base/CTRLEyesSide-Side.dsf
etc... etc....
I've had nothing but problems with installing products and programs for DAZ Studio, I gave up last time and went back to Carrara, good job DAZ supports IRAY otherwise I would kiss this program off.
Sorry to be negative, but what should be a simple task has turned into a complicated mess' I used to blame myself but this is the first time after decades of installing and removing software and products (including freeware and shareware) that I have faced such problems.
Any help is appreciated, I've tried searching the forums and no luck.
Cheers Chris
  • fixmypcmikefixmypcmike Posts: 19,695
    Can you post these 2 screenshots:
    1) In DS, Edit > Preferences > Content Library > Content Directory Manager, expand the "DAZ Studio Formats" and "Poser Formats"
    2) In DIM, on Ready to Install tab check the "Show Details" box in the lower right
  • Can you post these 2 screenshots:
    Hi, I've attached the screenshots, let me know if you need more.
    Cheers and Thanks
    Chris
    1920 x 1200 - 252K
    1920 x 1200 - 155K
    You need to add the path DIM is installing to in both DAZ Studio Formats and Poser Formats in DS (C:/Users/Public/Documents/My DAZ 3D Library).
  • You need to add the path DIM is installing to in both DAZ Studio Formats and Poser Formats in DS (C:/Users/Public/Documents/My DAZ 3D Library).
    That sorted the problem, it was hard to tell with the truncated path.
    Many thanks for your help.
    Chris
  • I had a similar problem, where I ccompletely removed all my 3D Art softward from one computer, because I ran out of space on ther ahd drive and it wasn't fast enough. So, after having my new system working 4 days around the clock downloalding and reinstalling my software and content using a custom install, I found a problem with the content; DS wasn't able to find everything, when building scenes or anything wile using the Smart Content Library tab. I found the problem, when I went and checked the settings for the Library Manager and discovered the DAZ Install Manager didn't set my Public Library folder correctly, so I changed it and restarted the software and everything seems to be well now.
    This is very easy to miss, since D|S and the DIM don't talk to each other. You must check, before you start downloading/installing anything, that DIM is installing your content to the same place that D|S is looking for it.
