Saving clothing adjustments.
After many weeks of trying, I've managed to make a set of V4 high heels fit on my K4 character (every little girl loves to have a pair of mummy's high heels to wear).This took a great deal of time and I had to change so many settings. Anyway, to cut a long story short, for which you will all be grateful, is there any easy way that I can save the settings that I've used so that I can fit the shoes to any other K4 character without having to start from scratch each time?
On the same subject, would this work in other situations? If I had to make a considerable number of changes to any other item of clothing (adding morphs, changing scales and so on), could those settings be saved too?
Thanks in advance.
"Just for yourself", yes, depending upon what type of file it is: export as .cr2 if it's a legacy rigged item, save as figure/prop for D/S files.
.... use a new name for the file of course, not to overwrite the original ;-)
